  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 180.8k Views 23 Watching
  • S Samuel235
    @m26872 Ahh right okay, good job i caught your reply before burning it haha! So if i set it to 8MHz internal with 64ms delay and untick that divide by 8 option, that'll be good?
    m26872M
    m26872M
    m26872
    Yes. but don't forget to enable the boot reset vector.
    • S Samuel235
      m26872M
      m26872M
      m26872
      @samuel235 I have not checked if the bootloader size and baud rate matches fuse settings.
      S 1 Reply Last reply
        @m26872:
        • for bod=0v, problems could be flash corruption for instance..so it's good to know (it's explained in datasheet that for instance it ensures that a flash write is completely done before reset, I think it makes sense, plus I imagine that there are some internal things with voltage levels related stuff. but I'm not a guru on this....). So my interpretation is sometimes we don't care about it for sleepmode, for instance, and sometimes in wakeup, it's important or not, depending of tasks involved...
          maybe I should have said a good practice is to know what you do, lol!
        • for prescaler, are you asking for something like this : http://www.gammon.com.au/forum/?id=11497&reply=7#reply7
        • glad to share what I learn :)
        m26872M 1 Reply Last reply
        • scalzS scalz
          @m26872:
          m26872M
          m26872M
          m26872
          @scalz .
          l don't fulfil that either, lol! :smiley:
          Thanks for the prescaler info. Seems like a yes - it can be changed on-the-fly, but for me it's a No. I won't even dare to think of consequences for the rest of the software.
          • m26872M m26872
            Samuel235
            I'm not 100% sure of what you mean here, on the fuse calculator there is not an option to specify the baud rate.... As for the bootloader size, the calculator is set to "Boot Flash section size=2048 words Boot start address=$3800; [BOOTSZ=00]". As this is the highest it can be I'm assuming it is correct, however i will try and check the size of the MYSBootloader.hex size and see if it is below 2048 words (Is this what this setting means?).
            MySensors 2.1.1
            • S Samuel235
              m26872M
              m26872M
              m26872
              @samuel235 No, but bootloader and boards.txt must have same buad rate. I think you already have the correct though since 8MHz is pretty much standard clock speed. Slower clock would require lower buad rate.
              • m26872M m26872
                Samuel235
                @m26872 Is there a way to read the .hex file to see the specified baud rate before i go and brick the chip? Also, just to confirm, i have to burn the fuse settings in AVRDUDE then burn the bootloader with arduino IDE. Is there anything I'm failing to understand, i only have one more uC here at the moment and i don't want to brick several of them :(
                MySensors 2.1.1
                • S Samuel235
                  m26872M
                  m26872M
                  m26872
                  wrote on last edited by m26872
                  #127
                  @samuel235 Sorry, I can't help you further. I don't know for sure about these things.
                  • m26872M m26872
                    Samuel235
                    @m26872 - That is okay, I think I'm pretty safe to assume that it is correct as it is what is provided on Tekka's guide. So I'm going to attempt to burn the fuses at E2 D8 FE. Once I've done that (and it works fine), Arduino IDE should burn the bootloader onto the uC without an issue and then i can just upload a arduino sketch, right? o.O
                    MySensors 2.1.1
                      Samuel235
                      #129
                      I've just written the fuse settings and got this log report:
                      avrdude.exe: set SCK frequency to 187500 Hz
                      avrdude.exe: AVR device initialized and ready to accept instructions
                      avrdude.exe: Device signature = 0x1e950f
                      avrdude.exe: reading input file "0xE2"
                      avrdude.exe: writing lfuse (1 bytes):
                      Writing | ################################################## | 100% -0.00s
                      avrdude.exe: 1 bytes of lfuse written
                      avrdude.exe: verifying lfuse memory against 0xE2:
                      avrdude.exe: load data lfuse data from input file 0xE2:
                      avrdude.exe: input file 0xE2 contains 1 bytes
                      avrdude.exe: reading on-chip lfuse data:
                      avrdude.exe: verifying ...
                      avrdude.exe: 1 bytes of lfuse verified
                      avrdude.exe: reading input file "0xD8"
                      avrdude.exe: writing hfuse (1 bytes):
                      Writing | ################################################## | 100% 0.02s
                      avrdude.exe: 1 bytes of hfuse written
                      avrdude.exe: verifying hfuse memory against 0xD8:
                      avrdude.exe: load data hfuse data from input file 0xD8:
                      avrdude.exe: input file 0xD8 contains 1 bytes
                      avrdude.exe: reading on-chip hfuse data:
                      avrdude.exe: 1 bytes of hfuse verified
                      avrdude.exe: reading input file "0xFE"
                      avrdude.exe: writing efuse (1 bytes):
                      Writing |  ***failed;
                      ################################################## | 100% 0.09s
                      avrdude.exe: 1 bytes of efuse written
                      avrdude.exe: verifying efuse memory against 0xFE:
                      avrdude.exe: load data efuse data from input file 0xFE:
                      avrdude.exe: input file 0xFE contains 1 bytes
                      avrdude.exe: reading on-chip efuse data:
                      avrdude.exe: verification error, first mismatch at byte 0x0000
                                   0x06 != 0xfe
                      avrdude.exe: verification error; content mismatch
                      avrdude.exe done.  Thank you.
                      I then checked the fuses by reading them. I can confirm it has written the Low and the High fuse but as the log says, it failed to write the extended. So I went to the calculator site and read the following (This is what i was asking about hex vs binary for):
                      "Note that some numerical values refer to fuses containing undefined bits (set to '1' here). Depending on the target device these fuse bits will be read either as '0' or '1'. Verification errors will occur if the values are read back with undefined bits set to '0'. Everything is fine if the values read from the device are either the same as programmed, or the following values (undefined set to '0'): Extended: 0x06."
                      I then attempted to burn the bootloader, assuming the error is fine to skip (as the fuse calculator said), but it gave me the same error of:
                      avrdude: verification error, first mismatch at byte 0x0000
                               0x06 != 0xfe
                      So basically, telling me that my boards.txt is telling the IDE that the fuse should be FE, but its 06.
                      MySensors 2.1.1
                      • m26872M
                        m26872M
                        m26872
                        Looks like ext fuse is already 0x06 and you only need to change your board.txt to the same. I've never heard before that the 0xFE type of writing should work in avrdude/Arduino IDE.
                        • m26872M m26872
                          Samuel235
                          I went ahead and changed my board.txt to reflect 0x06, to check. It passed through and burnt the bootloader. However, if i try to upload a sketch (using the FTDI adapter that i have, this) I get a timing error. How do i upload a sketch to the chip with the ISP connection (just to test if my FTDI pins are wired incorrectly). This is my log from arduino IDE:
                          Sketch uses 12,610 bytes (41%) of program storage space. Maximum is 30,720 bytes.
                          Global variables use 398 bytes (19%) of dynamic memory, leaving 1,650 bytes for local variables. Maximum is 2,048 bytes.
                          avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7c
                          avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7c
                          "programmer is not responding" - I was asking myself "Would this mean that arduino IDE can't use avrdude for some reason?" but then i figured that it used it to burn the bootloader so that isnt right. Is it trying to find the ISP programmer and cant because i'm connected through FTDI maybe?
                          MySensors 2.1.1
                            Samuel235
                            I have just remembered that if you go to the file menu in Arduino IDE you get the option to upload using programmer. I have just done this through my SPI programmer, it has uploaded correctly. I will now solder the nRF module onto the board and i will report back with my results. Crosses fingers
                            MySensors 2.1.1
                              Samuel235
                              #133
                              BINGO!!
                              We have a working coin cell powered light switch.
                              2_1455483349684_image.jpeg 1_1455483349683_image.jpeg 0_1455483349682_image.jpeg
                              I will upload some decent images later on tonight or tomorrow.
                              I'de just like to talk everyone that has contributed to this thread/post and enabled me to create my first of many embedded projects. I'm applying for a University course in september for Computer Science (Smart Technologies), all about embedded systems, drones, home automation etc etc. This is just the beginning!
                              I'll get this project up on OpenHardware.io asap as Version 1 and we can build on this as a base plate for futher projects.
                              MySensors 2.1.1
                                Samuel235
                                Now, the next two steps I'm interested in taking is to get this working with 2 switches (Software modification, should be simple) and then to have it report its remaining power every 30 minutes to allow me to set up notifications through openhab to alert me to change the batteries so I'm not left with no light switch.
                                MySensors 2.1.1
                                  Samuel235
                                  #135
                                  It would appear that I'm having a timing issue with uploading via the FTDI adapter. Would this be down to the speed of the uC effecting the RX and TX connections?
                                  MySensors 2.1.1
                                  m26872M 2 Replies Last reply
                                  • S Samuel235
                                    m26872M
                                    m26872M
                                    m26872
                                    • S Samuel235
                                      m26872M
                                      m26872M
                                      m26872
                                      @samuel235 Are you trying to upload with Ftdi serial to MYSbootloader? I think it's only for OTA uploads, if you read here.
                                      • m26872M m26872
                                        Samuel235
                                        #138
                                        @m26872 - Thank you for pointing this out to me. I'm unsure why I haven't stumbled across that thread/topic today of all days, been searching and reading about MYSBootloader all day >.<
                                        From personal experience, would you advise any other bootloader, I'm guessing you're going to tell me about the one you are using. Could you link any information for me to check out regarding your choice of bootloader?
                                        Am I correct in recalling you're using DualOptiBoot?
                                        Does DualOptiBoot need external memory/flash?
                                        MySensors 2.1.1
                                        • S Samuel235
                                          m26872M
                                          m26872M
                                          m26872
                                          @samuel235 No, I use plain optiboot, but I couldn't find a suiteable precompiled one for you. DualOptiboot requires external flash as you say.
                                          It's been a while since I played with bootloaders, but I think normal 8MHz Arduino Pro Mini bootloader would work for you with internal clock as well. It's this [ATmegaBOOT_168_atmega328_pro_8MHz.hex ] and I can find it in my "C:\Program Files\Arduino\hardware\arduino\avr\bootloaders\atmega" -folder, should be about the same for you I think. Try fuse settings E2-DA-06 (Lo-Hi-Ex) and rest of the boards.txt-settings from ArduinoProMini 3.3V 8MHz.
