  3. Another beginner project
20 Posts 5 Posters 11.1k Views 2 Watching
  • AstrofotografA Astrofotograf
    can't wait until the parts arrive..
    HenryWhiteH
    HenryWhiteH
    HenryWhite
    Hi! Which "Funklichtschalter (Sender)" are you going to use?
    • AstrofotografA
      AstrofotografA
      Astrofotograf
      wrote on last edited by Astrofotograf
      I ordered this one: "Smartwares SmartHome Funk-Einzelwandschalter 1-Kanal, SH5-TSW-A"
      together with this one: "Smartwares SmartHome Funk-Einbauschalter 1000 W, SH5-RBS-10A"
      and this one: "Smartwares SmartHome Funk-Fernbedienung 4-Kanal, SH5-TDR-F"
      But didn't try them yet, so no further experiences with them yet
      HenryWhiteH 1 Reply Last reply
        HenryWhiteH
        HenryWhiteH
        HenryWhite
        wrote on last edited by HenryWhite
        @Astrofotograf nice, didn't knew they were that cheap nowadays. How are you going to get the (binary) code from these 433mhz switches? Do you have any useful links/tutorials for that? :smile:
        • AstrofotografA
          AstrofotografA
          Astrofotograf
          With an arduino + 433 MHz receiver. The library is rc switch. There is a receive example sketch coming with it
          • sundberg84S
            sundberg84S
            Are you sure this library are supported by openhab? Might be worth checking out first.
            A quick google shows atleast there are RFXCom bindings (protocoll for gateway to talk to controller) for openhab
            • B
              B
              BastienVH
              wrote on last edited by BastienVH
              When I used OpenHAB as a controller , I used the pilight plugin.
              If you setup a pilight-instance, you can connect it to OpenHAB and let that read out states and send commands.
              I didn't look dor a way to directly control an arduino from OpenHAB, seeing as pilight worked fine.
              EDIT: just to clarify: pilight has an arduino sketch you can upload to a nano (which is what I used) to act as a gateway.
              You won't need the expensive RFXCom.
              • AstrofotografA
                AstrofotografA
                Astrofotograf
                So you add the 433 MHz modules directly to the rapberry GPIO pins and use the arduino just for the sensors?
                  HenryWhiteH
                  HenryWhiteH
                  HenryWhite
                  Besides pilight there's also rcswitch-pi, basically rcswitch for the raspberry pi.
                  • AstrofotografA
                    AstrofotografA
                    Astrofotograf
                    But in general, I could save the second gateway with that?
                    I'm not sure if I understand all of that correctly. Just spent a few hours to get the demo of openHAB running and still get some errors (persistence service not available) where I don't know whether it is normal to get these errors..
                    B 1 Reply Last reply
                      B
                      B
                      BastienVH
                      @Astrofotograf
                      Pilight can use 433MHz senders and receivers connected to the GPIO-pins of the Raspberry Pi.
                      Problem with that is that the pi will need to filter all of the frequency noise which leads to higher cpu-usage and slower processing of other tasks (OpenHAB is quite resource-heavy in my opinion - on a RPi B+).
                      That's why they also have pilight-usb-nano which is a sketch/hex-file to upload to an arduino nano. This way the nano will filter out the noise and only feed recognizable commands to pilight, which in its way sends the commands to OpenHAB.
                      In that regard it acts as a gateway for your controller.
                      • AstrofotografA
                        AstrofotografA
                        Astrofotograf
                        Okay, thanks. Seems I just have to experiment a bit with it.
                        • AstrofotografA
                          AstrofotografA
                          Astrofotograf
                          Hm, I installed OpenHAB now on my RasPi, also Mosquitto. I think I begin to understand this. So MQTT is just some kind of "forum", and when in the thread "livingroom/temperature" something changes, OpenHAB recognizes it. The sensor sends just its data to the gateway and the gateway writes the MQTT thread?
                          Will the other way round work too, so OpenHAB writes data into a specific thread, the gateway recognizes it and sends a command so, say a servo node to move something?
                          If that all is correct, I sould be able to connect the 433 MHz things just like a normal sensor node. The receiver acts as a normal sensor and the sender could use the servo sketch to send some commands via 433 MHz band?
