  3. Solar Powered Mini-Weather Station
111 Posts 39 Posters 152.0k Views 27 Watching
  • C
    C
    chickey
    I have one of these lights and got it with the plan of dissembling it for this very project but it was too good lol so think I'll buy another to dissect. The only disappointing thing is how the light is always on at a dim level so drains the battery. I'd much rather have it only activate on motion detection with the PIR.
    • D
      Dylano
      Dear...
      Great project...[ when i got my stuff i am going to build to...
      Only how do you use the motionsensor of this light...[ new one or do you use the build in one ]
      In the sketch is can not see this motionsensor?
      Only in our Vera controller is see arm and bypass?
      Can you set the level of the lights, in vera?
      Two times temperature?
      And how is your battery action in the winter-period?
      Domoticz, with a lot of working hardware, include mysensors :-)
      OpenPLI, RuneAudio, Solarmeter, etc......
      Not a great builder of software and hardware, more a user...
      Only i try to do my best :-(
      • E
        E
        Elfnoir
        wrote on last edited by Elfnoir
        #70
        Here is the fritzing shema ; could you please tell me if it is correct before I begin the building of the weather station ?
        Thanks for your support !
        D 1 Reply Last reply
        • E Elfnoir
          Dylano
          @Elfnoir
          This is great.....[ and great for a dummy like me ]
          Would you please tell me all the hardware you use?
          Or the strength of the resistor etc etc
          • E
            E
            Elfnoir
            The left resistor is a 1Mohm 2W(I'll confirm the power value once I'll received it), the right one is 4,7kohm, 1/4W.
            For the Hardware, I read the beginning of the post, but unfortunately I'm also a newby, and need to have a validation of this diagram, because I'm not sure if it is correct, and I don't want to burn my house if I'll do cabling mistakes ;-)
            I am not able to put the file created under fritzing, but if someone wants it, tell me how to do it please.
            Thanks for your feedback!
            Regards.
            • bisschopsrB
              bisschopsrB
              bisschopsr
              Hi all,
              the lamp used as a basis for this desing is now frequently offered at Aliexpress. Price is around $10,-. DOn't know about quality, but looks very simular.
              Ralph
              Domoticz, P1 meter interface, MySensors and more to come!
              • peerkersezuukerP
                peerkersezuukerP
                peerkersezuuker
                Hello All,
                Long time reader, first time poster.
                I've been building my-sensors in combo with Domoticz for a while now , and this project is one of my favorites.
                I can confirm that the fritzing schema is correct, i checked it against the one i build. (whish i had the schema earlier, it would have been so much easier ;-))
                I used the followin library from Rob Tillaart for the DHT22 (http://playground.arduino.cc/Main/DHTLib / https://github.com/RobTillaart/Arduino/tree/master/libraries/DHTlib) because the standard was not working...
                Change line 37 to dht DHT;
                comment out line 51
                From line 78 i changed the code to this :
                delay(2000);
                      int chk = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
                      temp = DHT.temperature;
                             //Serial.print("Temperature DHT :");
                             //Serial.println(temp);
                      if (isnan(temp)) {
                          lastTemp = -1;
                        lastTemp = temp;
                        if (!metric) {
                          temp = temp * 1.8 + 32.0;
                        gw.send(msgTemp.set(temp, 1));
                      hum = DHT.humidity;
                      if (isnan(hum)) {
                          lastHum = -1;
                      } else if (hum != lastHum) {
                          lastHum = hum;
                          gw.send(msgHum.set(hum, 1));
                And it is working like a charm.
                Now i ordered one of these : Wind Sensor
                I want to trie to get it working with this build.
                And indeed the lamp is stil available Solar Lamp
                Hope this helps,
                With Regard's
                Peer
                Domoticz / My Sensors / Z-Wave
                https://www.kermisbuks.nl
                peerkersezuukerP 1 Reply Last reply
                • E
                  E
                  Elfnoir
                  #75
                  Thanks for your help! I'm waiting for the LiPo charger, because I purchased a wrong one to pursue my implementation...
                  • Could you tell me how I can comment our line 51 please? Just like this?
                    'dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
                  • Also, do you have already implement the Wind Speed Module, or it's under shipment? Do you use Domoticz as domotic software? It's to know how to implement this kind of child on it?
                  • Is the solar panel providing enough power to have the weather station always working? (I'm living in France on Paris latitude, and I would like to know if the quantity of sun is enough, or I need a second solar panel)
                  • And it appears my Barometric Pressure sensor gave me also the humidity and temperature; Why do we have 1DHT22 and 1BMP180 ?
                  • And finally, how do you deal with the battery level, as I didn't see at the beginning of this post how it is implemented inside Vera? Because I would like to implement it in Domoticz
                    Many thanks for your feedback!
                  • peerkersezuukerP peerkersezuuker
                    Hello All,
                    comment out line 51
                    delay(2000);
                          if (isnan(temp)) {
                              lastTemp = -1;
                            lastTemp = temp;
                            if (!metric) {
                          hum = DHT.humidity;
                          if (isnan(hum)) {
                              lastHum = -1;
                              lastHum = hum;
                    Hope this helps,
                    With Regard's
                    Peer
                    peerkersezuukerP
                    peerkersezuukerP
                    peerkersezuuker
                    Commenting is done with //
                    so //dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
                    The wind sensor is stil in shipment, so can't tell you anything about it, and i use Domoticz as controler software.
                    I presume you have your gateway setup and connected, so the node should show up in domoticz with all the childs.
                    I tested the the weather station only a few day's past monyh, because it is still under construction, but those day's it held out (I live near Eindhoven the Netherlands, so weather conditions are almost the same as yours ;-)).
                    The battery reports through the potentiometer to A0, if the battery level = 100% the readout of A0 should be 1023 (adjustable with the portentio meter.
                    Here is my sketch in total, althoug verry crude it works, it yust needs a lot of cleanup when i am done, but i need the sensor first to work.
                        #include <dht.h>
                        #include <BH1750.h>
                        #include <Adafruit_BMP085.h>
                        #define CHILD_ID_HUM 0
                        #define CHILD_ID_TEMP 1
                        #define CHILD_ID_LIGHT 2
                        #define CHILD_ID_BARO 3
                        #define CHILD_ID_BTEMP 4
                        #define CHILD_ID_WINDSPEED 5
                        #define CHILD_ID_RAIN 6
                        #define CHILD_ID_RAINRATE 7
                        #define MESSAGEWAIT 500
                        #define nRainIn A2
                        #define DIGITAL_INPUT_RAIN_SENSOR 3
                        #define HUMIDITY_SENSOR_DIGITAL_PIN 5
                        #define ENCODER_PIN 2
                        #define INTERRUPT DIGITAL_INPUT_RAIN_SENSOR-2
                        //int encoder_pin = 7; // pulse output from the module
                        unsigned int rpm; // rpm reading
                        volatile byte pulses; // number of pulses
                        unsigned long timeold;
                        // number of pulses per revolution
                        // based on your encoder disc
                        unsigned int pulsesperturn = 1;
                        boolean metric = false;
                        int altitude = 16; // meters above sealevel
                        float lastBmpTemp = -1;
                        float lastPressure = -1;
                        float lastHum = -1;
                        float lastTemp = -1;
                        double temp;
                        double hum;
                        int BATTERY_SENSE_PIN = A0;
                        int lastRainValue = -1;
                        int nRainVal;
                        boolean bIsRaining = false;
                        String strRaining = "NO";
                        int lastBatteryPcnt = 0;
                        int updateAll = 60;
                        int updateCount = 0;
                        uint16_t lastLux;
                        // unsigned long SLEEP_TIME = 60000;
                        unsigned long SLEEP_TIME = 600;
                        int batteryBasement = 800;
                        float batteryConstant = 100.0 / (1023 - batteryBasement);
                        Adafruit_BMP085 bmp = Adafruit_BMP085();
                        BH1750 lightSensor;
                        dht DHT;
                        MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                        MyMessage msgBtemp(CHILD_ID_BTEMP, V_TEMP);
                        MyMessage msgPressure(CHILD_ID_BARO, V_PRESSURE);
                        MyMessage msgWindSpeed(CHILD_ID_WINDSPEED, V_WIND);
                        MyMessage msgRain(CHILD_ID_RAIN, V_TRIPPED);
                        MyMessage msgRainRate(CHILD_ID_RAINRATE, V_RAIN);
                        void counter()
                          //Update count
                          pulses++;
                          analogReference(INTERNAL);
                          gw.begin(incomingMessage, 3, true);
                          bmp.begin();
                          gw.sendSketchInfo("Weather Sensor", "1.0");
                          gw.present(CHILD_ID_HUM, S_HUM, "WS Humidity");
                          gw.present(CHILD_ID_TEMP, S_TEMP, "WS Temperature");
                          gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "WS Lux");
                          gw.present(CHILD_ID_BARO, S_BARO, "WS Pressure");
                          gw.present(CHILD_ID_BTEMP, S_TEMP, "WS P Temperature");
                          gw.present(CHILD_ID_WINDSPEED, S_WIND, "WS Windspeed");
                          gw.present(CHILD_ID_RAIN, S_MOTION, "WS Rain");
                          gw.present(CHILD_ID_RAINRATE, S_RAIN, "WS RainRate");
                          pinMode(DIGITAL_INPUT_RAIN_SENSOR, INPUT);
                          lightSensor.begin();
                          pinMode(ENCODER_PIN, INPUT);
                          //Interrupt 0 is digital pin 2
                          //Triggers on Falling Edge (change from HIGH to LOW)
                          attachInterrupt(0, counter, FALLING);
                          // Initialize
                          pulses = 0;
                          rpm = 0;
                          timeold = 0;
                          updateCount += 1;
                          if (updateCount == updateAll) {
                            lastTemp = -1;
                            lastHum = -1;
                            lastLux = -1;
                            lastBmpTemp = -1;
                            lastPressure = -1;
                            lastRainValue = -1;
                            lastBatteryPcnt = -1;
                            updateCount = 0;
                          delay(2000);
                          if (isnan(temp)) {
                              lastTemp = -1;
                            lastTemp = temp;
                            if (!metric) {
                          hum = DHT.humidity;
                          if (isnan(hum)) {
                              lastHum = -1;
                              lastHum = hum;
                          uint16_t lux = lightSensor.readLightLevel();
                          if (lux != lastLux) {
                              gw.send(msgLux.set(lux));
                              lastLux = lux;
                          float pressure = bmp.readSealevelPressure(altitude) * 0.01;
                          float bmptemp = bmp.readTemperature();
                          if (!metric) {
                            bmptemp = bmptemp * 1.8 + 32.0;
                          if (bmptemp != lastBmpTemp) {
                            gw.send(msgBtemp.set(bmptemp,1));
                            lastBmpTemp = bmptemp;
                          if (pressure != lastPressure) {
                            gw.send(msgPressure.set(pressure, 0));
                            lastPressure = pressure;
                          nRainVal = analogRead(nRainIn);
                                 Serial.print("RainVal :");
                                 Serial.println(nRainVal);
                          bIsRaining = !(digitalRead(DIGITAL_INPUT_RAIN_SENSOR));
                                 Serial.print("Is Raining :");
                                 Serial.println(bIsRaining);
                          if(bIsRaining){
                              strRaining = "YES";
                          else{
                              strRaining = "NO";
                      //Serial.print("Raining?: ");
                      //Serial.print(strRaining);
                      //Serial.print("\t Moisture Level: ");
                      //Serial.println(nRainVal);
                      //http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-rain-sensor-module-guide-and-tutorial/
                          gw.send(msgRain.set(bIsRaining));
                          nRainVal = nRainVal * -1;
                          gw.send(msgRainRate.set(nRainVal));
                          int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
                          if (lastBatteryPcnt != batteryPcnt) {
                            lastBatteryPcnt = batteryPcnt;
                         if (millis() - timeold >= 1000) {
                            //Don't process interrupts during calculations
                            detachInterrupt(0);
                            rpm = (60 * 1000 / pulsesperturn )/ (millis() - timeold)* pulses;
                            timeold = millis();
                            Serial.print("RPM = ");
                            Serial.println(rpm,DEC);
                            Serial.println(pulses);
                            pulses = 0;
                            rpm = rpm,DEC;
                            if (rpm == 0) {
                              rpm = 1;
                            gw.send(msgWindSpeed.set(rpm, 1));
                            //Restart the interrupt processing
                          gw.sleep(SLEEP_TIME);
                        void incomingMessage(const MyMessage & message) {
                         if (message.isAck()) {
                    And there is the puls counter which i abandoned for the wind speed meter (wanted to build my own with a optocoupler, but changed my mind).
                    Hope this is helpfull.
                    Regard's
                    Peer
                    • peerkersezuukerP
                      peerkersezuukerP
                      peerkersezuuker
                      @Elfnoir,
                      Could you please send me the fritzing schema, or attach it here ?
                      I want to add the windmeter i bought.
                      I got it today, and with a little help from google i got it working.
                      Greetz Peer
                      E 1 Reply Last reply
                        @Elfnoir,
                        Greetz Peer
                        E
                        E
                        Elfnoir
                        @peerkersezuuker 0_1459719366114_Weather Station.fzz
                        And thanks for your feedback and support!
                        • peerkersezuukerP
                          peerkersezuukerP
                          peerkersezuuker
                          So here it is :
                          0_1459792588384_upload-3adeb2e3-0d4c-41e1-a7d7-e973e5081210
                          And the code (still very rude but it works)
                              #include <dht.h>
                              #include <BH1750.h>
                              #define nRainIn A2
                              const int  windSpeedPin = 2; // contact on pin 2 digital
                              int windSpeedPinCounter = 0; // impuls counter
                              int windSpeedPinStatus = 0; // actual impuls
                              int windSpeedPinStatusAlt = 0; // oude Impuls-Status
                              unsigned long windmeterStart;
                              unsigned long windmeterStartAlt = 0;
                              int windSpeed; // Variable voor Wind Speed
                              int beaufort = 0; // Variable Wind in Beaufort
                              const int windmeterTime = 10000;
                              //float knoten = 0.0;
                              //float wind = 0.0;
                              int knoten = 0.0;
                              int wind = 0.0;
                              float lastHum = -1;
                              double temp;
                              double hum;
                              int nRainVal;
                              int updateAll = 60;
                              uint16_t lastLux;
                              BH1750 lightSensor;
                              dht DHT;
                                bmp.begin();
                              // Wind Meter https://github.com/chiemseesurfer/arduinoWeatherstation/blob/master/weatherstation/weatherstation.ino
                              float windmeter()
                                  windmeterStart = millis(); // Actual start time measuringMessung
                                  windmeterStartAlt = windmeterStart; // Save start time
                                  windSpeedPinCounter = 0; // Set pulse counter to 0
                                  windSpeedPinStatusAlt = HIGH; // Set puls status High
                                  while ((windmeterStart - windmeterStartAlt) <= windmeterTime) // until 10000 ms (10 Seconds) ..
                                      windSpeedPinStatus = digitalRead(windSpeedPin); // Read input pin 2
                                      if (windSpeedPinStatus != windSpeedPinStatusAlt) // When the pin status changed
                                          if (windSpeedPinStatus == HIGH) // When status - HIGH
                                              windSpeedPinCounter++; // Counter + 1
                                      windSpeedPinStatusAlt = windSpeedPinStatus; // Save status for next loop
                                      windmeterStart = millis(); // Actual time
                                  windSpeed =  ((windSpeedPinCounter * 24) / 10) + 0.5; //  WindSpeed - one Pulse ~ 2,4 km/h,
                                  windSpeed = (windSpeed / (windmeterTime / 1000)); // Devided in measure time in seconds
                                  Serial.print("wind Speed :");
                                  Serial.println(windSpeed);
                                  knoten = windSpeed / 1.852; //knot's
                                  return knoten;
                                updateCount += 1;
                                  lastTemp = -1;
                                  lastHum = -1;
                                  lastLux = -1;
                                  lastBmpTemp = -1;
                                  lastPressure = -1;
                                  lastRainValue = -1;
                                  updateCount = 0;
                                delay(2000);
                                if (isnan(temp)) {
                                    lastTemp = -1;
                                  lastTemp = temp;
                                  if (!metric) {
                                hum = DHT.humidity;
                                if (isnan(hum)) {
                                    lastHum = -1;
                                    lastHum = hum;
                                    lastLux = lux;
                                if (!metric) {
                                if(bIsRaining){
                                    strRaining = "YES";
                                else{
                                    strRaining = "NO";
                                wind = windmeter();
                                Serial.print("Wind :");
                                Serial.println(wind);
                                gw.send(msgWindSpeed.set(wind));
                          Still need some cleaning and calibrating (rain and wind sensor)
                          [0_1459792799776_Weather-station.fzz](/uploads/files/1459792799984-weather-station.fzz)
                          Regard's Peer
                          • peerkersezuukerP
                            peerkersezuukerP
                            peerkersezuuker
                            Oh yeah, a little source mentioning :
                            Weather Station
                            Weather Station Code
                            Greetz Peer
                            • Dombo71D
                              Dombo71D
                              Dombo71
                              Please can you ex-plane how i can remove 1 of the sensors in the sketch...
                              I will try to build more of this sensors...
                              Only 1 rain and 1 baro is good for me
                              • gigiG
                                gigiG
                                gigi
                                This is my project!!!!
                                // Example sketch för a "light switch" where you can control light or something
                                // else from both vera and a local physical button (connected between digital
                                // pin 3 and GND).
                                // This node also works as a repeader for other nodes
                                //pin sensori
                                #define PIR_PIN 2                   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                #define HUMIDITY_TEMPERATURE_PIN 3  // sensore temperatura umidita
                                #define RELAY_PIN  4                // relay pin
                                int BATTERY_SENSE_PIN = A1;         // Pin carica batteria o pannello solare
                                int FOTORESIST_SENSE_PIN = A2;      // Pin fotoresistenza
                                //interupt per sleep arduino
                                #define INTERRUPT PIR_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                                //id per vera
                                #define CHILD_ID_RELE 1   // Id relay
                                #define CHILD_ID_HUM 2    // id temperatura
                                #define CHILD_ID_TEMP 3   // id umidita
                                #define CHILD_ID_PIR 4    // Id pir
                                #define CHILD_ID_LIGHT 5  // Id luminosita (fotoresistenza)
                                //definizione per nodo vera
                                #define NODE_ID 10
                                #define SN "meteo station"
                                #define SV "1.4"
                                //variabili
                                bool state_relay;                 //stato relay
                                float batt_valore;                //dichiaro la variabile valore che memorizzerà il valore della batteria dal pin analogico
                                float batt_volt;                  //volt batteria
                                float batt_charged_percent;       //percentuale carica batteria
                                float last_batt_charged_percent;  //percentuale carica batteria precedente
                                float batt_min_voltage = 0.5;     //tensione minima batteria
                                float batt_max_voltage = 5;       //tensione massima batteria
                                float fotoresistenza_valore;      //dichiaro la variabile valore che memorizzerà il valore della fotoresistenza dal pin analogico
                                float last_fotoresistenza_valore; //dichiaro la variabile valore precedente
                                int lux_vera;                      //valore luminosita da inviare a vera
                                DHT dht_int;
                                float lastTemp_int = -1;
                                float lastHum_int = -1;
                                boolean metric = true;
                                MyMessage msgRelay(CHILD_ID_RELE,V_LIGHT);
                                MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
                                  gw.begin(incomingMessage, NODE_ID, false);
                                  gw.sendSketchInfo(SN, SV);
                                  //Sensore umidita temperatura
                                  dht_int.setup(HUMIDITY_TEMPERATURE_PIN);
                                  gw.present(CHILD_ID_RELE, S_LIGHT);       //light vera
                                  gw.present(CHILD_ID_HUM, S_HUM);          //umidity vera
                                  gw.present(CHILD_ID_TEMP, S_TEMP);           // temp vera
                                  gw.present(CHILD_ID_PIR, S_MOTION);          // motion vera
                                  gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);  //light level (fotoresistenza)
                                  pinMode(RELAY_PIN, OUTPUT);
                                  //PIR
                                  pinMode(PIR_PIN, INPUT);
                                  state_relay = 0;
                                  //GestisciRelay();
                                  digitalWrite(RELAY_PIN, LOW);
                                  gw.send(msgRelay.set(state_relay));
                                    //sensore temperatura umidita
                                    delay(dht_int.getMinimumSamplingPeriod());
                                    float temperature_int = dht_int.getTemperature();
                                    if (isnan(temperature_int))
                                        lastTemp_int = -1;
                                    else if (temperature_int != lastTemp_int)
                                      lastTemp_int = temperature_int;
                                      if (!metric)
                                        temperature_int = dht_int.toFahrenheit(temperature_int);
                                      gw.send(msgTemp.set(temperature_int, 1));
                                      Serial.print("T int: ");
                                      Serial.println(temperature_int);
                                    float humidity_int = dht_int.getHumidity();
                                    if (isnan(humidity_int))
                                        lastHum_int = -1;
                                    else if (humidity_int != lastHum_int)
                                        lastHum_int = humidity_int;
                                        gw.send(msgHum.set(humidity_int, 1));
                                        Serial.print("H int: ");
                                        Serial.println(humidity_int);
                                    //fotoresistenza
                                    for(int i=0;i<150;i++)
                                      fotoresistenza_valore += analogRead(FOTORESIST_SENSE_PIN);  //read the input voltage from battery or solar panel
                                      delay(2);
                                    fotoresistenza_valore = fotoresistenza_valore / 150;
                                    Serial.print ("fotoresistenza: ");
                                    Serial.println(fotoresistenza_valore);
                                    if (fotoresistenza_valore != last_fotoresistenza_valore)
                                      lux_vera = (int) fotoresistenza_valore;
                                      gw.send(msgLux.set(lux_vera));
                                      last_fotoresistenza_valore = fotoresistenza_valore;
                                    //fotoresistenza
                                    //pir relay
                                    // Read digital motion value
                                    boolean tripped = digitalRead(PIR_PIN) == HIGH;
                                    Serial.println("pir:");
                                    Serial.println(tripped);
                                    gw.send(msgPir.set(tripped?"1":"0"));  // Send tripped value to gw
                                    //accende la luce con il buio
                                    if (fotoresistenza_valore < 200)  //poca luce
                                      if (tripped == 1)
                                         state_relay = 1;
                                         state_relay = 0;
                                    GestisciRelay();
                                    //pir relay
                                    //battery
                                      batt_valore += analogRead(BATTERY_SENSE_PIN);  //read the input voltage from battery or solar panel
                                      delay(2);
                                    batt_valore = batt_valore / 150;
                                    Serial.print ("batt_valore: ");
                                    Serial.println(batt_valore);
                                    batt_volt = (batt_valore / 1024) * batt_max_voltage;
                                    Serial.print ("batt_volt: ");
                                    Serial.println(batt_volt);
                                   //The map() function uses integer math so will not generate fractions
                                   // so I multiply battery voltage with 10 to convert float into a intiger value
                                   // when battery voltage is 6.0volt it is totally discharged ( 6*10 =60)
                                   // when battery voltage is 7.2volt it is fully charged (7.2*10=72)
                                   // 6.0v =0% and 7.2v =100%
                                   //batt_charged_percent = batt_volt*10;
                                   //batt_charged_percent = map(batt_volt*10, 60 , 72, 0, 100);
                                    batt_charged_percent = batt_volt * 10;
                                    batt_charged_percent = map(batt_volt * 10, batt_min_voltage * 10 , batt_max_voltage * 10, 0, 100);
                                    //batt_charged_percent = (batt_volt / batt_max_voltage) * 100;
                                    Serial.print ("batt_charged_percent: ");
                                    Serial.println(batt_charged_percent);
                                    if (last_batt_charged_percent != batt_charged_percent)
                                        gw.sendBatteryLevel(batt_charged_percent);
                                        last_batt_charged_percent = batt_charged_percent;
                                    //battery
                                    delay(50);
                                    gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                                     // Change relay state_relay
                                     state_relay = message.getBool();
                                     GestisciRelay();
                                void GestisciRelay()
                                    //Serial.print(" GestisciRelay state_relay:");
                                    //Serial.println(state_relay);
                                    if (state_relay == 0)
                                      //Serial.println("SPENTO RELAY");
                                      digitalWrite(RELAY_PIN, HIGH);
                                      //Serial.println("ACCESO RELAY");
                                On vera
                                On board
                                Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
                                • gigiG
                                  gigiG
                                  gigi
                                  I purchased a solar kit
                                  Solar Panel
                                  battery 12v
                                  landstar solar charge controller
                                  I want to insert into Arduino in output of charge controller (I have 12 volts)
                                  to lower the voltage can I use a mobile charger Car 1 Ah
                                  do you heat so much?
                                  Thank
                                  @Salmoides Good Project!!!!!
                                  • Dombo71D
                                    Dombo71D
                                    Dombo71
                                    what are the resistors? Or what do you u use between the wires?
                                    Look simple to me..
                                    gigiG 1 Reply Last reply
                                    • Dombo71D Dombo71
                                      Look simple to me..
                                      gigiG
                                      gigiG
                                      gigi
                                      @Dombo71 look a fritzing schematic
                                      DidiD 1 Reply Last reply
                                      • gigiG gigi
                                        DidiD
                                        DidiD
                                        Didi
                                        Can you share the fritzing file please
                                        • DidiD Didi
                                          gigiG
                                          gigiG
                                          gigi
                                          @Didi 0_1459967939633_schema-pannello-solare-2.fzz
                                          Fritzing File!!!!
