Node sending same value multiple times, why?
Hi guys,
I'm having an issue with one of my nodes sending the value multiple times (Mostly 3 or 4 times).
The sketch:
/* REVISION HISTORY Created by Mark Swift V1.1 - Started code clean up V1.2 - Cleaned up V1.3 - Changed sleep to smartSleep to allow for future developments // Cancelled for now as doesn't work so well! */ #include <SPI.h> #include <DallasTemperature.h> #include <OneWire.h> //*** MY SENSORS ****************************************** // Enable debug prints to serial monitor #define MY_DEBUG #define MY_NODE_ID 2 // #define MY_PARENT_NODE_ID 1 // AUTO // Enable and select radio type attached #define MY_RADIO_NRF24 // #define MY_RADIO_RFM69 // Channel furthest away from Wifi // #define MY_RF24_CHANNEL 125 // For crappy PA+LNA module // #define MY_RF24_PA_LEVEL RF24_PA_LOW // Enabled repeater feature for this node // #define MY_REPEATER_FEATURE #include <MySensor.h> //*** CONFIG ********************************************** // Send temperature only if changed? 1 = Yes 0 = No #define COMPARE_TEMP 0 // Pin where dallas sensor is connected #define ONE_WIRE_BUS 3 // The maximum amount of dallas temperatures connected #define MAX_ATTACHED_DS18B20 16 // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) OneWire oneWire(ONE_WIRE_BUS); // Pass the oneWire reference to Dallas Temperature DallasTemperature sensors(&oneWire); float lastTemperature[MAX_ATTACHED_DS18B20]; int numSensors = 0; // Define loop time #define LOOP_TIME 60000 // Sleep time between reads (in milliseconds) // Define sensor children #define CHILD_ID1 1 // Dallas temperature sensor // Initialise messages MyMessage msg(CHILD_ID1, V_TEMP); //********************************************************* void setup() { sensors.begin(); // Startup up the OneWire library sensors.setWaitForConversion(false); // RequestTemperatures() will not block current thread } void presentation() { sendSketchInfo("Garage Freezer", "1.3"); // Send the sketch version information to the gateway and Controller numSensors = sensors.getDeviceCount(); // Fetch the number of attached temperature sensors for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) // Present all sensors to controller { present(i, S_TEMP); } } void loop() { //*** DS18B20 ******************************************* sensors.requestTemperatures(); // Fetch temperatures from Dallas sensors int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution()); // Query conversion time and sleep until conversion completed wait(conversionTime); // Sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater) for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) // Read temperatures and send them to controller { float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.; // Fetch and round temperature to one decimal #if COMPARE_TEMP == 1 // Only send data if temperature has changed and no error if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00) { #else if (temperature != -127.00 && temperature != 85.00) { #endif send(msg.setSensor(i).set(temperature, 1)); // Send in the new temperature wait(500); // If set to sleeping, will still have time to wait for OTA messages... lastTemperature[i] = temperature; // Save new temperatures for next compare } } sleep(LOOP_TIME); // Sleep or wait (repeater) } -
Just one sensor...
Yes, always '0', sometimes it sends twice, sometimes 3, and the odd time 4.
I've tried clearing the node, uploading a new sketch, it's odd!
How close in time are the messages sent? If it is >500ms between the messages, there is probably something wrong with the loop or sleep (but they look fine to me).
If the time between messages is <100ms maybe the ACK doesn't reach the sensor node so it resends the message.
A serial debug output would show what is happening.
I'll try a debug when I'm home, but this is a remote node using MYS firmware...
See MYS screenshots here: http://postimg.org/gallery/8ynl0jw/c4dcd695/
