  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 183.1k Views 23 Watching
  • S Samuel235
    It would appear that I'm having a timing issue with uploading via the FTDI adapter. Would this be down to the speed of the uC effecting the RX and TX connections?
    m26872M
    m26872M
    m26872
    @samuel235 Are you trying to upload with Ftdi serial to MYSbootloader? I think it's only for OTA uploads, if you read here.
    S 1 Reply Last reply
    • m26872M m26872
      Samuel235
      #138
      @m26872 - Thank you for pointing this out to me. I'm unsure why I haven't stumbled across that thread/topic today of all days, been searching and reading about MYSBootloader all day >.<
      From personal experience, would you advise any other bootloader, I'm guessing you're going to tell me about the one you are using. Could you link any information for me to check out regarding your choice of bootloader?
      Am I correct in recalling you're using DualOptiBoot?
      Does DualOptiBoot need external memory/flash?
      MySensors 2.1.1
      m26872M 1 Reply Last reply
      • S Samuel235
        m26872M
        m26872M
        m26872
        @samuel235 No, I use plain optiboot, but I couldn't find a suiteable precompiled one for you. DualOptiboot requires external flash as you say.
        It's been a while since I played with bootloaders, but I think normal 8MHz Arduino Pro Mini bootloader would work for you with internal clock as well. It's this [ATmegaBOOT_168_atmega328_pro_8MHz.hex ] and I can find it in my "C:\Program Files\Arduino\hardware\arduino\avr\bootloaders\atmega" -folder, should be about the same for you I think. Try fuse settings E2-DA-06 (Lo-Hi-Ex) and rest of the boards.txt-settings from ArduinoProMini 3.3V 8MHz.
        • m26872M m26872
          Samuel235
          @m26872 - Ahh the generic arduino bootloader... I will have a look into using that tomorrow. As the MYSController gets more feature rich and support i will use that setup, however i love OpenHAB way too much to switch over right now.
          MySensors 2.1.1
            Samuel235
            @m26872 - I've just spent a few minutes looking through my boards.txt and i came across:
            ######## Settings for
            ATmega328 8MHz Internal clock
            atmega328bb.name=ATmega328 on a breadboard (8MHz internal clock)
            atmega328bb.upload.protocol=stk500
            atmega328bb.upload.maximum_size=30720
            atmega328bb.upload.speed=57600
            atmega328bb.bootloader.low_fuses=0xE2
            atmega328bb.bootloader.high_fuses=0xDA
            atmega328bb.bootloader.extended_fuses=0x05
            atmega328bb.bootloader.path=arduino:atmega
            atmega328bb.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
            atmega328bb.bootloader.unlock_bits=0x3F
            atmega328bb.bootloader.lock_bits=0x0F
            atmega328bb.build.mcu=atmega328p
            atmega328bb.build.f_cpu=8000000L
            atmega328bb.build.core=arduino:arduino
            atmega328bb.build.variant=arduino:standard
            Then out of interest I thought I would look at the bootloader that you suggested, to see what difference there would be. Turns out I was actually looking at it without knowing. I have a feeling that if I change the fuse settings to those that i am using now with MYSBootloader, I will be set to go.
            The High Fuse setting you provided enables 1024 words in the boot flash section, a couple of questions about this:
            • Is this defining the size of the area needed for the bootloader section on the built in memory (So smaller this is set to, as long as the bootloader will fit, the more room I will have for a sketch)?
            • How do i find out the 'word size' of the bootloader (if the first question is correct method) so I can determine if the 1024 is big enough? I would rather know how to work this out rather than just assuming that it is because it is specified as that as default.
            I was going to leave my fuses where they were at (E2, D8, 06 as LO:HI:EX) but if I can change the boot size setting, that would allow a bigger room for my sketches = Win Win!
            I'm still slightly confused as to not being able to burn my extended fuse. I have read somewhere (lost the page) about not being possible to burn an EX fuse on a ATmega328p, which i find very hard to believe.
            MySensors 2.1.1
            • S Samuel235
              m26872M
              m26872M
              m26872
              Yes.
              I don't have the tool or knowledge for that. Should be doable by removing indices and count the bytes in hex-file. But for me it's not a big deal to just use the size settings recommended for a particular bootloader. And in this case it´s stock Arduino, so why question it.
              So the '0x06'-kind of notation didn't work either? Strange.
              • m26872M m26872
                Yes.
                Samuel235
                I'm not questioning it, I just wanted to learn how to do it for if i ever came across a need to modify a bootloader i would then know how to record its size for the fuse burning.
                When i set the boards.txt file to read 0x06 it worked perfect, which insinuates that it couldn't burn the chosen BoD, even though the fuse calculator says to ignore the error of the extended fuse, it should burn it even though it gives the error. I'm interested in trying to burn the extended fuse in normal binary rather than hexa. But i doubt it would work anyway.
                MySensors 2.1.1
                  Samuel235
                  It has just clicked inside my busy mind that 0x06 in binary is the same as 0xFE in Hexa. How embarrassed am I now after many questions and hours thinking about the extended fuse value. I'm now assuming that it returns the error because it is already set at that fuse :flushed:
                  MySensors 2.1.1
                    Samuel235
                    So, i have it working using the following board.txt config:
                    ATmega328 8MHz Internal clock Brown-out detection 1.8v
                    atmega328bb.name=ATmega328 on a breadboard (8MHz internal clock) BoD1.8
                    atmega328bb.upload.tool=avrdude
                    atmega328bb.bootloader.tool=avrdude
                    atmega328bb.bootloader.extended_fuses=0x06
                    atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                    atmega328bb.bootloader.lock_bits=0x3F
                    However, no matter what I did I couldn't get it to upload via FTDI. I've tried looking at the Arduino Pro Mini settings in boards.txt to see what 'upload.tool' it uses, AVRDUDE, same as i specified. I also then went to the google docs for the boards.txt reference file, that advises everything i did too. I'm a little stumped. All that i can think of is that i have wired it incorrectly on the pcb. Whats your thoughts on this?
                    MySensors 2.1.1
                    • S Samuel235
                      m26872M
                      m26872M
                      m26872
                      I'm not saying you do, I just told how I think of it.
                      Why, when the result is exactly the same?
                      Also, I'm not familiar with from where the "binary or hexa" comes from? They're both hexadecimal notation as far as I can see.
                        #147
                        I'm not sure what is your problem with ftdi.maybe wirings...do you have cts to gnd, and of course dtr to dtr, only one vcc active...??? Maybe you should try to burn original arduino ide bootloader and then ftdi upload attempts. If it still doesn't work, it could be the wirings...
                        for hexa vs binary..in some case binary notation can be useful, but for fuses, I prefer hexa: shorter, no possibility of mistakes by missing/miscounting one "1" or "0" bit ;)
                          Samuel235
                          @m26872 - I wanted to try it because i'm sure i read somewhere that the ATmega328 can't accept Hexa as fuses. But i doubt that information is valid if i'm honest with you.
                          @scalz - I have dtr to dtr and cts linked to ground. I also only have one VCC pin (which obviously goes to VCC). I'll be perfectly honest with you; the boart.txt setting i posted above, i thought that was using the arduino .hex bootloader, please inform me if i'm in correct in that.
                          MySensors 2.1.1
                            Samuel235
                            This is the board layout, if you guys can see any issues with my FTDI connections/pinout please advice me that you do, I will get that sorted for revison 3 of the board. If i'm honest, I don't mind burning the sketches with the ISP programmer everytime, so I'm very tempted to remove the FTDI, allowing a smaller board still.
                            MySensors 2.1.1
                            • S Samuel235
                              m26872M
                              m26872M
                              m26872
                              @samuel235 How do you debug through ISP ?
                              Have you tested your FTDI USB-serial converter with ArduinoProMini or something?
                              • m26872M m26872
                                Samuel235
                                @m26872 - I haven't tried it out with a arduino pro mini, because i don't have one. However, tomorrow, I will get a Arduino nano out and sort some testing of my FTDI converter on that. I'm hoping that works and its just a simple wiring issue on my board.
                                From your statement of "How do you debug through ISP?" I'm guessing that it isn't possible too, or was that a genuine question? If its not possible then I will keep the FTDI connectors on the board.
                                MySensors 2.1.1
                                • S Samuel235
                                  m26872M
                                  m26872M
                                  m26872
                                  @samuel235
                                  I think you should get yourself a APM (ArduinoProMini) as a reference device. While waiting I think you could wire a DTR circuit to your Uno or Nano and see if you can get your FTDI to talk through rx/tx there.
                                  The "debug through ISP" is a genuine question. My guess is that it's possible if your bootloader, programmer and IDE support it.
                                  • sundberg84S
                                    sundberg84S
                                    #153
                                    Yea, we talked about this as well @m26872 the other night... and to make it easy I also suggest having the fdti connector - if your node is about other to use it (new members to mysensors) thats they easiest way to be able to debug.
                                    Its possible to debug through SPI, [1, 2 , 3] but requiers extra code in your sketch. With fdti you can just user serial.println();Also it looks like you need an second arduino acting with some code... to read and print on that second device serial.... have not read everything through... but its a bit of work it seems.
                                      Samuel235
                                      @m26872 - I'm going to get a APM sorted asap. Then i'll get to try my FTDI converter checked.
                                      @sundberg84 - Way too much hassle for what its worth, I will trouble shoot and sort out my existing connection for FTDI.
                                      MySensors 2.1.1
                                        Samuel235
                                        #155
                                        Current Situation Update
                                        The board is completely populated with correct hardware, tested for 24 hours functioning, working completely fine. There is a slight delay now and then between the switching state and the light illuminating, only sometimes, but nothing major (1/1.5 seconds). The fuse setting and the bootloader burning went unbelievably smooth, very easy once i got my head around all the different settings needed and why they were needed in certain situations. I'm currently using the default arduino bootloader (ATmegaBOOT_168_atmega328_pro_8MHz.hex), burnt with a ISP connection using AVRdudess for the software. I'm unsure if the device is sleeping between readings of the switch but that will be easily noticed soon as i get my FTDI situation fixed.
                                        Talking about FTDI Issues, I'm currently stuck with not being able to upload a sketch through FTDI, its hanging on the "upload" status in Arduino's IDE. I don't think it is a driver issue as my computer has always been configured to never update a driver through windows update (Just confirmed this through the advanced computer settings). The driver that I'm currently using is version 3.3.2011.11. However, if there is no issue with my wiring (shown in a recent previous post/comment above here) i'm struggling to see what else the issue could be other than soldering issues, which i can't notice from a few look over attempts using a 25x magnifier, I will give it another look over to make sure though.
                                        Which attempting to troubleshoot this, I have noticed that if I have the MYSbootloader on the chip and then attempt to upload a sketch (which i know wont work anyway due to MYSbootloader settings/usage rules) I get the generic message of memory allocation:
                                        Sketch uses 13,678 bytes (44%) of program storage space. Maximum is 30,720 bytes.
                                        Global variables use 438 bytes (21%) of dynamic memory, leaving 1,610 bytes for local variables. Maximum is 2,048 bytes.
                                        Where as if I use the default arduino bootloader I only get:
                                        Global variables use 438 bytes of dynamic memory.
                                        It completely misses out showing what space is left for the local variables. Could this shine any light onto the issue? The actual error that I am getting for the MYSbootloader version (after waiting literally over 1 minute from pressing upload), again that is expected, however the default bootloader version just hangs in the uploading state, its been there for well over 5 minutes without giving me an error now. Just to add, they both have the same 'upload.speed=57600' in their respected boards.txt config.
                                        The FTDI Issue is my only major issue on this board now, revision 3 will be just minor fixes, such as adding pull-up resistors between the switch and VCC, a more detailed list will be announced when revision 3's designing process starts.
                                        MySensors 2.1.1
                                          Samuel235
                                          Just to let everyone that is reading this thread know that it is possible to brick your uC with the simplest of mistakes. It would seem that i have bricked my uC by burning the Arduino Pro Mini bootloader to it. The file that i burnt was 'ATmegaBOOT_168_atmega328_pro_8MHz.hex' designed for the Arduino Pro or Pro Mini (3.3v, 8MHz). I will be perfectly honest and admit that i genuinely don't know why it bricked it. I just thought that as long as the uC signature matched that of the bootloader you was burning it can be any .hex file, as long as it matched that uC. Seems that for some reason this didn't like it. If someone would like to give some more in-depth information regarding this to just allow people here a little more knowledge on this subject to aid in them not making the same mistake, that would be appreciated by all.
                                          MySensors 2.1.1
