  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    #34
    FTDI Adapter
    • alexsh1A
      alexsh1A
      alexsh1
      My Set-up
      • alexsh1A
        alexsh1A
        alexsh1
        #36
        @GertSanders if I load a sketch via Upload using programmer - how do I control the frequency? (1Mhz or 8Mhz internal or external crystal)
        S 1 Reply Last reply
        • alexsh1A alexsh1
          Samuel235
          #37
          @alexsh1 - You would do this by setting the correct fuses. Can you just confirm my information @GertSanders :)
          I would also like to state that Atmel does not support or even recommend using FTDI with the internal crystal, my current board just will not upload via FTDI and no external crystal however yet a arduino pro mini does and that uses an external crystal with no other circuitry compared to my board apart from the physical reset switch.
          MySensors 2.1.1
          alexsh1A 1 Reply Last reply
          • S Samuel235
            alexsh1A
            alexsh1A
            alexsh1
            I think you have a point, but if I do not change anything, just use "Upload using programmer", what are the default frequency and fuses?
            S GertSandersG 2 Replies Last reply
            • alexsh1A alexsh1
              Samuel235
              @alexsh1 If you haven't touched the ATmega328p then it should be sitting with fuses of; L:0x62 H:0xD9 E:0xFF, which would run the uC at 1MHz
              MySensors 2.1.1
              • alexsh1A alexsh1
                GertSandersG
                GertSandersG
                GertSanders
                @*alexsh1
                Which fuses are set when loading a boot loader is defined by wich menu element in tools you have selected. Every processor or board you choose will correspond with values in a board.txt file.
                You can have several board.txt files: 1 file per "family" of boards.
                When uploading sketches, the fusesettings are ignored, only the uploadspeed counts then. Both when uploading with Arduino as ISP as with FTDI interface.
                The internal oscillator of 8 Mhz is not as accurate as a crystal, so at higher uploadspeeds the errorrate can increase or decrease depending on the mcu temperature.
                Some uploadspeeds are closer to optimal then others in relation to the frequency at which the mcu works. The baudcalculator shows the errorrates. Most are non optimal. avrdude can handle an errorrate of 2% or less. So using a specific baudrate in combination with the internal 8Mhz oscillator depends on the worst case combination of transmission errorrate plus clock deviation error.
                For most mcu's the rate of 9600 baud will be acceptable because at that slow rate a clockerror will be relative small. At higher speeds the small clockerror becomes more important. Then it is best to choose an upload speed close to the optimum.
                The fusesettings are only burnt when loading a boot loader (within the Arduino IDE, in AVRStudio you can set fuses seperatly from loading anything).
                The frequency of 8 Mhz can be obtained via a 8mhz crystal or the internal 8mhz oscillator. The low fuse value 0xE2 sets this internal oscillator. By using value 0x62 you also set the clock division bit in combination with the 8mhz internal oscillator, so your mcu will run at 8mhz / 8 = 1mhz
                There are other division values possible. Calculate the low byte value using an avr fuse calculator.
                You can also use an external 8 mhz crystal, and combine this with clock division by 8 to get 1mhz operation.
                And you can choose an external 1mhz crystal.
                All this from choose the right fuse bits.
                Same for Brown out Detection which is set via the three least significant bits of the extended fuse.
                • S Samuel235
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @samuel235 This is strange. The serial monitor was working only on 74880 - I do not think the AVR was running @ 1Mhz
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    #42
                    @GertSanders Thanks for a detailed write-up!
                    How is this influencing low power though? My understanding is that such setup (external crystal) takes more power.
                    • alexsh1A alexsh1
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @alexsh1
                      Using a 1mhz crystal would not be the best thing for low power use, you are correct there.
                      But it gives a more accurate clock base for the timing functions.
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        Not sure what happened, but the following error returned:
                        Board atmega328p:avr:atmega328pO5M8c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M8C
                        Board atmega328p:avr:atmega328pO5M16c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M16C
                        I did not change anything so very strange why it comes up.
                          Samuel235
                          Actually, i have no proof but i've been informed from the arduino standalone microcontroller forums, that using a external 8mhz crystal is good for power consumption. ONLY if its a sleeping module though, it enables it to perform its tasks quicker and then sleep quicker, resulting in more time sleeping.
                          That error code is something i ran into, i'm guessing you're working inside of arduino IDE, if so its to do with your boards.txt entry. Its missing that entry that it speak about. Check that its there, if not enter it in manually.
                          MySensors 2.1.1
                          • S Samuel235
                            alexsh1A
                            alexsh1A
                            alexsh1
                            #46
                            @samuel235
                            Thanks - yes you are right it is about boards.txt.
                            However, the problem is that I did not change anything. Two days ago I uploaded severa sketches and no errors were coming up and now two different boards are showing the same error. This is just odd...
                            • alexsh1A alexsh1
                              @samuel235
                              Samuel235
                              @alexsh1, have you performed an Arduino IDE update? I had this exact issue simply because I updated my IDE.
                              MySensors 2.1.1
                              • GertSandersG
                                GertSandersG
                                GertSanders
                                #48
                                This message pops up since IDE 1.6.7
                                The new IDE expects this entry for all boards, just add it or ignore (it's more a warning then an error).
                                carlierdC 1 Reply Last reply
                                  Samuel235
                                  And there you go, the forever informative @GertSanders has andwered your questioning ;)
                                  MySensors 2.1.1
                                  • S Samuel235
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @samuel235 Looks like you are right - without realising I did press update button thinking about a sketch rather than about the update :(
                                    Corrected this issue aleady in the boards.txt
                                    • GertSandersG GertSanders
                                      carlierdC
                                      carlierdC
                                      carlierd
                                      @GertSanders Hello ! I am trying to upload a sketch without success for the moment.
                                      Burning of the bootloader was done correctly (led on pin 8 lit three times) but impossible to load a sketch.
                                      For easy deployment I choose to create a new folder to include your bootloaders:
                                      But it seems that something is missing as upload is not possible:
                                      Le croquis utilise 1 030 octets (3%) de l'espace de stockage de programmes. Le maximum est de 32 256 octets.
                                      Les variables globales utilisent 9 octets (0%) de mémoire dynamique, ce qui laisse 2 039 octets pour les variables locales. Le maximum est de 2 048 octets.
                                      /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1411 -b38400 -D -Uflash:w:/var/folders/2y/_n7gfzjx5_sgmtyh9t_lp0wc0000gn/T/build8919458311701309495.tmp/Blink.cpp.hex:i
                                               User configuration file is "/Users/carlierd/.avrduderc"
                                               Using Port                    : /dev/cu.usbmodem1411
                                               Overriding Baud Rate          : 38400
                                      avrdude: ser_open(): can't open device "/dev/cu.usbmodem1411": No such file or directory
                                      ioctl("TIOCMGET"): Inappropriate ioctl for device
                                      avrdude done.  Thank you.
                                      Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
                                      Any suggestion ?
                                      David.
                                      • carlierdC carlierd
                                        Any suggestion ?
                                        David.
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @carlierd
                                        I am almost certain that you are NOT using my boards.txt because you put the bootloaders outside the reach of the IDE (must be in the sketchfolder and within the hardware subfolder of the sketches folder).
                                        carlierdC 2 Replies Last reply
                                          @carlierd
                                          carlierdC
                                          carlierdC
                                          carlierd
                                          @GertSanders
                                          No doubt that I using your file as I got the same problem as @alexsh1 with the arduino pin file.
                                          Look at my board choice:
                                          I find this method very good for deployment but only when it's working ;)
                                          I check the bootloader with Nick Gammon sketch and it seems good.
                                          David.
