  3. Node sending same value multiple times, why?
7 Posts 2 Posters 1.7k Views 2 Watching
  • Mark SwiftM Offline
    Mark SwiftM Offline
    Mark Swift
    wrote on last edited by Mark Swift
    Hi guys,
    I'm having an issue with one of my nodes sending the value multiple times (Mostly 3 or 4 times).
    The sketch:
      REVISION HISTORY
      Created by Mark Swift
      V1.1 - Started code clean up
      V1.2 - Cleaned up
      V1.3 - Changed sleep to smartSleep to allow for future developments // Cancelled for now as doesn't work so well!
    #include <OneWire.h>
    //*** MY SENSORS ******************************************
    #define MY_NODE_ID 2
    // #define MY_PARENT_NODE_ID 1 // AUTO
    // #define MY_RADIO_RFM69
    // Channel furthest away from Wifi
    // #define MY_RF24_CHANNEL 125
    // For crappy PA+LNA module
    // #define MY_RF24_PA_LEVEL RF24_PA_LOW
    //*** CONFIG **********************************************
    // Send temperature only if changed? 1 = Yes 0 = No
    #define COMPARE_TEMP 0
    // Pin where dallas sensor is connected
    #define ONE_WIRE_BUS 3
    // The maximum amount of dallas temperatures connected
    // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    // Pass the oneWire reference to Dallas Temperature
    int numSensors = 0;
    // Define loop time
    #define LOOP_TIME 60000 // Sleep time between reads (in milliseconds)
    // Define sensor children
    #define CHILD_ID1 1 // Dallas temperature sensor
    // Initialise messages
    MyMessage msg(CHILD_ID1, V_TEMP);
      sensors.begin(); // Startup up the OneWire library
      sensors.setWaitForConversion(false); // RequestTemperatures() will not block current thread
      sendSketchInfo("Garage Freezer", "1.3"); // Send the sketch version information to the gateway and Controller
      numSensors = sensors.getDeviceCount(); // Fetch the number of attached temperature sensors
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) // Present all sensors to controller
        present(i, S_TEMP);
      //*** DS18B20 *******************************************
      sensors.requestTemperatures(); // Fetch temperatures from Dallas sensors
      int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution()); // Query conversion time and sleep until conversion completed
      wait(conversionTime); // Sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater)
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) // Read temperatures and send them to controller
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.; // Fetch and round temperature to one decimal
    #if COMPARE_TEMP == 1 // Only send data if temperature has changed and no error
        if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00)
        if (temperature != -127.00 && temperature != 85.00)
          send(msg.setSensor(i).set(temperature, 1)); // Send in the new temperature
          wait(500); // If set to sleeping, will still have time to wait for OTA messages...
          lastTemperature[i] = temperature; // Save new temperatures for next compare
      sleep(LOOP_TIME); // Sleep or wait (repeater)
    • mfalkviddM Offline
      A serial debug output would be useful for troubleshooting.
      How many connected sensors do you have?
        Mark SwiftM Offline
        Mark Swift
        Just one sensor...
          Only one sensor is presented, and the same sensor ID is used for all 3-4 messages?
            Mark SwiftM Offline
            Mark Swift
            Yes, always '0', sometimes it sends twice, sometimes 3, and the odd time 4.
            I've tried clearing the node, uploading a new sketch, it's odd!
            • Mark SwiftM Mark Swift
              How close in time are the messages sent? If it is >500ms between the messages, there is probably something wrong with the loop or sleep (but they look fine to me).
              If the time between messages is <100ms maybe the ACK doesn't reach the sensor node so it resends the message.
              A serial debug output would show what is happening.
                Mark SwiftM Offline
                Mark Swift
                I'll try a debug when I'm home, but this is a remote node using MYS firmware...
                See MYS screenshots here: http://postimg.org/gallery/8ynl0jw/c4dcd695/
                12.0k
