  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.8k Views 38 Watching
    shabba
    I ordered some. Just would need a pin layout and make sure only 3.3v to all pins.
    • N
      N
      nunver
      @sundberg84 I am ordering the PCB's of Ver.8 today. Again, really nice and helpful work for newbies like me. Just one newbie question, though. I understand that both Arduino and NRF are capable of operating down to about 2V. Why do we need the booster in battery operation. I plan to use only Dallas 18B20. Thanks.
      • sundberg84S
        sundberg84S
        @nunver Some sensors are not able to work down below 3.3v, and the im really skeptical if you can operate the arduino 3.3v down to 2v... mine dies when it reaches like 2.8V. Also, with a booster you can operate down to 0.9v - so i highly recommend it.
        AnticimexA N 2 Replies Last reply
        • sundberg84S sundberg84
          AnticimexA
          AnticimexA
          Anticimex
          @sundberg84 to get the arduino to operate at lower voltages you need to reconfigure a few fuses. Brown out reset and such things. I've seen the settings somewhere in the forum and a google search also works. There are online tools to set up the fuses (to get the values to write that is).
            N
            N
            nunver
            @sundberg84 thanks for clarification. From what @Anticimex wrote, I understand I have to tinker beyond my newbie hat :smile: to get Arduino to operate without booster. Thanks again.
            • sundberg84S
              sundberg84S
              #30
              @Anticimex Thank you for that input - i have not change the fuses.
              But a small warning to new members - its not kind of newbie friendly.
              • BruseB
                BruseB
                Bruse
                • D
                  dakipro
                  I just received first order and made one sensor, and I must say that I was a bit skeptical if this is the right pcb for me, I was thinking on somehow reducing footprint a bit or having a better idea about positioning of elements etc, but after making one node I realized that I LOVE IT! :)
                  It brings back the title of the build section of this website (Build = Fun), wheres before I would spend a whole afternoon (and usually have a headache in the evening) for just connecting the radio on the prototype board. Now I made a node with 4 nodes in ~1 hour, and it looks much better then the wire mess from before (old node on the right)
                  However I did spent about 3 hours debugging why my "touch" capacitive sensor doesn't work when I plug inn the radio (it works fine without the radio, which was just headbanging to figure out).
                  I have found that pin 2 is connected to the radio, which could be a good thing if mysensors begins to use IRQ pin on the radio. This probably works in 99% of the cases as it is today, but for the capacitive touch sensor when resistor is connected between pins 2 and four, node never detects that you are touching it. Scalpel blade solved this pretty easily, but it took me 4 hours to figure out what was going on and why my touch sensor doesn't work.
                  I would suggest then to either make pin 2 reserved to the radio, thus removing it from the "available pins" area, or disconnect it from the radio for the time being (not sure when it is planned to use IRQ pin). Or at least marking it somehow on the board if possible, so that we get reminded that pin2 is connected to the radio as well and could interfere with some sensors.
                  While on the subject of suggestions, I see there is almost no connections bellow the radio, so maybe radio could go a bit lower in the board so that it doesn't stick (having no metal parts/lines bellow the radio should not obstruct the signal, it is just empty pcb?) Preserving space for antenna could be done something like this https://www.openhardware.io/uploads/56ecf010b2b0966107ebedfa/image/1458410585539-image.jpeg . I am not sure when I will have some time (and energy) to learn to modify pcb files my self, but maybe it is easy for someone to try it :)
                  Otherwise, as said before, excellent work, this should be featured in the 'build' section of the website as it is one of the most useful things, especially for novices.
                  Thank you for making it
                  • sundberg84S
                    sundberg84S
                    Hi @dakipro! Thank you for those kind words and thank you for the feedback.
                    About the IRQ pin, I will consider that, maybe a jumper, but what i know of the radio should not use this at all. Im not sure why its not working but good you found out. Do you use D3 for other things - if not i recommend to always use d3 instead of d2/irq.
                    Yes, in 99% if the cases you should be able to have the radio over the board... BUT I have had issue and since it should be a newbie frendly board i want it to work 100% of the times.
                    • D
                      dakipro
                      I used d3 for dallas temp sensor but have already soldered d2 to touch sensor. Touch sensor is very unique as it is measuring resistance (actually i think it is measuring time) between to pins, and when you connect 1Mohm resistor between d4 and d2, then radio introduces some other resistance or something, and that messes up the readings for touch. We can use other pins, but pins 2 and 4 are set by default, and it never occurred to me that it is the radio-pin ting.
                      I have quite a few sleeping sensors where PIR is connected to d2 and door-magnet-sensor is connected to d3 for example, as those are (if I understood it right) pins that can wake up the node from sleeping. Maybe radio can interfere with some of those "common" sensors usually connected to the wake-up pins?
                      I would then vote for having d2 available in the "available pins" area because it is one of two wakeup pins, and maybe as you suggested have a jumper (or a disconnected line, that can be just shorted with a short wire) that goes to irq.
                      Anyway, I think it is not an issue-critical as a knife solves it quickly, but it could demoralize us newbies :)
                      • D
                        dakipro
                        wrote on last edited by dakipro
                        #35
                        I just got notification from Paypal that my donation was returned due to non-acceptance. I never experienced someone not willing to take donations via donate button :)
                        I used the donations link on the right box here
                        https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors
                        If it is due to technical reasons that is ok, but maybe you want to check the link or paypal notifications or something if you want to receive donations
                        • sundberg84S
                          sundberg84S
                          #36
                          Hi dakipro! Aaah that was you :) sorry.
                          I wasnt notified (or missed in spam?) I got a donation until i got an email this morning saying it was returned. During this time i had not visited paypal and I had not idea I had to accept.
                          • N
                            N
                            nunver
                            @sundberg84 Just received the boards and installed my first node with it. I wanted to test all voltages are correct before hooking up the Arduino and NRF. Noticed that I get battery voltage at NRF and booster voltage on Arduino. Checked the schematic. It the board I received is correct after all. Is this intentional that we do not use booster voltage for NRF?
                            THanks
                            • sundberg84S
                              sundberg84S
                              Hi @nunver - Yes that is correct, Search the forum - it has been proven much better.
                              Nrf can handle down to 0.9v so its not a problem.
                              • barduinoB
                                barduinoB
                                barduino
                                Hi folks,
                                I finally had some time to assemble a couple of boards and they work perfectly.
                                2 things I need to do though and I appreciate any feed back folks may have.
                                Connect the voltage divider in a more elegant way, perhaps directly from the raw, however I wanted to keep the options open just in case some of the boards end up using REG or BAT.
                                Find a way to protect the VIN input against accidental reverse polarity. I ended up frying the voltage regulator on the arduino when I accidental touched the 9v battery on its connector reversed. Its quite a show with glowing red and sparks flying (the arduino actually survived but no more raw power).
                                @sundberg84 once again thanks for this board!!!
                                • barduinoB barduino
                                  Hi folks,
                                  sundberg84S
                                  sundberg84S
                                  @barduino - thank you for great feedback!
                                  I will look into whats possible if i have any upcoming revs.
                                  barduinoB 1 Reply Last reply
                                    barduinoB
                                    barduinoB
                                    barduino
                                    @sundberg84 , I forgot to mention something.
                                    I get my pro mini's from the local mega store and they have their own brand at a very good price.
                                    In the model they sell the A6, A7 and Ground do not line up with the board.
                                    Not a problem for my applications (I'm thinking of soldering some angled connectors) but I was wondering if they are supposed to be in that position from the original specs.
                                    If you ever think of making the board a bit bigger, having 4 extra connectors for A6, A7, D8 (and an extra ground perhaps) would be nice.
                                    Great job on these!!!
                                    • N
                                      N
                                      nunver
                                      @barduino nice board. One question, why do you have the cable? Sorry for my newbie question :blush:
                                      • N nunver
                                        barduinoB
                                        barduinoB
                                        barduino
                                        @nunver, it's not my board, @sundberg84 design it and made it available for all of us.
                                        The wire you see is to connect the RAW input to the voltage divider so I can measure the 9v battery.
                                        N 1 Reply Last reply
                                          N
                                          N
                                          nunver
                                          @barduino yes I know the boards are designed by sundberg84. I got my boards manufactured as well. What I meant was nicely done.
                                          As for the cable, you could have got raw voltage from the battery booster pin. I was wondering if for any specific reason you had the cable. I understand not.
                                          Regarding protection against reverse polarity, can't you use a diode? You loose 0.6V but there is ample margin.
