  3. Domoticz
  4. Is Raspberry a Solid Controller?
14 Posts 8 Posters 7.0k Views 9 Watching
  • sundberg84S
    sundberg84S
    Agree with above, but might add that when I have had power failures it has corrupted my sd-card. Also before i bought a better quality sd-card i had alot of troubles. If you are planning on running important functions you might wants to consider a UPS. There are several options, from expencive dedicated ups to usb power banks.
    • F
      F
      fleinze
      I run domoticz on a Rpi 1 B+. At first I had some issues with a weak power supply, but never had any problems since.
      Domoticz doesn't use more than a few percent of the cpu, I didn't even have problems running kodi on the same rpi or compiling large software packages at the same time as running domoticz.
      I am sure it would even run on the new zero without problems, but this piece of hardware seems unavailable for a decent price.
      • ewaldsreefE
        ewaldsreefE
        ewaldsreef
        Thank you for all of the input. I am going to take some advise above and purchase a ups for the pi. Also I will be buying a high quality sd card and going with the newest version of the pi. I am so excited for my upcoming projects and hope to have some stuff worthy of sharing.
        • F
          F
          fleinze
          This site (in german) suggests to use a standard power-bank as a raspi-ups:
          http://raspi-ups.appspot.com/de/index.jsp
          • sundberg84S
            sundberg84S
            @fleinze Yes - but you can not get any powerbank - you need to get one that charges AND delivers enough power at the same time.
            There are several good tips around the www... google and you will find.
            • J
              J
              jacikaas
              I think it would be apropriate topic to give here a question to open discusion.
              When I install Domoticz on my Raspberry 2, I found that Domotics offers already made image for raspberry already with included Domoticz server.
              Now I saw that after ~30 hours after raspberry boot, DomoticZ server goes offline. That issue repeats.
              Questions:
              1. How others install Domoticz server? On same Domoticz made image, on Raspbian or maybe other OS (Linux Mint)?
              2. Anybody had this type of issue how I described when Domoticz server goes offline?
              Thank You!
              • mfalkviddM
                1 I use the Domoticz image on my 4 controllers
                2 I have not seen that problem. Are there any clues in the log files?
                • sundberg84S
                  sundberg84S
                  @jacikaas Might be a corrupt database.
                  I have seen this, when a specific node wrote to the db it crashed.
                  • J
                    J
                    jacikaas
                    wrote on last edited by jacikaas
                    I install MONIT on my RPI2 and set logging in Domoticz.
                    LOG:
                    2016-02-28 14:04:28.676 Incoming Domoticz connection from: 192.168.1.26
                    2016-02-28 14:04:28.680 Error: Domoticz received fatal signal 6 !...
                    2016-02-28 14:04:28.683 Error: /home/pi/domoticz/domoticz() [0x163978]
                    2016-02-28 14:04:28.683 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x163a24]
                    2016-02-28 14:04:28.683 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76b87b20]
                    2016-02-28 14:04:28.684 Error: /lib/arm-linux-gnueabihf/libc.so.6(gsignal+0x40) [0x76b868dc]
                    Domoticz server goes offline when he got connection from IP 192.168.1.26, which are my Android phone. Earlier in Android I was trying to install Domoticz Android app, but no matter what settings I enter - I can't connect to server via app.
                    So now Domoticz Android app try to connect regulary to server, but something goes wrong.
                    MONIT sees that server goes offline and then restart RPI2. But I think its not good solution here.
                    Does it looks like a bug on Domoticz?
                    What opinions here?
                    • AWIA
                      AWIA
                      AWI
                      I suggest you try the Domoticz forum. Much more specific experience out there.
