  3. Has anyone made a 2 or 4 channel relay , and is that worked correct ?
40 Posts 7 Posters 12.0k Views 5 Watching
  • barduinoB
    barduinoB
    barduino
    wrote on last edited by barduino
    • R
      R
      Reza
      :/ why delete your post ? :(
      barduinoB 1 Reply Last reply
      • sundberg84S
        sundberg84S
        @Reza - ok communication looks good. My vote will be on power.
        I would try to power the relay separately and see what happens (not from Arduino).
        R 1 Reply Last reply
        • sundberg84S sundberg84
          R
          R
          Reza
          wrote on last edited by Reza
          i test this . with a adaptor 5v 1A but dont any happen !?
          • sundberg84S
            sundberg84S
            @Reza From your images you are not - do you have another adaptor for the relay?
              R
              R
              Reza
              I disconnect relay from arduino and connect to a adaptor 5v 1A
              • sundberg84S
                sundberg84S
                Strange... im out of ideas at this point. Hardware failure?
                Im not that good looking at the code, but I maybe someone else is.
                  R
                  R
                  Reza
                  :( thank you
                  this is strange for me too . pin 3 dont working . but pin4 worked . also if i change cable of pin 3 and 4 other relay working and pin 3 dont work
                  I change 2 line :
                  #define RELAY_1 4
                  #define NUMBER_OF_RELAYS 2
                  but so pin 4 dont work and pin 5 working....
                  • R Reza
                    barduinoB
                    barduinoB
                    barduino
                    @Reza,
                    I'm a noob at electronics and arduinos and have a wild imagination :smiley:
                    I had a theory but was unsure, so I decided to test it first rather than cause more confusion.
                    I know this is a place of sharing, but more than once I caused more problems when trying to help.
                    I don't want to bring some stupid idea into the fold.
                    I'll report back.
                    • R Reza
                      :( thank you
                      I change 2 line :
                      #define RELAY_1 4
                      barduinoB
                      barduinoB
                      barduino
                      #23
                      @Reza,
                      I guess reality is stranger than fiction.
                      To eliminate any bad connections I started by this:
                        pinMode(3, OUTPUT);
                        pinMode(4, OUTPUT);
                        pinMode(5, OUTPUT);
                        pinMode(6, OUTPUT);
                        digitalWrite(3,LOW);
                        digitalWrite(4,LOW);
                        digitalWrite(5,LOW);
                        digitalWrite(6,LOW);
                          for( int i=3;i<=6;i++){
                            digitalWrite(i,HIGH);
                            delay(500);
                            digitalWrite(i,LOW);
                            delay(500);
                      Using a 4 relay board, connected pins 3 through 6, I get a nice effect of all pins light up in sequence and then turn off in sequence.
                      With the relay sketch from the examples (lib 2.0.0) and debugging the load state values which where set to 0 for each sensor I have for each relay (off, ON, ON, ON).
                      Then on the setup I decide to reduce it to this:
                          pinMode(pin, OUTPUT);
                          digitalWrite(pin,LOW);
                          Serial.print("Pin ");
                          Serial.print(pin);
                          Serial.println(" to LOW");
                      Same result or each relay (off, ON, ON, ON).
                      Starting repeater (RNNRA-, 2.0.0-beta)
                      Radio init successful.
                      Pin 3 to LOW
                      Pin 4 to LOW
                      Pin 5 to LOW
                      Pin 6 to LOW
                      send: 15-15-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                      send: 15-15-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                      send: 15-15-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                      read: 0-0-15 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      send: 15-15-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                      send: 15-15-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                      send: 15-15-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      Presenting sensor:1
                      send: 15-15-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      Presenting sensor:2
                      send: 15-15-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      Presenting sensor:3
                      send: 15-15-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      Presenting sensor:4
                      Init complete, id=15, parent=0, distance=1
                      So I decided to re-initialize the pins once more in the loop section:
                          if (isFirstTime){
                            for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++,pin++) {
                                currState = loadState(sensor);
                                Serial.print("Current Status sensor:");
                                Serial.print(sensor);
                                Serial.print("\t");
                                Serial.print("State:");
                                Serial.print(currState);
                                Serial.print("\t");
                                Serial.print("Pin:");
                                Serial.println(pin);
                                digitalWrite(pin, currState?RELAY_ON:RELAY_OFF);
                                wait(500);
                            isFirstTime = false;
                      Now I have all relays off:
                      Current Status sensor:1	State:0	Pin:3
                      Current Status sensor:2	State:0	Pin:4
                      Current Status sensor:3	State:0	Pin:5
                      Current Status sensor:4	State:0	Pin:6
                      Now sending some messages:
                      Relay 1
                      read: 0-0-15 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                      Incoming change for sensor:1 On pin:3, New status: 1
                      read: 0-0-15 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                      Incoming change for sensor:1 On pin:3, New status: 0
                      Works fine but guess what, Relay 4 also turned ON after Relay 1
                      Relay 2:
                      read: 0-0-15 s=2,c=1,t=2,pt=0,l=1,sg=0:1
                      Incoming change for sensor:2 On pin:4, New status: 1
                      read: 0-0-15 s=2,c=1,t=2,pt=0,l=1,sg=0:0
                      Incoming change for sensor:2 On pin:4, New status: 0
                      Works fine but Relay 4 blinks and stays on
                      Relay 3:
                      read: 0-0-15 s=3,c=1,t=2,pt=0,l=1,sg=0:1
                      Incoming change for sensor:3 On pin:5, New status: 1
                      read: 0-0-15 s=3,c=1,t=2,pt=0,l=1,sg=0:0
                      Incoming change for sensor:3 On pin:5, New status: 0
                      Relay 4:
                      read: 0-0-15 s=4,c=1,t=2,pt=0,l=1,sg=0:1
                      Incoming change for sensor:4 On pin:6, New status: 1
                      read: 0-0-15 s=4,c=1,t=2,pt=0,l=1,sg=0:0
                      Incoming change for sensor:4 On pin:6, New status: 0
                      These relays are solid state 5v, arduino pro mini 5v and I both used the power from computer USB and a 6000 mAh phone battery with the same results.
                      Here is the full code:
                       * Version 1.0 - Henrik Ekblad
                       * Example sketch showing how to control physical relays.
                       * This example will remember relay state after power failure.
                       * http://www.mysensors.org/build/relay
                      // Define Node ID
                      #define MY_NODE_ID 15
                      #define MY_REPEATER_FEATURE
                      #define RELAY_ON HIGH  // GPIO value to write to turn on attached relay
                      #define RELAY_OFF LOW // GPIO value to write to turn off attached relay
                      bool isFirstTime = true;
                      bool currState;
                          Serial.print(pin);
                        sendSketchInfo("Relay", "1.0");
                          present(sensor, S_LIGHT);
                          Serial.print("Presenting sensor:");
                          Serial.println(sensor);
                          if (isFirstTime){
                                Serial.print("\t");
                                Serial.print("\t");
                                wait(500);
                        if (message.type==V_LIGHT) {
                           // Change relay state
                           // Store state in eeprom
                           Serial.print(" On pin:");
                           Serial.print(message.sensor-1+RELAY_1);
                      This could be some issue with the development branch of 2.0.0, its been some time since I refreshed.
                      So refreshing the libs I see a new before() section and an empty setup() from the RelayActuator example
                      void before() {
                      Now it runs fine
                      send: 15-15-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=fail:2.0.0-beta
                      read: 0-0-15 s=2Starting repeater (RNNRA-, 2.0.0-beta)
                      send: 15-15-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                      Incoming change for sensor:1, New status: 1
                      Incoming change for sensor:1, New status: 0
                      Incoming change for sensor:2, New status: 1
                      Incoming change for sensor:2, New status: 0
                      Incoming change for sensor:3, New status: 1
                      Incoming change for sensor:4, New status: 1
                      Incoming change for sensor:4, New status: 0
                      All relays behaving as expected before and after running a clearEEPROMconfig sketch.
                      So perhaps there is an issue with v1.5 but it seems the development branch of 2.0 is fine.
                      Or you can try to debug the hell out of it with plenty of Serial.prints.
                      Check with a simple sketch if your relays are fine.
                      If so check what are you getting from the loadState, make sure its boolean, initialize the pins to LOW in setup and if it doesn't work again in loop just once.
                      Try to have the relays always starting as off with no load or save state.
                      • R
                        R
                        Reza
                        if any one built a 2 or 4 channel please help me , please send me the codes that you use , and wiring and please told me what you use adaptor ( how much V and A ) ? which arduino use ?
                        TheoLT 1 Reply Last reply
                        • R Reza
                          TheoLT
                          TheoLT
                          TheoL
                          @Reza Since it's already a long thread I didn't want to read everything. But just a stupid question. Did you measure the relay? It would be my starting point. Because if that's not working, the rest will not work either.
                          Also I once had a relay connected to a ProMini 5V, which I powered over FDTI. But I forgot to setup my FDTI programmer to 5V. By this the Arduino didn't have enough power to switch on the relay. It took me a while before I discovered that, because the NFR24L01+ antenna was working just fine.
                          Before I add an external power source to an Arduino, I always feed the Arduino through the USB of my computer. In my experience it has always supplied enough power for controlling a relay state. You could try it, just to eliminate power supply issues.
                          Just a few tips for you my friend. I hope you'll be able to find the cause of your troubles really soon.
                          Take care.
                          • TheoLT TheoL
                            Take care.
                            R
                            R
                            Reza
                            #26
                            Take care.
                            hi thank you for help me , connected the in1 to pin3 and in2 to pin4 , but pin 4 work and 3 dont work ! (voltag Priority is pin 3 , is this true ? but pin 3 is off and pin4 is work !! also i change pin3 and 4 so other relay is work and other one connect to pin3 dont work ! i test this with a adaptor 5V and 1A but dont work , do need i use a adaptor with more amper ?
                            also i use a "ClearEepromConfig" program for my arduino and program relay again but dont work again...
                            ( my arduino is a arduino nano )
                            • R Reza
                              Take care.
                              TheoLT
                              TheoLT
                              TheoL
                              @Reza what happens if you connect pin 3 to in2 and pin 4 to in1? That's the easiest way to check your relay. I'm not an expert. Buy my guess is, that if there's a power problem, you wouldn't be able to control any one of the relays. But maybe someone with more knowledge will be able to confirm or deny that,
                              • TheoLT TheoL
                                R
                                R
                                Reza
                                Each relay connect to pin 4 is correct ,and each relay connect to pin 3 is not correct, ok thank you :(
                                • R Reza
                                  TheoLT
                                  TheoLT
                                  TheoL
                                  @Reza I'm not sure. But if I understand you correctly, my gut feeling is that your pin 3 on the Arduino is broken (or not correctly setup in the code). Could be a power issue, but I seriously doubt it.
                                  Just try the blink sketch example. Hookup an LED to pin 3 and change the BLINK_LED pin to pin 3 instead of 13. That way you can check if pin 3 is working correctly.
                                  • TheoLT TheoL
                                    R
                                    R
                                    Reza
                                    i change code to :
                                    #define RELAY_1 4
                                    and in wiring in1=pin4 and in2=pin5
                                    so pin 5 is working but pin4 is not work !!!
                                    • R Reza
                                      i change code to :
                                      #define RELAY_1 4
                                      TheoLT
                                      TheoLT
                                      TheoL
                                      @Reza In that case, since it's so predictable, it's a bug in your sketch. At least that's what I think. Unfortunately I have busy weekend and week ahead, so I don't think I have the time to investigate your code. I'm really sorry. I have to check if I have a spare relay, and if I can find one I'm willing to check your sketch. But as mentioned before I can't promise that.
                                      Hopefully others might be able to help you sooner. Take care.
                                      • TheoLT TheoL
                                        R
                                        R
                                        Reza
                                        ok :( thank you very much
                                        • NuubiN
                                          NuubiN
                                          Nuubi
                                          Maybe using increment operator causes your problem [https://www.arduino.cc/en/Reference/Increment]
                                          Replacing pin++ with pin=pin+1 in your code should fix it.
