  3. rfm69 and atc
rfm69 and atc
49 Posts 13 Posters 21.1k Views 12 Watching
  • L
    L
    lafleur
    have you tested the code enough to release it for our use and testing??
      @lafleur
      no, not yet. sorry for delay. I have no time actually..and I think perhaps lowpowerlab team is preparing few changes in their lib. so I am delaying a bit to finish other things in the mean time, and to see if they add new features. then, if nothing new, I will finish this if someone didn't beat me on this ;)
      but I will try to do my best :)
      L 1 Reply Last reply
      • scalzS scalz
        @lafleur
        L
        L
        lafleur
        wrote on last edited by lafleur
        @scalz
        I have it working to some extent, send me what you have and I will add your changes to what I've done to make sure I did not miss anything...
        Then I will post the changes to the development branch
        tom --at-- lafleur --.-- us
        • L
          L
          lafleur
          I have all this working now and have 7 devices on it to a serial gateway...
          Using new RFM69 driver and RFM69_ATC...
          Its interesting to see the power levels change as packets flow...
          If I can figure out how to do a PULL request, I will make it happen to 2.0b development branch...
          tom
            :thumbsup:
            sorry for delayed answer, a bit busy, I have actually no time to look at/share my experiments :confused:
            I found this interesting too, seeing powerlevels change. btw I didn't finish the listenmode part, I'm on other things for the moment, so that's great if your are doing the job :)
            thx ;)
              #23
              hi guys.
              just a little update to say that I'm back on this :blush:
              it's still a wip so I will share/release a bit later ;)
              I have this working in mysensors dev for the moment.
              • I can get rssi value.
              • atc power mode.
              • listenmode : an mqtt esp8266 GW is peridocially waking up a proto node which is in deepsleep (the node is woken up by INT0 triggered by the radio of course). I will mainly use this for sort of remote watchdog for some of my nodes etc..
              • F
                F
                Fabien
                @scalz, good work ! Nice features.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  @scalz As you noticed I have just started with rfm69 and thanks for your help in the other thread. Really looking forward to your work as ATC is something I am missing in MySensors.
                    @alexsh1 : thx. i know i have not pr this yet..it's still working local but have not done extended tests as I'm busy improving mqtt wifi gw..but i will do my best
                    • FleischtorteF
                      FleischtorteF
                      Fleischtorte
                      Hi Scalz,
                      any progress here? Cant wait to use ATC and the rssi-value for my nodes :D
                      Thanks for your work :thumbsup:
                      regards
                      david
                      carlierdC 1 Reply Last reply
                      • FleischtorteF Fleischtorte
                        Hi Scalz,
                        regards
                        david
                        carlierdC
                        carlierdC
                        carlierd
                        @Fleischtorte So I am not the only one David waiting for ATC and RSSI ;)
                        David.
                        • FleischtorteF
                          FleischtorteF
                          Fleischtorte
                          @carlierd Yeah Davids FTW :D
                          • frenchoF
                            frenchoF
                            frencho
                            @lafleur @scalz
                            Hi guys,
                            Have one of you succed with the PR, so we can enjoy at least the ATC feature.
                            This is really the down side with the RFM69HW, power consumption so your work could be really helpfull !
                            Really thank you for that
                            Your second life begins when you understand you only have one !
                            • frenchoF frencho
                              @lafleur @scalz
                              Hi guys,
                              L
                              L
                              lafleur
                              #31
                              @frencho
                              I have it all working, but my development environment and Jenkins are not in alignment, so my PR was rejected by the development team. They provide me NO help in resolving the issue... They tend to favor and support only the older NRF24L01 radio and have little interests in the newer, better preforming RFM69 or RFM95 radios. So have a look at my code changes in the close PR. It was not hard to implement. I have move on.....
                              frenchoF 1 Reply Last reply
                                wrote on last edited by hek
                                #32
                                @lafleur
                                I'm sorry if your feelings got hurt. But you simply wouldn't do what the team instructed you in PR #440 to get it merged.
                                https://github.com/mysensors/MySensors/pull/440
                                • L lafleur
                                  @frencho
                                  frenchoF
                                  frenchoF
                                  frencho
                                  Thanks @lafleur, found your PR, I will try to do my own thing based on your work. Shouldn't be a big deal.
                                  • L
                                    L
                                    lafleur
                                    I did exactly what you ask, but it continued to fail in building the examples... In another PR, you pointed out that there were issue in building the examples under IDE 1.6.9.
                                    My feeling were not hurt, but I did NOT want to wast anymore time in dealing with Jenkins with out guidance.... Also there is NO guide on what Jenkins expect to see in its development environment. it all trial and error...
                                    FYI... I have developed RFM95 and TTN transport layers for my snapshot of your code.
                                      @frencho @lafleur
                                      sorry for this delay. i'm busy, running..sometimes i refresh myself doing some sw but I admit i spent more time on hw than looking how to cleanly do this PR. ouch :sweat: but for me it has to be hobby even if I'm always rushing myself.
                                      you're not true ;) in fact mysensors team is not nrf24 only :)
                                      as soon as i can, i will look. it could be a bit time consuming as it would be my first PR, why i always delay..boo lazy i am :blush: The best way I think (as, now, I'm not up to date with dev branch, I will need diffchecking my stuff):
                                      • I would start/improve PR437 with minor changes needed. As mysensors drivers compiles ok, i would do in this way than taking lowpowerlab lib first (all warnings enabled of course)
                                      • then a separated for ATC + or another one for ListenMode. to have a better history and not breaking anything.
                                      so, I would separate the PR. I don't know if you tried like this (if i'm overhead), or what were your PR issue. I will look a bit later for curiosity or in case I would run in similar issue hihi.
                                      Cool if you have it working :)
                                      • FleischtorteF
                                        FleischtorteF
                                        Fleischtorte
                                        @lafleur thanks for your work! On the weekend i was able to upgrade the driver and enable ATC with RSSI-Report. With the instructions from PR440 it was very easy :thumbsup:
                                        • L
                                          L
                                          lafleur
                                          It's great to see that you got it all working from the PR440. I hope others will find your work useful....
                                          I'm my test,it works very well.....
                                          B 1 Reply Last reply
