  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 456.1k Views 35 Watching
  • B
    B
    bhavika
    I am confused with MiCS 4514 sensor. What I had done is :
    using MiCS quick start evaluation board, measured ADC value
    calculated Vout and from that calculated R0.
    Rs/R0 concentration gives me high value, which is not possible, My data is as follows
    clean air file is used for the purpose of R0 value
    https://drive.google.com/file/d/0B8sF8a6FHoseWjhWOHRoYzIxakk/view?usp=sharing
    and Polluted file is used to calculate the actual pollution
    https://drive.google.com/file/d/0B8sF8a6FHoseR1BnclhCUHdibEU/view?usp=sharing
    I am confused. Please help me
    VirV 1 Reply Last reply
    • tantt2810T tantt2810
      @epierre
      Thank you. Your mean is Vcc->5V, GND->GND, Dout->Digital pin, Aout->Analog pin. Is it right?
      But I don't know the tcm pin connect with ? I have read datasheet but I don't find any info about tcm pin. Please help me. Thank you so much !!!
      epierreE
      epierreE
      epierre
      #167
      @tantt2810 said:
      @epierre
      do not use the digital pin !!! it only reacts with the potentiometer in on/off mode, so useless... you need to power the device with Vcc/Gnd, and read the output with Aout (A stands for analog). The last one forget it.
      z-wave - Vera -> Domoticz
      tantt2810T 1 Reply Last reply
      • alexsh1A alexsh1
        @epierre
        Readings of my MQ135 are going up and down like a yo-yo. Not sure how to read them really?
        What do you think?
        epierreE
        epierreE
        epierre
        @alexsh1 is that raw ADC output or with a calculation ? normaly this should go up or down but not in sucha drastic way
        alexsh1A 1 Reply Last reply
        • epierreE epierre
          alexsh1A
          alexsh1A
          alexsh1
          @epierre
          This is a value gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ))) reported to Domoticz.
          It does not make any sense to me at all.
          epierreE 1 Reply Last reply
          • epierreE epierre
            @tantt2810 said:
            @epierre
            tantt2810T
            tantt2810T
            tantt2810
            @epierre
            Thanks you so much !!! Good job, Good boy =)).
            • alexsh1A alexsh1
              @epierre
              epierreE
              epierreE
              epierre
              @alexsh1 said:
              @epierre
              same for mle, sometime it is good to have two piece to compare their behavior... I have 3 o them ...
              • alexsh1A
                alexsh1A
                alexsh1
                @epierre do you think it is a faulty sensor though?
                • tantt2810T
                  tantt2810T
                  tantt2810
                  wrote on last edited by tantt2810
                  #173
                  Can I use pinMode(digitalpin, OUTPUT) to turn off sensor? Or Is there any way to wirte a function that turn off sensor?
                  I want to remote it on web to turn on or off it.
                  • supersjimmieS
                    supersjimmieS
                    supersjimmie
                    For those who are trying to use an MQ135 module from e-bay or other sellers, on a small pcb with a chip, LED and potmeter:
                    It took me a while until I figured out that the little chip has a very big influence on the value that you read on the A-out pin.
                    Only after removing the connection between the A-out pin and the little chip, I got normal measurements.
                    I also replaced the small resistor marked "102" with a 10k resistor, to make measurements more compatible with code that uses a 10k pull down resistor. But that was already a known issue, found on many other places.
                      epierreE
                      epierreE
                      epierre
                      well no, powering is through Vcc/GND, so you whould use a switch on this. Digital pins do not gives enough power for such sensors.
                      • alexsh1A alexsh1
                        epierreE
                        epierreE
                        epierre
                        coud be, hard to know without possibility to compare to another one.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @epierre
                          This is what I discovered. When nobody is around the sensor 'settles' on a particular value. However, when there is anyone around in the room, the sensor reading goes up and down - see the snapshot attached. Any idea what the problem may be?
                          • epierreE
                            epierreE
                            epierre
                            @alexsh1 hard to say, could be something moving inside if someone makes vibration around and thus this strange reaction... the down curve at the end is correct, the in between not
                            • E
                              E
                              Elfnoir
                              Can you check the reception level?
                              I had same behaviour with an old temperature/humidity module; need to move it to another place in the room, and works perfectly now :-)
                              • E Elfnoir
                                epierreE
                                epierreE
                                epierre
                                temp/hum are "less" sensitive on environment, here the sensors heats up to 40-60° (or more) so temp/hum is not the most impacting (I can be wrong anyway ;-)
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @epierre I wonder if you looked at this sensor Figaro TGS8100:
                                  http://www.figarosensor.com/products/entry/tgs8100.html
                                  Looks like it is perfect for a low-powered platform.
                                  epierreE R 2 Replies Last reply
                                  • alexsh1A alexsh1
                                    epierreE
                                    epierreE
                                    epierre
                                    #182
                                    as a replacement for MQ in low power yes could be... the bad part is how to get one ?
                                    • epierreE epierre
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      How about http://www.soselectronic.com/?str=371&artnum=170939&name=figaro-tgs8100 ?
                                      • epierreE epierre
                                        I'm now testing the MICS-6814 (3 sensors in one) given for :
                                        Carbon monoxide CO 1 -1000ppm
                                        **Nitrogen dioxide NO2 0.05 –10ppm **
                                        Ethanol C2H5OH 10 –500ppm
                                        Hydrogen H2 1 –1000ppm
                                        Ammonia NH3 1 –500ppm
                                        Methane CH4 >1000ppm
                                        Propane C3H8 >1000ppm
                                        Iso-butane C4H10 >1000ppm
                                        Datasheet maionly speaks on CO, NO2 and NH3:
                                        http://www.seeedstudio.com/wiki/images/1/10/MiCS-6814_Datasheet.pdf
                                        Here is are scripts:
                                        http://www.seeedstudio.com/wiki/Grove_-_Multichannel_Gas_Sensor
                                        Some readings:
                                        The concentration of NH3 is 0.99 ppm
                                        The concentration of CO is 1.20 ppm
                                        The concentration of NO2 is 0.15 ppm
                                        The concentration of C3H8 is 1000.04 ppm
                                        The concentration of C4H10 is 999.98 ppm
                                        The concentration of CH4 is 2991.14 ppm
                                        The concentration of H2 is 1.09 ppm
                                        The concentration of C2H5OH is 1.40 ppm
                                        I guess I'll make a script soon...
                                        VirV
                                        VirV
                                        Vir
                                        Hi, It all make sense, I am just confused that in your code once your multiply and once you divide...
                                        case CO:
                                        if(ratio1 < 0.01) ratio1 = 0.01;
                                        if(ratio1 > 3) ratio1 = 3;
                                        //c = pow(10, 0.6) / pow(ratio1, 1.2);
                                        ** c = pow(ratio1, -1.179)4.385; //mod by jack*
                                        case NO2:
                                        if(ratio2 < 0.07) ratio2 = 0.07;
                                        if(ratio2 > 40) ratio2 = 40;
                                        //c = ratio2 / pow(10, 0.8);
                                        ** c = pow(ratio2, 1.007)/6.855; //mod by jack**
                                        SO, what is the actual formula?
                                        Vir
                                        Some readings:
                                        • epierreE epierre
                                          @tantt2810 said:
                                          I'm don't understand the recipe below. Why RL_Value(Load Resistance)(1023-raw_adc)/raw_adc)? Can you explain for me?
                                          Input: raw_adc - raw value read from adc, which represents the voltage
                                          Output: the calculated sensor resistance
                                          Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
                                          across the load resistor and its resistance, the resistance of the sensor
                                          could be derived.
                                          float MQ2::MQResistanceCalculation(int raw_adc)
                                          RL_VALUE
                                          (1023-raw_adc)/raw_adc));
                                          in fact it is above described, you have a voltage, you want a resistance.
                                          https://learn.sparkfun.com/tutorials/voltage-dividers
                                          datasheet needs a value which is the Rs/Ro (called here RL) where
                                          Ro: sensor resistance at 100ppm of NH3 in the clean air.
                                          Rs:sensor resistance at various concentrations of gases
                                          here the formula is a simplification of this:
                                          float Vrl = val * ( 5.00 / 1024.0 ); // V
                                          float Rs = 20000 * ( 5.00 - Vrl) / Vrl ; // Ohm
                                          int ratio = Rs/Ro;
                                          ppm = 37143 * pow (ratio, -3.178);
                                          VirV
                                          VirV
                                          Vir
                                          What does 37143 represents, Rs? and -3.178 is a second value from your regression method, but what about the first value?
                                          Can you elaborate on ppm line, please
                                          Vir
                                          int ratio = Rs/Ro;
                                          12.5k
