  3. Vera
  4. Sending Variables to a arduino switch
28 Posts 8 Posters 15.5k Views 6 Watching
  • sundberg84S
    sundberg84S
    What is similar in our sketches that does not work is that we use pin 3. I have seen some post with relays that it worked if you move to pin 4. Don't know why but I will try this tonight. Worth a shot...
    • BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      @patrick-schaerer and @sundberg84
      I've compiled your code and uploaded in my Arduino to debug your issue. What i noticed is that the sketch worked on my side, two remarks on the code snipped:
      • why switching back to 9600 baud and not just setting your terminal to 115200 baud.
      • line 83 contains an error i think the + should be removed so it becomes this line:
      LED_Level = gwLEDLevel;
      But this will not solve you original problem. What i also noticed is when you requesting data from a none exiting node you do not get any data but the following error in your Vera controller log file:
      Open a terminal like putty -> new connection to your Vera's IP address login with username root and the WIFI password and give this command
      tail -f /var/log/cmh/LuaUPnP.log
      The error line you might see is this one (the second line is yellow marked)
      50      01/17/16 15:07:28.915   luup_log:64: Arduino: Log: read: 50-50-0 s=255,c=3,t=12,pt=0,l=3,sg=0:0.2 <0x6011>
      02      01/17/16 15:07:28.918   luup_log:64: Arduino: Incoming internal command '50;255;3;0;12;0.2' discarded for child: nil <0x6011>
      So it might help to:
      • start MySensors inclusion mode
      • give a reset on your Arduino
      • wait to see MySensors does find new nodes
      • press stop inclusion
      • wait until Vera is ready again
      • press reload
      • reset your Arduino again and make sure the MySensor node shows the corrent version information
      • sundberg84S
        sundberg84S
        Tried my hypothesis above but same error. What made some different now was to add a second cap of 10uF to the radio... still nog good, but at least after some tries I now receive the V_VAR1.
        • clio75C
          clio75C
          clio75
          @sundberg84
          Can your code be used on 1.5.1 ??
          I need to get Temp Values from Vera. to my PID controller
          • sundberg84S
            sundberg84S
            No - code is > 1.6b
            @clio75 I couldnt find out what my problem was... got tired of it and uploaded same sketch so complete new set of hardware... and now its working so my occlusion was bad hardware.
            • clio75C
              clio75C
              clio75
              @sundberg84
              Thanx for your reply,
              Do you know where I can find one example for getting variables from Vera ?
              I have tried searching, but can't seem to find any :(
              Thanx
              • sundberg84S
                sundberg84S
                In the library you can use timeawaresensor to recieve time
                https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/TimeAwareSensor
                The raingauge, WaterMeterPulseSensor and Power meter to recieve V_VAR1
                • P
                  P
                  patrick schaerer
                  @BartE: Thank you for your corrections to the code. I changed that.
                  Now the sketch works. All I did is to add a new repeaternode between the gateway and the receiving node. It was definetly a hardware problem (or the problem was solved in 1.5.3 update).
                  The LED_Node_var sketch works!
                  • NuubiN
                    NuubiN
                    Nuubi
                    Eh, how do you define or set a value for, let's say, V_VAR1 in Vera?
                    • P
                      P
                      patrick schaerer
                      in the advanced tab all the way down at the bottom there are should be Variable1. Put a value in the field and save.
                      the next time your device requests the variable, the new value will be sent.
                      NuubiN 1 Reply Last reply
                      • P patrick schaerer
                        NuubiN
                        NuubiN
                        Nuubi
                        Thanks, though so, too.
                        So the next question is, is it possible to add variables to sensor types that don't have those to begin with? In my case I'd like to add few variables to window covers (S_COVER in http://www.mysensors.org/download/serial_api_15). Can't test now, but would this gw.present(CHILD_ID_OF_BLINDS, V_VAR1) work in adding this property to the blinds?
                        • P
                          P
                          patrick schaerer
                          It should work. The variable1 appears in vera after the sensor had requested var1. (But Im not completely shure about that ... )
                            NuubiN
                            NuubiN
                            Nuubi
                            Oh yeah, works as you suggested. Thanks!
                            First I didn't get it to work, but re-reading your answer solved it. One really needs to request the variable to make it appear in the controller (Vera, that is in this case).
                            • P
                              P
                              patrick schaerer
                              On my newest project I have several sensors on the same node. Some of those sensors demand values on Var1 and Var2.
                              The code works fine so far, but I have to write those values all in the same number of digits. (sorry for my english) For example:
                              Sensor 1 has V_Var1 422
                              Sensor 2 has V_Var1 20
                              In order to get the right value on my node I must write the value on Sensor2 in Vera like this: 020
                              Otherwise Sensor 2 would receive a V_Var1 of 420.
                              Also I had to write a workaround for the incoming message of the switch states. I receive a String and check if the first value is asci 48 for 0 or asci 49 for 1
                              It looks to me that some memory in receiving values is left after a value is received. Is it possible to clear that memory?
                              Here is the code I am talking about:
                               * Version 1.0 - Henrik Ekblad
                              #define SKETCH_NAME "Bewässerung"
                              #define SKETCH_VERSION "0.7a"
                              #include "DHT.h"
                              #include <BH1750.h>
                              DHT dht;
                              BH1750 lightMeter;
                              int dhtpin = 47;
                              int strom_beet_pin = 48;
                              int first_hum_pin = 0;
                              int first_temp_pin = 4;
                              int first_valve_pin = 43;
                              unsigned long timer_manual;
                              unsigned long timer_umgebung;
                              unsigned long timer_beet;
                              unsigned long zeit_umgebung = 30;
                              unsigned long zeit_beet = 50;
                              unsigned long zeit_manual = 60;
                              unsigned int helligkeit = 700; // Schwellenwert für Licht bei Bewässerung
                              int feuchtigkeit = 50; // Schwellenwert für Erdfeuchtigkeit bei Bewässerung
                              int temperatur = 25; //Schwellenwert für Erdtemperatur bei Bewässerung
                              // 0 wasser ein, 1-4 hum, 5-8 temp, 9-12 valve, 13 DHT temp, 14 DHT hum, 15 light
                              float beet_data[16];
                              //definitions for mySensors
                              #define DHT_TEMP_ID 13
                              #define DHT_HUM_ID 14
                              #define LIGHT_ID 15
                              //Initialize MySensors
                              MyTransportNRF24 transport(49, 53);
                              MySensor gw(transport);
                              MyMessage msg_temp(DHT_TEMP_ID, V_TEMP);
                              MyMessage msg_hum(DHT_HUM_ID, V_HUM);
                              MyMessage msg_light(LIGHT_ID, V_LIGHT_LEVEL);
                              MyMessage msg_hum1(1,V_HUM);
                              MyMessage msg_hum2(2,V_HUM);
                              MyMessage msg_hum3(3,V_HUM);
                              MyMessage msg_hum4(4,V_HUM);
                              MyMessage msg_temp1 (5,V_TEMP);
                              MyMessage msg_temp2 (6,V_TEMP);
                              MyMessage msg_temp3 (7,V_TEMP);
                              MyMessage msg_temp4 (8,V_TEMP);
                              MyMessage msg_valve1 (9,V_LIGHT);
                              MyMessage msg_valve2 (10,V_LIGHT);
                              MyMessage msg_valve3 (11,V_LIGHT);
                              MyMessage msg_valve4 (12,V_LIGHT);
                              //Initialize mySensor Variables
                              MyMessage msg_zeit_umgebung(DHT_TEMP_ID, V_VAR1);
                              MyMessage msg_helligkeit(LIGHT_ID, V_VAR1);
                              MyMessage msg_feuchtigkeit(1, V_VAR1);
                              MyMessage msg_zeit_beet(1, V_VAR2);
                              MyMessage msg_temperatur(5, V_VAR1);
                              MyMessage msg_zeit_manual(9, V_VAR1);
                                Serial1.begin(115200);
                                gw.begin(incomingMessage);
                                lightMeter.begin();
                                dht.setup(dhtpin);
                                pinMode(strom_beet_pin, OUTPUT);
                                gw.present(DHT_TEMP_ID, S_TEMP);
                                gw.present(DHT_HUM_ID, S_HUM);
                                gw.present(LIGHT_ID, S_LIGHT_LEVEL);
                                int i=0;
                                for ( i=0;i<4;i++) {
                                  pinMode(first_valve_pin+i,OUTPUT);
                                  gw.present(i+1,S_HUM);
                                  gw.present(i+5,S_TEMP);
                                  gw.present(i+9, S_LIGHT);
                                  digitalWrite(first_valve_pin+i,HIGH);
                                getVariables();
                                timer_umgebung = millis()-zeit_umgebung*1000;
                                timer_beet = millis()-zeit_beet*1000;
                                Serial.println("Initialized");
                                // Abfrage der Umgebungsdaten
                              if (zeit_umgebung*1000 <= millis()- timer_umgebung) {
                                umgebung();
                                timer_umgebung = millis();
                                Ausgabe();
                              //Abfrage der Beetdaten und evtl. Wässerung
                              if (zeit_beet*1000 <= millis() - timer_beet) {
                                beet();
                                send_beet_data();
                                wassern_entscheid();
                                timer_beet = millis();
                                getVariables();
                              for (int i=0;i<4;i++) {
                                if (beet_data[9+i] == HIGH) {
                                beet();
                              // Manuelle Wässerung nach zeit_manual ausschalten
                              if (zeit_manual*1000 <= millis() - timer_manual && beet_data[0] == HIGH) {
                                Serial.println("Manual time is up");
                                  beet_data[i+9] = LOW;
                                  wasser(i,LOW);
                                 beet_data[0] = LOW;
                              // Alle Timer nach Overflow von millis() zurücksetzen
                              if (millis() < timer_umgebung) {
                                timer_manual = millis();
                              void getVariables() {
                                gw.request(DHT_TEMP_ID, V_VAR1);
                                gw.request(LIGHT_ID, V_VAR1);
                                gw.request(1, V_VAR1);
                                gw.request(1, V_VAR2);
                                gw.request(5, V_VAR1);
                                gw.request(9, V_VAR1);
                              void wassern_entscheid() {
                                /* kriterien:
                                 *  Morgen oder Abend d.h. Lux unter bestimmtem Wert
                                 *  Feuchtigkeit Beet unter bestimmtem Wert
                                 *  Temperatur Beet über bestimmtem Wert ?
                                 if (beet_data[0] == HIGH) {
                                  Serial.println("Manual Valve override");
                                 else {
                                 if (beet_data[15] < helligkeit) {
                                    if (beet_data[i+1] < feuchtigkeit) {
                                      if (beet_data[i+9] == LOW) wasser(i,HIGH);
                                    else {
                                      if (beet_data[i+9] == HIGH) wasser(i,LOW);
                                 else {
                              void umgebung() {
                                uint16_t lux = lightMeter.readLightLevel();
                                gw.send(msg_temp.set(temperature,1));
                                gw.send(msg_hum.set(humidity,1));
                                gw.send(msg_light.set(lux,1));
                                beet_data[13] = temperature;
                                beet_data[14] = humidity;
                                beet_data[15] = lux;
                              void beet() {
                                digitalWrite(strom_beet_pin, HIGH);
                                gw.wait(2000);
                                int i=0;
                                for(i = 0;i<4;i++) {
                                  int hum = analogRead(first_hum_pin+i);
                                  hum = map(hum,1023,0,0,100);
                                  beet_data[1+i] = hum;
                                  int rawvoltage= analogRead(first_temp_pin+i);
                                  rawvoltage = 1024 - rawvoltage;
                                  float temp= ((rawvoltage/1024.0) * 5000/10)-273.15;
                                  beet_data[5+i] = temp;
                                digitalWrite(strom_beet_pin, LOW);
                              void send_beet_data() {
                                  gw.send(msg_hum1.set(beet_data[1],1));
                                  gw.send(msg_hum2.set(beet_data[2],1));
                                  gw.send(msg_hum3.set(beet_data[3],1));
                                  gw.send(msg_hum4.set(beet_data[4],1));
                                  gw.send(msg_temp1.set(beet_data[5],1));
                                  gw.send(msg_temp2.set(beet_data[6],1));
                                  gw.send(msg_temp3.set(beet_data[7],1));
                                  gw.send(msg_temp4.set(beet_data[8],1));
                                  Serial.println("beet data sent");
                              void Ausgabe() {
                                Serial.print("Hum: ");
                               for (int i=0; i<4; i++) {
                                Serial.print(beet_data[i+1]);
                                Serial.print(" ");
                               Serial.print(" Temp: ");
                                Serial.print(beet_data[i+5]);
                                Serial.print(" ");
                               Serial.print(" Valve: ");
                                Serial.print(beet_data[i+9]);
                                Serial.print(" ");
                               Serial.print(" Zeit Beet: ");
                               Serial.print(millis() - timer_beet);
                               Serial.println("finished");
                               //Variabeln anzeigen
                                 Serial.print("Variables ");
                                 Serial.print(zeit_umgebung);
                                 Serial.print("  ");
                                 Serial.print(zeit_beet);
                                 Serial.print("  ");
                                 Serial.print(zeit_manual);
                                 Serial.print("  ");
                                 Serial.print(feuchtigkeit);
                                 Serial.print("  ");
                                 Serial.print(helligkeit);
                                 Serial.print("  ");
                                 Serial.print(temperatur);
                                 Serial.println("  ");
                              void wasser(int valve_nr,boolean state) {
                                  digitalWrite(first_valve_pin+valve_nr,!state);
                                  beet_data[valve_nr+9] = state;
                                  if (valve_nr == 0) gw.send(msg_valve1.set(state,1));
                                  if (valve_nr == 1) gw.send(msg_valve2.set(state,1));
                                  if (valve_nr == 2) gw.send(msg_valve3.set(state,1));
                                  if (valve_nr == 3) gw.send(msg_valve4.set(state,1));
                                int i;
                                for (i=0;i<4;i++) {
                                   if (message.sensor == i+9) {
                                      char buffer[10];
                                      char* empfang = message.getString(buffer);
                                      int asci = buffer[0];
                                      boolean state;
                                      if (asci == 49) state=HIGH;
                                      if (asci == 48) state = LOW;
                                      wasser(i,state);
                                      if (state == HIGH) beet_data[0] = HIGH;
                                      Serial.print(i+9);
                                      //Serial.print(" Empfangen:  ");
                                      //Serial.print(asci);
                                      Serial.print(" State: ");
                                      Serial.println(state);
                                if (message.sensor == DHT_TEMP_ID && message.type == V_VAR1) zeit_umgebung = message.getULong();
                                if (message.sensor == LIGHT_ID && message.type == V_VAR1) helligkeit = message.getInt();
                                if (message.sensor == 1 && message.type == V_VAR1) feuchtigkeit = message.getInt();
                                if (message.sensor == 1 && message.type == V_VAR2) zeit_beet = message.getULong();
                                if (message.sensor == 5 && message.type == V_VAR1) temperatur = message.getInt();
                                if (message.sensor == 9 && message.type == V_VAR1) zeit_manual = message.getULong();
                              • MagiskeM
                                MagiskeM
                                Magiske
                                I have started to use ESP8266 for some of my devices with my Vera. So a combination of mysensors and esp's.
                                How would I go around reading values via WIFI only(esp8266) ? I can do a HTTP request to put values but how would I do a READ ?
                                /M
                                  The ESP gateway will send any incoming (radio messages) or locally sent messages on to the socket you have opened from the controller.
                                  The ESP gateway doesn't differ from the Ethernet variant in any way (from the controllers point of view).
