  3. Controlling Relay Actuator
17 Posts 6 Posters 8.0k Views 5 Watching
  • sundberg84S
    sundberg84S
    I have read alot of reports here lately with this issue in both Domoticz and Vera (pushing button works, but not sending from controller to relay). I dont know why but i tried it myself with 2.0b and exact the same behaivour. It works with my 1.4 relays but not 2.0...
    I have no more info at this time but will try to figure something out when i have the time...
    • sundberg84S
      sundberg84S
      Have not been able to test this (@ work), but according to Domoticz github it looks like Domoticz sends V_STATUS to update a Lightning2.
      In the sketch we have message.type == V_LIGHT
      MySensors github:
      S_LIGHT, // Binary light or relay, V_STATUS (or V_LIGHT), V_WATT
      Domoticz github:
      SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STATUS, lState, pChild->useAck);
      MySensors Github RelayWityButtonAcc
      Im not that good in understanding coding, but this would be the first im going to experiment with tonight.
      • BartEB
        BartEB
        BartE
        wrote on last edited by BartE
        V_LIGHT and V_STATUS are complementary to each other they are both are defined as 2.
        There are however a couple of remarks regarding your code.
        1. when the button is pressed only a message is sent to the GW the relay is not toggled
        2. when a state change request is received there is no status update sent to the gatewat
        3. a minor issue debouncer.update() return true when a change change was detected so you do not have to remember the old state.
        All three comments I've processed in the sketch below you might want to try this
         * Version 1.0 - Henrik Ekblad
         * Example sketch for a "light switch" where you can control light or something
         * else from both HA controller and a local physical button
         * (connected between digital pin 3 and GND).
         * This node also works as a repeader for other nodes
         * http://www.mysensors.org/build/relay
        #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
        #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer = Bounce();
        bool state;
          gw.sendSketchInfo("Relay & Button", "1.0");
         // Setup the button
          pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          gw.present(CHILD_ID, S_LIGHT);
          pinMode(RELAY_PIN, OUTPUT);
          state = gw.loadState(CHILD_ID);
        *  Example on how to asynchronously check for new messages from gw
          // Get the update value and if push button was release toggle the relay and send an update to the gw
          if (debouncer.update() && debouncer.read() != 0) {
              state = state ? true : false;
              gw.send(msg.set(state?false:true), true); // Send new state and request ack back
          if (message.isAck()) {
             // Change relay state
             state = message.getBool();
             // Store state in eeprom
             gw.saveState(CHILD_ID, state);
             // Send new state to the GW
             gw.send(msg.set(state?false:true));
        • sundberg84S
          sundberg84S
          Sorry about that... yea see that they are the same now. Spared me some time there BartE - tnx. He is using the standard sketch and this has been working great ever since... strange.
          • BartEB BartE
            #define RELAY_ON 1
            #define RELAY_OFF 0
            bool state;
             // Setup the button
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @BartE
            Regarding 1.
            I think the point is to wait for the acknowledge from the controller before changing relay state, after the press of the button.
            • sundberg84S
              sundberg84S
              and regarding 2 - why send a statusupdate to controller when the status comes from the controller? The ack should be enough?
              • sundberg84S
                sundberg84S
                So, recreated this now - all standard sketch (2.0b) except I used pin 5 instead of pin4 for relay (due to PCB pinout layout, should not matter).
                Everything works great both from Domoticz and Myscontroller but there was some small issues...
                1. Power - my pro mini was just a little to weak to trigger the relay... :( It needs 5v but my pin 5 was only giving 4.7V and some tries resulted in a unsuccessful relay switch even if the logs told me so.
                2. Radio - at some points i had the radio to close to the gw, so it didnt get the ACK and therefore i got the error "Error sending command, check device/hardware" message in Domoticz .
                This is from Myscontroller, sending a on command with ack:
                Correct seriallog node when incoming command from controller
                read: 0-0-4 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                send: 4-4-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                Incoming change for sensor:1, New status: 1
                What i dont know if why it works one way (command) but not the other (ack). I guess my GW radio is stronger, bigger or better powered.
                • BartEB
                  BartEB
                  BartE
                  @sundberg84 your right the ack should be enough
                  @martinhjelmare this should be enough, but when for some reason your network is down you'r not able to control the devices locally
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    Yes, good point.
                    Maybe one could have a timeout event that compares button state with relay state, and after three failed comparisons, turns off the waiting for the acknowledge, as a sign of network failure.
                    • sundberg84S
                      sundberg84S
                      @BartE, @martinhjelmare - this is sometime we should work with in the standard sketch.
                      I have one relay on the edge and sometimes its having really hard to get that ack back from the controller and it never changes. It would be good if the relay made the switch, send the on/off to controller and waited for the ack. If you dont recieve it you send again and tries for some times.
