  3. rfm69 and atc
rfm69 and atc
49 Posts 13 Posters 21.1k Views 12 Watching
  • L
    L
    lafleur
    Is the code mods on Github for us to look at??
    • FrancoisF
      FrancoisF
      Francois
      @scalz how is atc working on the rfm69?
        @Francois sorry this work is still in progress, I will work on it this week.
        This is handled in the rfm69 lib. And lowpowerlab explains this well: copied from Lowpowerlab
        • "The basic idea behind this extension is to allow your nodes to dial down transmission power based on the received signal strength indicator (RSSI)."
        • "with RFM69_ATC this is done automatically for you, you just need to indicate a target RSSI. On each packet sent and ACK received (using sendWithRetry(…) is required), the node analyzes the actual RSSI and continuously adjusts its own transmission power level of the RFM69 transceiver to attempt to match the target RSSI (+ or -)"
        Require some small changes in libs, but for the moment I have to check/think few things for the listenmode to have everything well packaged with mysensors..not finished yet.
        • L
          L
          lafleur
          have you tested the code enough to release it for our use and testing??
            @lafleur
            no, not yet. sorry for delay. I have no time actually..and I think perhaps lowpowerlab team is preparing few changes in their lib. so I am delaying a bit to finish other things in the mean time, and to see if they add new features. then, if nothing new, I will finish this if someone didn't beat me on this ;)
            but I will try to do my best :)
            L 1 Reply Last reply
            • scalzS scalz
              @lafleur
              L
              L
              lafleur
              wrote on last edited by lafleur
              @scalz
              I have it working to some extent, send me what you have and I will add your changes to what I've done to make sure I did not miss anything...
              Then I will post the changes to the development branch
              tom --at-- lafleur --.-- us
              • L
                L
                lafleur
                I have all this working now and have 7 devices on it to a serial gateway...
                Using new RFM69 driver and RFM69_ATC...
                Its interesting to see the power levels change as packets flow...
                If I can figure out how to do a PULL request, I will make it happen to 2.0b development branch...
                tom
                  :thumbsup:
                  sorry for delayed answer, a bit busy, I have actually no time to look at/share my experiments :confused:
                  I found this interesting too, seeing powerlevels change. btw I didn't finish the listenmode part, I'm on other things for the moment, so that's great if your are doing the job :)
                  thx ;)
                    #23
                    hi guys.
                    just a little update to say that I'm back on this :blush:
                    it's still a wip so I will share/release a bit later ;)
                    I have this working in mysensors dev for the moment.
                    • I can get rssi value.
                    • atc power mode.
                    • listenmode : an mqtt esp8266 GW is peridocially waking up a proto node which is in deepsleep (the node is woken up by INT0 triggered by the radio of course). I will mainly use this for sort of remote watchdog for some of my nodes etc..
                    • F
                      F
                      Fabien
                      @scalz, good work ! Nice features.
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        @scalz As you noticed I have just started with rfm69 and thanks for your help in the other thread. Really looking forward to your work as ATC is something I am missing in MySensors.
                          @alexsh1 : thx. i know i have not pr this yet..it's still working local but have not done extended tests as I'm busy improving mqtt wifi gw..but i will do my best
                          • FleischtorteF
                            FleischtorteF
                            Fleischtorte
                            Hi Scalz,
                            any progress here? Cant wait to use ATC and the rssi-value for my nodes :D
                            Thanks for your work :thumbsup:
                            regards
                            david
                            carlierdC 1 Reply Last reply
                            • FleischtorteF Fleischtorte
                              Hi Scalz,
                              regards
                              david
                              carlierdC
                              carlierdC
                              carlierd
                              @Fleischtorte So I am not the only one David waiting for ATC and RSSI ;)
                              David.
                              • FleischtorteF
                                FleischtorteF
                                Fleischtorte
                                @carlierd Yeah Davids FTW :D
                                • frenchoF
                                  frenchoF
                                  frencho
                                  @lafleur @scalz
                                  Hi guys,
                                  Have one of you succed with the PR, so we can enjoy at least the ATC feature.
                                  This is really the down side with the RFM69HW, power consumption so your work could be really helpfull !
                                  Really thank you for that
                                  Your second life begins when you understand you only have one !
                                  • frenchoF frencho
                                    @lafleur @scalz
                                    Hi guys,
                                    L
                                    L
                                    lafleur
                                    #31
                                    @frencho
                                    I have it all working, but my development environment and Jenkins are not in alignment, so my PR was rejected by the development team. They provide me NO help in resolving the issue... They tend to favor and support only the older NRF24L01 radio and have little interests in the newer, better preforming RFM69 or RFM95 radios. So have a look at my code changes in the close PR. It was not hard to implement. I have move on.....
                                    frenchoF 1 Reply Last reply
                                      wrote on last edited by hek
                                      #32
                                      @lafleur
                                      I'm sorry if your feelings got hurt. But you simply wouldn't do what the team instructed you in PR #440 to get it merged.
                                      https://github.com/mysensors/MySensors/pull/440
                                      • L lafleur
                                        @frencho
                                        frenchoF
                                        frenchoF
                                        frencho
                                        Thanks @lafleur, found your PR, I will try to do my own thing based on your work. Shouldn't be a big deal.
                                        • L
                                          L
                                          lafleur
                                          I did exactly what you ask, but it continued to fail in building the examples... In another PR, you pointed out that there were issue in building the examples under IDE 1.6.9.
                                          My feeling were not hurt, but I did NOT want to wast anymore time in dealing with Jenkins with out guidance.... Also there is NO guide on what Jenkins expect to see in its development environment. it all trial and error...
                                          FYI... I have developed RFM95 and TTN transport layers for my snapshot of your code.
