  3. Home Assistant
  4. Windows and configuration.yaml
11 Posts 5 Posters 6.4k Views 5 Watching
  • L Offline
    L Offline
    Lemme
    Hi
    A am trying to configure Home Assistant on Windows, but it does not detect the GW. In configuration.yaml I have these lines:
    Example configuration.yaml entry
    mysensors:
    gateways:
    - port: com5
    version: '1.5'
    What have I done wrong? Has anybody a working example that they want to share?
    Br
    Flemming
    • D Offline
      drock1985
      Might be the formatting of your configuration.yaml file. Spacing is very important. Try opening in notepad or a more text base/programmer environment (ex, Notepad++) and do a copy/paste from the info on the HA website. Edit as necessary.
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      • L Offline
        L Offline
        Lemme
        OK - I will check the formatting.
        But the example file are Linux based, I use Windows, and my serial port are Com 5.
        I would be nice if someone with a Windows configuration would share their working config. One thing is the formatting, but I am not sure that I have written the correct com5 statement.
        Br
        Flemming
        • D Offline
          drock1985
          wrote on last edited by drock1985
          Yes and no. They are formatted for the YAML language; which is basically a series of lines with the proper spaces (not tabs) in them.
          You can use any plain text editor, as long as you obey the spaces. A good program to start with is Notepad++ or Notepad2 (make a copy first) and copy/paste the example from the home-assistant wiki/info.
          As for the Windows entry to point to a serial port i'm afraid I can't help you there. Haven't tried this with Windows yet.
          My Projects
          2 Door Chime Sensor
          • L Lemme
            Br
            Flemming
            martinhjelmareM Offline
            martinhjelmare
            @Lemme
            Hi!
            If you have python and pyserial installed you can use pyserial to list the available ports.
            https://pythonhosted.org/pyserial/shortintro.html#testing-ports
            I think that COM# (COM5, for example) is correct though. The device manager in Windows is another bet.
            • L Offline
              L Offline
              Lemme
              Hi again
              Thanks - I tried to clean up using a YAML translator, and using Notepad2.
              I forgot to set the baudrate to 115200 in Windows, changed that, but still no luck.
              I give up, and continue with Domoticz.
              Thanks for helping.
              • L Lemme
                Hi again
                Thanks for helping.
                martinhjelmare
                @Lemme
                No problem.
                An advice on the way, would be to look at the log output and activate debug mode wherever possible when troubleshooting. A log and as much background info as possible will also give those you ask for help a better chance of helping you solve the problem.
                • Lee GroomL Offline
                  Lee GroomL Offline
                  Lee Groom
                  I am using mysensors/home assistant on windows.....its working fine....here is my conf...
                  mysensors:
                  gateways:
                  - port: 'COM4'
                  baud_rate: 115200
                  debug: true
                  version: '1.5'
                  optimistic: 'true'
                  Hope this helps...
                  Lee
                  • G Offline
                    G Offline
                    Gefkuz
                    sorry to reply to this old topic, but I have the same problem.
                    my config yaml :
                    mysensors:
                    gateways:
                    • device: 'COM5'
                      baud_rate: 115200
                      debug: true
                      version: '1.5'
                      optimistic: 'true'
                    debug lines on python repeating this :
                    INFO:mysensors.mysensors:Trying to connect to COM5
                    INFO:mysensors.mysensors:COM5 is open...
                    INFO:mysensors.mysensors:Connected to COM5
                    ERROR:mysensors.mysensors:Serial exception
                    File "C:\Users\Fabien\AppData\Roaming.homeassistant\deps\mysensors\mysensors.
                    py", line 380, in run
                    line = self.serial.readline()
                    File "C:\Users\Fabien\AppData\Roaming.homeassistant\deps\serial\serialwin32.p
                    y", line 236, in read
                    raise SerialException("ReadFile failed (%s)" % ctypes.WinError())
                    serial.serialutil.SerialException: ReadFile failed ([WinError 6] Descripteur non
                    valide)
                    File "C:\Users\Fabien\AppData\Local\Programs\Python\Python35\lib\runpy.py", li
                    ne 184, in run_module_as_main
                    "main", mod_spec)
                    ne 85, in run_code
                    exec(code, run_globals)
                    File "C:\Users\Fabien\AppData\Local\Programs\Python\Python35\lib\site-packages
                    \homeassistant_main
                    .py", line 335, in <module>
                    sys.exit(main())
                    \homeassistant_main
                    .py", line 327, in main
                    exit_code = setup_and_run_hass(config_dir, args)
                    \homeassistant_main_.py", line 225, in setup_and_run_hass
                    subprocess.check_call(args)
                    File "C:\Users\Fabien\AppData\Local\Programs\Python\Python35\lib\subprocess.py
                    ", line 576, in check_call
                    retcode = call(*popenargs, **kwargs)
                    ", line 559, in call
                    return p.wait(timeout=timeout)
                    ", line 1275, in wait
                    timeout_millis)
                    Some one have an idea?
                    • G Gefkuz
                      my config yaml :
                      mysensors:
                      gateways:
                      • device: 'COM5'
                        baud_rate: 115200
                        debug: true
                        version: '1.5'
                        optimistic: 'true'
                      valide)
                      "main", mod_spec)
                      ne 85, in run_code
                      \homeassistant_main
                      sys.exit(main())
                      \homeassistant_main
                      timeout_millis)
                      martinhjelmare
                      @Gefkuz
                      This looks like a problem with pyserial and not with your configuration. User bazis posted a similar problem in the middle of this thread:
                      https://github.com/home-assistant/home-assistant/issues/868
                      It was solved by installing 32 bit version of python.
                      For the record, what version of pyserial are you using?
                      G 1 Reply Last reply
                        @Gefkuz
                        G Offline
                        G Offline
                        Gefkuz
                        @martinhjelmare Hi, with python 32bit, it's perfect. Thank you.
                        12.1k
