  3. Controlling Relay Actuator
17 Posts 6 Posters 8.0k Views 5 Watching
  • P
    P
    PostaanErik
    Sorry..the last 2 blue lines in the picture are send via MYSController, but no result in serial output of the sensor or a relay ticking....( relay is working when pressing physical button )
    • AndurilA
      AndurilA
      Anduril
      Could you please post your actuator sketch? Sounds like the node is not handling the incoming traffic.
      • P
        P
        PostaanErik
        Im using the default example sketch 1.5.3:
         * LEDs (OPTIONAL):
        #define NO_PORTB_PINCHANGES
        #include <MySigningNone.h>
        #include <MyTransportRFM69.h>
        #include <MyTransportNRF24.h>
        #include <MyHwATMega328.h>
        #include <MyParserSerial.h>
        #include <stdarg.h>
        #include <PinChangeInt.h>
        #include "GatewayUtil.h"
        //MyTransportRFM69 transport;
        //MySigningNone signer;
        //MySigningAtsha204 signer;
        // Hardware profile
        MyHwATMega328 hw;
        #ifdef WITH_LEDS_BLINKING
        MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
        char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
        int inputPos = 0;
        boolean commandComplete = false;  // whether the string is complete
        void parseAndSend(char *commandBuffer);
        void output(const char *fmt, ... ) {
           va_list args;
           va_start (args, fmt );
           va_end (args);
           Serial.print(serialBuffer);
          // Add interrupt for inclusion button to pin
          PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
          // Send startup log message on serial
          serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
          checkInclusionFinished();
          if (commandComplete) {
            // A command wass issued from serial interface
            // We will now try to send it to the actuator
            parseAndSend(gw, inputString);
            inputPos = 0;
          SerialEvent occurs whenever a new data comes in the
         hardware serial RX.  This routine is run between each
         time loop() runs, so using delay inside loop can delay
         response.  Multiple bytes of data may be available.
        void serialEvent() {
          while (Serial.available()) {
            // get the new byte:
            char inChar = (char)Serial.read();
            // if the incoming character is a newline, set a flag
            // so the main loop can do something about it:
            if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
              if (inChar == '\n') {
                inputString[inputPos] = 0;
                commandComplete = true;
                // add it to the inputString:
                inputString[inputPos] = inChar;
                inputPos++;
                inputPos = 0;
        • P
          P
          PostaanErik
          just enabled led blinking for the gateway. When pressing relay sensor button: RX and TX blink on serial gateway + serial out:
          send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
          read: 0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0:0
          This is an ack from gateway
          Incoming change for sensor:1, New status: 0italicised text
          When controlling with Domoticz or MYSController....nothing send to the serial gateway, no TX, RX
          :( Spending hours without any progress
          Is there something i did not configure? Just using the example sketch for the serial gateway and enabled Led's in myconfig
          • ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            Please post your actuator sketch not the GW. As said above, maybe you are not handling the incoming data to the actuator correctly.
            • P
              P
              PostaanErik
              Im using the example RelayWithButtonActuator:
               * Version 1.0 - Henrik Ekblad
               * Example sketch for a "light switch" where you can control light or something
               * else from both HA controller and a local physical button
               * (connected between digital pin 3 and GND).
               * This node also works as a repeader for other nodes
               * http://www.mysensors.org/build/relay
              #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
              #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
              #define RELAY_ON 1
              #define RELAY_OFF 0
              Bounce debouncer = Bounce();
              int oldValue=0;
              bool state;
                gw.sendSketchInfo("Relay & Button", "1.0");
               // Setup the button
                pinMode(BUTTON_PIN,INPUT);
                // Activate internal pull-up
                debouncer.attach(BUTTON_PIN);
                debouncer.interval(5);
                gw.present(CHILD_ID, S_LIGHT);
                pinMode(RELAY_PIN, OUTPUT);
                state = gw.loadState(CHILD_ID);
              *  Example on how to asynchronously check for new messages from gw
                debouncer.update();
                // Get the update value
                int value = debouncer.read();
                if (value != oldValue && value==0) {
                    gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                oldValue = value;
                if (message.isAck()) {
                   // Change relay state
                   state = message.getBool();
                   // Store state in eeprom
                   gw.saveState(CHILD_ID, state);
              • sundberg84S
                sundberg84S
                I have read alot of reports here lately with this issue in both Domoticz and Vera (pushing button works, but not sending from controller to relay). I dont know why but i tried it myself with 2.0b and exact the same behaivour. It works with my 1.4 relays but not 2.0...
                I have no more info at this time but will try to figure something out when i have the time...
                • sundberg84S
                  sundberg84S
                  Have not been able to test this (@ work), but according to Domoticz github it looks like Domoticz sends V_STATUS to update a Lightning2.
                  In the sketch we have message.type == V_LIGHT
                  MySensors github:
                  S_LIGHT, // Binary light or relay, V_STATUS (or V_LIGHT), V_WATT
                  Domoticz github:
                  SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STATUS, lState, pChild->useAck);
                  MySensors Github RelayWityButtonAcc
                  Im not that good in understanding coding, but this would be the first im going to experiment with tonight.
                  • BartEB
                    BartEB
                    BartE
                    wrote on last edited by BartE
                    V_LIGHT and V_STATUS are complementary to each other they are both are defined as 2.
                    There are however a couple of remarks regarding your code.
                    1. when the button is pressed only a message is sent to the GW the relay is not toggled
                    2. when a state change request is received there is no status update sent to the gatewat
                    3. a minor issue debouncer.update() return true when a change change was detected so you do not have to remember the old state.
                    All three comments I've processed in the sketch below you might want to try this
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    bool state;
                     // Setup the button
                      // Get the update value and if push button was release toggle the relay and send an update to the gw
                      if (debouncer.update() && debouncer.read() != 0) {
                          state = state ? true : false;
                         // Send new state to the GW
                         gw.send(msg.set(state?false:true));
                    • sundberg84S
                      sundberg84S
                      Sorry about that... yea see that they are the same now. Spared me some time there BartE - tnx. He is using the standard sketch and this has been working great ever since... strange.
                      • BartEB BartE
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        bool state;
                         // Setup the button
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @BartE
                        Regarding 1.
                        I think the point is to wait for the acknowledge from the controller before changing relay state, after the press of the button.
                        • sundberg84S
                          sundberg84S
                          and regarding 2 - why send a statusupdate to controller when the status comes from the controller? The ack should be enough?
                          • sundberg84S
                            sundberg84S
                            So, recreated this now - all standard sketch (2.0b) except I used pin 5 instead of pin4 for relay (due to PCB pinout layout, should not matter).
                            Everything works great both from Domoticz and Myscontroller but there was some small issues...
                            1. Power - my pro mini was just a little to weak to trigger the relay... :( It needs 5v but my pin 5 was only giving 4.7V and some tries resulted in a unsuccessful relay switch even if the logs told me so.
                            2. Radio - at some points i had the radio to close to the gw, so it didnt get the ACK and therefore i got the error "Error sending command, check device/hardware" message in Domoticz .
                            This is from Myscontroller, sending a on command with ack:
                            Correct seriallog node when incoming command from controller
                            read: 0-0-4 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                            send: 4-4-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                            Incoming change for sensor:1, New status: 1
                            What i dont know if why it works one way (command) but not the other (ack). I guess my GW radio is stronger, bigger or better powered.
                            • BartEB
                              BartEB
                              BartE
                              @sundberg84 your right the ack should be enough
                              @martinhjelmare this should be enough, but when for some reason your network is down you'r not able to control the devices locally
                              • martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                Yes, good point.
                                Maybe one could have a timeout event that compares button state with relay state, and after three failed comparisons, turns off the waiting for the acknowledge, as a sign of network failure.
                                • sundberg84S
                                  sundberg84S
                                  @BartE, @martinhjelmare - this is sometime we should work with in the standard sketch.
                                  I have one relay on the edge and sometimes its having really hard to get that ack back from the controller and it never changes. It would be good if the relay made the switch, send the on/off to controller and waited for the ack. If you dont recieve it you send again and tries for some times.
