  3. Can't get RFM69 working
27 Posts 5 Posters 12.1k Views 3 Watching
  • carlierdC
    carlierdC
    carlierd
    @Sweebee said:
    SerialGateway:52: error: no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&, int, int, int)'
    Did you enabled signing feature in MyConfig.h : #define MY_SIGNING_FEATURE ??
    • SweebeeS
      SweebeeS
      Sweebee
      I think the gateway works now, i removed the separate 5-3.3v converter and used the arduino 3.3v.
      Now the sensor, i uploaden your sketch, but i get no init message?
      • carlierdC
        carlierdC
        carlierd
        Did you connect the gateway to a controller ? or to MYSController ? You get the gateway ready message ?
        For the sensor, you are using the sketch I upload ?
        Debug mode is enable in MyConfig.h ?
        You should have some debug messages in the console when connecting to the node.
        David.
        • SweebeeS
          SweebeeS
          Sweebee
          wrote on last edited by Sweebee
          The problem is on the uno everything seems to work fine.
          for the sensor i attached the RFM to a arduino pro mini 3.3v
          double checked the wiring, tried 2 different RFM's, tried 2 arduino pro mini's.
          uploaden the gateway to it and i get:
          but when i try to send something with the pro mini i get nothing back, while on the UNO I get:
          0;0;3;0;9;send: 0-0-10-10 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
          So on the pro mini i get the init message, but no message when i try to send something.
          • carlierdC
            carlierdC
            carlierd
            RFM69 or RFM69HW ?
            For RFM69HW you have to modify MyTransportRFM69.hand enable HW model on line 33.
            Replace bool isRFM69HW=falseby bool isRFM69HW=true.
            Nothing on the serial output of the pro mini ??
            • fetsF
              fetsF
              fets
              Do you use 4.7uF capacitor ?
              • SweebeeS
                SweebeeS
                Sweebee
                Yes i have the HW versions, so i replaced bool isRFM69HW=false by bool isRFM69HW=true
                added a capacitor.
                refreshed and still no feedback after sending.
                I get a serial output from the pro mini on start. but no more serial messages when i try to send a message.
                • carlierdC
                  carlierdC
                  carlierd
                  Put your arduino pro debug message to see what happens.
                  You used DHT22 ?
                  • SweebeeS
                    SweebeeS
                    Sweebee
                    Its working now!
                    Gateway doesn't work on the pro mini, but your sensor sketch is working :D
                    now the next thing, i get a lot of fails:
                    send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=fail:GHAS sensor
                    send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,st=fail:1.1.5
                    send: 10-10-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=fail:
                    find parent
                    send: 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                    send: 10-10-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=fail:
                    send: 10-10-0-0 s=2,c=0,t=16,pt=0,l=0,sg=0,st=fail:
                    send: 10-10-0-0 s=3,c=0,t=30,pt=0,l=0,sg=0,st=fail:
                    [Setup duration: 7385 ms]
                    send: 10-10-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=fail:0.0
                    send: 10-10-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:0.0
                    send: 10-10-0-0 s=2,c=1,t=37,pt=2,l=2,sg=0,st=fail:9
                    find parent
                    send: 10-10-0-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=fail:3.30
                    send: 10-10-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=fail:100
                    0.0 degC   0.0 %   9 lx   3.30 v   [4851 ms]
                    but the gateway receives everything fine?
                    22:13:05.403 [pimatic-mysensors] debug: <- Presented Node  [ '10', '0', '0', '0', '7', '' ]
                    22:13:05.451 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    22:13:05.497 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    22:13:05.538 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    22:13:05.980 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                    22:13:06.115 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                    22:13:06.246 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                    22:13:07.594 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                    22:13:07.594 [pimatic-mysensors] debug: <- Presented Node  [ '10', '1', '0', '0', '6', '' ]
                    22:13:07.635 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                    22:13:07.639 [pimatic-mysensors] debug: <- Presented Node  [ '10', '1', '0', '0', '6', '' ]
                    22:13:07.680 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                    22:13:07.680 [pimatic-mysensors] debug: <- Presented Node  [ '10', '1', '0', '0', '6', '' ]
                    22:13:07.729 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=0,t=16,pt=0,l=0,sg=0:
                    22:13:07.729 [pimatic-mysensors] debug: <- Presented Node  [ '10', '2', '0', '0', '16', '' ]
                    22:13:07.774 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=0,t=16,pt=0,l=0,sg=0:
                    22:13:07.775 [pimatic-mysensors] debug: <- Presented Node  [ '10', '2', '0', '0', '16', '' ]
                    22:13:07.815 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=0,t=16,pt=0,l=0,sg=0:
                    22:13:07.816 [pimatic-mysensors] debug: <- Presented Node  [ '10', '2', '0', '0', '16', '' ]
                    22:13:07.864 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=0,t=30,pt=0,l=0,sg=0:
                    22:13:07.865 [pimatic-mysensors] debug: <- Presented Node  [ '10', '3', '0', '0', '30', '' ]
                    22:13:07.909 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=0,t=30,pt=0,l=0,sg=0:
                    22:13:07.909 [pimatic-mysensors] debug: <- Presented Node  [ '10', '3', '0', '0', '30', '' ]
                    22:13:07.950 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=0,t=30,pt=0,l=0,sg=0:
                    22:13:07.954 [pimatic-mysensors] debug: <- Presented Node  [ '10', '3', '0', '0', '30', '' ]
                    22:13:10.060 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=0,c=1,t=1,pt=7,l=5,sg=0:0.0
                    22:13:10.105 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=0,c=1,t=1,pt=7,l=5,sg=0:0.0
                    22:13:10.150 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=0,c=1,t=1,pt=7,l=5,sg=0:0.0
                    22:13:10.244 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=1,t=0,pt=7,l=5,sg=0:0.0
                    22:13:10.289 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=1,t=0,pt=7,l=5,sg=0:0.0
                    22:13:10.342 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=1,t=37,pt=2,l=2,sg=0:9
                    22:13:10.383 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=1,t=37,pt=2,l=2,sg=0:9
                    22:13:10.428 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=1,t=37,pt=2,l=2,sg=0:9
                    22:13:10.477 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    22:13:10.522 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    22:13:10.563 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    22:13:10.903 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                    22:13:11.038 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                    22:13:11.174 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                    22:13:12.583 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=1,t=38,pt=7,l=5,sg=0:3.30
                    22:13:12.628 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=1,t=38,pt=7,l=5,sg=0:3.30
                    22:13:12.673 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=1,t=38,pt=7,l=5,sg=0:3.30
                    22:13:12.722 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=255,c=3,t=0,pt=1,l=1,sg=0:100
                    • carlierdC
                      carlierdC
                      carlierd
                      It's perhaps due to the signing feature ...
                      May be you should disable it for the moment.
                      Disable the feature in MyConfig.h and replace the gateway constructor by:
                      MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                      • SweebeeS
                        SweebeeS
                        Sweebee
                        #24
                        Thanks! it working great now.
                        Why does signing not work? Because of the controller? or is this handled by the gateway?
                        Edit: Oh it was disabled on the gateway, now it works :)
                        • carlierdC
                          carlierdC
                          carlierd
                          Good news !!
                          If you enable signing, don't forget to change MY_HMAC_KEYin MyConfig.h !
                          David.
                          • SweebeeS
                            SweebeeS
                            Sweebee
                            #26
                            I'm trying to create my gateway with a arduino nano. Attached everything and on the serial output I get:
                            But nothing happens when i try to send something.
                            When I try to send something with a sensor it gets fail:
                            send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.1
                            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
                            sensor started, id=1, parent=0, distance=0
                            send: 1-1-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=fail:1
                            On a arduino uno it works fine. But the gateway won't work on a pro mini or a nano?
                            • SweebeeS
                              SweebeeS
                              Sweebee
                              I tried the samples from the RFM69 library and they all work fine on any arduino.
                              Maybe someone can upload their library and some RFM69 mysensors samples that are working?
