  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.5k Views 18 Watching
  • alexsh1A alexsh1
    @GertSanders I have the same breadboard setup, but can only read serial and cannot upload a sketch (out of sync). My settings are the same as yours as per my post earlier on today so I reckon it must be something wrong with the wiring on the breadboard since "Uploading using Programmer" works fine. Not sure what it is as I checked it a few times today.
    GertSandersG
    GertSandersG
    GertSanders
    #29
    @alexsh1
    Maybe make a picture of your setup?
    Upload using programmer means you use another Arduino to load the sketch on the atmega328, which at the same time deletes any bootloader.
    I load bootloaders with an Arduino and the sketch ArduinoISP loaded on that one. Then I issue a "burn bootloader" command.
    To load sketches I switch to my FTDI interface and upload sketches with the same processor setting. But as said with a different interface. And I do not use "upload using programmer", but the upload button next to the compile button.
    Maybe I should try to make a video like Mr Pete.
    alexsh1A 1 Reply Last reply
    • GertSandersG GertSanders
      @alexsh1
      alexsh1A
      alexsh1A
      alexsh1
      #30
      @GertSanders Yes, this is normally the way I do (burn bootloader and then upload a sketch via FTDI on the breadboard). Will post photos shortly.
      Are you sure "Upload using programmer" deleting the bootloader?
      • alexsh1A alexsh1
        alexsh1A
        alexsh1A
        alexsh1
        @GertSanders
        Yes, looks like you are right - it kills the bootloader. So what's happening? I do not have any bootloader when I use this method to load up sketches?
        • alexsh1A alexsh1
          @GertSanders
          GertSandersG
          GertSandersG
          GertSanders
          @alexsh1
          If you load a sketch with "Upload using programmer" you replace anything in flash with the sketch. Just the sketch will run on the mcu.
          In the very narrow node, there is no FTDI connector, so for those nodes it does not make sense to have a boot loader in flash (it does not hurt either). You couldvjust as well just load the sketch and skip the boot loader altogether.
          If you need the extra 512 that optiboot occupies, then "Upload using programmer" allows you to recuperate that space.
          So this shoudl explain why you can reed data from the Node via Serial (because the sketch is running and taking care of the serial connection), but why uploading a sketch fails, because for that you need a boot loader in flash.
          • alexsh1A
            alexsh1A
            alexsh1
            @GertSanders
            I did a short video how I upload optiboot
            Finally, success!
            I think I had to reassemble the breadboard set-up three times before finally being able to upload the sketch. I think the problem was no connection at RTS, but I am not sure. I need to assemble a more permanent board to upload sketches via FTDI.
            • alexsh1A
              alexsh1A
              alexsh1
              #34
              FTDI Adapter
              • alexsh1A
                alexsh1A
                alexsh1
                My Set-up
                • alexsh1A
                  alexsh1A
                  alexsh1
                  #36
                  @GertSanders if I load a sketch via Upload using programmer - how do I control the frequency? (1Mhz or 8Mhz internal or external crystal)
                  S 1 Reply Last reply
                  • alexsh1A alexsh1
                    Samuel235
                    #37
                    @alexsh1 - You would do this by setting the correct fuses. Can you just confirm my information @GertSanders :)
                    I would also like to state that Atmel does not support or even recommend using FTDI with the internal crystal, my current board just will not upload via FTDI and no external crystal however yet a arduino pro mini does and that uses an external crystal with no other circuitry compared to my board apart from the physical reset switch.
                    MySensors 2.1.1
                    • S Samuel235
                      alexsh1A
                      alexsh1A
                      alexsh1
                      I think you have a point, but if I do not change anything, just use "Upload using programmer", what are the default frequency and fuses?
                      S GertSandersG 2 Replies Last reply
                      • alexsh1A alexsh1
                        Samuel235
                        @alexsh1 If you haven't touched the ATmega328p then it should be sitting with fuses of; L:0x62 H:0xD9 E:0xFF, which would run the uC at 1MHz
                        MySensors 2.1.1
                        • alexsh1A alexsh1
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @*alexsh1
                          Which fuses are set when loading a boot loader is defined by wich menu element in tools you have selected. Every processor or board you choose will correspond with values in a board.txt file.
                          You can have several board.txt files: 1 file per "family" of boards.
                          When uploading sketches, the fusesettings are ignored, only the uploadspeed counts then. Both when uploading with Arduino as ISP as with FTDI interface.
                          The internal oscillator of 8 Mhz is not as accurate as a crystal, so at higher uploadspeeds the errorrate can increase or decrease depending on the mcu temperature.
                          Some uploadspeeds are closer to optimal then others in relation to the frequency at which the mcu works. The baudcalculator shows the errorrates. Most are non optimal. avrdude can handle an errorrate of 2% or less. So using a specific baudrate in combination with the internal 8Mhz oscillator depends on the worst case combination of transmission errorrate plus clock deviation error.
                          For most mcu's the rate of 9600 baud will be acceptable because at that slow rate a clockerror will be relative small. At higher speeds the small clockerror becomes more important. Then it is best to choose an upload speed close to the optimum.
                          The fusesettings are only burnt when loading a boot loader (within the Arduino IDE, in AVRStudio you can set fuses seperatly from loading anything).
                          The frequency of 8 Mhz can be obtained via a 8mhz crystal or the internal 8mhz oscillator. The low fuse value 0xE2 sets this internal oscillator. By using value 0x62 you also set the clock division bit in combination with the 8mhz internal oscillator, so your mcu will run at 8mhz / 8 = 1mhz
                          There are other division values possible. Calculate the low byte value using an avr fuse calculator.
                          You can also use an external 8 mhz crystal, and combine this with clock division by 8 to get 1mhz operation.
                          And you can choose an external 1mhz crystal.
                          All this from choose the right fuse bits.
                          Same for Brown out Detection which is set via the three least significant bits of the extended fuse.
                          • S Samuel235
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @samuel235 This is strange. The serial monitor was working only on 74880 - I do not think the AVR was running @ 1Mhz
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              #42
                              @GertSanders Thanks for a detailed write-up!
                              How is this influencing low power though? My understanding is that such setup (external crystal) takes more power.
                              • alexsh1A alexsh1
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @alexsh1
                                Using a 1mhz crystal would not be the best thing for low power use, you are correct there.
                                But it gives a more accurate clock base for the timing functions.
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  Not sure what happened, but the following error returned:
                                  Board atmega328p:avr:atmega328pO5M8c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M8C
                                  Board atmega328p:avr:atmega328pO5M16c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M16C
                                  I did not change anything so very strange why it comes up.
                                    Samuel235
                                    Actually, i have no proof but i've been informed from the arduino standalone microcontroller forums, that using a external 8mhz crystal is good for power consumption. ONLY if its a sleeping module though, it enables it to perform its tasks quicker and then sleep quicker, resulting in more time sleeping.
                                    That error code is something i ran into, i'm guessing you're working inside of arduino IDE, if so its to do with your boards.txt entry. Its missing that entry that it speak about. Check that its there, if not enter it in manually.
                                    MySensors 2.1.1
                                    • S Samuel235
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #46
                                      @samuel235
                                      Thanks - yes you are right it is about boards.txt.
                                      However, the problem is that I did not change anything. Two days ago I uploaded severa sketches and no errors were coming up and now two different boards are showing the same error. This is just odd...
                                      • alexsh1A alexsh1
                                        @samuel235
                                        Samuel235
                                        @alexsh1, have you performed an Arduino IDE update? I had this exact issue simply because I updated my IDE.
                                        MySensors 2.1.1
                                        • GertSandersG
                                          GertSandersG
                                          GertSanders
                                          #48
                                          This message pops up since IDE 1.6.7
                                          The new IDE expects this entry for all boards, just add it or ignore (it's more a warning then an error).
                                          carlierdC 1 Reply Last reply
