  3. Universal wireless sensor board w/NRF24l01+ and ESP8266 socket - ceech board
board
41 Posts 9 Posters 27.0k Views 4 Watching
  • epierreE epierre
    @ceech I have an issue on a board (lipo+solar) where when I put the programmer it works, when I remove it and leave it on battery it doesn't... battery is 94%, I checked sensors get the energy.. but no more radio it seems, an idea ?
    C
    C
    ceech
    @epierre It is probably a loose contact on the battery connector. Try using a multimeter and check the important connections.
    • epierreE
      epierreE
      epierre
      @ceech can you point me to the wirings ? thanks,
      z-wave - Vera -> Domoticz
      C 1 Reply Last reply
      • epierreE epierre
        C
        C
        ceech
        @epierre Which board are you using?
        • epierreE
          epierreE
          epierre
          on this one this is the lipo+solar.
          On the other thread, I mistakenly ordered the "standard" version through mysensor website, and had no time till now to test this out... so bard both weren't proposed...
          • epierreE epierre
            C
            C
            ceech
            wrote on last edited by ceech
            #29
            @epierre The battery is connected with the marked trace:
            It goes to the switch an over to the voltage regulator:
            You should measure battery voltage along those lines with respect to the GND. On the other side of the voltage regulator there should be 3V3.
            On the side note -- you can use those boards that you've mentioned on the other thread to charge the battery. No problem.
            epierreE 1 Reply Last reply
            • C ceech
              epierreE
              epierreE
              epierre
              #30
              thanks, but I should not have mixed both, my issue is with the other one.
              • epierreE epierre
                C
                C
                ceech
                #31
                @epierre The one with LTC4067 or the one with LTC4079? It's probably the one with LTC4067.
                Here, this is the battery path to the charger:
                and then to the voltage regulator:
                • epierreE
                  epierreE
                  epierre
                  #32
                  on the LCT4067, I have 4.17 , on the battery, VCC/GND gives 1.608, same on programmer pin. But this is correct with the programmer, so I get I have an issue from the battery circuit voltage transformation.
                  on the standard one LTC4079, voltages are correct, 4.17 on Vin/GND, 3.3 on VCC/GND
                  • epierreE epierre
                    C
                    C
                    ceech
                    @epierre It's either the LTC4067, or the voltage regulator. Can you send me the board back?
                    I'll repair it and send you back.
                    • epierreE
                      epierreE
                      epierre
                      hello fine, also I wanted to try the thermopile so there will be more on return ;-)
                      In the meanwhile, how can I have my solar panel on the LTC4079 ? can the lithium charger do the trick ?
                      • epierreE epierre
                        C
                        C
                        ceech
                        @epierre I've received the board and repaired it. I had to replace the battery management IC. The LTC4067. The output was fried. I also replaced the voltage regulator while I was at it.
                        • epierreE
                          epierreE
                          epierre
                          @ceech thanks a lot, any idea why this would happen ?
                          what kind of bluetooth module are you using ? I've managed nothing good with the HC-05, maybe faulty hard to know.
                          • C
                            C
                            ceech
                            There are current limiters on input and output side. So short circuit is out of the question. Maybe overvoltage on the input side.
                            Yes, that's HC-05. Just use it as a serial monitor. It's the same.
                            • N
                              N
                              nunver
                              @ceech for the solar panel and lipo version, could you let me know what type of battery and panel I shoulld buy? Also, is there a tutorial for usage of that version? I am new in solar panel and cahrging batteries. Thanks
                              • N nunver
                                C
                                C
                                ceech
                                #39
                                @nunver The best solar panel is the one with voltages between 5 and 12 volts. And the board is set for a standard 3.7V Li-ion single cell battery. I've just updated the board with a DC-DC buck-boost converter which works below and above battery voltage. There is also plenty of other information on the following page:
                                http://www.ebay.com/itm/331800929918?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
                                • epierreE
                                  epierreE
                                  epierre
                                  @ceech what did you use for soldering, I cannot see it myself (sure I have a lot to learn for SMD soldering...
                                  • epierreE epierre
                                    C
                                    C
                                    ceech
                                    @epierre I normally use a reflow oven and in your case I had to use a heat gun.
