  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.2k Views 38 Watching
  • D
    dakipro
    I used d3 for dallas temp sensor but have already soldered d2 to touch sensor. Touch sensor is very unique as it is measuring resistance (actually i think it is measuring time) between to pins, and when you connect 1Mohm resistor between d4 and d2, then radio introduces some other resistance or something, and that messes up the readings for touch. We can use other pins, but pins 2 and 4 are set by default, and it never occurred to me that it is the radio-pin ting.
    I have quite a few sleeping sensors where PIR is connected to d2 and door-magnet-sensor is connected to d3 for example, as those are (if I understood it right) pins that can wake up the node from sleeping. Maybe radio can interfere with some of those "common" sensors usually connected to the wake-up pins?
    I would then vote for having d2 available in the "available pins" area because it is one of two wakeup pins, and maybe as you suggested have a jumper (or a disconnected line, that can be just shorted with a short wire) that goes to irq.
    Anyway, I think it is not an issue-critical as a knife solves it quickly, but it could demoralize us newbies :)
    • D
      dakipro
      wrote on last edited by dakipro
      #35
      I just got notification from Paypal that my donation was returned due to non-acceptance. I never experienced someone not willing to take donations via donate button :)
      I used the donations link on the right box here
      https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors
      If it is due to technical reasons that is ok, but maybe you want to check the link or paypal notifications or something if you want to receive donations
      • sundberg84S
        sundberg84S
        #36
        Hi dakipro! Aaah that was you :) sorry.
        I wasnt notified (or missed in spam?) I got a donation until i got an email this morning saying it was returned. During this time i had not visited paypal and I had not idea I had to accept.
        • N
          N
          nunver
          @sundberg84 Just received the boards and installed my first node with it. I wanted to test all voltages are correct before hooking up the Arduino and NRF. Noticed that I get battery voltage at NRF and booster voltage on Arduino. Checked the schematic. It the board I received is correct after all. Is this intentional that we do not use booster voltage for NRF?
          THanks
          • sundberg84S
            sundberg84S
            Hi @nunver - Yes that is correct, Search the forum - it has been proven much better.
            Nrf can handle down to 0.9v so its not a problem.
            • barduinoB
              barduinoB
              barduino
              Hi folks,
              I finally had some time to assemble a couple of boards and they work perfectly.
              2 things I need to do though and I appreciate any feed back folks may have.
              Connect the voltage divider in a more elegant way, perhaps directly from the raw, however I wanted to keep the options open just in case some of the boards end up using REG or BAT.
              Find a way to protect the VIN input against accidental reverse polarity. I ended up frying the voltage regulator on the arduino when I accidental touched the 9v battery on its connector reversed. Its quite a show with glowing red and sparks flying (the arduino actually survived but no more raw power).
              @sundberg84 once again thanks for this board!!!
              • barduinoB barduino
                Hi folks,
                sundberg84S
                sundberg84S
                @barduino - thank you for great feedback!
                I will look into whats possible if i have any upcoming revs.
                barduinoB 1 Reply Last reply
                • sundberg84S sundberg84
                  barduinoB
                  barduinoB
                  barduino
                  @sundberg84 , I forgot to mention something.
                  I get my pro mini's from the local mega store and they have their own brand at a very good price.
                  In the model they sell the A6, A7 and Ground do not line up with the board.
                  Not a problem for my applications (I'm thinking of soldering some angled connectors) but I was wondering if they are supposed to be in that position from the original specs.
                  If you ever think of making the board a bit bigger, having 4 extra connectors for A6, A7, D8 (and an extra ground perhaps) would be nice.
                  Great job on these!!!
                  • N
                    N
                    nunver
                    @barduino nice board. One question, why do you have the cable? Sorry for my newbie question :blush:
                    • N nunver
                      barduinoB
                      barduinoB
                      barduino
                      @nunver, it's not my board, @sundberg84 design it and made it available for all of us.
                      The wire you see is to connect the RAW input to the voltage divider so I can measure the 9v battery.
                      N 1 Reply Last reply
                        N
                        N
                        nunver
                        @barduino yes I know the boards are designed by sundberg84. I got my boards manufactured as well. What I meant was nicely done.
                        As for the cable, you could have got raw voltage from the battery booster pin. I was wondering if for any specific reason you had the cable. I understand not.
                        Regarding protection against reverse polarity, can't you use a diode? You loose 0.6V but there is ample margin.
                        • N nunver
                          barduinoB
                          barduinoB
                          barduino
                          @nunver your're right I need a more elegant solution for that wire, there was no particular reason to connect it on the other side.
                          For the protection i'm thinking a daughter board with the diode and the 9v connector and then join it with angle connectors on the main.
                          • sundberg84S
                            sundberg84S
                            @barduino ok - strange with that footprint.
                            According to Arduino website those holes does not exist in that position at all (either as your board or my PCB are designed). I downloaded a popular pro mini footprint from somewhere and used that - first time i see they are not aligned.
                            • barduinoB
                              barduinoB
                              barduino
                              yes, indeed
                              source: https://www.arduino-board.com/boards/arduino-pro-mini
                              anyway, no worries, I was just curious
                              • N
                                N
                                nunver
                                @sundberg84 Assembled my second node. This time 5V regulated. One remark and a quick question. You have LE33 in BOM as regulator. I did not have one readily available but an LM1117 which is a totally different package. I had to go through all datasheets to get correct pinout. Could you put labels near pins like 5 3 G?
                                And the question; dumb as it may sound, do we place a jumper at REG pins when using the regulator version? :confused:
                                • sundberg84S
                                  sundberg84S
                                  @nunver - great idea with the labels for voltage reg - that makes it more userfriendly! Will do.
                                  Yes - REG should have a jumper connected.
                                    shabba
                                    What is the purpose of the Raw connection under the radio connection? Designed for a jumper to supply RAW to MYSX connection?
                                    Also any other caveats to be aware of when using RAW and a 3.3 mini and skipping the regulator?
                                    dbemowskD 1 Reply Last reply
                                    • sundberg84S
                                      sundberg84S
                                      @shabba - Its a criteria of the MysX connector - to be able to switch RAW on/off from a daughter pcb. Nothing I have ever used and you dont have to think about it until you have a mother/daughter board.
                                      Using RAW input and the internal regulator on the arduino you need to bypass the "REG" jumper and also the external voltage regulator if i remember right.
                                        shabba
                                        @sundberg84 :+1:
                                        • B
                                          B
                                          BastienVH
                                          @sundberg84
                                          Hey, I've been having a bit of trouble lately.
                                          I've been trying to setup a node with your board which supports a PIR and a temp sensor (ds18b20).
                                          Since there is a spot for a resistor on D3 on your board, I attached the temp sensor to that pin.
                                          The PIR needs a pin that supports interrupts, so I connected that to D2.
                                          Here is where the confusion starts.
                                          If I read this page correctly, D2 is already in use for the radio.
                                          I only checked it after I soldered everything together and found out my PIR doesn't work (it always sends a 1-signal).
                                          Any thoughts on this?
                                          Is D2 really free for use on the board?
