  3. Can't get RFM69 working
27 Posts 5 Posters 12.1k Views 3 Watching
  • SweebeeS
    SweebeeS
    Sweebee
    Arduino uno > level shifter > RFM69HW
    the level shifter / RFM is powered by a separate 5 > 3.3v converter.
    • carlierdC
      carlierdC
      carlierd
      hello,
      How did you powered the rfm69 on the uno ? using the 3.3 from the uno or using a voltage regulator ?
      I first used voltage regulator but I encountered some issues with the uno so I finally directly used the 3.3 from the uni board.
      another thing, remove not used include such 'MyTransportNRF24' in your code.
      I will post my gateway and sensor code thus evening as I can't do it from my phone now ...
      • SweebeeS
        SweebeeS
        Sweebee
        The RFM is powered by the regulator. Havent tried to power it from the 3v from the arduino yet.
        • carlierdC
          carlierdC
          carlierd
          The code as promise.
          For the gateway I don't change a lot of thing from the example provided in the lib:
          /* Serial gateway (RFM69 with encryption, soft signing and LEDs).                     */
          /* Version     : 0.1.1        */
          /* Date        : 29/11/2015                                                           */
          /* Modified by : David Carlier                                                        */
          #define NO_PORTB_PINCHANGES
          #include <MyTransportRFM69.h>
          #include <MyHwATMega328.h>
          #include <MyParserSerial.h>
          #include <stdarg.h>
          #include <PinChangeInt.h>
          #include "GatewayUtil.h"
          //Construct MySensors library
          MySigningAtsha204Soft signer;
          MyHwATMega328 hw;
          MyTransportRFM69 transport;
          MySensor gw(transport, hw, signer, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
          //Variables
          char inputString[MAX_RECEIVE_LENGTH] = "";
          int inputPos = 0;
          boolean commandComplete = false;
          void parseAndSend(char *commandBuffer);
          void output(const char *fmt, ... ) {
             va_list args;
             va_start (args, fmt );
             va_end (args);
             Serial.print(serialBuffer);
          /* Initialization        */
            //Start MySensors
            //Add interrupt for inclusion button to pin
            PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
            //Send startup log message on serial
            serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"), C_INTERNAL, I_GATEWAY_READY);
          /* Main loop        */
            checkInclusionFinished();
            if (commandComplete)
              //A command wass issued from serial interface
              //We will now try to send it to the actuator
              parseAndSend(gw, inputString);
              inputPos = 0;
            SerialEvent occurs whenever a new data comes in the
           hardware serial RX.  This routine is run between each
           time loop() runs, so using delay inside loop can delay
           response.  Multiple bytes of data may be available.
          void serialEvent() {
            while (Serial.available()) {
              // get the new byte:
              char inChar = (char)Serial.read();
              // if the incoming character is a newline, set a flag
              // so the main loop can do something about it:
              if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                if (inChar == '\n') {
                  inputString[inputPos] = 0;
                  commandComplete = true;
                  // add it to the inputString:
                  inputString[inputPos] = inChar;
                  inputPos++;
                  inputPos = 0;
          For the sensor, there is more difference from the humidity example:
          /* Temperature, humidity and luminosity measurements.                                 */
          /* Version     : 1.1.5        */
          /* Date        : 04/01/2016                                                           */
          /*                            RST |             |  A5                                 */
          /*                            RX  |             |  A4                                 */
          /*                            TX  |   ARDUINO   |  A3                                 */
          /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
          /*            DHT22 --------- D3  |             |  A1                                 */
          /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
          /*              +3v --------- VCC |             | GND --------- GND                   */
          /*              GND --------- GND |  8MHz int.  | REF                                 */
          /*                            OSC |             | VCC --------- +3v                   */
          /*                            OSC |             | D13 --------- RFM69 (SCK)           */
          /*                            D5  |             | D12 --------- RFM69 (MISO)          */
          /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
          /*                            D7  |             | D10 --------- RFM69 (NSS)           */
          /*                            D8  |             |  D9                                 */
          /* Power = Vcc for LDR and DHT22 et SWITCH.                                           */
          /* +3v = 2*AA        */
          #include <dht.h>
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define CHILD_ID_LIGHT 2
          #define CHILD_ID_VOLTAGE 3
          #define POWER_PIN 4
          unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds)
          MyHwATMega328 hw;
          MySensor gw(transport, hw, signer);
          dht DHT;
          MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
          MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
            //Get time (for setup duration)
            #ifdef DEBUG
              unsigned long startTime = millis();
            //Start MySensors
            gw.begin();
            //Send the Sketch Version Information to the Gateway
            gw.sendSketchInfo("GHAS sensor", "1.1.5");
            //Register all sensors to gw (they will be created as child devices)
            gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
            //Delay for DHT22
            delay(1500);
            //Print setup debug
            #ifdef DEBUG
              int duration = millis() - startTime;
              Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
          /* Main loop        */
            //Get time (for a complete loop)
            #ifdef DEBUG
            //Power on
            powerOnPeripherals();
            delay(2000);
            //Get DHT22 data
            int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
            switch (dht22Result)
              case DHTLIB_OK:
                          //Serial.println("OK,\t");
              case DHTLIB_ERROR_CHECKSUM:
                          #ifdef DEBUG
                            Serial.println("Checksum error,\t");
              case DHTLIB_ERROR_TIMEOUT:
                          #ifdef DEBUG
                            Serial.println("Time out error,\t");
              case DHTLIB_ERROR_CONNECT:
                          #ifdef DEBUG
                            Serial.println("Connect error,\t");
              case DHTLIB_ERROR_ACK_L:
                          #ifdef DEBUG
                            Serial.println("Ack Low error,\t");
              case DHTLIB_ERROR_ACK_H:
                          #ifdef DEBUG
                            Serial.println("Ack High error,\t");
              default:
                          #ifdef DEBUG
                            Serial.println("Unknown error,\t");
            //Get temperature and humidity
            float temperature = 0;
            float humidity = 0;
            if (dht22Result == DHTLIB_OK)
              temperature = DHT.temperature;
              humidity = DHT.humidity;
            //Get power before luminosity to use real voltage
            float realVoltage = getVoltage() / 100.0;
            int batteryPcnt = realVoltage * 100 / 3.0;
            if (batteryPcnt > 100) {batteryPcnt = 100;}
            int lux = computeIlluminance(realVoltage);
            //Power off
            powerOffPeripherals();
            //Send data to gateway
            gw.send(msgLum.set(lux));
            gw.send(msgVolt.set(realVoltage, 2));
            //Print debug
            #ifdef DEBUG
              Serial.print(temperature, 1);
              Serial.print(" degC");
              Serial.print("   ");
              Serial.print(humidity, 1);
              Serial.print(" %");
              Serial.print("   ");
              Serial.print(lux);
              Serial.print(" lx");
              Serial.print("   ");
              Serial.print(realVoltage);
              Serial.print(" v");
              Serial.print("   ");
              Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
              Serial.flush();
            //Sleep
            gw.sleep(SLEEP_TIME);
          /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
          int computeIlluminance(float realVoltage)
            //Get luminosity
            int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
            //Calculating the voltage in the input of the ADC
            double voltage = realVoltage * ((double)luminosity / 1024.0);
            //Calculating the resistance of the photoresistor in the voltage divider
            double resistance = (10.0 * realVoltage) / voltage - 10.0;
            //Calculating the intensity of light in lux and return it
            int illuminance = 255.84 * pow(resistance, -10/9);
            return illuminance;
          /* Allows to get the real Vcc (return value * 100).                                   */
          int getVoltage()
            const long InternalReferenceVoltage = 1056L;
            ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
            delay(50);  // Let mux settle a little to get a more stable A/D conversion
            //Start a conversion
            ADCSRA |= _BV( ADSC );
            //Wait for it to complete
            while (((ADCSRA & (1<<ADSC)) != 0));
            //Scale the value
            int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
            return result;
          /* Allows to power ON peripherals.                                                    */
          void powerOnPeripherals()
            //Power-up
            pinMode (POWER_PIN, OUTPUT);
            digitalWrite (POWER_PIN, HIGH);
            delay(1);
          /* Allows to power OFF peripherals.                                                   */
          void powerOffPeripherals()
            //Power off
            digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
            digitalWrite (POWER_PIN, LOW);
            pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
            pinMode (POWER_PIN, INPUT);
          David
          SweebeeS 1 Reply Last reply
          • SweebeeS
            SweebeeS
            Sweebee
            Thanks, will try it :)
            • L
              L
              lafleur
              How do you change I/O pins define for the RFM69 if using a different platform??
              will this work under 1.6 development ?
              • carlierdC carlierd
                #include <stdarg.h>
                MyHwATMega328 hw;
                //Variables
                int inputPos = 0;
                   va_list args;
                   va_end (args);
                  //Start MySensors
                /* Main loop        */
                    inputPos = 0;
                        inputPos++;
                        inputPos = 0;
                /*                            RST |             |  A5                                 */
                /*                            RX  |             |  A4                                 */
                /*                            D8  |             |  D9                                 */
                /* +3v = 2*AA        */
                #include <dht.h>
                #define POWER_PIN 4
                MyHwATMega328 hw;
                dht DHT;
                  #ifdef DEBUG
                  //Start MySensors
                  gw.begin();
                  //Delay for DHT22
                  delay(1500);
                  //Print setup debug
                  #ifdef DEBUG
                /* Main loop        */
                  #ifdef DEBUG
                  //Power on
                  delay(2000);
                  //Get DHT22 data
                    case DHTLIB_OK:
                                #ifdef DEBUG
                                #ifdef DEBUG
                                #ifdef DEBUG
                                #ifdef DEBUG
                                #ifdef DEBUG
                    default:
                                #ifdef DEBUG
                  float humidity = 0;
                  //Power off
                  //Print debug
                  #ifdef DEBUG
                    Serial.print("   ");
                    Serial.print(" %");
                    Serial.print("   ");
                    Serial.print(lux);
                    Serial.print("   ");
                    Serial.print(" v");
                    Serial.print("   ");
                    Serial.flush();
                  //Sleep
                  //Get luminosity
                  return illuminance;
                int getVoltage()
                  //Scale the value
                  return result;
                  //Power-up
                  delay(1);
                  //Power off
                David
                SweebeeS
                SweebeeS
                Sweebee
                @carlierd I tried to compile your gateway but i get this error:
                Arduino: 1.6.5 (Mac OS X), Board:"Arduino Uno"
                SerialGateway:52: error: no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&, int, int, int)'
                SerialGateway.ino:52:91: note: candidates are:
                In file included from SerialGateway.ino:37:0:
                /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:158:2: note: MySensor::MySensor(MyTransport&, MyHw&)
                /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:158:2: note:   candidate expects 2 arguments, 6 provided
                /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:149:7: note: MySensor::MySensor(const MySensor&)
                 class MySensor
                /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:149:7: note:   candidate expects 1 argument, 6 provided
                • carlierdC
                  carlierdC
                  carlierd
                  I am using stable version of MySensors not the dev branch. What version are you using ?
                  David
                    David
                    SweebeeS
                    SweebeeS
                    Sweebee
                    @carlierd 1.5 https://github.com/mysensors/Arduino/tree/master
                    • carlierdC
                      carlierdC
                      carlierd
                      Did you enabled signing feature in MyConfig.h : #define MY_SIGNING_FEATURE ??
                      • SweebeeS
                        SweebeeS
                        Sweebee
                        I think the gateway works now, i removed the separate 5-3.3v converter and used the arduino 3.3v.
                        Now the sensor, i uploaden your sketch, but i get no init message?
                        • carlierdC
                          carlierdC
                          carlierd
                          Did you connect the gateway to a controller ? or to MYSController ? You get the gateway ready message ?
                          For the sensor, you are using the sketch I upload ?
                          Debug mode is enable in MyConfig.h ?
                          You should have some debug messages in the console when connecting to the node.
                          David.
                          • SweebeeS
                            SweebeeS
                            Sweebee
                            wrote on last edited by Sweebee
                            The problem is on the uno everything seems to work fine.
                            for the sensor i attached the RFM to a arduino pro mini 3.3v
                            double checked the wiring, tried 2 different RFM's, tried 2 arduino pro mini's.
                            uploaden the gateway to it and i get:
                            but when i try to send something with the pro mini i get nothing back, while on the UNO I get:
                            0;0;3;0;9;send: 0-0-10-10 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                            So on the pro mini i get the init message, but no message when i try to send something.
                            • carlierdC
                              carlierdC
                              carlierd
                              RFM69 or RFM69HW ?
                              For RFM69HW you have to modify MyTransportRFM69.hand enable HW model on line 33.
                              Replace bool isRFM69HW=falseby bool isRFM69HW=true.
                              Nothing on the serial output of the pro mini ??
                              • fetsF
                                fetsF
                                fets
                                Do you use 4.7uF capacitor ?
                                • SweebeeS
                                  SweebeeS
                                  Sweebee
                                  Yes i have the HW versions, so i replaced bool isRFM69HW=false by bool isRFM69HW=true
                                  added a capacitor.
                                  refreshed and still no feedback after sending.
                                  I get a serial output from the pro mini on start. but no more serial messages when i try to send a message.
                                  • carlierdC
                                    carlierdC
                                    carlierd
                                    Put your arduino pro debug message to see what happens.
                                    You used DHT22 ?
                                    • SweebeeS
                                      SweebeeS
                                      Sweebee
                                      Its working now!
                                      Gateway doesn't work on the pro mini, but your sensor sketch is working :D
                                      now the next thing, i get a lot of fails:
                                      send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=fail:GHAS sensor
                                      send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,st=fail:1.1.5
                                      send: 10-10-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=fail:
                                      find parent
                                      send: 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                      send: 10-10-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=fail:
                                      send: 10-10-0-0 s=2,c=0,t=16,pt=0,l=0,sg=0,st=fail:
                                      send: 10-10-0-0 s=3,c=0,t=30,pt=0,l=0,sg=0,st=fail:
                                      [Setup duration: 7385 ms]
                                      send: 10-10-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=fail:0.0
                                      send: 10-10-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:0.0
                                      send: 10-10-0-0 s=2,c=1,t=37,pt=2,l=2,sg=0,st=fail:9
                                      find parent
                                      send: 10-10-0-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=fail:3.30
                                      send: 10-10-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=fail:100
                                      0.0 degC   0.0 %   9 lx   3.30 v   [4851 ms]
                                      but the gateway receives everything fine?
                                      22:13:05.403 [pimatic-mysensors] debug: <- Presented Node  [ '10', '0', '0', '0', '7', '' ]
                                      22:13:05.451 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      22:13:05.497 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      22:13:05.538 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      22:13:05.980 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                                      22:13:06.115 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                                      22:13:06.246 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                                      22:13:07.594 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                      22:13:07.594 [pimatic-mysensors] debug: <- Presented Node  [ '10', '1', '0', '0', '6', '' ]
                                      22:13:07.635 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                      22:13:07.639 [pimatic-mysensors] debug: <- Presented Node  [ '10', '1', '0', '0', '6', '' ]
                                      22:13:07.680 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                      22:13:07.680 [pimatic-mysensors] debug: <- Presented Node  [ '10', '1', '0', '0', '6', '' ]
                                      22:13:07.729 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=0,t=16,pt=0,l=0,sg=0:
                                      22:13:07.729 [pimatic-mysensors] debug: <- Presented Node  [ '10', '2', '0', '0', '16', '' ]
                                      22:13:07.774 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=0,t=16,pt=0,l=0,sg=0:
                                      22:13:07.775 [pimatic-mysensors] debug: <- Presented Node  [ '10', '2', '0', '0', '16', '' ]
                                      22:13:07.815 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=0,t=16,pt=0,l=0,sg=0:
                                      22:13:07.816 [pimatic-mysensors] debug: <- Presented Node  [ '10', '2', '0', '0', '16', '' ]
                                      22:13:07.864 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=0,t=30,pt=0,l=0,sg=0:
                                      22:13:07.865 [pimatic-mysensors] debug: <- Presented Node  [ '10', '3', '0', '0', '30', '' ]
                                      22:13:07.909 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=0,t=30,pt=0,l=0,sg=0:
                                      22:13:07.909 [pimatic-mysensors] debug: <- Presented Node  [ '10', '3', '0', '0', '30', '' ]
                                      22:13:07.950 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=0,t=30,pt=0,l=0,sg=0:
                                      22:13:07.954 [pimatic-mysensors] debug: <- Presented Node  [ '10', '3', '0', '0', '30', '' ]
                                      22:13:10.060 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=0,c=1,t=1,pt=7,l=5,sg=0:0.0
                                      22:13:10.105 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=0,c=1,t=1,pt=7,l=5,sg=0:0.0
                                      22:13:10.150 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=0,c=1,t=1,pt=7,l=5,sg=0:0.0
                                      22:13:10.244 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=1,t=0,pt=7,l=5,sg=0:0.0
                                      22:13:10.289 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=1,c=1,t=0,pt=7,l=5,sg=0:0.0
                                      22:13:10.342 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=1,t=37,pt=2,l=2,sg=0:9
                                      22:13:10.383 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=1,t=37,pt=2,l=2,sg=0:9
                                      22:13:10.428 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=2,c=1,t=37,pt=2,l=2,sg=0:9
                                      22:13:10.477 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      22:13:10.522 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      22:13:10.563 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      22:13:10.903 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                                      22:13:11.038 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                                      22:13:11.174 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;send: 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                                      22:13:12.583 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=1,t=38,pt=7,l=5,sg=0:3.30
                                      22:13:12.628 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=1,t=38,pt=7,l=5,sg=0:3.30
                                      22:13:12.673 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=3,c=1,t=38,pt=7,l=5,sg=0:3.30
                                      22:13:12.722 [pimatic-mysensors] debug: <- I_LOG_MESSAGE  0;0;3;0;9;read: 10-10-0 s=255,c=3,t=0,pt=1,l=1,sg=0:100
                                      • carlierdC
                                        carlierdC
                                        carlierd
                                        It's perhaps due to the signing feature ...
                                        May be you should disable it for the moment.
                                        Disable the feature in MyConfig.h and replace the gateway constructor by:
                                        MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                                        • SweebeeS
                                          SweebeeS
                                          Sweebee
                                          #24
                                          Thanks! it working great now.
                                          Why does signing not work? Because of the controller? or is this handled by the gateway?
                                          Edit: Oh it was disabled on the gateway, now it works :)
