  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.6k Views 35 Watching
  • epierreE epierre
    @tantt2810 said:
    Hi everyone,
    I have an CO2 MG811 sensor. I don't know where tcm pin connect with ?
    Please help me. Thank you so much !!!!
    this is an analogic sensor, so VCC/Gnd to power it, and readings on analogic Aout
    tantt2810T
    tantt2810T
    tantt2810
    @epierre
    Thank you. Your mean is Vcc->5V, GND->GND, Dout->Digital pin, Aout->Analog pin. Is it right?
    But I don't know the tcm pin connect with ? I have read datasheet but I don't find any info about tcm pin. Please help me. Thank you so much !!!
    epierreE 1 Reply Last reply
    • alexsh1A
      alexsh1A
      alexsh1
      @epierre
      Readings of my MQ135 are going up and down like a yo-yo. Not sure how to read them really?
      What do you think?
      • B
        B
        bhavika
        I am confused with MiCS 4514 sensor. What I had done is :
        using MiCS quick start evaluation board, measured ADC value
        calculated Vout and from that calculated R0.
        Rs/R0 concentration gives me high value, which is not possible, My data is as follows
        clean air file is used for the purpose of R0 value
        https://drive.google.com/file/d/0B8sF8a6FHoseWjhWOHRoYzIxakk/view?usp=sharing
        and Polluted file is used to calculate the actual pollution
        https://drive.google.com/file/d/0B8sF8a6FHoseR1BnclhCUHdibEU/view?usp=sharing
        I am confused. Please help me
        VirV 1 Reply Last reply
        • tantt2810T tantt2810
          @epierre
          epierreE
          epierreE
          epierre
          #167
          @tantt2810 said:
          @epierre
          do not use the digital pin !!! it only reacts with the potentiometer in on/off mode, so useless... you need to power the device with Vcc/Gnd, and read the output with Aout (A stands for analog). The last one forget it.
          z-wave - Vera -> Domoticz
          tantt2810T 1 Reply Last reply
          • alexsh1A alexsh1
            @epierre
            What do you think?
            epierreE
            epierreE
            epierre
            @alexsh1 is that raw ADC output or with a calculation ? normaly this should go up or down but not in sucha drastic way
            alexsh1A 1 Reply Last reply
            • epierreE epierre
              alexsh1A
              alexsh1A
              alexsh1
              @epierre
              This is a value gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ))) reported to Domoticz.
              It does not make any sense to me at all.
              • epierreE epierre
                @tantt2810 said:
                @epierre
                tantt2810T
                tantt2810T
                tantt2810
                @epierre
                Thanks you so much !!! Good job, Good boy =)).
                • alexsh1A alexsh1
                  @epierre
                  epierreE
                  epierreE
                  epierre
                  @alexsh1 said:
                  @epierre
                  same for mle, sometime it is good to have two piece to compare their behavior... I have 3 o them ...
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @epierre do you think it is a faulty sensor though?
                    • tantt2810T
                      tantt2810T
                      tantt2810
                      wrote on last edited by tantt2810
                      #173
                      Can I use pinMode(digitalpin, OUTPUT) to turn off sensor? Or Is there any way to wirte a function that turn off sensor?
                      I want to remote it on web to turn on or off it.
                      • supersjimmieS
                        supersjimmieS
                        supersjimmie
                        For those who are trying to use an MQ135 module from e-bay or other sellers, on a small pcb with a chip, LED and potmeter:
                        It took me a while until I figured out that the little chip has a very big influence on the value that you read on the A-out pin.
                        Only after removing the connection between the A-out pin and the little chip, I got normal measurements.
                        I also replaced the small resistor marked "102" with a 10k resistor, to make measurements more compatible with code that uses a 10k pull down resistor. But that was already a known issue, found on many other places.
                          epierreE
                          epierreE
                          epierre
                          well no, powering is through Vcc/GND, so you whould use a switch on this. Digital pins do not gives enough power for such sensors.
                          • alexsh1A alexsh1
                            epierreE
                            epierreE
                            epierre
                            coud be, hard to know without possibility to compare to another one.
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              @epierre
                              This is what I discovered. When nobody is around the sensor 'settles' on a particular value. However, when there is anyone around in the room, the sensor reading goes up and down - see the snapshot attached. Any idea what the problem may be?
                              • epierreE
                                epierreE
                                epierre
                                @alexsh1 hard to say, could be something moving inside if someone makes vibration around and thus this strange reaction... the down curve at the end is correct, the in between not
                                • E
                                  E
                                  Elfnoir
                                  Can you check the reception level?
                                  I had same behaviour with an old temperature/humidity module; need to move it to another place in the room, and works perfectly now :-)
                                  • E Elfnoir
                                    epierreE
                                    epierreE
                                    epierre
                                    temp/hum are "less" sensitive on environment, here the sensors heats up to 40-60° (or more) so temp/hum is not the most impacting (I can be wrong anyway ;-)
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @epierre I wonder if you looked at this sensor Figaro TGS8100:
                                      http://www.figarosensor.com/products/entry/tgs8100.html
                                      Looks like it is perfect for a low-powered platform.
                                      epierreE R 2 Replies Last reply
                                      • alexsh1A alexsh1
                                        epierreE
                                        epierreE
                                        epierre
                                        #182
                                        as a replacement for MQ in low power yes could be... the bad part is how to get one ?
                                        • epierreE epierre
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          How about http://www.soselectronic.com/?str=371&artnum=170939&name=figaro-tgs8100 ?
