Sending Variables to a arduino switch
@patrick-schaerer the problem in your code snipped is the delay(1000).
This is a blocking call which blocks also your radio module from communicating. You have to use gw.wait(1000); i.s.o. delay. Now your plugin will receive data.
ok Ill try that
I don't have any delay in my code. Still same problem with var1 and domoticz.
delay is not the problem ... i changed the code to gw.wait(1000)
Serial output is the same -
I wrote a code that only fetch time and the V_VAR1 - works every time.
MySensors 2.0b, Ethernet GW, Domoticz latest version:#NOTE THAT CODE IS FOR MySensors > 1.6.0b version #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #define MY_NODE_ID 7 #include <SPI.h> #include <MySensor.h> #include <Time.h> boolean timeReceived = false; unsigned long lastUpdate=0, lastRequest=0; #define CHILD_ID 1 boolean pcReceived = false; unsigned long lastSend =0; void setup() { } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo("Test to get V_VAR1", "1.0"); } void loop() { unsigned long now = millis(); // If no time has been received yet, request it every 5 second from controller // When time has been received, request update every hour if ((!timeReceived && (now-lastRequest) > (5UL*1000UL)) || (timeReceived && (now-lastRequest) > (60UL*1000UL*60UL))) { requestTime(); lastRequest = now; } //Request V_VAR1 every 5 sec if not recieved. if (!pcReceived && (now - lastSend > 5000)) { request(CHILD_ID, V_VAR1); lastSend=now; return; } if (!pcReceived) { return; } } void receive(const MyMessage &message) { if (message.type==V_VAR1) { Serial.print("Received last pulse count from gw:"); Serial.println(message.getULong()); pcReceived = true; } } // This is called when a new time value was received void receiveTime(unsigned long time) { // Ok, set incoming time setTime(time); Serial.print("Got time, hour: "); Serial.println(hour()); timeReceived = true; }Its not different from my Rain sensor code... where i have the same problem as above... so there must be something else blocking recieve function in that code or radiotraffic... Its nothing wrong with Domoticz and/or Gateway what i can see... its something wrong with the code in the sensor itself. To be continued...
What is similar in our sketches that does not work is that we use pin 3. I have seen some post with relays that it worked if you move to pin 4. Don't know why but I will try this tonight. Worth a shot...
@patrick-schaerer and @sundberg84
I've compiled your code and uploaded in my Arduino to debug your issue. What i noticed is that the sketch worked on my side, two remarks on the code snipped:
- why switching back to 9600 baud and not just setting your terminal to 115200 baud.
- line 83 contains an error i think the + should be removed so it becomes this line:
LED_Level = gwLEDLevel;But this will not solve you original problem. What i also noticed is when you requesting data from a none exiting node you do not get any data but the following error in your Vera controller log file:
Open a terminal like putty -> new connection to your Vera's IP address login with username root and the WIFI password and give this command
tail -f /var/log/cmh/LuaUPnP.logThe error line you might see is this one (the second line is yellow marked)
50 01/17/16 15:07:28.915 luup_log:64: Arduino: Log: read: 50-50-0 s=255,c=3,t=12,pt=0,l=3,sg=0:0.2 <0x6011> 02 01/17/16 15:07:28.918 luup_log:64: Arduino: Incoming internal command '50;255;3;0;12;0.2' discarded for child: nil <0x6011>So it might help to:
- start MySensors inclusion mode
- give a reset on your Arduino
- wait to see MySensors does find new nodes
- press stop inclusion
- wait until Vera is ready again
- press reload
- reset your Arduino again and make sure the MySensor node shows the corrent version information
Tried my hypothesis above but same error. What made some different now was to add a second cap of 10uF to the radio... still nog good, but at least after some tries I now receive the V_VAR1.
@sundberg84
Can your code be used on 1.5.1 ??
I need to get Temp Values from Vera. to my PID controller -
No - code is > 1.6b
@clio75 I couldnt find out what my problem was... got tired of it and uploaded same sketch so complete new set of hardware... and now its working so my occlusion was bad hardware. -
@sundberg84
Thanx for your reply,Do you know where I can find one example for getting variables from Vera ?
I have tried searching, but can't seem to find any :(
Thanx -
In the library you can use timeawaresensor to recieve time
https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/TimeAwareSensorThe raingauge, WaterMeterPulseSensor and Power meter to recieve V_VAR1
@BartE: Thank you for your corrections to the code. I changed that.
Now the sketch works. All I did is to add a new repeaternode between the gateway and the receiving node. It was definetly a hardware problem (or the problem was solved in 1.5.3 update).
The LED_Node_var sketch works!
in the advanced tab all the way down at the bottom there are should be Variable1. Put a value in the field and save.
the next time your device requests the variable, the new value will be sent. -
the next time your device requests the variable, the new value will be sent.@patrick-schaerer said:
the next time your device requests the variable, the new value will be sent.Thanks, though so, too.
So the next question is, is it possible to add variables to sensor types that don't have those to begin with? In my case I'd like to add few variables to window covers (S_COVER in http://www.mysensors.org/download/serial_api_15). Can't test now, but would this gw.present(CHILD_ID_OF_BLINDS, V_VAR1) work in adding this property to the blinds? -
It should work. The variable1 appears in vera after the sensor had requested var1. (But Im not completely shure about that ... )
Oh yeah, works as you suggested. Thanks!
First I didn't get it to work, but re-reading your answer solved it. One really needs to request the variable to make it appear in the controller (Vera, that is in this case). -
On my newest project I have several sensors on the same node. Some of those sensors demand values on Var1 and Var2.
The code works fine so far, but I have to write those values all in the same number of digits. (sorry for my english) For example:
Sensor 1 has V_Var1 422
Sensor 2 has V_Var1 20
In order to get the right value on my node I must write the value on Sensor2 in Vera like this: 020
Otherwise Sensor 2 would receive a V_Var1 of 420.
Also I had to write a workaround for the incoming message of the switch states. I receive a String and check if the first value is asci 48 for 0 or asci 49 for 1It looks to me that some memory in receiving values is left after a value is received. Is it possible to clear that memory?
Here is the code I am talking about:
/** * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* * * REVISION HISTORY * Version 1.0 - Henrik Ekblad */ #define SKETCH_NAME "Bewässerung" #define SKETCH_VERSION "0.7a" #include <MySensor.h> #include <SPI.h> #include "DHT.h" #include <Wire.h> #include <BH1750.h> DHT dht; BH1750 lightMeter; int dhtpin = 47; int strom_beet_pin = 48; int first_hum_pin = 0; int first_temp_pin = 4; int first_valve_pin = 43; unsigned long timer_manual; unsigned long timer_umgebung; unsigned long timer_beet; unsigned long zeit_umgebung = 30; unsigned long zeit_beet = 50; unsigned long zeit_manual = 60; unsigned int helligkeit = 700; // Schwellenwert für Licht bei Bewässerung int feuchtigkeit = 50; // Schwellenwert für Erdfeuchtigkeit bei Bewässerung int temperatur = 25; //Schwellenwert für Erdtemperatur bei Bewässerung // 0 wasser ein, 1-4 hum, 5-8 temp, 9-12 valve, 13 DHT temp, 14 DHT hum, 15 light float beet_data[16]; //definitions for mySensors #define DHT_TEMP_ID 13 #define DHT_HUM_ID 14 #define LIGHT_ID 15 //Initialize MySensors MyTransportNRF24 transport(49, 53); MySensor gw(transport); MyMessage msg_temp(DHT_TEMP_ID, V_TEMP); MyMessage msg_hum(DHT_HUM_ID, V_HUM); MyMessage msg_light(LIGHT_ID, V_LIGHT_LEVEL); MyMessage msg_hum1(1,V_HUM); MyMessage msg_hum2(2,V_HUM); MyMessage msg_hum3(3,V_HUM); MyMessage msg_hum4(4,V_HUM); MyMessage msg_temp1 (5,V_TEMP); MyMessage msg_temp2 (6,V_TEMP); MyMessage msg_temp3 (7,V_TEMP); MyMessage msg_temp4 (8,V_TEMP); MyMessage msg_valve1 (9,V_LIGHT); MyMessage msg_valve2 (10,V_LIGHT); MyMessage msg_valve3 (11,V_LIGHT); MyMessage msg_valve4 (12,V_LIGHT); //Initialize mySensor Variables MyMessage msg_zeit_umgebung(DHT_TEMP_ID, V_VAR1); MyMessage msg_helligkeit(LIGHT_ID, V_VAR1); MyMessage msg_feuchtigkeit(1, V_VAR1); MyMessage msg_zeit_beet(1, V_VAR2); MyMessage msg_temperatur(5, V_VAR1); MyMessage msg_zeit_manual(9, V_VAR1); void setup() { // put your setup code here, to run once: Serial.begin(115200); Serial1.begin(115200); gw.begin(incomingMessage); gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION); lightMeter.begin(); dht.setup(dhtpin); pinMode(strom_beet_pin, OUTPUT); gw.present(DHT_TEMP_ID, S_TEMP); gw.present(DHT_HUM_ID, S_HUM); gw.present(LIGHT_ID, S_LIGHT_LEVEL); int i=0; for ( i=0;i<4;i++) { pinMode(first_valve_pin+i,OUTPUT); gw.present(i+1,S_HUM); gw.present(i+5,S_TEMP); gw.present(i+9, S_LIGHT); digitalWrite(first_valve_pin+i,HIGH); } getVariables(); timer_umgebung = millis()-zeit_umgebung*1000; timer_beet = millis()-zeit_beet*1000; Serial.println("Initialized"); } void loop() { gw.process(); // Abfrage der Umgebungsdaten if (zeit_umgebung*1000 <= millis()- timer_umgebung) { umgebung(); timer_umgebung = millis(); Ausgabe(); } //Abfrage der Beetdaten und evtl. Wässerung if (zeit_beet*1000 <= millis() - timer_beet) { beet(); send_beet_data(); wassern_entscheid(); timer_beet = millis(); getVariables(); } for (int i=0;i<4;i++) { if (beet_data[9+i] == HIGH) { beet(); wassern_entscheid(); } } // Manuelle Wässerung nach zeit_manual ausschalten if (zeit_manual*1000 <= millis() - timer_manual && beet_data[0] == HIGH) { Serial.println("Manual time is up"); for (int i=0;i<4;i++) { beet_data[i+9] = LOW; wasser(i,LOW); } beet_data[0] = LOW; } // Alle Timer nach Overflow von millis() zurücksetzen if (millis() < timer_umgebung) { timer_umgebung = millis(); timer_beet = millis(); timer_manual = millis(); } } void getVariables() { gw.request(DHT_TEMP_ID, V_VAR1); gw.request(LIGHT_ID, V_VAR1); gw.request(1, V_VAR1); gw.request(1, V_VAR2); gw.request(5, V_VAR1); gw.request(9, V_VAR1); } void wassern_entscheid() { /* kriterien: * Morgen oder Abend d.h. Lux unter bestimmtem Wert * Feuchtigkeit Beet unter bestimmtem Wert * Temperatur Beet über bestimmtem Wert ? */ if (beet_data[0] == HIGH) { Serial.println("Manual Valve override"); } else { if (beet_data[15] < helligkeit) { for (int i=0;i<4;i++) { if (beet_data[i+1] < feuchtigkeit) { if (beet_data[i+9] == LOW) wasser(i,HIGH); } else { if (beet_data[i+9] == HIGH) wasser(i,LOW); } } } else { for (int i=0;i<4;i++) { if (beet_data[i+9] == HIGH) wasser(i,LOW); } } } } void umgebung() { float temperature = dht.getTemperature(); float humidity = dht.getHumidity(); uint16_t lux = lightMeter.readLightLevel(); gw.send(msg_temp.set(temperature,1)); gw.send(msg_hum.set(humidity,1)); gw.send(msg_light.set(lux,1)); beet_data[13] = temperature; beet_data[14] = humidity; beet_data[15] = lux; } void beet() { digitalWrite(strom_beet_pin, HIGH); gw.wait(2000); int i=0; for(i = 0;i<4;i++) { int hum = analogRead(first_hum_pin+i); hum = map(hum,1023,0,0,100); beet_data[1+i] = hum; int rawvoltage= analogRead(first_temp_pin+i); rawvoltage = 1024 - rawvoltage; float temp= ((rawvoltage/1024.0) * 5000/10)-273.15; beet_data[5+i] = temp; } digitalWrite(strom_beet_pin, LOW); } void send_beet_data() { gw.send(msg_hum1.set(beet_data[1],1)); gw.send(msg_hum2.set(beet_data[2],1)); gw.send(msg_hum3.set(beet_data[3],1)); gw.send(msg_hum4.set(beet_data[4],1)); gw.send(msg_temp1.set(beet_data[5],1)); gw.send(msg_temp2.set(beet_data[6],1)); gw.send(msg_temp3.set(beet_data[7],1)); gw.send(msg_temp4.set(beet_data[8],1)); Serial.println("beet data sent"); } void Ausgabe() { Serial.print("Hum: "); for (int i=0; i<4; i++) { Serial.print(beet_data[i+1]); Serial.print(" "); } Serial.print(" Temp: "); for (int i=0; i<4; i++) { Serial.print(beet_data[i+5]); Serial.print(" "); } Serial.print(" Valve: "); for (int i=0; i<4; i++) { Serial.print(beet_data[i+9]); Serial.print(" "); } Serial.print(" Zeit Beet: "); Serial.print(millis() - timer_beet); Serial.println("finished"); //Variabeln anzeigen Serial.print("Variables "); Serial.print(zeit_umgebung); Serial.print(" "); Serial.print(zeit_beet); Serial.print(" "); Serial.print(zeit_manual); Serial.print(" "); Serial.print(feuchtigkeit); Serial.print(" "); Serial.print(helligkeit); Serial.print(" "); Serial.print(temperatur); Serial.println(" "); } void wasser(int valve_nr,boolean state) { digitalWrite(first_valve_pin+valve_nr,!state); beet_data[valve_nr+9] = state; if (valve_nr == 0) gw.send(msg_valve1.set(state,1)); if (valve_nr == 1) gw.send(msg_valve2.set(state,1)); if (valve_nr == 2) gw.send(msg_valve3.set(state,1)); if (valve_nr == 3) gw.send(msg_valve4.set(state,1)); } void incomingMessage(const MyMessage &message) { int i; for (i=0;i<4;i++) { if (message.sensor == i+9) { if (message.type == V_LIGHT) { char buffer[10]; char* empfang = message.getString(buffer); int asci = buffer[0]; boolean state; if (asci == 49) state=HIGH; if (asci == 48) state = LOW; wasser(i,state); if (state == HIGH) beet_data[0] = HIGH; timer_manual = millis(); Serial.print(" Valve: "); Serial.print(i+9); //Serial.print(" Empfangen: "); //Serial.print(asci); Serial.print(" State: "); Serial.println(state); } } } if (message.sensor == DHT_TEMP_ID && message.type == V_VAR1) zeit_umgebung = message.getULong(); if (message.sensor == LIGHT_ID && message.type == V_VAR1) helligkeit = message.getInt(); if (message.sensor == 1 && message.type == V_VAR1) feuchtigkeit = message.getInt(); if (message.sensor == 1 && message.type == V_VAR2) zeit_beet = message.getULong(); if (message.sensor == 5 && message.type == V_VAR1) temperatur = message.getInt(); if (message.sensor == 9 && message.type == V_VAR1) zeit_manual = message.getULong(); } -
