  3. Multi-button relay switch without debounce
9 Posts 3 Posters 3.2k Views 3 Watching
  • CJ CassarinoC Offline
    CJ Cassarino
    I am trying to figure out how to have multiple relays (2 in my case) with a button to trip the relays but without the debounce. I want the relay to only be active while the switch is being pushed. Could anyone help me with this?
    • AndurilA Offline
      AndurilA Offline
      Anduril
      why do you want to do that without debounce? Afaik there is no downside on using the debounce lib to get a smoother switching behaviour.
      CJ CassarinoC 1 Reply Last reply
      • AndurilA Anduril
        CJ Cassarino
        @Anduril
        Because I am controlling an actuator with the ability for manual controls with a button. I want 1 button when held down to open it and another button when held down to close. With debounce I have to click it to open, click it again to turn of relay, then click the other button to retract, and then click to turn of relay.
        • mfalkviddM Offline
          The bounce2 library supports detecting changes. See this example https://github.com/thomasfredericks/Bounce2/blob/master/examples/change/change.ino
            CJ Cassarino
            @mfalkvidd
            I get this error "'class Bounce' has no member named 'fell'"
              You'll probably need Bounce2 then.
                CJ Cassarino
                @mfalkvidd
                I have bounce2... Ill try redownloading it
                • AndurilA Offline
                  AndurilA Offline
                  Anduril
                  When downloading MySensors this library is included. For usage see MySensors example 'BinarySwitchSensor'.
                  • AndurilA Anduril
                    CJ Cassarino
                    @Anduril
                    Yea thats what I thought, and I see it. Ill check this out thanks
