  3. Code is required for 16-relays shift register actuator
5 Posts 3 Posters 2.3k Views 3 Watching
  • T
    tjay4x4
    First of all I want to say thanks for a very in-demand Irrigation Controller (up to 16 valves with Shift Registers). I managed to repeat it. And it works fine. But I couldn't find a sketch for 16 relays shift register actuator operating as a simple relay actuator and running separately.
    I find sketch by @ferpando 16 relay with arduino But it's need to change startup Lua and using <MyBuffer.h>
    So please help me find sketch. Maybe someone already uses something like this?
    • ferpandoF
      ferpandoF
      ferpando
      This <MyBuffer.h> is not really needed if you don't want to check if message is received on the node.
      Just remove that line and everything should work.
      • ferpandoF ferpando
        tjay4x4
        Thank you so mutch. I'll try this.
        And I have to try to do like you explain here link text Just another nube quastion, how to create a function in the startup Lua?
        • helmchen81H
          helmchen81H
          helmchen81
          Hi @ferpando and @tjay4x4. Thanks too for the Irrigation Controller (I'll use later) I've tried to adapt 16 relay with arduino to mysensors 2.0 using this manual . I'm not able to fully convert, hence the way how received messages from controller changed. Did someone from you already adapt the sketch to fit 2.0?
          In any case, I think it would be a good idea to create a sample sketch / manual to simply handle 8+ relays driven by the shift register SN74HC595.
          Thanks in advanced,
          Sebastian
          • helmchen81H helmchen81
            Thanks in advanced,
            Sebastian
            tjay4x4
            @helmchen81
            I recently soldered a modile
            .... but couldn't win the sketch. Since I am just a gynecologist, not a programmer and I do not understand with the code for 16 relay module using SN74HC595. :) On this site are a lot of professionals for whom this is not the problem, the code may soon emerge. I use just 3 separate Arduinos for my 16 channel relay.
            16 relay
