  3. rfm69 and atc
rfm69 and atc
49 Posts 13 Posters 21.1k Views 12 Watching
    cool it compiles after updated rfm69 lib. I do some define and tests, and I will try my first PR ;) I also need to check what are all diff between old and new lib. can't wait to try listenmode now...
    • D
      DavidZH
      I will keep a very close eye on this!
      Listen mode is very interesting, but also the possible prolonged battery life from the other sensors!!!
      Big thumbs up! :+1:
        thx. so far so good ;)
        I had a little bit time last night...I think I will rename this topic "improvements for our mysensors rfm69 lib" lol :)
        I diff checked with mysensors rfm69 driver lib: latest lowpowerlab rfm69 lib (master+spi transaction version) + few others variant I found to see if something could be missing. So I started from mysensors rfm69 driver one and added step by step the changes, and of course not forgot to keep boards define (atsam, esp, 328...) + checked the purpose of these changes.
        The list of improvements I noticed:
        • ATC, Automatic Transfer Power Control : merged, working (not the biggest part)
        • small improvements on spi transaction part : merged but not full tested. I don't use ethernet shield, so just tested with eeprom but I think this change was mostly made for things like w5100 shield...if I have time I will try to make more tests on this..
        • ListenMode : still, in progress but in a good way I think :) Almost merged but not tested yet (was too late!!). For the moment it compiles. It will need some tests I think to see if all properly works, power consumption..At lowpowerlab they get very few ua (1-2ua order) in listenmode. sounds great I hope to have same success. I need register to their forum at least to thx them. not done. booo :flushed:
        • with this listenmode, I plan to use gammon sketch J. I already did tests and noticed a better low consumption than lowpowerlab sleep of mysensors. but I will check if it's still the same case
        • still about sleep mode, I will look if it's possible to improve wakeup time, I read interesting things.
        • when all this will be ok, I will try to see if it's interesting to use sort of WDT Listenmode : a wdt done by rssi using listenmode. but that's at the end of the list! and needs to see then if it's better or not than common wdt power consumption. but that looks tempting because common wdt don't do listenmode...
        Files impacted for those interested to know:
        • rfm69 libs updated
        • rfm69_atc added
        • myTransportRFM69 updated
        • one cpp include in mysensor.h
        • few define in myconfig.h
        • mysensorscore, transport, hw..to add a SleepWithListenMode method ...For the moment I add my own sleep method to not break anything and keep mysensors archi...
        Some stuff, I hope I will have everything ok! But I'm very happy doing this as now I am a lot lot more confident with mysensors archi. very cool :)
        see you soon :)
        • F
          F
          Fabien
          very good work ! especially for ATC and Listenmode.
          • L
            L
            lafleur
            Is the code mods on Github for us to look at??
            • FrancoisF
              FrancoisF
              Francois
              @scalz how is atc working on the rfm69?
                @Francois sorry this work is still in progress, I will work on it this week.
                This is handled in the rfm69 lib. And lowpowerlab explains this well: copied from Lowpowerlab
                • "The basic idea behind this extension is to allow your nodes to dial down transmission power based on the received signal strength indicator (RSSI)."
                • "with RFM69_ATC this is done automatically for you, you just need to indicate a target RSSI. On each packet sent and ACK received (using sendWithRetry(…) is required), the node analyzes the actual RSSI and continuously adjusts its own transmission power level of the RFM69 transceiver to attempt to match the target RSSI (+ or -)"
                Require some small changes in libs, but for the moment I have to check/think few things for the listenmode to have everything well packaged with mysensors..not finished yet.
                • L
                  L
                  lafleur
                  have you tested the code enough to release it for our use and testing??
                    @lafleur
                    no, not yet. sorry for delay. I have no time actually..and I think perhaps lowpowerlab team is preparing few changes in their lib. so I am delaying a bit to finish other things in the mean time, and to see if they add new features. then, if nothing new, I will finish this if someone didn't beat me on this ;)
                    but I will try to do my best :)
                    L 1 Reply Last reply
                    • scalzS scalz
                      @lafleur
                      L
                      L
                      lafleur
                      wrote on last edited by lafleur
                      @scalz
                      I have it working to some extent, send me what you have and I will add your changes to what I've done to make sure I did not miss anything...
                      Then I will post the changes to the development branch
                      tom --at-- lafleur --.-- us
                      • L
                        L
                        lafleur
                        I have all this working now and have 7 devices on it to a serial gateway...
                        Using new RFM69 driver and RFM69_ATC...
                        Its interesting to see the power levels change as packets flow...
                        If I can figure out how to do a PULL request, I will make it happen to 2.0b development branch...
                        tom
                          :thumbsup:
                          sorry for delayed answer, a bit busy, I have actually no time to look at/share my experiments :confused:
                          I found this interesting too, seeing powerlevels change. btw I didn't finish the listenmode part, I'm on other things for the moment, so that's great if your are doing the job :)
                          thx ;)
                            #23
                            hi guys.
                            just a little update to say that I'm back on this :blush:
                            it's still a wip so I will share/release a bit later ;)
                            I have this working in mysensors dev for the moment.
                            • I can get rssi value.
                            • atc power mode.
                            • listenmode : an mqtt esp8266 GW is peridocially waking up a proto node which is in deepsleep (the node is woken up by INT0 triggered by the radio of course). I will mainly use this for sort of remote watchdog for some of my nodes etc..
                            • F
                              F
                              Fabien
                              @scalz, good work ! Nice features.
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                @scalz As you noticed I have just started with rfm69 and thanks for your help in the other thread. Really looking forward to your work as ATC is something I am missing in MySensors.
                                  @alexsh1 : thx. i know i have not pr this yet..it's still working local but have not done extended tests as I'm busy improving mqtt wifi gw..but i will do my best
                                  • FleischtorteF
                                    FleischtorteF
                                    Fleischtorte
                                    Hi Scalz,
                                    any progress here? Cant wait to use ATC and the rssi-value for my nodes :D
                                    Thanks for your work :thumbsup:
                                    regards
                                    david
                                    carlierdC 1 Reply Last reply
                                    • FleischtorteF Fleischtorte
                                      Hi Scalz,
                                      regards
                                      david
                                      carlierdC
                                      carlierdC
                                      carlierd
                                      @Fleischtorte So I am not the only one David waiting for ATC and RSSI ;)
                                      David.
                                      • FleischtorteF
                                        FleischtorteF
                                        Fleischtorte
                                        @carlierd Yeah Davids FTW :D
                                        • frenchoF
                                          frenchoF
                                          frencho
                                          @lafleur @scalz
                                          Hi guys,
                                          Have one of you succed with the PR, so we can enjoy at least the ATC feature.
                                          This is really the down side with the RFM69HW, power consumption so your work could be really helpfull !
                                          Really thank you for that
                                          Your second life begins when you understand you only have one !
