  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
  • carlierdC carlierd
    I will try some bootloader so I will be able to give you some fuse settings I have tested to.
    One more question, what B0 means ? I understood it's the pin for the LED ? Why B ? It's not D0 for digital 0 ?
    David.
    GertSandersG
    GertSandersG
    GertSanders
    @carlierd
    "B0" is the Port B - pin 0 as is the terminology in AVR compiler ("port pins"). It is the parameter I need to add to GCC compiler to be able to use that pin.
    In Arduino IDE terms this is digital arduino pin nr 8. On the DIL version of the chip it is physical pin nr 14. The Arduino IDE makes abstraction of the port pins, by designating numbers to the pins of various ports. The relation between the two can be found in the file "pins_arduino.h", which is stored in a subdirectory "variants". This allows the IDE to use the same number of "pin" for different versions of boards and processors.
    In this file you will find (for the "standard" Arduino Uno the following comments:
    // ATMEL ATMEGA8 & 168 / ARDUINO
    //            PC6  1|    |28  PC5 (AI 5)
    //      (D 0) PD0  2|    |27  PC4 (AI 4)
    //      (D 1) PD1  3|    |26  PC3 (AI 3)
    //      (D 2) PD2  4|    |25  PC2 (AI 2)
    // PWM+ (D 3) PD3  5|    |24  PC1 (AI 1)
    //      (D 4) PD4  6|    |23  PC0 (AI 0)
    //            VCC  7|    |22  GND
    //            GND  8|    |21  AREF
    //            PB6  9|    |20  AVCC
    //            PB7 10|    |19  PB5 (D 13)
    // PWM+ (D 5) PD5 11|    |18  PB4 (D 12)
    // PWM+ (D 6) PD6 12|    |17  PB3 (D 11) PWM
    //      (D 7) PD7 13|    |16  PB2 (D 10) PWM
    //      (D 8) PB0 14|    |15  PB1 (D 9) PWM
    // (PWM+ indicates the additional PWM pins on the ATmega168.)
    In the diagram below you see the relation between IDE, physical and ATMEL definition of the pins for the DIL variant.
    In this diagram below you see the CPU variant used on the Pro Mini. Port B, pin 0 is here physical pin 12, but for Arduino IDE this is still digital pin number 8:
    carlierdC 1 Reply Last reply
    • bjacobseB
      bjacobseB
      bjacobse
      will there be an "Arduino Pro Mini" (Using external 8MHz scaled to 1MHz="X8M1") with LED B5 blink -> optiboot_atmega328_X8M1_057600_B5.hex avialable? preferable with BOD=disabled or set to 1,8v
      • GertSandersG GertSanders
        @carlierd
        //            VCC  7|    |22  GND
        //            GND  8|    |21  AREF
        //            PB6  9|    |20  AVCC
        carlierdC
        carlierdC
        carlierd
        @GertSanders Perfect !!!
        • bjacobseB bjacobse
          GertSandersG
          GertSandersG
          GertSanders
          @bjacobse
          Try this one.
          0_1457034725597_optiboot_atmega328_X8M1_057600_B5.hex
          I doubt uploading will work since 57600baud for a 1MHz device will generate around 8% error, which is way above the 2% AVRDUDE tolerates (I think). For the error calculation see below (WormFood's...)
          But test it. I may be wrong.
          I will make a 4800 baud version if you want later.
          The BOD setting is something independent of the boot loader, you choose this with the fuses.
          This boot loader expects to run at 1MHz, so you can either choose the internal 8MHz oscillator or a crystal at 8Mhz and set the fuses for clock division by 8. The clockdivision is also decided via the fuses and independent of the boot loader itself.
          There are only a few things that are important to a boot loader as far as I know:
          Frequency of the cpu needs to be known at compile time, so that functions like wait() and delay() have an exact time reference (meaning that wait(1000) take 1 second and not some other duration).
          Speed of the expected uploads also needs to be known, so that it can match the speed used to upload sketches. Not all combinations of cpu frequency and upload speed are possible. Some combinations have too much error. Google the "WormFood's AVR Baud Rate Calculator" and you will find info on this.
          In the boards.txt file of the Arduino IDE you need to match the cpu and upload frequency.
          The fact that a LED needs to flash also needs to be known when compiling the boot loader (it's a parameter
          This is how I started the make tool for Optiboot compilation for your bootloader:
          make atmega328 BAUD_RATE=57600 AVR_FREQ=1000000L LED_START_FLASHES=3 LED=B5
          Fuse settings:
          For Clock division by 8
          Internal 8Mhz oscillator
          BOD at 1.8V:
          Low: 0x62
          High: 0xDF
          Extended: 0xFE (or 06 in the boards.txt)
          External Full Swing 8Mhz crystal
          BOD at 1.8V:
          Low: 0x77
          High: 0xDF
          For No BOD at all, Low and High fuses stay the same, only the Extended fuse changes:
          Extended: 0xFF (or 07 in the boards.txt)
          Let me know if you can get it to work.
          • bjacobseB
            bjacobseB
            bjacobse
            I tried to compile as you write that my baudrate was unrealistic high. to get a 4800 baudrate hexfile
            I downloaded from github optiboot, and tried your compile settings, but get an AVR_FREQ error. I can understand that the AVR_FREQ isn't correctly taken as input from the commandline ans used by the makefile
            I'm on Ubuntu Linux
            /media/bjacobse/documents/Downloads/optiboot-master/optiboot/bootloaders/optiboot$ make atmega328 BAUD_RATE=4800 AVR_FREQ=1000000L LED_FLASHES=3 LED=B5
            avr-gcc (GCC) 4.8.2
            Copyright (C) 2013 Free Software Foundation, Inc.
            This is free software; see the source for copying conditions. There is NO
            warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
            avr-gcc: error: 000L: No such file or directory
            make: [baudcheck] Error 1 (ignored)
            baudcheck.tmp.sh: line 17: ( (H�00 + 4800 * 4) / ((4800 * 8))) - 1 : syntax error: invalid arithmetic operator (error token is "�00 + 4800 * 4) / ((4800 * 8))) - 1 ")
            baudcheck.tmp.sh: line 25: (H�00/(8 * (()+1))) : syntax error: invalid arithmetic operator (error token is "�00/(8 * (()+1))) ")
            BAUD RATE CHECK: Desired: 4800, Real: , UBRRL = , Error=-100.0%
            avr-gcc -g -Wall -Os -fno-split-wide-types -mrelax -mmcu=atmega328p -DF_CPU=HW� 000L -DBAUD_RATE=4800 -DLED_START_FLASHES=3 -DLED=B5 -c -o optiboot.o optiboot.c
            make: *** [optiboot.o] Error 1
            GertSandersG 2 Replies Last reply
              I'm on Ubuntu Linux
              avr-gcc (GCC) 4.8.2
              GertSandersG
              GertSandersG
              GertSanders
              @bjacobse
              You can not just compile on linux. The make file needs to be adapted to your setup. I compile my bootloaders on a Mac within a virtual machine running WinAVR version 2010 (oktober).
              Tomorrow I will make a 4800 baud version. The 9600 baud 1Mhz should work as well, but the errorrate for uploads will be higher. Seems acceptable on some peoples boards.
                I'm on Ubuntu Linux
                avr-gcc (GCC) 4.8.2
                GertSandersG
                GertSandersG
                GertSanders
                @bjacobse
                Here is a 4800 baud version.
                0_1457256109633_optiboot_atmega328_X8M1_004800_B5.hex
                bjacobseB 1 Reply Last reply
                  @bjacobse
                  bjacobseB
                  bjacobseB
                  bjacobse
                  @GertSanders
                  Thank you for the file, however I have some troubles, I can flash via USBtiny but I am not able to upload sketch via Arduino IDE+ FTDI,
                  will you check my settings are correct?
                  Here is my boards.txt file for the optiboot
                  pro328opti.name=BJa BOD 1,8V Optiboot, Arduino Pro Mini (3.3V, 8 MHz) w/ ATmega328
                  pro328opti.upload.protocol=arduino
                  pro328opti.upload.maximum_size=30720
                  pro328opti.upload.speed=4800
                  pro328opti.bootloader.low_fuses=0x77
                  pro328opti.bootloader.high_fuses=0xDF
                  pro328opti.bootloader.extended_fuses=0x06
                  pro328opti.bootloader.path=optiboot
                  pro328opti.bootloader.file=1457256062840-optiboot_atmega328_x8m1_004800_b5.hex
                  pro328opti.bootloader.unlock_bits=0x3F
                  pro328opti.bootloader.lock_bits=0x0F
                  pro328opti.build.mcu=atmega328p
                  pro328opti.build.f_cpu=8000000L
                  pro328opti.build.core=arduino
                  pro328opti.build.variant=standard
                    @GertSanders
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @bjacobse
                    As you use the clock divider, you should inform the Arduino IDE that the processor is running slower.
                    So you need to set this:
                    pro328opti.build.f_cpu=1000000L
                    • bjacobseB
                      bjacobseB
                      bjacobse
                      Sounds like good idea :-) Thanks
                      now the board.tx file is updated: pro328opti.build.f_cpu=1000000L
                      restart Arduino, but still get upload errors
                      Error messages:
                      Binary sketch size: 1,102 bytes (of a 30,720 byte maximum)
                      avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                      I feel it's an unlucky Sunday... Can you provide more ideas what I can do?
                        Error messages:
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @bjacobse
                        Not sure, but an out of sync message is usually because of a mismatch in speed between what the IDE en avrdude expect, and what the cpu does.
                        So I would check the fuses of the cpu to be sure. I will try this boot loader on one of my nodes to see if the boot loader itself is the problem.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @GertSanders I installed your compiled bootloaders - thanks for compiling them, but I cannot compile a Blink sketch using 1Mhz internal one
                          Board GertSanders:avr:atmega328pO5M16c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M16C
                          Board GertSanders:avr:atmega328pO5M8c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M8C
                          Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
                          In file included from sketch\Blink.ino.cpp:1:0:
                          C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:249:26: fatal error: pins_arduino.h: No such file or directory
                          #include "pins_arduino.h"
                          compilation terminated.
                          exit status 1
                          Error compiling.```
                          • alexsh1A alexsh1
                            exit status 1
                            Error compiling.```
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @alexsh1
                            My boards.txt file is pointing to a location you are not using.
                            You have your library in a different place then I.
                            You should make sure that the directory in which you put the variant matches with what you have. I can not know which directory you put the Arduino IDE, so matching this is an exercise for you ;-)
                            In my case, my variants boards is here:
                            \Dropbox\Arduino\hardware\atmega328p\avr\variants\BlueBoard\pins_arduino.h
                            This is matched with the fact that my boards file is here:
                            \Dropbox\Arduino\hardware\atmega328p\avr\boards.txt
                            Within the boards.txt file, I'm referring to the following variant: "BlueBoard". This is done here:
                            BlueBoard.build.core=arduino:arduino
                            BlueBoard.build.mcu=atmega328p
                            BlueBoard.build.board=AVR_GERTSANDERSBLUEBOARD
                            BlueBoard.build.variant=BlueBoard
                            You seem to have a different path:
                            I'm not sure where you added my files or boards.txt, but do not just copy it. You need to adapt your boards.txt file.
                            My "hardware" directory is within the Arduino sketch directory and contains this:
                            All my boot loaders are in directory "bootloaders\myoptiboot":
                            the file pins_arduino.h is a pins layout file for a standard atmega328p (copied from the "standard" variant directory.
                            If you have a pro micro with the flat atmega328p, you need to use the "eightanaloginputs" variant.
                            This is what it looks like in my Arduino IDE installation directory:
                            alexsh1A 1 Reply Last reply
                              @alexsh1
                              alexsh1A
                              alexsh1A
                              alexsh1
                              That's what I did - I adopted your boards.txt
                              All my bootloaders are in the hardware directory (C:\Users\Alex\Documents\Arduino\hardware). The hardware directory is located together with all my sketches in the Arduino directory. Now, for whatever reason, the error is point out to the completely different location:
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                @GertSanders OK, I sorted it out.
                                I had to create "BlueBoard" and "standard" under "variants" and copy two corresponding files pins_arduino.h
                                At least I can compile now.
                                Will try to upload a sketch later on and see if it works.
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #21
                                  @GertSanders Unfortunately, I was able to upload the bootloader, but was not able to upload any sketches on the breadboard:
                                  avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x78
                                  avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc0
                                  avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x78
                                  Not sure why - I can upload a sketch via the programmer though. Will upload Nick Gammon sketch to test the bootloader.
                                  UPDATE1: Nick Gammon's sketch cannot detect the bootloader (tried 1MHz internal). Once again, I uploaded the bootloader (1Mhz internal) and the sketch via the programmer and it works, but....the serial monitor works only on 74880, despite for "1Mhz internal" boards.txt clearly says "9600":
                                  BlueBoard.menu.mhz.1Mi= 1Mhz - internal - 9K6 upload speed
                                  BlueBoard.menu.mhz.1Mi.bootloader.low_fuses=0xE2
                                  BlueBoard.menu.mhz.1Mi.bootloader.high_fuses=0xDE
                                  BlueBoard.menu.mhz.1Mi.build.f_cpu=1000000L
                                  BlueBoard.menu.mhz.1Mi.upload.speed=9600
                                  BlueBoard.menu.mhz.1Mi.bootloader.file=myoptiboot/optiboot_atmega328_01M_009600_B0.hex
                                  Additionally, I loaded the ASCIITable example sketch and it states " Serial.begin(9600);"
                                  I do not understand why it works only on 74880...
                                  • alexsh1A alexsh1
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    #22
                                    @alexsh1
                                    I will do some testing tonight, I have not used the 1MHz bootloader yet.
                                    The instruction Serial.begin(9600) is independant of the upload.speed mentioned in the boards file. But I would expect that at 1MHz the higher serial comms speeds also give errors.
                                    A possible reason for the problem, is that the fuse E2 actually means that you run the processor at 8Mhz internally, but without any clock division, while the bootloader was compiled for 1MHz. Without clock division by 8 the processor actually runs at 8Mhz (the speed of the internal oscillator), while all timing code is set for a cpu working frequency of 1Mhz. This would also explain why you can communicate at 74880 (which is close to 76800, which in turn is 8 times 9600).
                                    I think the fuse should be set to both internal 8MHz oscillator AND clock division by 8. I do not know that correct value by hart, need to check that with a fuse calculator.
                                    UPDATE: I think the lower fuse should be set to 0x62 instead of 0xE2.
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @GertSanders
                                      OK, I have come to the following fuse settings for 1Mhz internal:
                                      BlueBoard.menu.mhz.1Mi.bootloader.low_fuses=0x62
                                      For Optiboot, the high fuse is always 0xDE.
                                      Now, a standard example sketch runs at 9600 - I have not checked if atmega328p is running at 1Mhz.
                                      Still have a problem uploading a sketch on the breadboard via FTDI
                                      • alexsh1A alexsh1
                                        @GertSanders
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @alexsh1
                                        I will do some tests later tonight.
                                        • alexsh1A alexsh1
                                          @GertSanders
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          #25
                                          @alexsh1
                                          I just loaded a blink sketch at 4800 baud using FTDI and that works with the following combination:
                                          Boot loader:
                                          0_1457554985438_optiboot_atmega328_08M1_004800_B0.hex
                                          Fuses:
                                          BlueBoard.menu.mhz.1Mi48= 1Mhz - internal 8MHz DIV 8 - 4K8 upload speed
                                          BlueBoard.menu.mhz.1Mi48.bootloader.low_fuses=0x62
                                          BlueBoard.menu.mhz.1Mi48.bootloader.high_fuses=0xDE
                                          BlueBoard.menu.mhz.1Mi48.build.f_cpu=1000000L
                                          BlueBoard.menu.mhz.1Mi48.upload.speed=4800
                                          BlueBoard.menu.mhz.1Mi48.bootloader.file=myoptiboot/optiboot_atmega328_08M1_004800_B0.hex
                                          You will have to strip the "0_1457554985438_" part from the uploaded filename.
                                          Loading the sketch is VERY slow, but it works perfectly. The Blink sketch blinks the led at 500ms on and 500ms off, and that is checked on the breadboard.
                                          Whether the processor actually runs at 1MHz I do not know for sure, since I have no frequency meter (still missing from my toolbox).
                                          I used an arduino as ISP to load the boot loader, and then used an FTDI interface (from Adafruit) to load the sketch while the atmega328 was plugged in a breadboard (Gammon style).
                                          Next I will try with the 9600 baud version at 1Mhz.
