  3. Code problem
Code problem
6 Posts 3 Posters 1.7k Views 3 Watching
  • M Offline
    M Offline
    moskovskiy82
    Trying to implement a code for a kitchen hood with 4 push buttons which send the data to the controller.
    Also have 3 dimmers.
    The problem is that only the first 2 buttons work (not a hardware problem) and they only set their state to 1 and never to 0. Please advice on solution (MQ and DHT code is commented out for now)
    #define SN "Kitchen Hood"
    #define SV "1.0"
    #include <math.h>
    //DEFINE CHILD_IDS
    #define DIMMER_NODE_1 0
    #define DIMMER_NODE_2 1
    #define DIMMER_NODE_3 2
    #define CHILD_ID_HUM 4
    #define CHILD_ID_TEMP 5
    #define CHILD_ID_MQ 6
    #define CHILD_BUT1 7
    #define CHILD_BUT2 8
    #define CHILD_BUT3 9
    #define CHILD_BUT4 10
    //BUTTONS
    #define BUTTON_PIN1  A4
    #define BUTTON_PIN2  A5
    #define BUTTON_PIN3  A6
    #define BUTTON_PIN4  A7
    //MQ+DHT
    #define HUMIDITY_SENSOR_DIGITAL_PIN 8
    const int MQ_Pin = A3;
    //DIMMER
    #define LED_PIN_1 3
    #define LED_PIN_2 5
    #define LED_PIN_3 6
    #define FADE_DELAY 10
    DHT dht;
    //BUTTONS
    Bounce debouncer_1 = Bounce();
    Bounce debouncer_2 = Bounce();
    Bounce debouncer_3 = Bounce();
    Bounce debouncer_4 = Bounce();
    int oldValue_1=-1;
    int oldValue_2=-1;
    int oldValue_3=-1;
    int oldValue_4=-1;
    bool state1;
    bool state2;
    bool state3;
    bool state4;
    MyMessage msgbut1(CHILD_BUT1,V_TRIPPED);
    MyMessage msgbut2(CHILD_BUT2,V_TRIPPED);
    MyMessage msgbut3(CHILD_BUT3,V_TRIPPED);
    MyMessage msgbut4(CHILD_BUT4,V_TRIPPED);
    //MQ+DHT
    float lastTemp;
    float lastHum;
    float hum_floa;
    float last_mq_reading;
    MyMessage msgMQ(CHILD_ID_MQ, V_LEVEL);
    //DIMMER
    byte currentLevel[3] = {0,0,0};
    MyMessage dimmerMsg0(0, V_DIMMER);
    MyMessage lightMsg0(0, V_LIGHT);
    MyMessage dimmerMsg1(1, V_DIMMER);
    MyMessage lightMsg1(1, V_LIGHT);
    MyMessage dimmerMsg2(2, V_DIMMER);
    MyMessage lightMsg2(2, V_LIGHT);
      Serial.begin(9600);
      Serial.println( SN );
      gw.begin( incomingMessage, 71 );
      gw.sendSketchInfo(SN, SV);
      //MQ+DHT
     /* dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
      gw.present(CHILD_ID_MQ, S_AIR_QUALITY);
      gw.wait( 50 );
      //DIMMER
      gw.present( DIMMER_NODE_1, S_DIMMER );
      gw.wait( 50 );
      gw.present( DIMMER_NODE_2, S_DIMMER );
      gw.wait( 50 );
      gw.present( DIMMER_NODE_3, S_DIMMER );
      gw.wait( 50 );
      gw.request( DIMMER_NODE_1, V_DIMMER );
      gw.wait( 50 );
      gw.request( DIMMER_NODE_2, V_DIMMER );
      gw.wait( 50 );
      gw.request( DIMMER_NODE_3, V_DIMMER );
      //BUTTONS
      pinMode(BUTTON_PIN1,INPUT);
      pinMode(BUTTON_PIN2,INPUT);
      pinMode(BUTTON_PIN3,INPUT);
      pinMode(BUTTON_PIN4,INPUT);
      digitalWrite(BUTTON_PIN1, HIGH);
      digitalWrite(BUTTON_PIN2, HIGH);
      digitalWrite(BUTTON_PIN3, HIGH);
      digitalWrite(BUTTON_PIN4, HIGH);
      debouncer_1.attach(BUTTON_PIN1);
      debouncer_1.interval(5);
      debouncer_2.attach(BUTTON_PIN2);
      debouncer_2.interval(5);
      debouncer_3.attach(BUTTON_PIN3);
      debouncer_3.interval(5);
      debouncer_4.attach(BUTTON_PIN4);
      debouncer_4.interval(5);
      gw.present(CHILD_BUT1, S_LIGHT);
      gw.wait( 50 );
      gw.present(CHILD_BUT2, S_LIGHT);
      gw.wait( 50 );
      gw.present(CHILD_BUT3, S_LIGHT);
      gw.wait( 50 );
      gw.present(CHILD_BUT4, S_LIGHT);
      gw.wait( 50 );
    int value_but_1 = debouncer_1.read();
    int value_but_2 = debouncer_2.read();
    int value_but_3 = debouncer_3.read();
    int value_but_4 = debouncer_3.read();
    //BUTTONS
      debouncer_1.update();
      if (value_but_1 != oldValue_1 && value_but_1==0)
         gw.send(msgbut1.set(state1?false:true), true);
         oldValue_1 = value_but_1;
      debouncer_2.update();
        if (value_but_2 != oldValue_2 && value_but_2==0)
         gw.send(msgbut2.set(state2?false:true), true);
         oldValue_2 = value_but_2;
      debouncer_3.update();
         if (value_but_3 != oldValue_3 && value_but_3==0)
         gw.send(msgbut3.set(state3?false:true), true);
         oldValue_3 = value_but_3;
      debouncer_4.update();
         if (value_but_4 != oldValue_4 && value_but_4==0)
         gw.send(msgbut4.set(state4?false:true), true);
         oldValue_4 = value_but_4;
    //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    //DHT+MQ
    /*  delay(dht.getMinimumSamplingPeriod());
      if (isnan(temperature))
      { Serial.println("Failed reading temperature from DHT"); }
      else if (temperature != lastTemp)
      { lastTemp = temperature;
      if (isnan(humidity))
      { Serial.println("Failed reading humidity from DHT"); }
      else if (humidity != lastHum)
      {  lastHum = humidity;
      float mq_reading = analogRead(MQ_Pin);
      if (isnan(mq_reading))
      { Serial.println("Failed mq_reading"); }
      else if (mq_reading != last_mq_reading)
      { last_mq_reading = mq_reading;
        gw.send(msgMQ.set(mq_reading, 1));
    //DIMMER
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        Serial.print( "Changing level to " );
        Serial.print( ", from " );
        Serial.println( currentLevel[message.sensor] );
        fadeToLevel( requestedLevel, message.sensor);
    switch(message.sensor)
        case 0:
          gw.send(lightMsg0.set(currentLevel[0] > 0 ? 1 : 0));
          gw.send( dimmerMsg0.set(currentLevel[0]) );
        case 1:
          gw.send(lightMsg1.set(currentLevel[1] > 0 ? 1 : 0));
          gw.send( dimmerMsg1.set(currentLevel[1]) );
        case 2:
          gw.send(lightMsg2.set(currentLevel[2] > 0 ? 1 : 0));
          gw.send( dimmerMsg2.set(currentLevel[2]) );
    void fadeToLevel( int toLevel, byte sensorId ) {
      int delta = ( toLevel - currentLevel[sensorId] ) < 0 ? -1 : 1;
      while ( currentLevel[sensorId] != toLevel ) {
        currentLevel[sensorId] += delta;
      switch(sensorId)
        case 0:
          analogWrite( LED_PIN_1, (int)(currentLevel[sensorId] / 100. * 255) );
        case 1:
          analogWrite( LED_PIN_2, (int)(currentLevel[sensorId] / 100. * 255) );
        case 2:
          analogWrite( LED_PIN_3, (int)(currentLevel[sensorId] / 100. * 255) );
         delay( FADE_DELAY );
    • M moskovskiy82
      #define SV "1.0"
      #include <math.h>
      //DEFINE CHILD_IDS
      //BUTTONS
      //MQ+DHT
      //DIMMER
      #define LED_PIN_1 3
      #define LED_PIN_2 5
      #define LED_PIN_3 6
      DHT dht;
      //BUTTONS
      int oldValue_1=-1;
      int oldValue_2=-1;
      int oldValue_3=-1;
      int oldValue_4=-1;
      bool state1;
      bool state2;
      bool state3;
      bool state4;
      //MQ+DHT
      float lastTemp;
      float lastHum;
      float hum_floa;
      //DIMMER
        Serial.begin(9600);
        //MQ+DHT
        gw.wait( 50 );
        //DIMMER
        gw.wait( 50 );
        gw.wait( 50 );
        gw.wait( 50 );
        gw.wait( 50 );
        gw.wait( 50 );
        //BUTTONS
        gw.wait( 50 );
        gw.wait( 50 );
        gw.wait( 50 );
        gw.wait( 50 );
      //BUTTONS
      //DHT+MQ
      //DIMMER
          case 0:
          case 1:
          case 2:
        switch(sensorId)
          case 0:
          case 1:
          case 2:
      T Offline
      T Offline
      TheoL
      wrote on last edited by TheoL
      @moskovskiy82 You're not checking whether the debouncer's value have changed.
      debouncer_1.update() returns a boolean, which is telling you whether the state of a switch has changed. Try this
        if ( debouncer_1.update() ) {
            if (value_but_1 != oldValue_1 && value_but_1==0) {
      • mfalkviddM Offline
        A6 and A7 don't have pullups on most Arduinos so that might be a reason.
        Since you are not reading analog, you can use the digital pins instead.
        • M Offline
          M Offline
          moskovskiy82
          They are all occupied by the mosfet dimmers (PWM). I will shift than to a0-a4. Thanks!
          • M Offline
            M Offline
            moskovskiy82
            Got it working with the followoing code
              if (value_but_1 != oldValue_1)
              if ( value_but_1==0)
                 state1 = !state1;
                 gw.send(msgbut1.set(state1, true));
            Only problem left - it's giving value 1.0 instead of 1.
            And I wonder which type of message it should be V-LIGHT or V_TRIPPED
            MyMessage msgbut3(CHILD_BUT3,V_LIGHT);
            • M Offline
              M Offline
              moskovskiy82
              Well everything almost fixed. The code if somebody will be building something similar...
              4 push buttons attached and 3 dimmers + MQ and DHT22
              All the logic is supposed to be handled by the controller.
              Problems remaining... If you set the button state in the controller - it doesn't get updated on the node... Any hints appreciated on this
              And the major problem - if the node resets the LIGHTS are ON! As has been hinted in another topic the code has to be rewritten so in the beginning it sets the values to zero and informs the controller isntead of pulling values. But my lack of knowledge stops me on this one. So help will be much appreciated
              #define SV "1.0"
              #include <math.h>
              //DEFINE CHILD_IDS
              //BUTTONS
              #define BUTTON_PIN1  A0
              #define BUTTON_PIN2  A1
              #define BUTTON_PIN3  A2
              #define BUTTON_PIN4  A3
              //MQ+DHT
              const int MQ_Pin = A4;
              //DIMMER
              #define LED_PIN_1 3
              #define LED_PIN_2 5
              #define LED_PIN_3 6
              DHT dht;
              //BUTTONS
              int oldValue_1=-1;
              int oldValue_2=-1;
              int oldValue_3=-1;
              int oldValue_4=-1;
              bool state1;
              bool state2;
              bool state3;
              bool state4;
              //MQ+DHT
              float lastTemp;
              float lastHum;
              float hum_floa;
              //DIMMER
                Serial.begin(9600);
                gw.begin( incomingMessage );
                //MQ+DHT
                gw.wait( 50 );
                //DIMMER
                gw.wait( 50 );
                gw.wait( 50 );
                gw.wait( 50 );
                gw.wait( 50 );
                gw.wait( 50 );
                //BUTTONS
                gw.present(CHILD_BUT1, S_DOOR);
                gw.wait( 50 );
                gw.present(CHILD_BUT2, S_DOOR);
                gw.wait( 50 );
                gw.present(CHILD_BUT3, S_DOOR);
                gw.wait( 50 );
                gw.present(CHILD_BUT4, S_DOOR);
                gw.wait( 50 );
              int value_but_4 = debouncer_4.read();
              //BUTTONS
                   state1 = !state1;
                   gw.send(msgbut1.set(state1));
                if (value_but_2 != oldValue_2)
                if ( value_but_2==0)
                   state2 = !state2;
                   gw.send(msgbut2.set(state2));
                if (value_but_3 != oldValue_3)
                if ( value_but_3==0)
                   state3 = !state3;
                   gw.send(msgbut3.set(state3));
                if (value_but_4 != oldValue_4)
                if ( value_but_4==0)
                   state4 = !state4;
                   gw.send(msgbut4.set(state4));
              //DHT+MQ
              //DIMMER
                  case 0:
                  case 1:
                  case 2:
                switch(sensorId)
                  case 0:
                  case 1:
                  case 2:
              12.2k
