  3. Has anyone made a 2 or 4 channel relay , and is that worked correct ?
40 Posts 7 Posters 12.0k Views 5 Watching
  • sundberg84S
    sundberg84S
    Hi @Reza
    The start logs looks ok. Does the relay/node log say anything when you send a command from your controller. Any info from your controller?
    Did you define your pins for the relay? A long shot but someone wrote it worked when they changed from 3,4,5,6 to 4,5,6,7 for some reason.
    In most cases though it seems to be a power problem. Try changin your power source and see what happens.
    What im most curous about at this point is to see the log from your relay when you send a on/off command for the two relays.
    R 1 Reply Last reply
    • sundberg84S sundberg84
      Hi @Reza
      R
      R
      Reza
      @sundberg84 said:
      Hi @Reza
      now I have a 2channel relay , i want test for 2channel but this is similar to 4channel .
      in pics 2_1459249017068_photo_2016-03-29_15-23-20.jpg 1_1459249017064_photo_2016-03-29_15-23-10.jpg 0_1459249017027_123223454.jpg
      in1=pin3 , in2=pin4 . the pin 3 is not working , now in2 is working , but if i change pin3 and 4 in1 will working. also i change 2 line of program to and wiring in1=5 and in2=4 but now pin4 dont work ....
      #define RELAY_1 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define NUMBER_OF_RELAYS 2 // Total number of attached relays
      now
      AWIA 1 Reply Last reply
      • sundberg84S
        sundberg84S
        Looks great - but taking steps here i want to know what happens in the serial log on your node when you send a on/off command from your controller?
        • R Reza
          @sundberg84 said:
          Hi @Reza
          now
          AWIA
          AWIA
          AWI
          @Reza we are kind of guessing in the dark right now. Can you post your sketch (as code, use the </> format button)
            R
            R
            Reza
            read: 0-0-2 s=2,c=1,t=2,pt=0,l=1,sg=0:1
            send: 2-2-0-0 s=2,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
            Incoming change for sensor:2, New status: 1
            • AWIA AWI
              R
              R
              Reza
              #include <MySigningNone.h>
              #include <MyTransportNRF24.h>
              #include <MyTransportRFM69.h>
              #include <MyHwATMega328.h>
              MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
              //MyTransportRFM69 radio;
              // Message signing driver (none default)
              //MySigningNone signer;
              // Select AtMega328 hardware profile
              MyHwATMega328 hw;
              MySensor gw(radio, hw);
                gw.sendSketchInfo("Relay", "1.0");
                // Fetch relay status
                  gw.present(sensor, S_LIGHT);
                  pinMode(pin, OUTPUT);
                  digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                if (message.type==V_LIGHT) {
                   // Change relay state
                   // Store state in eeprom
              • R
                R
                Reza
                wrote on last edited by Reza
                I change power supply and use a 5v 1A adaptor , but one relay is off always ( led off). and 2channel relay is not failure because when I change output pin 3 and 4 , that relay is on and work !!
                • barduinoB
                  barduinoB
                  barduino
                  wrote on last edited by barduino
                  • R
                    R
                    Reza
                    :/ why delete your post ? :(
                    barduinoB 1 Reply Last reply
                    • sundberg84S
                      sundberg84S
                      @Reza - ok communication looks good. My vote will be on power.
                      I would try to power the relay separately and see what happens (not from Arduino).
                        R
                        R
                        Reza
                        i test this . with a adaptor 5v 1A but dont any happen !?
                        • sundberg84S
                          sundberg84S
                          @Reza From your images you are not - do you have another adaptor for the relay?
                            R
                            R
                            Reza
                            I disconnect relay from arduino and connect to a adaptor 5v 1A
                            • sundberg84S
                              sundberg84S
                              Strange... im out of ideas at this point. Hardware failure?
                              Im not that good looking at the code, but I maybe someone else is.
                                R
                                R
                                Reza
                                :( thank you
                                this is strange for me too . pin 3 dont working . but pin4 worked . also if i change cable of pin 3 and 4 other relay working and pin 3 dont work
                                I change 2 line :
                                #define RELAY_1 4
                                but so pin 4 dont work and pin 5 working....
                                • R Reza
                                  barduinoB
                                  barduinoB
                                  barduino
                                  @Reza,
                                  I'm a noob at electronics and arduinos and have a wild imagination :smiley:
                                  I had a theory but was unsure, so I decided to test it first rather than cause more confusion.
                                  I know this is a place of sharing, but more than once I caused more problems when trying to help.
                                  I don't want to bring some stupid idea into the fold.
                                  I'll report back.
                                  • R Reza
                                    :( thank you
                                    I change 2 line :
                                    #define RELAY_1 4
                                    barduinoB
                                    barduinoB
                                    barduino
                                    #23
                                    @Reza,
                                    I guess reality is stranger than fiction.
                                    To eliminate any bad connections I started by this:
                                      pinMode(3, OUTPUT);
                                      pinMode(4, OUTPUT);
                                      pinMode(5, OUTPUT);
                                      pinMode(6, OUTPUT);
                                      digitalWrite(3,LOW);
                                      digitalWrite(4,LOW);
                                      digitalWrite(5,LOW);
                                      digitalWrite(6,LOW);
                                        for( int i=3;i<=6;i++){
                                          digitalWrite(i,HIGH);
                                          delay(500);
                                          digitalWrite(i,LOW);
                                          delay(500);
                                    Using a 4 relay board, connected pins 3 through 6, I get a nice effect of all pins light up in sequence and then turn off in sequence.
                                    With the relay sketch from the examples (lib 2.0.0) and debugging the load state values which where set to 0 for each sensor I have for each relay (off, ON, ON, ON).
                                    Then on the setup I decide to reduce it to this:
                                        digitalWrite(pin,LOW);
                                        Serial.print("Pin ");
                                        Serial.print(pin);
                                        Serial.println(" to LOW");
                                    Same result or each relay (off, ON, ON, ON).
                                    Starting repeater (RNNRA-, 2.0.0-beta)
                                    Radio init successful.
                                    Pin 3 to LOW
                                    Pin 4 to LOW
                                    Pin 5 to LOW
                                    Pin 6 to LOW
                                    send: 15-15-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                                    send: 15-15-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                                    send: 15-15-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                    read: 0-0-15 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    send: 15-15-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                                    send: 15-15-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                                    send: 15-15-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    Presenting sensor:1
                                    send: 15-15-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    Presenting sensor:2
                                    send: 15-15-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    Presenting sensor:3
                                    send: 15-15-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    Presenting sensor:4
                                    Init complete, id=15, parent=0, distance=1
                                    So I decided to re-initialize the pins once more in the loop section:
                                        if (isFirstTime){
                                          for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++,pin++) {
                                              currState = loadState(sensor);
                                              Serial.print("Current Status sensor:");
                                              Serial.print(sensor);
                                              Serial.print("\t");
                                              Serial.print("State:");
                                              Serial.print(currState);
                                              Serial.print("\t");
                                              Serial.print("Pin:");
                                              Serial.println(pin);
                                              digitalWrite(pin, currState?RELAY_ON:RELAY_OFF);
                                              wait(500);
                                          isFirstTime = false;
                                    Now I have all relays off:
                                    Current Status sensor:1	State:0	Pin:3
                                    Current Status sensor:2	State:0	Pin:4
                                    Current Status sensor:3	State:0	Pin:5
                                    Current Status sensor:4	State:0	Pin:6
                                    Now sending some messages:
                                    Relay 1
                                    read: 0-0-15 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                                    Incoming change for sensor:1 On pin:3, New status: 1
                                    read: 0-0-15 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                    Incoming change for sensor:1 On pin:3, New status: 0
                                    Works fine but guess what, Relay 4 also turned ON after Relay 1
                                    Relay 2:
                                    read: 0-0-15 s=2,c=1,t=2,pt=0,l=1,sg=0:1
                                    Incoming change for sensor:2 On pin:4, New status: 1
                                    read: 0-0-15 s=2,c=1,t=2,pt=0,l=1,sg=0:0
                                    Incoming change for sensor:2 On pin:4, New status: 0
                                    Works fine but Relay 4 blinks and stays on
                                    Relay 3:
                                    read: 0-0-15 s=3,c=1,t=2,pt=0,l=1,sg=0:1
                                    Incoming change for sensor:3 On pin:5, New status: 1
                                    read: 0-0-15 s=3,c=1,t=2,pt=0,l=1,sg=0:0
                                    Incoming change for sensor:3 On pin:5, New status: 0
                                    Relay 4:
                                    read: 0-0-15 s=4,c=1,t=2,pt=0,l=1,sg=0:1
                                    Incoming change for sensor:4 On pin:6, New status: 1
                                    read: 0-0-15 s=4,c=1,t=2,pt=0,l=1,sg=0:0
                                    Incoming change for sensor:4 On pin:6, New status: 0
                                    These relays are solid state 5v, arduino pro mini 5v and I both used the power from computer USB and a 6000 mAh phone battery with the same results.
                                    Here is the full code:
                                     * Version 1.0 - Henrik Ekblad
                                     * Example sketch showing how to control physical relays.
                                     * This example will remember relay state after power failure.
                                     * http://www.mysensors.org/build/relay
                                    // Define Node ID
                                    #define MY_NODE_ID 15
                                    #define MY_REPEATER_FEATURE
                                    #define RELAY_ON HIGH  // GPIO value to write to turn on attached relay
                                    #define RELAY_OFF LOW // GPIO value to write to turn off attached relay
                                    bool isFirstTime = true;
                                    bool currState;
                                        Serial.print(pin);
                                        Serial.print("Presenting sensor:");
                                        Serial.println(sensor);
                                        if (isFirstTime){
                                              Serial.print("\t");
                                              Serial.print("\t");
                                              wait(500);
                                         Serial.print(" On pin:");
                                         Serial.print(message.sensor-1+RELAY_1);
                                    This could be some issue with the development branch of 2.0.0, its been some time since I refreshed.
                                    So refreshing the libs I see a new before() section and an empty setup() from the RelayActuator example
                                    void before() {
                                    Now it runs fine
                                    send: 15-15-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=fail:2.0.0-beta
                                    read: 0-0-15 s=2Starting repeater (RNNRA-, 2.0.0-beta)
                                    send: 15-15-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                                    Incoming change for sensor:1, New status: 1
                                    Incoming change for sensor:1, New status: 0
                                    Incoming change for sensor:2, New status: 0
                                    Incoming change for sensor:3, New status: 1
                                    Incoming change for sensor:4, New status: 1
                                    Incoming change for sensor:4, New status: 0
                                    All relays behaving as expected before and after running a clearEEPROMconfig sketch.
                                    So perhaps there is an issue with v1.5 but it seems the development branch of 2.0 is fine.
                                    Or you can try to debug the hell out of it with plenty of Serial.prints.
                                    Check with a simple sketch if your relays are fine.
                                    If so check what are you getting from the loadState, make sure its boolean, initialize the pins to LOW in setup and if it doesn't work again in loop just once.
                                    Try to have the relays always starting as off with no load or save state.
                                    • R
                                      R
                                      Reza
                                      if any one built a 2 or 4 channel please help me , please send me the codes that you use , and wiring and please told me what you use adaptor ( how much V and A ) ? which arduino use ?
                                      TheoLT 1 Reply Last reply
                                      • R Reza
                                        TheoLT
                                        TheoLT
                                        TheoL
                                        @Reza Since it's already a long thread I didn't want to read everything. But just a stupid question. Did you measure the relay? It would be my starting point. Because if that's not working, the rest will not work either.
                                        Also I once had a relay connected to a ProMini 5V, which I powered over FDTI. But I forgot to setup my FDTI programmer to 5V. By this the Arduino didn't have enough power to switch on the relay. It took me a while before I discovered that, because the NFR24L01+ antenna was working just fine.
                                        Before I add an external power source to an Arduino, I always feed the Arduino through the USB of my computer. In my experience it has always supplied enough power for controlling a relay state. You could try it, just to eliminate power supply issues.
                                        Just a few tips for you my friend. I hope you'll be able to find the cause of your troubles really soon.
                                        Take care.
                                        • TheoLT TheoL
                                          Take care.
                                          R
                                          R
                                          Reza
                                          #26
                                          Take care.
                                          hi thank you for help me , connected the in1 to pin3 and in2 to pin4 , but pin 4 work and 3 dont work ! (voltag Priority is pin 3 , is this true ? but pin 3 is off and pin4 is work !! also i change pin3 and 4 so other relay is work and other one connect to pin3 dont work ! i test this with a adaptor 5V and 1A but dont work , do need i use a adaptor with more amper ?
                                          also i use a "ClearEepromConfig" program for my arduino and program relay again but dont work again...
                                          ( my arduino is a arduino nano )
