  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 456.1k Views 35 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    #188
    @epierre I have the problem with the dust sketch (shinyei ppd42ns). The following code does not work in MySensors 1.5
    gw.send(msgPM10.set("ppm"));
    gw.send(msgPM25.set("ppm"));
    2016-04-24 14:44:19.438 Error: MySensors: Unknown/Invalid sensor type (43)
    So far both PM10 and PM25 are showing zero. However, if I upload the following code, it works fine (one channel though):
    // Watch video here: https://www.youtube.com/watch?v=a8r4CeQopfY
     Connection:
     JST Pin 1 (Black Wire)  => Arduino GND
     JST Pin 3 (Red wire)    => Arduino 5VDC
     JST Pin 4 (Yellow wire) => Arduino Digital Pin 8
     Green Led connected to Arduino D7
     Yellow Led connected to Arduino D6
     Red Led connected to Arduino D5
    Dust Sensor possible application:
    - Applications of customer
    - Air quality sensor
    - Dustlessness workshop
    - Cigarette detector
    Sensor is to create Digital (Lo Pulse) output to Particulate Matters (PM). Lo Pulse Occupancy time (LPO time) is in proportion
    to PM concentration. The output is for PM whose size is around 1 micro meter or larger. We can use the sensor to detect the dust in clean room.
    Minimum detect particle: 1um
    http://www.seeedstudio.com/wiki/Grove_-_Dust_Sensor
     Grove - Dust Sensor Demo v1.0
     Interface to Shinyei Model PPD42NS Particle Sensor
     Program by Christopher Nafis
     Written April 2012
     http://www.seeedstudio.com/depot/grove-dust-sensor-p-1050.html
     http://www.sca-shinyei.com/pdf/PPD42NS.pdf
    int pin = 8;
    unsigned long duration;
    unsigned long starttime;
    unsigned long sampletime_ms = 1000;//sampe 1s ;
    unsigned long lowpulseoccupancy = 0;
    float ratio = 0;
    float concentration = 0;
    int gLed = 7;
    int yLed = 6;
    int rLed = 5;
      Serial.begin(9600);
      pinMode(8,INPUT);
      pinMode(gLed,OUTPUT);
      pinMode(yLed,OUTPUT);
      pinMode(rLed,OUTPUT);
      starttime = millis();//get the current time;
      duration = pulseIn(pin, LOW);
      lowpulseoccupancy = lowpulseoccupancy+duration;
      if ((millis()-starttime) > sampletime_ms)//if the sampel time == 30s
        ratio = lowpulseoccupancy/(sampletime_ms*10.0);  // Integer percentage 0=>100
        concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62; // using spec sheet curve
        Serial.print("concentration = ");
        Serial.print(concentration);
        Serial.print(" pcs/0.01cf  -  ");
        if (concentration < 1.0) {
         Serial.println("It's a smokeless and dustless environment");
         digitalWrite(gLed, HIGH);
         digitalWrite(yLed, LOW);
         digitalWrite(rLed, LOW);
        if (concentration > 1.0 && concentration < 20000) {
         Serial.println("It's probably only you blowing air to the sensor :)");
        if (concentration > 20000 && concentration < 315000) {
         Serial.println("Smokes from matches detected!");
         digitalWrite(gLed, LOW);
         digitalWrite(yLed, HIGH);
          if (concentration > 315000) {
         Serial.println("Smokes from cigarettes detected! Or It might be a huge fire! Beware!");
         digitalWrite(rLed, HIGH);
    • epierreE epierre
      sadly the discussions were lost...
      So let's start again on the subject:
      https://github.com/empierre/arduino
      Here is the list of my current experimentations:
      • MQ135.ino : for CO2/COV ... validated
      • MQ2.ino : for ethanol... needs pre-heat : ongoing
      • MQ6 sensor : just received
      • MQ131 sensor : just received
      • TGS2600 sensor : just received
      I'm getting serious a with a mega and a sensor board, 4 of them are connected together !
      The MQ135 is not on the list, I use it to measure CO2 in children's room...
      Values:
      • MQ2: 85 - Combustible gas and smoke
      • MQ6: 25 - Isobutane, Butane, LPG
      • MQ131: 57 - O3, CL2
      • TGS2600: 943 - ethanol, hydrogen, iso-butane, CO, Methane
      As discussed before, I would appreciate someone helping me reading the logarithmic curves in the datasheet (link on each sensor name above) to get the linear value based on analog reading. I need to learn reading it... thanks!
      as an example here in sandboxelectronics we saw that several values could be read from the datasheet:
      float           LPGCurve[3]  =  {2.3,0.21,-0.47};   //two points are taken from the curve.
                                                          //with these two points, a line is formed which is "approximately equivalent"
                                                       //to the original curve.
                                                      //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
      float           COCurve[3]  =  {2.3,0.72,-0.34};    //two points are taken from the curve.
                                                      //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
      float           SmokeCurve[3] ={2.3,0.53,-0.44};    //two points are taken from the curve.
                                                      //data format:{ x, y, slope}; point1: (lg200, 0.53), point2: (lg10000,  -0.22)
      float           Ro           =  10;                 //Ro is initialized to 10 kilo ohms
      AnneFRA
      AnneFRA
      AnneFR
      @epierre hi, could remove some doubts regarding the mq131 sensor?
      thanks,
      Anne
      • epierreE
        epierreE
        epierre
        @alexsh1 said:
        (shinyei ppd42ns)
        I corrected the following sketch which had bad yg/m3 to ppm conversion thanks to LouiS22 from Domoticz forum remark (type conversion errors leading to 0 values).
        https://github.com/empierre/arduino/blob/master/DustSensor_SamYoung_DSM501.ino
        I guess I'll have to do the same here (but I lack time...):
        DustSensor_Shinyei_PPD42NS.ino
        z-wave - Vera -> Domoticz
        alexsh1A 1 Reply Last reply
        • epierreE epierre
          @alexsh1 said:
          (shinyei ppd42ns)
          alexsh1A
          alexsh1A
          alexsh1
          @epierre Thanks - I'll have another go at Shinyei PPD42NS sketch once I have time. Ideally, I'd like to combine it with MH-Z14A sketch.
          epierreE 1 Reply Last reply
          • alexsh1A alexsh1
            epierreE
            epierreE
            epierre
            @alexsh1 which is a good idea, also a temp/him is quite usefull though I didn't added the impact in the formulas so far.
            alexsh1A 2 Replies Last reply
            • epierreE epierre
              alexsh1A
              alexsh1A
              alexsh1
              #193
              @epierre I have combined the two sketches - works just fine, but need to find a spare temp sensor.The hardware setup looks messy so adding an extra i2c sensor will complicate it even more. I'll come back with the combined three-in-one sketch shortly.
              BTW, this
              still throws the following error. What version MySensors are you using?
              • epierreE epierre
                alexsh1A
                alexsh1A
                alexsh1
                #194
                @epierre I started looking at the formula you have used in ppmv calculation. Why do you need ppmv? All values in EPA or Europe are in μg/m3.
                The ppmv equation is:
                ppmv = mg/m^3 * (0.08205*T)/M
                T = atmospheric temperature in kelvins = 273.15 + °C
                M = molecular weight of the air pollutant = 28.97
                (http://www.engineeringtoolbox.com/molecular-mass-air-d_679.html - this is a good link)
                0.08205 = Universal Gas Law constant in atm·l/(mol·K)
                Your code for this equation is:
                ppmv=(float)(((concentrationPM25*0.0283168)/100) * ((0.08205*temp)/0.01))/1000;
                Now, I think it should be as follows:
                1. temp = °C + 273.15
                int temp=273.15 + 22;
                22C - is a typical temp inside though the intention is to use a sensor
                1. The amended ppmv equation is going to be:
                ppmv=(((concentrationPM25*0.0283168)/100) * ((0.08205*temp)/28.97))/1000;
                I have not changed 0.0283168 /100 - not sure that this is. And the whole thing is divided by 1000? why?
                IMPORTANT UPDATE:
                I have just received the following result:
                PM10: 7373
                send: 11-11-0-0 s=0,c=1,t=37,pt=7,l=5,sg=0,st=ok:1.744
                If I use the following web-site http://www.herramientasingenieria.com/onlinecalc/ppm-mg_m3.php and the result is
                mg/m3 = 7373 * 0.283168/100 = 2.08 mg/m3
                The molecular weight is 28.97 for dry air
                2.08 mg/m3 is equivalent to 1.74ppm for a gas with molecular weight=28.97 Pressure=1013.25, Temperature=22C
                Success!
                Now I have found a spare BMP280 (temp and pressure sensor) which I can use here.
                Additionally, I need to use 24-h and 1 year averages - https://www3.epa.gov/airquality/particlepollution/2012/decfsstandards.pdf
                Stay tuned!
                • alexsh1A alexsh1
                  IMPORTANT UPDATE:
                  PM10: 7373
                  Success!
                  Stay tuned!
                  epierreE
                  epierreE
                  epierre
                  because domoticz only knows ppm... and many AIQ like use only that except for particles.
                  not for me ;-)
                    ppmv=(((concentrationPM250.0283168)/100) * ((0.08205temp)/28.97))/1000;
                  was a volume conversion
                  Success!
                  success for the mysensors value ?
                  Domoticz doesn't recognize this command... I use 1.5.x but I have my own gateway to domoticz
                  alexsh1A bezeeflyB 2 Replies Last reply
                  • epierreE epierre
                    not for me ;-)
                    Success!
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @epierre Yes, all works fine now. I modified the combined sketch and here is the final result.
                      moskovskiy82
                      Which one to use for detection of fire smoke? Currently have got several MQ-7 but they don't seem so good at it
                      • M moskovskiy82
                        epierreE
                        epierreE
                        epierre
                        as discussed just above, a particle sensor could be good for smoke is a particle concentration, coupled with heat this would be a good indicator
                          moskovskiy82
                          What about mq2 or mq135? Any experience? As a gas sensor will be more suitable detecting early fire
                          • M moskovskiy82
                            epierreE
                            epierreE
                            epierre
                            please see what it does, this is not a gas sensor this only detect particle size whatever the gas...
                            • epierreE epierre
                              moskovskiy82
                              @epierre
                              It still detects concentration. Both state CO detection. So in case of fire won't they detect the increase in concentration much faster that the particle sensor like Sharp’s GP2Y1010AU0F or alternative?
                              • M moskovskiy82
                                @epierre
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @moskovskiy82 For a fire smoke, you can use pretty much any gas or particle sensor - there are a quite few gases formed during the burning process. MQ2 is highly sensitivity and has a fast response time. I can recommend it for a fire detection usage. However, I have been disappointed in MQ* sensors in general - there are not accurate, require 24h heat-up time, consume a lot of power etc. The only advantage is the price.
                                To detect fire to can use a flame sensor - http://www.instructables.com/id/Flame-detection-using-Arduino-and-flame-sensor/
                                • rollercontainerR
                                  rollercontainerR
                                  rollercontainer
                                  Can someone tell me how to read this line?
                                  float mq135_ro = 10000.0;    // this has to be tuned 10K Ohm
                                  Do I have to messure the sensor and adjust the variable or do I have to tune the resistance? If I have to do the first thing, when do I have to messure it? In warm state and clean air with a multimeter?
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #204
                                    @epierre Did you check out the airbeam, which is based on a more expensive sensor Shinyei PPD60PV?
                                    http://www.takingspace.org/airbeam-technical-specifications-operation-performance/
                                    They made a step-by-step manual about building the same on Shinyei PPD42NS. I took their code and stripped a few parts and this is what I am left with:
                                    #include  <SoftwareSerial.h>
                                    #include  <FlexiTimer2.h>
                                    int pin = 3;
                                    volatile  double  rawParticalCount;
                                    volatile  double  totalParticles  = 0;
                                    volatile  double  particleCountToDisplay  = 0;
                                    volatile  double  ratio = 0;
                                    volatile  uint16_t  timeCounter = 0;
                                    #define         numberOfPeaksRecording                            5
                                    volatile        uint32_t        previousPeaks[numberOfPeaksRecording];
                                    volatile        uint32_t        sumOfPreviousPeaks          = 0;
                                    volatile        uint32_t        instantGoal                         = 0;
                                    volatile        int32_t         delta                                     = 0;
                                    volatile        uint32_t        slowMovingAverage             = 0;
                                    volatile  boolean readyToSendData = false;
                                    void  setup() {
                                        pinMode(pin,INPUT);
                                        FlexiTimer2::set(1,1.0/10000,readPin);
                                        FlexiTimer2::start();
                                    void  loop()  {
                                        if(readyToSendData){
                                                    Serial.print(rawParticalCount,  DEC);
                                                    Serial.print("  Raw Particle  Count (0-10000) ");
                                                    Serial.print(ratio, DEC);
                                                    Serial.print("  Ratio (0-100%)  ");
                                                    Serial.print(particleCountToDisplay,  DEC);
                                                    Serial.print("  Particle  Count");
                                                    Serial.println("");
                                    void  readPin(){
                                        if(digitalRead(pin) ==  LOW){
                                            rawParticalCount++;
                                        timeCounter++;
                                        if  (timeCounter  ==  10000)
                                            timeCounter=0;
                                            //Changes are made  here  based on  Chris Nafis's code: http://www.howmuchsnow.com/arduino/airquality/grovedust/
                                            ratio = rawParticalCount/100.0;
                                            //Convert to  percentage, the shinyei reads 10milliseconds  to  90milliseconds  duration  for particles.  Basing on 10milliseconds, smallest  particle  assumingly  from  specification sheet.
                                            //FlexiTimer2,  reads 10,000  readings  per second, which would be  1 reading per 100 microseconds. 100 readings  would be  10  milliseconds. Since Shinyei runs  at minimal 10  millisecond range.  I divided 10,000  readings  by  100 to  get 100.
                                            //Good  example would be  rawPArticalCount  is  5000  half  of  the 10,000  readings were  active. 5000/100  would be  50  which translate to  50% low pulse occupancy.
                                            totalParticles  = (1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62);
                                            rawParticalCount  = 0;
                                                    //  shift counters  over, code  adapted from  template  provided  by  Mike  Taylor  and Joshua  Schapiro  from  Carnegie  Mellon  University's  CREATE  Lab
                                                    for (uint8_t  i = 0;  i < (numberOfPeaksRecording-1); i++)  {
                                                            previousPeaks[i]  = previousPeaks[i+1];
                                                    previousPeaks[numberOfPeaksRecording  - 1]  = totalParticles;
                                                    for (uint8_t  i = 0;  i < numberOfPeaksRecording; i++)  {
                                                            sumOfPreviousPeaks  +=  previousPeaks[i];
                                                    instantGoal = 2*sumOfPreviousPeaks;
                                                    delta = instantGoal - slowMovingAverage;
                                                    if  (delta  < -5000){
                                                            slowMovingAverage = slowMovingAverage - 250;
                                                    } else  if  (delta  < -2500){
                                                            slowMovingAverage = slowMovingAverage - 120;
                                                    } else  if(delta  < -1200){
                                                            slowMovingAverage = slowMovingAverage - 60;
                                                    } else  if(delta  < -500){
                                                            slowMovingAverage = slowMovingAverage - 25;
                                                    } else  if(delta  < -5){
                                                            slowMovingAverage = slowMovingAverage - 5;
                                                    } else  if(delta  < -1){
                                                            slowMovingAverage = slowMovingAverage - 1;
                                                    } else  if(delta  > 5000) {
                                                            slowMovingAverage = slowMovingAverage + 500;
                                                    } else  if(delta  > 2500){
                                                            slowMovingAverage = slowMovingAverage + 250;
                                                    } else  if(delta  > 1200){
                                                            slowMovingAverage = slowMovingAverage + 120;
                                                    } else  if(delta  > 500){
                                                            slowMovingAverage = slowMovingAverage + 50;
                                                    } else  if(delta  > 5){
                                                            slowMovingAverage = slowMovingAverage + 5;
                                                    } else  if(delta  > 1){
                                                            slowMovingAverage = slowMovingAverage + 1;
                                                    particleCountToDisplay  = slowMovingAverage;
                                            readyToSendData = true;
                                    I have not adopted it for MySensors yet.
                                    I like moving average they use, but the values do not make sense to me:
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  53470.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 27.0000000000  Ratio (0-100%)  53970.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  54470.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 21.6200008392  Ratio (0-100%)  54970.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  55470.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 24.2800006866  Ratio (0-100%)  55970.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  56470.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 24.1200008392  Ratio (0-100%)  56970.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  57470.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 22.3199996948  Ratio (0-100%)  57970.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  58470.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 20.3600006103  Ratio (0-100%)  58970.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  59470.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 17.6299991607  Ratio (0-100%)  59970.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  60220.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 19.0499992370  Ratio (0-100%)  60720.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  60715.0000000000  Particle  Count
                                    0.0000000000  Raw Particle  Count (0-10000) 20.6599998474  Ratio (0-100%)  61215.0000000000  Particle  Count
                                    • epierreE
                                      epierreE
                                      epierre
                                      @alexsh1 the PPDN42 is for 1 micron and 2.5 micron , this one is for 0.5 micron
                                      airbeam has standard code: https://github.com/HabitatMap/AirCastingAndroidClient/blob/master/arduino/aircasting/aircasting_shinyeiPPD42NS.ino
                                      or I've not seen ?
                                      • epierreE epierre
                                        or I've not seen ?
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @epierre this is not the air beam code. They introduced "do it yourself" consept similar to the airbeam but with a different sensor (shinyei ppd42ns)
                                        • rollercontainerR
                                          rollercontainerR
                                          rollercontainer
                                          Hey guys, I am struggeling to get the MQ135 to work. Is there a step by step howto? Or can someone answer my question from 3 days ago?
                                          I would appreciate it very much.
                                          12.5k
