  3. Home Assistant
  4. Windows and configuration.yaml
11 Posts 5 Posters 6.8k Views 5 Watching
  • D
    drock1985
    Might be the formatting of your configuration.yaml file. Spacing is very important. Try opening in notepad or a more text base/programmer environment (ex, Notepad++) and do a copy/paste from the info on the HA website. Edit as necessary.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • L
      L
      Lemme
      OK - I will check the formatting.
      But the example file are Linux based, I use Windows, and my serial port are Com 5.
      I would be nice if someone with a Windows configuration would share their working config. One thing is the formatting, but I am not sure that I have written the correct com5 statement.
      Br
      Flemming
      • D
        drock1985
        wrote on last edited by drock1985
        Yes and no. They are formatted for the YAML language; which is basically a series of lines with the proper spaces (not tabs) in them.
        You can use any plain text editor, as long as you obey the spaces. A good program to start with is Notepad++ or Notepad2 (make a copy first) and copy/paste the example from the home-assistant wiki/info.
        As for the Windows entry to point to a serial port i'm afraid I can't help you there. Haven't tried this with Windows yet.
        My Projects
        2 Door Chime Sensor
        • L Lemme
          Br
          Flemming
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Lemme
          Hi!
          If you have python and pyserial installed you can use pyserial to list the available ports.
          https://pythonhosted.org/pyserial/shortintro.html#testing-ports
          I think that COM# (COM5, for example) is correct though. The device manager in Windows is another bet.
          • L
            L
            Lemme
            Hi again
            Thanks - I tried to clean up using a YAML translator, and using Notepad2.
            I forgot to set the baudrate to 115200 in Windows, changed that, but still no luck.
            I give up, and continue with Domoticz.
            Thanks for helping.
            • L Lemme
              Hi again
              Thanks for helping.
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @Lemme
              No problem.
              An advice on the way, would be to look at the log output and activate debug mode wherever possible when troubleshooting. A log and as much background info as possible will also give those you ask for help a better chance of helping you solve the problem.
              • Lee GroomL
                Lee GroomL
                Lee Groom
                I am using mysensors/home assistant on windows.....its working fine....here is my conf...
                mysensors:
                gateways:
                - port: 'COM4'
                baud_rate: 115200
                debug: true
                version: '1.5'
                optimistic: 'true'
                Hope this helps...
                Lee
                • G
                  G
                  Gefkuz
                  sorry to reply to this old topic, but I have the same problem.
                  my config yaml :
                  mysensors:
                  gateways:
                  • device: 'COM5'
                    baud_rate: 115200
                    debug: true
                    version: '1.5'
                    optimistic: 'true'
                  debug lines on python repeating this :
                  INFO:mysensors.mysensors:Trying to connect to COM5
                  INFO:mysensors.mysensors:COM5 is open...
                  INFO:mysensors.mysensors:Connected to COM5
                  ERROR:mysensors.mysensors:Serial exception
                  File "C:\Users\Fabien\AppData\Roaming.homeassistant\deps\mysensors\mysensors.
                  py", line 380, in run
                  line = self.serial.readline()
                  File "C:\Users\Fabien\AppData\Roaming.homeassistant\deps\serial\serialwin32.p
                  y", line 236, in read
                  raise SerialException("ReadFile failed (%s)" % ctypes.WinError())
                  serial.serialutil.SerialException: ReadFile failed ([WinError 6] Descripteur non
                  valide)
                  File "C:\Users\Fabien\AppData\Local\Programs\Python\Python35\lib\runpy.py", li
                  ne 184, in run_module_as_main
                  "main", mod_spec)
                  ne 85, in run_code
                  exec(code, run_globals)
                  File "C:\Users\Fabien\AppData\Local\Programs\Python\Python35\lib\site-packages
                  \homeassistant_main
                  .py", line 335, in <module>
                  sys.exit(main())
                  \homeassistant_main
                  .py", line 327, in main
                  exit_code = setup_and_run_hass(config_dir, args)
                  \homeassistant_main_.py", line 225, in setup_and_run_hass
                  subprocess.check_call(args)
                  File "C:\Users\Fabien\AppData\Local\Programs\Python\Python35\lib\subprocess.py
                  ", line 576, in check_call
                  retcode = call(*popenargs, **kwargs)
                  ", line 559, in call
                  return p.wait(timeout=timeout)
                  ", line 1275, in wait
                  timeout_millis)
                  Some one have an idea?
                  • G Gefkuz
                    my config yaml :
                    mysensors:
                    gateways:
                    • device: 'COM5'
                      baud_rate: 115200
                      debug: true
                      version: '1.5'
                      optimistic: 'true'
                    valide)
                    "main", mod_spec)
                    ne 85, in run_code
                    \homeassistant_main
                    sys.exit(main())
                    \homeassistant_main
                    timeout_millis)
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @Gefkuz
                    This looks like a problem with pyserial and not with your configuration. User bazis posted a similar problem in the middle of this thread:
                    https://github.com/home-assistant/home-assistant/issues/868
                    It was solved by installing 32 bit version of python.
                    For the record, what version of pyserial are you using?
                    G 1 Reply Last reply
                      @Gefkuz
                      G
                      G
                      Gefkuz
                      @martinhjelmare Hi, with python 32bit, it's perfect. Thank you.
