  3. Solar Powered Mini-Weather Station
111 Posts 39 Posters 152.0k Views 27 Watching
  • E
    E
    Elfnoir
    The left resistor is a 1Mohm 2W(I'll confirm the power value once I'll received it), the right one is 4,7kohm, 1/4W.
    For the Hardware, I read the beginning of the post, but unfortunately I'm also a newby, and need to have a validation of this diagram, because I'm not sure if it is correct, and I don't want to burn my house if I'll do cabling mistakes ;-)
    I am not able to put the file created under fritzing, but if someone wants it, tell me how to do it please.
    Thanks for your feedback!
    Regards.
    • bisschopsrB
      bisschopsrB
      bisschopsr
      Hi all,
      the lamp used as a basis for this desing is now frequently offered at Aliexpress. Price is around $10,-. DOn't know about quality, but looks very simular.
      Ralph
      Domoticz, P1 meter interface, MySensors and more to come!
      • peerkersezuukerP
        peerkersezuukerP
        peerkersezuuker
        Hello All,
        Long time reader, first time poster.
        I've been building my-sensors in combo with Domoticz for a while now , and this project is one of my favorites.
        I can confirm that the fritzing schema is correct, i checked it against the one i build. (whish i had the schema earlier, it would have been so much easier ;-))
        I used the followin library from Rob Tillaart for the DHT22 (http://playground.arduino.cc/Main/DHTLib / https://github.com/RobTillaart/Arduino/tree/master/libraries/DHTlib) because the standard was not working...
        Change line 37 to dht DHT;
        comment out line 51
        From line 78 i changed the code to this :
        delay(2000);
              int chk = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
              temp = DHT.temperature;
                     //Serial.print("Temperature DHT :");
                     //Serial.println(temp);
              if (isnan(temp)) {
                  lastTemp = -1;
                lastTemp = temp;
                if (!metric) {
                  temp = temp * 1.8 + 32.0;
                gw.send(msgTemp.set(temp, 1));
              hum = DHT.humidity;
              if (isnan(hum)) {
                  lastHum = -1;
              } else if (hum != lastHum) {
                  lastHum = hum;
                  gw.send(msgHum.set(hum, 1));
        And it is working like a charm.
        Now i ordered one of these : Wind Sensor
        I want to trie to get it working with this build.
        And indeed the lamp is stil available Solar Lamp
        Hope this helps,
        With Regard's
        Peer
        Domoticz / My Sensors / Z-Wave
        https://www.kermisbuks.nl
        peerkersezuukerP 1 Reply Last reply
        • E
          E
          Elfnoir
          wrote on last edited by Elfnoir
          #75
          Thanks for your help! I'm waiting for the LiPo charger, because I purchased a wrong one to pursue my implementation...
          • Could you tell me how I can comment our line 51 please? Just like this?
            'dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
          • Also, do you have already implement the Wind Speed Module, or it's under shipment? Do you use Domoticz as domotic software? It's to know how to implement this kind of child on it?
          • Is the solar panel providing enough power to have the weather station always working? (I'm living in France on Paris latitude, and I would like to know if the quantity of sun is enough, or I need a second solar panel)
          • And it appears my Barometric Pressure sensor gave me also the humidity and temperature; Why do we have 1DHT22 and 1BMP180 ?
          • And finally, how do you deal with the battery level, as I didn't see at the beginning of this post how it is implemented inside Vera? Because I would like to implement it in Domoticz
            Many thanks for your feedback!
          • peerkersezuukerP peerkersezuuker
            Hello All,
            comment out line 51
            delay(2000);
                  if (isnan(temp)) {
                      lastTemp = -1;
                    lastTemp = temp;
                    if (!metric) {
                  hum = DHT.humidity;
                  if (isnan(hum)) {
                      lastHum = -1;
                      lastHum = hum;
            Hope this helps,
            With Regard's
            Peer
            peerkersezuukerP
            peerkersezuukerP
            peerkersezuuker
            Commenting is done with //
            so //dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
            The wind sensor is stil in shipment, so can't tell you anything about it, and i use Domoticz as controler software.
            I presume you have your gateway setup and connected, so the node should show up in domoticz with all the childs.
            I tested the the weather station only a few day's past monyh, because it is still under construction, but those day's it held out (I live near Eindhoven the Netherlands, so weather conditions are almost the same as yours ;-)).
            The battery reports through the potentiometer to A0, if the battery level = 100% the readout of A0 should be 1023 (adjustable with the portentio meter.
            Here is my sketch in total, althoug verry crude it works, it yust needs a lot of cleanup when i am done, but i need the sensor first to work.
                #include <dht.h>
                #include <BH1750.h>
                #include <Adafruit_BMP085.h>
                #define CHILD_ID_HUM 0
                #define CHILD_ID_TEMP 1
                #define CHILD_ID_LIGHT 2
                #define CHILD_ID_BARO 3
                #define CHILD_ID_BTEMP 4
                #define CHILD_ID_WINDSPEED 5
                #define CHILD_ID_RAIN 6
                #define CHILD_ID_RAINRATE 7
                #define MESSAGEWAIT 500
                #define nRainIn A2
                #define DIGITAL_INPUT_RAIN_SENSOR 3
                #define HUMIDITY_SENSOR_DIGITAL_PIN 5
                #define ENCODER_PIN 2
                #define INTERRUPT DIGITAL_INPUT_RAIN_SENSOR-2
                //int encoder_pin = 7; // pulse output from the module
                unsigned int rpm; // rpm reading
                volatile byte pulses; // number of pulses
                unsigned long timeold;
                // number of pulses per revolution
                // based on your encoder disc
                unsigned int pulsesperturn = 1;
                boolean metric = false;
                int altitude = 16; // meters above sealevel
                float lastBmpTemp = -1;
                float lastPressure = -1;
                float lastHum = -1;
                float lastTemp = -1;
                double temp;
                double hum;
                int BATTERY_SENSE_PIN = A0;
                int lastRainValue = -1;
                int nRainVal;
                boolean bIsRaining = false;
                String strRaining = "NO";
                int lastBatteryPcnt = 0;
                int updateAll = 60;
                int updateCount = 0;
                uint16_t lastLux;
                // unsigned long SLEEP_TIME = 60000;
                unsigned long SLEEP_TIME = 600;
                int batteryBasement = 800;
                float batteryConstant = 100.0 / (1023 - batteryBasement);
                Adafruit_BMP085 bmp = Adafruit_BMP085();
                BH1750 lightSensor;
                dht DHT;
                MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                MyMessage msgBtemp(CHILD_ID_BTEMP, V_TEMP);
                MyMessage msgPressure(CHILD_ID_BARO, V_PRESSURE);
                MyMessage msgWindSpeed(CHILD_ID_WINDSPEED, V_WIND);
                MyMessage msgRain(CHILD_ID_RAIN, V_TRIPPED);
                MyMessage msgRainRate(CHILD_ID_RAINRATE, V_RAIN);
                void counter()
                  //Update count
                  pulses++;
                  analogReference(INTERNAL);
                  gw.begin(incomingMessage, 3, true);
                  bmp.begin();
                  gw.sendSketchInfo("Weather Sensor", "1.0");
                  gw.present(CHILD_ID_HUM, S_HUM, "WS Humidity");
                  gw.present(CHILD_ID_TEMP, S_TEMP, "WS Temperature");
                  gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "WS Lux");
                  gw.present(CHILD_ID_BARO, S_BARO, "WS Pressure");
                  gw.present(CHILD_ID_BTEMP, S_TEMP, "WS P Temperature");
                  gw.present(CHILD_ID_WINDSPEED, S_WIND, "WS Windspeed");
                  gw.present(CHILD_ID_RAIN, S_MOTION, "WS Rain");
                  gw.present(CHILD_ID_RAINRATE, S_RAIN, "WS RainRate");
                  pinMode(DIGITAL_INPUT_RAIN_SENSOR, INPUT);
                  lightSensor.begin();
                  pinMode(ENCODER_PIN, INPUT);
                  //Interrupt 0 is digital pin 2
                  //Triggers on Falling Edge (change from HIGH to LOW)
                  attachInterrupt(0, counter, FALLING);
                  // Initialize
                  pulses = 0;
                  rpm = 0;
                  timeold = 0;
                  updateCount += 1;
                  if (updateCount == updateAll) {
                    lastTemp = -1;
                    lastHum = -1;
                    lastLux = -1;
                    lastBmpTemp = -1;
                    lastPressure = -1;
                    lastRainValue = -1;
                    lastBatteryPcnt = -1;
                    updateCount = 0;
                  delay(2000);
                  if (isnan(temp)) {
                      lastTemp = -1;
                    lastTemp = temp;
                    if (!metric) {
                  hum = DHT.humidity;
                  if (isnan(hum)) {
                      lastHum = -1;
                      lastHum = hum;
                  uint16_t lux = lightSensor.readLightLevel();
                  if (lux != lastLux) {
                      gw.send(msgLux.set(lux));
                      lastLux = lux;
                  float pressure = bmp.readSealevelPressure(altitude) * 0.01;
                  float bmptemp = bmp.readTemperature();
                  if (!metric) {
                    bmptemp = bmptemp * 1.8 + 32.0;
                  if (bmptemp != lastBmpTemp) {
                    gw.send(msgBtemp.set(bmptemp,1));
                    lastBmpTemp = bmptemp;
                  if (pressure != lastPressure) {
                    gw.send(msgPressure.set(pressure, 0));
                    lastPressure = pressure;
                  nRainVal = analogRead(nRainIn);
                         Serial.print("RainVal :");
                         Serial.println(nRainVal);
                  bIsRaining = !(digitalRead(DIGITAL_INPUT_RAIN_SENSOR));
                         Serial.print("Is Raining :");
                         Serial.println(bIsRaining);
                  if(bIsRaining){
                      strRaining = "YES";
                  else{
                      strRaining = "NO";
              //Serial.print("Raining?: ");
              //Serial.print(strRaining);
              //Serial.print("\t Moisture Level: ");
              //Serial.println(nRainVal);
              //http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-rain-sensor-module-guide-and-tutorial/
                  gw.send(msgRain.set(bIsRaining));
                  nRainVal = nRainVal * -1;
                  gw.send(msgRainRate.set(nRainVal));
                  int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
                  if (lastBatteryPcnt != batteryPcnt) {
                    lastBatteryPcnt = batteryPcnt;
                 if (millis() - timeold >= 1000) {
                    //Don't process interrupts during calculations
                    detachInterrupt(0);
                    rpm = (60 * 1000 / pulsesperturn )/ (millis() - timeold)* pulses;
                    timeold = millis();
                    Serial.print("RPM = ");
                    Serial.println(rpm,DEC);
                    Serial.println(pulses);
                    pulses = 0;
                    rpm = rpm,DEC;
                    if (rpm == 0) {
                      rpm = 1;
                    gw.send(msgWindSpeed.set(rpm, 1));
                    //Restart the interrupt processing
                  gw.sleep(SLEEP_TIME);
                void incomingMessage(const MyMessage & message) {
                 if (message.isAck()) {
            And there is the puls counter which i abandoned for the wind speed meter (wanted to build my own with a optocoupler, but changed my mind).
            Hope this is helpfull.
            Regard's
            Peer
            • peerkersezuukerP
              peerkersezuukerP
              peerkersezuuker
              @Elfnoir,
              Could you please send me the fritzing schema, or attach it here ?
              I want to add the windmeter i bought.
              I got it today, and with a little help from google i got it working.
              Greetz Peer
              E 1 Reply Last reply
                @Elfnoir,
                Greetz Peer
                E
                E
                Elfnoir
                @peerkersezuuker 0_1459719366114_Weather Station.fzz
                And thanks for your feedback and support!
                • peerkersezuukerP
                  peerkersezuukerP
                  peerkersezuuker
                  So here it is :
                  0_1459792588384_upload-3adeb2e3-0d4c-41e1-a7d7-e973e5081210
                  And the code (still very rude but it works)
                      #include <dht.h>
                      #include <BH1750.h>
                      #define nRainIn A2
                      const int  windSpeedPin = 2; // contact on pin 2 digital
                      int windSpeedPinCounter = 0; // impuls counter
                      int windSpeedPinStatus = 0; // actual impuls
                      int windSpeedPinStatusAlt = 0; // oude Impuls-Status
                      unsigned long windmeterStart;
                      unsigned long windmeterStartAlt = 0;
                      int windSpeed; // Variable voor Wind Speed
                      int beaufort = 0; // Variable Wind in Beaufort
                      const int windmeterTime = 10000;
                      //float knoten = 0.0;
                      //float wind = 0.0;
                      int knoten = 0.0;
                      int wind = 0.0;
                      float lastHum = -1;
                      double temp;
                      double hum;
                      int nRainVal;
                      int updateAll = 60;
                      uint16_t lastLux;
                      BH1750 lightSensor;
                      dht DHT;
                        bmp.begin();
                      // Wind Meter https://github.com/chiemseesurfer/arduinoWeatherstation/blob/master/weatherstation/weatherstation.ino
                      float windmeter()
                          windmeterStart = millis(); // Actual start time measuringMessung
                          windmeterStartAlt = windmeterStart; // Save start time
                          windSpeedPinCounter = 0; // Set pulse counter to 0
                          windSpeedPinStatusAlt = HIGH; // Set puls status High
                          while ((windmeterStart - windmeterStartAlt) <= windmeterTime) // until 10000 ms (10 Seconds) ..
                              windSpeedPinStatus = digitalRead(windSpeedPin); // Read input pin 2
                              if (windSpeedPinStatus != windSpeedPinStatusAlt) // When the pin status changed
                                  if (windSpeedPinStatus == HIGH) // When status - HIGH
                                      windSpeedPinCounter++; // Counter + 1
                              windSpeedPinStatusAlt = windSpeedPinStatus; // Save status for next loop
                              windmeterStart = millis(); // Actual time
                          windSpeed =  ((windSpeedPinCounter * 24) / 10) + 0.5; //  WindSpeed - one Pulse ~ 2,4 km/h,
                          windSpeed = (windSpeed / (windmeterTime / 1000)); // Devided in measure time in seconds
                          Serial.print("wind Speed :");
                          Serial.println(windSpeed);
                          knoten = windSpeed / 1.852; //knot's
                          return knoten;
                        updateCount += 1;
                          lastTemp = -1;
                          lastHum = -1;
                          lastLux = -1;
                          lastBmpTemp = -1;
                          lastPressure = -1;
                          lastRainValue = -1;
                          updateCount = 0;
                        delay(2000);
                        if (isnan(temp)) {
                            lastTemp = -1;
                          lastTemp = temp;
                          if (!metric) {
                        hum = DHT.humidity;
                        if (isnan(hum)) {
                            lastHum = -1;
                            lastHum = hum;
                            lastLux = lux;
                        if (!metric) {
                        if(bIsRaining){
                            strRaining = "YES";
                        else{
                            strRaining = "NO";
                        wind = windmeter();
                        Serial.print("Wind :");
                        Serial.println(wind);
                        gw.send(msgWindSpeed.set(wind));
                  Still need some cleaning and calibrating (rain and wind sensor)
                  [0_1459792799776_Weather-station.fzz](/uploads/files/1459792799984-weather-station.fzz)
                  Regard's Peer
                  • peerkersezuukerP
                    peerkersezuukerP
                    peerkersezuuker
                    Oh yeah, a little source mentioning :
                    Weather Station
                    Weather Station Code
                    Greetz Peer
                    • Dombo71D
                      Dombo71D
                      Dombo71
                      Please can you ex-plane how i can remove 1 of the sensors in the sketch...
                      I will try to build more of this sensors...
                      Only 1 rain and 1 baro is good for me
                      • gigiG
                        gigiG
                        gigi
                        This is my project!!!!
                        // Example sketch för a "light switch" where you can control light or something
                        // else from both vera and a local physical button (connected between digital
                        // pin 3 and GND).
                        // This node also works as a repeader for other nodes
                        //pin sensori
                        #define PIR_PIN 2                   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                        #define HUMIDITY_TEMPERATURE_PIN 3  // sensore temperatura umidita
                        #define RELAY_PIN  4                // relay pin
                        int BATTERY_SENSE_PIN = A1;         // Pin carica batteria o pannello solare
                        int FOTORESIST_SENSE_PIN = A2;      // Pin fotoresistenza
                        //interupt per sleep arduino
                        #define INTERRUPT PIR_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                        //id per vera
                        #define CHILD_ID_RELE 1   // Id relay
                        #define CHILD_ID_HUM 2    // id temperatura
                        #define CHILD_ID_TEMP 3   // id umidita
                        #define CHILD_ID_PIR 4    // Id pir
                        #define CHILD_ID_LIGHT 5  // Id luminosita (fotoresistenza)
                        //definizione per nodo vera
                        #define NODE_ID 10
                        #define SN "meteo station"
                        #define SV "1.4"
                        //variabili
                        bool state_relay;                 //stato relay
                        float batt_valore;                //dichiaro la variabile valore che memorizzerà il valore della batteria dal pin analogico
                        float batt_volt;                  //volt batteria
                        float batt_charged_percent;       //percentuale carica batteria
                        float last_batt_charged_percent;  //percentuale carica batteria precedente
                        float batt_min_voltage = 0.5;     //tensione minima batteria
                        float batt_max_voltage = 5;       //tensione massima batteria
                        float fotoresistenza_valore;      //dichiaro la variabile valore che memorizzerà il valore della fotoresistenza dal pin analogico
                        float last_fotoresistenza_valore; //dichiaro la variabile valore precedente
                        int lux_vera;                      //valore luminosita da inviare a vera
                        DHT dht_int;
                        float lastTemp_int = -1;
                        float lastHum_int = -1;
                        boolean metric = true;
                        MyMessage msgRelay(CHILD_ID_RELE,V_LIGHT);
                        MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
                          gw.begin(incomingMessage, NODE_ID, false);
                          gw.sendSketchInfo(SN, SV);
                          //Sensore umidita temperatura
                          dht_int.setup(HUMIDITY_TEMPERATURE_PIN);
                          gw.present(CHILD_ID_RELE, S_LIGHT);       //light vera
                          gw.present(CHILD_ID_HUM, S_HUM);          //umidity vera
                          gw.present(CHILD_ID_TEMP, S_TEMP);           // temp vera
                          gw.present(CHILD_ID_PIR, S_MOTION);          // motion vera
                          gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);  //light level (fotoresistenza)
                          pinMode(RELAY_PIN, OUTPUT);
                          //PIR
                          pinMode(PIR_PIN, INPUT);
                          state_relay = 0;
                          //GestisciRelay();
                          digitalWrite(RELAY_PIN, LOW);
                          gw.send(msgRelay.set(state_relay));
                            //sensore temperatura umidita
                            delay(dht_int.getMinimumSamplingPeriod());
                            float temperature_int = dht_int.getTemperature();
                            if (isnan(temperature_int))
                                lastTemp_int = -1;
                            else if (temperature_int != lastTemp_int)
                              lastTemp_int = temperature_int;
                              if (!metric)
                                temperature_int = dht_int.toFahrenheit(temperature_int);
                              gw.send(msgTemp.set(temperature_int, 1));
                              Serial.print("T int: ");
                              Serial.println(temperature_int);
                            float humidity_int = dht_int.getHumidity();
                            if (isnan(humidity_int))
                                lastHum_int = -1;
                            else if (humidity_int != lastHum_int)
                                lastHum_int = humidity_int;
                                gw.send(msgHum.set(humidity_int, 1));
                                Serial.print("H int: ");
                                Serial.println(humidity_int);
                            //fotoresistenza
                            for(int i=0;i<150;i++)
                              fotoresistenza_valore += analogRead(FOTORESIST_SENSE_PIN);  //read the input voltage from battery or solar panel
                              delay(2);
                            fotoresistenza_valore = fotoresistenza_valore / 150;
                            Serial.print ("fotoresistenza: ");
                            Serial.println(fotoresistenza_valore);
                            if (fotoresistenza_valore != last_fotoresistenza_valore)
                              lux_vera = (int) fotoresistenza_valore;
                              gw.send(msgLux.set(lux_vera));
                              last_fotoresistenza_valore = fotoresistenza_valore;
                            //fotoresistenza
                            //pir relay
                            // Read digital motion value
                            boolean tripped = digitalRead(PIR_PIN) == HIGH;
                            Serial.println("pir:");
                            Serial.println(tripped);
                            gw.send(msgPir.set(tripped?"1":"0"));  // Send tripped value to gw
                            //accende la luce con il buio
                            if (fotoresistenza_valore < 200)  //poca luce
                              if (tripped == 1)
                                 state_relay = 1;
                                 state_relay = 0;
                            GestisciRelay();
                            //pir relay
                            //battery
                              batt_valore += analogRead(BATTERY_SENSE_PIN);  //read the input voltage from battery or solar panel
                              delay(2);
                            batt_valore = batt_valore / 150;
                            Serial.print ("batt_valore: ");
                            Serial.println(batt_valore);
                            batt_volt = (batt_valore / 1024) * batt_max_voltage;
                            Serial.print ("batt_volt: ");
                            Serial.println(batt_volt);
                           //The map() function uses integer math so will not generate fractions
                           // so I multiply battery voltage with 10 to convert float into a intiger value
                           // when battery voltage is 6.0volt it is totally discharged ( 6*10 =60)
                           // when battery voltage is 7.2volt it is fully charged (7.2*10=72)
                           // 6.0v =0% and 7.2v =100%
                           //batt_charged_percent = batt_volt*10;
                           //batt_charged_percent = map(batt_volt*10, 60 , 72, 0, 100);
                            batt_charged_percent = batt_volt * 10;
                            batt_charged_percent = map(batt_volt * 10, batt_min_voltage * 10 , batt_max_voltage * 10, 0, 100);
                            //batt_charged_percent = (batt_volt / batt_max_voltage) * 100;
                            Serial.print ("batt_charged_percent: ");
                            Serial.println(batt_charged_percent);
                            if (last_batt_charged_percent != batt_charged_percent)
                                gw.sendBatteryLevel(batt_charged_percent);
                                last_batt_charged_percent = batt_charged_percent;
                            //battery
                            delay(50);
                            gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                             // Change relay state_relay
                             state_relay = message.getBool();
                             GestisciRelay();
                        void GestisciRelay()
                            //Serial.print(" GestisciRelay state_relay:");
                            //Serial.println(state_relay);
                            if (state_relay == 0)
                              //Serial.println("SPENTO RELAY");
                              digitalWrite(RELAY_PIN, HIGH);
                              //Serial.println("ACCESO RELAY");
                        On vera
                        On board
                        Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
                        • gigiG
                          gigiG
                          gigi
                          I purchased a solar kit
                          Solar Panel
                          battery 12v
                          landstar solar charge controller
                          I want to insert into Arduino in output of charge controller (I have 12 volts)
                          to lower the voltage can I use a mobile charger Car 1 Ah
                          do you heat so much?
                          Thank
                          @Salmoides Good Project!!!!!
                          • Dombo71D
                            Dombo71D
                            Dombo71
                            what are the resistors? Or what do you u use between the wires?
                            Look simple to me..
                            gigiG 1 Reply Last reply
                            • Dombo71D Dombo71
                              Look simple to me..
                              gigiG
                              gigiG
                              gigi
                              @Dombo71 look a fritzing schematic
                              DidiD 1 Reply Last reply
                              • gigiG gigi
                                DidiD
                                DidiD
                                Didi
                                Can you share the fritzing file please
                                • DidiD Didi
                                  gigiG
                                  gigiG
                                  gigi
                                  @Didi 0_1459967939633_schema-pannello-solare-2.fzz
                                  Fritzing File!!!!
                                  • gigiG
                                    gigiG
                                    gigi
                                    New fritzing
                                    I have two questions?
                                    1. voltage divider for more 5 v (battery voltage 12-13 volts)
                                    2. I use a auto phone charger for step down (12v --> 5 V) - warmers if I close in a box?
                                    Thank
                                    PetjepetP 1 Reply Last reply
                                    • gigiG gigi
                                      New fritzing
                                      Thank
                                      PetjepetP
                                      PetjepetP
                                      Petjepet
                                      @gigi said:
                                      New fritzing
                                      Thank
                                      Is your fritzing correct?
                                      On the green wire (light sensor?) you measure on ground where I guess you should measure between the resistor and the sensor.
                                      • PetjepetP Petjepet
                                        @gigi said:
                                        New fritzing
                                        Thank
                                        gigiG
                                        gigiG
                                        gigi
                                        Is the same
                                        voltage divider
                                        • PetjepetP
                                          PetjepetP
                                          Petjepet
                                          wrote on last edited by Petjepet
                                          #91
                                          @gigi I know but in your breadboard picture the now mentioned V output is connected directly to ground. :smirk:
