  3. Relay Sketch (1.6dev ) failed messages cause relay to activate.
5 Posts 2 Posters 2.0k Views 1 Watching
  • greglG Offline
    greglG Offline
    gregl
    I'm wondering if anyone can reproduce this.
    Using the Relay actuator sketch as a base, im adding a switch ( so as to make a garage door opener/monitor) - i have this all working, except for when i encounter a failed transmission, the relay activates!
    Here is a sketch with minimal modifications from the example RelayActuator sketch - in effect all ive added to it, is to send some packets frequently, in order to generate some fail messages.: ( im running it on a rBoard -mini )
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to control physical relays.
     * This example will remember relay state after power failure.
     * http://www.mysensors.org/build/relay
    #define MY_NODE_ID 4
    #define MY_REPEATER_FEATURE
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define CHILD_ID_R1 8
    MyMessage doorLockMsg(CHILD_ID_R1, V_LOCK_STATUS);
    int value = 1;
        pinMode(pin, OUTPUT);
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_LIGHT);
     //generate some traffic
    	if (value == 3000) {
    		//Serial.println(value);
    		send(doorLockMsg.set(value == HIGH ? 1 : 0));
    		value = 0;
    	value++ ;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    Serial output looks like this:
    send: 4-4-0-0 s=8,c=1,t=36,pt=2,l=2,sg=0,st=ok:0
    3000
    3000
    3000
    3000
    3000
    3000
    3000
    3000
    send: 4-4-0-0 s=8,c=1,t=36,pt=2,l=2,sg=0,st=**fail:0**
    3000
    3000
    3000
    every time the fail:0 appears the relay toggles! I know its not going through the void recieve function, as there are no prints due to 'Serial.print("Incoming change for sensor:");'
    It also occurs at the intialisation phase, when the sketchname/version is sent.
    Starting repeater (RNNRA-, 2.0.0-beta)
    Radio init successful.
    send: 4-4-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=ok:0
    send: 4-4-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=fail:2.0.0-beta
    send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=fail:Relay
    send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
    send: 4-4-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    Init complete, id=4, parent=0, distance=1
    3000
    3000
    Is anyone able/interested in trying to reproduce this? or any ideas what may be the cause? I will setup another arduino and relay to see if its hardware specific, but id be surprised if it was!
    Cheers,
    Greg
    • greglG Offline
      greglG Offline
      gregl
      I have been able to reproduce it on a another arduino and relay. ( nano IO shield + relay board )
      but... if i move the relay from D4 to D8 there is no issue! Failed messages do not cause the relay to activate.
      Could the radio be somehow driving D4 ??
      • greglG Offline
        greglG Offline
        gregl
        Ive been digging, and in MyConfig.h i see this:
        // The Error LED default pin
        #ifndef MY_DEFAULT_ERR_LED_PIN
        		#define MY_DEFAULT_ERR_LED_PIN 7
        		#define MY_DEFAULT_ERR_LED_PIN 4
        Could this be the cause?
        and if so shouldnt it be disabled by default due to line 141,
        //#define MY_LEDS_BLINKING_FEATURE
        • S Offline
          Hi!
          Have a look here: http://forum.mysensors.org/topic/2749/1-6-gateway-possible-error/11
          Maybe something to do with this?
          • greglG Offline
            greglG Offline
            gregl
            Yeah -right on! In my sketch ive set them to use unused analogue pins
            #define MY_DEFAULT_TX_LED_PIN A0
            #define MY_DEFAULT_RX_LED_PIN A1
            #define MY_DEFAULT_ERR_LED_PIN A2
            ...problem went away. ;-)
