  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.5k Views 18 Watching
  • bjacobseB
    bjacobseB
    bjacobse
    Sounds like good idea :-) Thanks
    now the board.tx file is updated: pro328opti.build.f_cpu=1000000L
    restart Arduino, but still get upload errors
    Error messages:
    Binary sketch size: 1,102 bytes (of a 30,720 byte maximum)
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
    I feel it's an unlucky Sunday... Can you provide more ideas what I can do?
    • bjacobseB bjacobse
      Error messages:
      GertSandersG
      GertSandersG
      GertSanders
      @bjacobse
      Not sure, but an out of sync message is usually because of a mismatch in speed between what the IDE en avrdude expect, and what the cpu does.
      So I would check the fuses of the cpu to be sure. I will try this boot loader on one of my nodes to see if the boot loader itself is the problem.
      • alexsh1A
        alexsh1A
        alexsh1
        @GertSanders I installed your compiled bootloaders - thanks for compiling them, but I cannot compile a Blink sketch using 1Mhz internal one
        Board GertSanders:avr:atmega328pO5M16c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M16C
        Board GertSanders:avr:atmega328pO5M8c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M8C
        Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
        In file included from sketch\Blink.ino.cpp:1:0:
        C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:249:26: fatal error: pins_arduino.h: No such file or directory
        #include "pins_arduino.h"
        compilation terminated.
        exit status 1
        Error compiling.```
        • alexsh1A alexsh1
          exit status 1
          Error compiling.```
          GertSandersG
          GertSandersG
          GertSanders
          @alexsh1
          My boards.txt file is pointing to a location you are not using.
          You have your library in a different place then I.
          You should make sure that the directory in which you put the variant matches with what you have. I can not know which directory you put the Arduino IDE, so matching this is an exercise for you ;-)
          In my case, my variants boards is here:
          \Dropbox\Arduino\hardware\atmega328p\avr\variants\BlueBoard\pins_arduino.h
          This is matched with the fact that my boards file is here:
          \Dropbox\Arduino\hardware\atmega328p\avr\boards.txt
          Within the boards.txt file, I'm referring to the following variant: "BlueBoard". This is done here:
          BlueBoard.build.core=arduino:arduino
          BlueBoard.build.mcu=atmega328p
          BlueBoard.build.board=AVR_GERTSANDERSBLUEBOARD
          BlueBoard.build.variant=BlueBoard
          You seem to have a different path:
          I'm not sure where you added my files or boards.txt, but do not just copy it. You need to adapt your boards.txt file.
          My "hardware" directory is within the Arduino sketch directory and contains this:
          All my boot loaders are in directory "bootloaders\myoptiboot":
          the file pins_arduino.h is a pins layout file for a standard atmega328p (copied from the "standard" variant directory.
          If you have a pro micro with the flat atmega328p, you need to use the "eightanaloginputs" variant.
          This is what it looks like in my Arduino IDE installation directory:
          alexsh1A 1 Reply Last reply
          • GertSandersG GertSanders
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            That's what I did - I adopted your boards.txt
            All my bootloaders are in the hardware directory (C:\Users\Alex\Documents\Arduino\hardware). The hardware directory is located together with all my sketches in the Arduino directory. Now, for whatever reason, the error is point out to the completely different location:
            • alexsh1A
              alexsh1A
              alexsh1
              @GertSanders OK, I sorted it out.
              I had to create "BlueBoard" and "standard" under "variants" and copy two corresponding files pins_arduino.h
              At least I can compile now.
              Will try to upload a sketch later on and see if it works.
              • alexsh1A
                alexsh1A
                alexsh1
                #21
                @GertSanders Unfortunately, I was able to upload the bootloader, but was not able to upload any sketches on the breadboard:
                avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x78
                avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc0
                avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x78
                Not sure why - I can upload a sketch via the programmer though. Will upload Nick Gammon sketch to test the bootloader.
                UPDATE1: Nick Gammon's sketch cannot detect the bootloader (tried 1MHz internal). Once again, I uploaded the bootloader (1Mhz internal) and the sketch via the programmer and it works, but....the serial monitor works only on 74880, despite for "1Mhz internal" boards.txt clearly says "9600":
                BlueBoard.menu.mhz.1Mi= 1Mhz - internal - 9K6 upload speed
                BlueBoard.menu.mhz.1Mi.bootloader.low_fuses=0xE2
                BlueBoard.menu.mhz.1Mi.bootloader.high_fuses=0xDE
                BlueBoard.menu.mhz.1Mi.build.f_cpu=1000000L
                BlueBoard.menu.mhz.1Mi.upload.speed=9600
                BlueBoard.menu.mhz.1Mi.bootloader.file=myoptiboot/optiboot_atmega328_01M_009600_B0.hex
                Additionally, I loaded the ASCIITable example sketch and it states " Serial.begin(9600);"
                I do not understand why it works only on 74880...
                • alexsh1A alexsh1
                  GertSandersG
                  GertSandersG
                  GertSanders
                  #22
                  @alexsh1
                  I will do some testing tonight, I have not used the 1MHz bootloader yet.
                  The instruction Serial.begin(9600) is independant of the upload.speed mentioned in the boards file. But I would expect that at 1MHz the higher serial comms speeds also give errors.
                  A possible reason for the problem, is that the fuse E2 actually means that you run the processor at 8Mhz internally, but without any clock division, while the bootloader was compiled for 1MHz. Without clock division by 8 the processor actually runs at 8Mhz (the speed of the internal oscillator), while all timing code is set for a cpu working frequency of 1Mhz. This would also explain why you can communicate at 74880 (which is close to 76800, which in turn is 8 times 9600).
                  I think the fuse should be set to both internal 8MHz oscillator AND clock division by 8. I do not know that correct value by hart, need to check that with a fuse calculator.
                  UPDATE: I think the lower fuse should be set to 0x62 instead of 0xE2.
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @GertSanders
                    OK, I have come to the following fuse settings for 1Mhz internal:
                    BlueBoard.menu.mhz.1Mi.bootloader.low_fuses=0x62
                    For Optiboot, the high fuse is always 0xDE.
                    Now, a standard example sketch runs at 9600 - I have not checked if atmega328p is running at 1Mhz.
                    Still have a problem uploading a sketch on the breadboard via FTDI
                    GertSandersG 2 Replies Last reply
                    • alexsh1A alexsh1
                      @GertSanders
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @alexsh1
                      I will do some tests later tonight.
                      • alexsh1A alexsh1
                        @GertSanders
                        GertSandersG
                        GertSandersG
                        GertSanders
                        #25
                        @alexsh1
                        I just loaded a blink sketch at 4800 baud using FTDI and that works with the following combination:
                        Boot loader:
                        0_1457554985438_optiboot_atmega328_08M1_004800_B0.hex
                        Fuses:
                        BlueBoard.menu.mhz.1Mi48= 1Mhz - internal 8MHz DIV 8 - 4K8 upload speed
                        BlueBoard.menu.mhz.1Mi48.bootloader.low_fuses=0x62
                        BlueBoard.menu.mhz.1Mi48.bootloader.high_fuses=0xDE
                        BlueBoard.menu.mhz.1Mi48.build.f_cpu=1000000L
                        BlueBoard.menu.mhz.1Mi48.upload.speed=4800
                        BlueBoard.menu.mhz.1Mi48.bootloader.file=myoptiboot/optiboot_atmega328_08M1_004800_B0.hex
                        You will have to strip the "0_1457554985438_" part from the uploaded filename.
                        Loading the sketch is VERY slow, but it works perfectly. The Blink sketch blinks the led at 500ms on and 500ms off, and that is checked on the breadboard.
                        Whether the processor actually runs at 1MHz I do not know for sure, since I have no frequency meter (still missing from my toolbox).
                        I used an arduino as ISP to load the boot loader, and then used an FTDI interface (from Adafruit) to load the sketch while the atmega328 was plugged in a breadboard (Gammon style).
                        Next I will try with the 9600 baud version at 1Mhz.
                          @alexsh1
                          Boot loader:
                          Fuses:
                          alexsh1A
                          alexsh1A
                          alexsh1
                          THanks
                          I'm looking forward to this - 4800 is way too slow.
                          I think the way to check the frequency is to time delay(1000); in the blink sketch...
                          • alexsh1A alexsh1
                            THanks
                            GertSandersG
                            GertSandersG
                            GertSanders
                            #27
                            @alexsh1
                            I just tested with the 9600 baud version at 1MHz, and the blink sketch at 250ms, 500ms and 1000ms per on/off cycle. All rock solid and as expected.
                            Here is the setup I tested the transfer with FTDI:
                            I used the following combination:
                            Boot loader:
                            0_1457556618255_optiboot_atmega328_01M_009600_B0.hex
                            Fuses:
                            BlueBoard.menu.mhz.1Mi= 1Mhz - internal 8MHz DIV 8 - 9K6 upload speed
                            Also here the "0_1457556618255_" is added by uploading on this forum, strip when downloaded.
                            Uploads were at twice the speed then before. Still slow, but acceptable.
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              @GertSanders I have the same breadboard setup, but can only read serial and cannot upload a sketch (out of sync). My settings are the same as yours as per my post earlier on today so I reckon it must be something wrong with the wiring on the breadboard since "Uploading using Programmer" works fine. Not sure what it is as I checked it a few times today.
                              • alexsh1A alexsh1
                                GertSandersG
                                GertSandersG
                                GertSanders
                                #29
                                @alexsh1
                                Maybe make a picture of your setup?
                                Upload using programmer means you use another Arduino to load the sketch on the atmega328, which at the same time deletes any bootloader.
                                I load bootloaders with an Arduino and the sketch ArduinoISP loaded on that one. Then I issue a "burn bootloader" command.
                                To load sketches I switch to my FTDI interface and upload sketches with the same processor setting. But as said with a different interface. And I do not use "upload using programmer", but the upload button next to the compile button.
                                Maybe I should try to make a video like Mr Pete.
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #30
                                  @GertSanders Yes, this is normally the way I do (burn bootloader and then upload a sketch via FTDI on the breadboard). Will post photos shortly.
                                  Are you sure "Upload using programmer" deleting the bootloader?
                                  • alexsh1A alexsh1
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @GertSanders
                                    Yes, looks like you are right - it kills the bootloader. So what's happening? I do not have any bootloader when I use this method to load up sketches?
                                    • alexsh1A alexsh1
                                      @GertSanders
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @alexsh1
                                      If you load a sketch with "Upload using programmer" you replace anything in flash with the sketch. Just the sketch will run on the mcu.
                                      In the very narrow node, there is no FTDI connector, so for those nodes it does not make sense to have a boot loader in flash (it does not hurt either). You couldvjust as well just load the sketch and skip the boot loader altogether.
                                      If you need the extra 512 that optiboot occupies, then "Upload using programmer" allows you to recuperate that space.
                                      So this shoudl explain why you can reed data from the Node via Serial (because the sketch is running and taking care of the serial connection), but why uploading a sketch fails, because for that you need a boot loader in flash.
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @GertSanders
                                        I did a short video how I upload optiboot
                                        Finally, success!
                                        I think I had to reassemble the breadboard set-up three times before finally being able to upload the sketch. I think the problem was no connection at RTS, but I am not sure. I need to assemble a more permanent board to upload sketches via FTDI.
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #34
                                          FTDI Adapter
