  3. Universal wireless sensor board w/NRF24l01+ and ESP8266 socket - ceech board
board
41 Posts 9 Posters 27.0k Views 4 Watching
  • epierreE
    epierreE
    epierre
    #32
    on the LCT4067, I have 4.17 , on the battery, VCC/GND gives 1.608, same on programmer pin. But this is correct with the programmer, so I get I have an issue from the battery circuit voltage transformation.
    on the standard one LTC4079, voltages are correct, 4.17 on Vin/GND, 3.3 on VCC/GND
    z-wave - Vera -> Domoticz
    C 1 Reply Last reply
    • epierreE epierre
      C
      C
      ceech
      @epierre It's either the LTC4067, or the voltage regulator. Can you send me the board back?
      I'll repair it and send you back.
      • epierreE
        epierreE
        epierre
        hello fine, also I wanted to try the thermopile so there will be more on return ;-)
        In the meanwhile, how can I have my solar panel on the LTC4079 ? can the lithium charger do the trick ?
        • epierreE epierre
          C
          C
          ceech
          @epierre I've received the board and repaired it. I had to replace the battery management IC. The LTC4067. The output was fried. I also replaced the voltage regulator while I was at it.
          • epierreE
            epierreE
            epierre
            @ceech thanks a lot, any idea why this would happen ?
            what kind of bluetooth module are you using ? I've managed nothing good with the HC-05, maybe faulty hard to know.
            • C
              C
              ceech
              There are current limiters on input and output side. So short circuit is out of the question. Maybe overvoltage on the input side.
              Yes, that's HC-05. Just use it as a serial monitor. It's the same.
              • N
                N
                nunver
                @ceech for the solar panel and lipo version, could you let me know what type of battery and panel I shoulld buy? Also, is there a tutorial for usage of that version? I am new in solar panel and cahrging batteries. Thanks
                • N nunver
                  C
                  C
                  ceech
                  wrote on last edited by ceech
                  #39
                  @nunver The best solar panel is the one with voltages between 5 and 12 volts. And the board is set for a standard 3.7V Li-ion single cell battery. I've just updated the board with a DC-DC buck-boost converter which works below and above battery voltage. There is also plenty of other information on the following page:
                  http://www.ebay.com/itm/331800929918?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
                  • epierreE
                    epierreE
                    epierre
                    @ceech what did you use for soldering, I cannot see it myself (sure I have a lot to learn for SMD soldering...
                    • epierreE epierre
                      C
                      C
                      ceech
                      @epierre I normally use a reflow oven and in your case I had to use a heat gun.
