  3. Another beginner project
20 Posts 5 Posters 11.1k Views 2 Watching
  • sundberg84S
    sundberg84S
    Hi!
    You need two gateways, one for each channel (2.4ghz/433mhz). They report to the controller (openhab). The controller will watch the 2.4ghz motion detector and when its detected normally a script activates and sends the on command through the 433 gateway.
    I use this with Domoticz as controller and it works great. Motion is detected in MySensors network and a lua script fires and turns my 433mhz outlet on.
    I dont know exatcly which support openhab has, but someone else might be able to answer that.
    • AstrofotografA
      AstrofotografA
      Astrofotograf
      Is the gateway always one way? So it will receive the data from sensors and transmits it to the controller? What if I want to expand the system with a light switch? The light switch works also with 433 MHz, but it should not directly control the light. Instead it should send the signal to the controller, which then sends the signal to the receiver. Do I need a gateway per frequency band or a controller per task (receiving gateway / transmit gateway)?
      • sundberg84S
        sundberg84S
        No the gateway is always two ways. It communicates with the controller and sends/recieve from/to the nodes. Yes, it will recieve data from sensors and transmit it to controller.
        Works the same way, 433mhz switch sends to gateway, and then to controller. Scripts fire and controller sends back the same way.
        • mikeeM
          mikeeM
          mikee
          I've gone same route as you are starting. After all I'm at Domoticz + MS gateway + RFlink. Works beautifully.
          • AstrofotografA
            AstrofotografA
            Astrofotograf
            So it should work like this (german, but I hope you can understand)
            • mikeeM
              mikeeM
              mikee
              Exactly, different GWs, different Frequency and protocols.
              • AstrofotografA
                AstrofotografA
                Astrofotograf
                can't wait until the parts arrive..
                HenryWhiteH 1 Reply Last reply
                • AstrofotografA Astrofotograf
                  HenryWhiteH
                  HenryWhiteH
                  HenryWhite
                  Hi! Which "Funklichtschalter (Sender)" are you going to use?
                  • AstrofotografA
                    AstrofotografA
                    Astrofotograf
                    wrote on last edited by Astrofotograf
                    I ordered this one: "Smartwares SmartHome Funk-Einzelwandschalter 1-Kanal, SH5-TSW-A"
                    together with this one: "Smartwares SmartHome Funk-Einbauschalter 1000 W, SH5-RBS-10A"
                    and this one: "Smartwares SmartHome Funk-Fernbedienung 4-Kanal, SH5-TDR-F"
                    But didn't try them yet, so no further experiences with them yet
                      HenryWhiteH
                      HenryWhiteH
                      HenryWhite
                      wrote on last edited by HenryWhite
                      @Astrofotograf nice, didn't knew they were that cheap nowadays. How are you going to get the (binary) code from these 433mhz switches? Do you have any useful links/tutorials for that? :smile:
                      • AstrofotografA
                        AstrofotografA
                        Astrofotograf
                        With an arduino + 433 MHz receiver. The library is rc switch. There is a receive example sketch coming with it
                        • sundberg84S
                          sundberg84S
                          Are you sure this library are supported by openhab? Might be worth checking out first.
                          A quick google shows atleast there are RFXCom bindings (protocoll for gateway to talk to controller) for openhab
                          • B
                            B
                            BastienVH
                            wrote on last edited by BastienVH
                            When I used OpenHAB as a controller , I used the pilight plugin.
                            If you setup a pilight-instance, you can connect it to OpenHAB and let that read out states and send commands.
                            I didn't look dor a way to directly control an arduino from OpenHAB, seeing as pilight worked fine.
                            EDIT: just to clarify: pilight has an arduino sketch you can upload to a nano (which is what I used) to act as a gateway.
                            You won't need the expensive RFXCom.
                            • AstrofotografA
                              AstrofotografA
                              Astrofotograf
                              So you add the 433 MHz modules directly to the rapberry GPIO pins and use the arduino just for the sensors?
                                HenryWhiteH
                                HenryWhiteH
                                HenryWhite
                                Besides pilight there's also rcswitch-pi, basically rcswitch for the raspberry pi.
                                • AstrofotografA
                                  AstrofotografA
                                  Astrofotograf
                                  But in general, I could save the second gateway with that?
                                  I'm not sure if I understand all of that correctly. Just spent a few hours to get the demo of openHAB running and still get some errors (persistence service not available) where I don't know whether it is normal to get these errors..
                                  B 1 Reply Last reply
                                    B
                                    B
                                    BastienVH
                                    @Astrofotograf
                                    Pilight can use 433MHz senders and receivers connected to the GPIO-pins of the Raspberry Pi.
                                    Problem with that is that the pi will need to filter all of the frequency noise which leads to higher cpu-usage and slower processing of other tasks (OpenHAB is quite resource-heavy in my opinion - on a RPi B+).
                                    That's why they also have pilight-usb-nano which is a sketch/hex-file to upload to an arduino nano. This way the nano will filter out the noise and only feed recognizable commands to pilight, which in its way sends the commands to OpenHAB.
                                    In that regard it acts as a gateway for your controller.
                                    • AstrofotografA
                                      AstrofotografA
                                      Astrofotograf
                                      Okay, thanks. Seems I just have to experiment a bit with it.
                                      • AstrofotografA
                                        AstrofotografA
                                        Astrofotograf
                                        Hm, I installed OpenHAB now on my RasPi, also Mosquitto. I think I begin to understand this. So MQTT is just some kind of "forum", and when in the thread "livingroom/temperature" something changes, OpenHAB recognizes it. The sensor sends just its data to the gateway and the gateway writes the MQTT thread?
                                        Will the other way round work too, so OpenHAB writes data into a specific thread, the gateway recognizes it and sends a command so, say a servo node to move something?
                                        If that all is correct, I sould be able to connect the 433 MHz things just like a normal sensor node. The receiver acts as a normal sensor and the sender could use the servo sketch to send some commands via 433 MHz band?
