  3. Domoticz
  4. Domoticz and heater
Domoticz and heater
8 Posts 4 Posters 5.0k Views 4 Watching
  • siklosiS Offline
    siklosiS Offline
    siklosi
    How can I set setpoint from domoticz. I tried with gw.present(7, S_HEATER). I see in hardware that S_HEATER is present but there is no device reported. Also on that same node I have one dht22 and ds18s20 sensors and in domoticz humidity is reported on both sensors. Is there a way to send values so that domoticz separates them (I tried setting same child for temp and hum from dht22 and other id for ds18s20 but again I get combined temp/hum for both sensors)
    • S Offline
      Hi
      1. the node is not presented until the first value is reported - maybe thats the problem, try to send the current heater value on startup.
      2. I dont know, tried as well but didnt find any sollution.
      • siklosiS Offline
        siklosiS Offline
        siklosi
        You were right. It works now. Thank you.
        • jlehtinenJ Offline
          jlehtinenJ Offline
          jlehtinen
          Have you (or anyone else here) figured out the solution for 2nd problem (humidity reported for both sensors DTH22 and DS18S20 when in same node)? I have node with DTH22 for indoor temp/hum and DS18S20 for outdoor temp and get outdoor temp with indoor humidity in the Domoticz graph. :-(
          • S Offline
            @jlehtinen - Are they connected to the same node (ie presented as the same nodeid)? If so they will be merged as a weatherstation and presented as one. Thats how Domoticz i made and i dont know any sollution for this... there is a ongoing discussion at the moment on Domoticz forum about this and wind meter.
              jlehtinenJ Offline
              jlehtinen
              Yes, both sensor DTH22 and DS18S20 are connected to same physical node i.e. are reporting using same nodeid. OK, so the easiest solution is not to mix multiple temp and humidity sensors in same physical node. Time to built a dedicated node for outdoor temp. Thanks @sundberg84! :thumbsup:
              • H Offline
                H Offline
                HarryDutch
                @sundberg84 , @jlehtinen
                I've solved this problem with a LUA script in Domoticz. The script copies the values of temperature and humidity to a TEXT sensor (as a string). In the Arduino sketch (you need the MySensors development branch) the string is split in 2 separate values (Strings). Works like a charm.
                LUA script:
                   tempString = ""
                   stringReturn = ""
                   sensor = '103OutsideTempHum'
                   tempString = otherdevices_svalues[sensor]
                   sep = ";"
                   i=1
                   for str in string.gmatch(tempString, "([^"..sep.."]+)") do
                      stringReturn = stringReturn .. str .. "#"
                      i = i + 1
                   end
                commandArray = {}
                   time = os.date("*t")
                   if ((time.min % 5)==0) then--run script every 5 minutes
                   commandArray[1] = {['UpdateDevice'] = 77 .. '|0|' .. tostring(stringReturn)} -- 77 = idx of TEXT sensor in Domoticz
                   end
                return commandArray
                Arduino sketch:
                #include <TFT_ILI9341.h>
                #define CHILD_ID_TEXT 1
                #define CHILD_ID_BUTTON 2
                #define MIN_V 2600
                #define MAX_V 3200
                #define sclk 13  // Don't change
                #define mosi 11  // Don't change
                #define cs   17
                #define dc   16
                #define rst  15  // you can also connect this to the Arduino reset
                TFT_ILI9341 tft = TFT_ILI9341();
                void Button() {}
                int interrupt;
                String tempSensor;
                byte batteryPcnt;
                MyMessage msgTemp(CHILD_ID_TEXT, V_TEXT);
                MyMessage msgButton(CHILD_ID_BUTTON, V_STATUS);
                  sendSketchInfo("103 TEST", "1.0");
                  present(CHILD_ID_TEXT, S_INFO);
                  present(CHILD_ID_BUTTON, S_BINARY);
                  Serial.begin(9600);
                  pinMode(4, OUTPUT);
                  digitalWrite(4, HIGH);
                  pinMode(3, INPUT_PULLUP); // int 1 used by button
                  attachInterrupt(digitalPinToInterrupt(3), Button,FALLING);
                  if(interrupt == 1)
                    send(msgButton.set(1));
                    request(CHILD_ID_TEXT, V_TEXT);
                    batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100);
                    wait(500);
                    Screen();
                    send(msgButton.set(0));
                  digitalWrite(rst, LOW);
                  wait(10);
                  interrupt = sleep(1,FALLING);
                  if (message.sensor == 1)
                    tempSensor = message.getString();
                  wait(200);
                //====== Show screen after hitting button ==============================
                void Screen()
                  digitalWrite(4, LOW);
                  wait(10);
                  tft.init();
                  tft.setRotation(2);
                  char c_tmp[6];
                  char c_hum[6];
                  int sepIndex1 = tempSensor.indexOf('#');
                  int sepIndex2 = tempSensor.indexOf('#',sepIndex1+1);
                  String tmp = tempSensor.substring(0,sepIndex1);
                  String hum = tempSensor.substring(sepIndex1+1,sepIndex2);
                  tft.fillScreen(ILI9341_BLACK);
                  wait(5);//don't touch this!!
                  tft.setTextSize(1);
                  tft.fillRoundRect(5, 5, 230, 180, 10, ILI9341_WHITE);
                  tft.setTextColor(ILI9341_BLUE);
                  tmp.toCharArray(c_tmp, 6);
                  tft.drawCentreString(c_tmp,120,50,8);
                  tft.fillRoundRect(5, 190, 230, 90, 10, ILI9341_WHITE);
                  tft.setTextColor(ILI9341_BLACK);
                  tft.setCursor(10,200,4);
                  tft.print("Humidity ");
                  tft.setCursor(120,200,4);
                  hum.toCharArray(c_hum, 6);
                  tft.print(c_hum); tft.print(" %");
                  tft.setCursor(200,245,4);
                  tft.print(batteryPcnt);
                  wait(15000L);
                long readVcc() {
                  jlehtinenJ Offline
                  jlehtinen
                  Thanks @HarryDutch! Good to know that there is a way around this hum temp issue. 👍
