  3. 3 + 4 way switch with a relay
12 Posts 5 Posters 12.5k Views 11 Watching
  • Sefi NinioS Offline
    Sefi NinioS Offline
    Sefi Ninio
    Hey!
    This is a wiring question.
    I have in my house a lamp that can be turned on/off by 2 switches, something like this:
    0_1455819461422_upload-5d8e84b8-de9c-47a3-be1e-d6e392f1b48d
    However, I would like to throw an arduino controlled relay into the mix.
    So, while keeping the functionality to turn the light on/off by any one of the switches, I also want to be able to turn the light on/off by the relay.
    two problems:
    1. I am not sure how to wire this. I guess I need something similar to this, not sure,
      0_1455819613256_upload-cb05558b-361f-4f95-b5c0-d245a866d9ec
    2. The software cannot know if the light is no or off just by the relay state... The relay could be hot but then someone flips the switch and the light os off even though the relay is hot. There has to be some light sensor in the mix and even this might not be good enough since while it is daytime the light sensor cant know if the reading is from the lamp or the daylight.
      I guess, conceptually, I don't care about the relay state, just turn it on/off like any other switch. But based on what should I decide to switch state?
    Any help would be greatly appreciated!
    Sefi
    • B Offline
      B Offline
      BartE
      wrote on last edited by BartE
      @Sefi-Ninio There is a way to solve this problem| by NOT directly connecting the original switches to the light bulb but as input on the Arduino + MySensers and control the light with an extra relais. Now the Arduino can decide to switch on of off the lamp.
      And when the input is toggled e.g. when a 3-way switch is toggled the Arduino can toggle the relais as well.
      I've tried to make a drawing:
      Sefi NinioS 1 Reply Last reply
      • mfalkviddM Offline
        A agree with BartE's solution, but if you want to wire everything 3-way, this is a way to do it:
        http://www.kjell.com/se/fraga-kjell/hur-funkar-det/elelektronik/starkstrom/belysningsinstallationer
        Exchange any of the switches with relays.
        • B BartE
          Sefi NinioS Offline
          Sefi NinioS Offline
          Sefi Ninio
          @BartE Thanks for your reply!
          In your suggestion, I can see how the arduino can control the light, however I am not sure I understand how flipping a switch will turn on the light.
          Do you mean that in that case, flipping a switch will cause the 2nd relay to change state, and this will allow the arduino to know that it should change the state of the 1st relay (the one that is directly connected to the lamp)?
          B 1 Reply Last reply
          • Sefi NinioS Sefi Ninio
            B Offline
            B Offline
            BartE
            @Sefi-Ninio yes exactly
            When the first (left) relay is toggled the Arduino sees an input change and in your Arduino sketch you can toggle the 2nd (right) relay which actually controls the lamp.
            Modifying the Relay with Button example sketch should like this (where the button should be replace by the left relay:
             * Version 1.0 - Henrik Ekblad
             * Example sketch for a "light switch" where you can control light or something
             * else from both HA controller and a local physical button
             * (connected between digital pin 3 and GND).
             * This node also works as a repeader for other nodes
             * http://www.mysensors.org/build/relay
            #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
            #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
            #define RELAY_ON 1
            #define RELAY_OFF 0
            Bounce debouncer = Bounce();
            bool state;
              gw.sendSketchInfo("Relay & Button", "1.0");
             // Setup the button
              pinMode(BUTTON_PIN,INPUT);
              // Activate internal pull-up
              debouncer.attach(BUTTON_PIN);
              debouncer.interval(5);
              gw.present(CHILD_ID, S_LIGHT);
              pinMode(RELAY_PIN, OUTPUT);
              state = gw.loadState(CHILD_ID);
            *  Example on how to asynchronously check for new messages from gw
              // Get the update value
              if (debouncer.update()) {
                  gw.send(msg.set(state?false:true), true); // Send new state and request ack back
              if (message.isAck()) {
                 // Change relay state
                 state = message.getBool();
                 // Store state in eeprom
                 gw.saveState(CHILD_ID, state);
              Sefi NinioS Offline
              Sefi Ninio
              @BartE ok sounds good, thanks.
              Though I'm not sure how to wire the first relay.
              AFAIK, switching the relay state NO/NC is controlled by the arduino Dx gpio pin, not the other way around.
              So while I understand the concept, I fail to see how to wire this...
              • T Offline
                T Offline
                TimO
                You need a relay that is capable of your mains voltage 230/110 V.
                So you need two different types of relays:
                1. 5 V input, 230/110V output
                2. 230/110V input, 5 V output
                  Sefi NinioS Offline
                  Sefi Ninio
                  Hey @TimO , @BartE
                  Thanks for the info
                  I can find 5V input, 230V output relays on eBay, no problem.
                  Can't find 220V input 5V output relays, though...
                  Anyone has a link maybe?
                    Hey @TimO , @BartE
                    Thanks for the info
                    @Sefi-Ninio it is called a phone charger :-)
                    Or just this http://s.click.aliexpress.com/e/Rbq7UZRFa
                    • B Offline
                      B Offline
                      BartE
                      @Sefi-Ninio What about the wiring this would look like this:
                      @mfalkvidd is right you can use an mobile phone charger or an USB 230v adapter plug like this
                      Of course a real 230v coil relay this this
                        Sefi NinioS Offline
                        Sefi NinioS Offline
                        Sefi Ninio
                        @mfalkvidd
                        You know?
                        I started thinking about instead of going with the solution @BartE suggested, I could simulate the 4way switch with 2 relay units. Then I remembered your reply and then the chip fell into place, this is just what you suggested :)
                        Somehow, I think this solution is the best one. It it easier for me to comprehend and wire, and I think it is also more robust, as potentially, I can connect several of those along the wire if needed.
                        Software-wise, I think it's a simple matter of switching both relays to their NC or NO state in sync, so they both are either NO or NC, so the software is also relatively easier to implement.
                        I would love to hear what you guys think, though.
                        Thanks again for all the help, I'm learning this as I go. Software I know, but all the wirings is very new to me :)
                        • Miro KrsjakM Offline
                          Miro Krsjak
                          I dont think the solution is what you wanted, if the arduino fails, you will not be able to turn the light on. It is good only to be able to override switches and turn lights off. I would like to come up with a full solution instead...
                          12.1k
