  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.9k Views 35 Watching
  • alexsh1A alexsh1
    Whatever I did, did not help to solve st=fail
    When I disable signing I have got the following (not a signle st=fail):
    Starting sensor (RNONA-, 2.0.0-beta)
    Radio init successful.
    Sensebender Micro FW 1.5 - Online!
    send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=17,sg=0,st=ok:Sensebender Micro
    send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.5
    send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 3-3-0-0 s=2,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    send: 3-3-0-0 s=3,c=0,t=13,pt=0,l=0,sg=0,st=ok:
    isMetric: 1
    TempDiff :125.61
    HumDiff  :150.00
    T: 25.61
    H: 50
    send: 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:25.6
    send: 3-3-0-0 s=2,c=1,t=1,pt=2,l=2,sg=0,st=ok:50
    send: 3-3-0-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.09
    send: 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:85
    I am going to try different channels now with signing
    AnticimexA
    AnticimexA
    Anticimex
    @alexsh1 yes, without signing your messages are significantly shorter, and thus have a better chance of getting through. You can try experimenting with amplification as well.
    YveauxY alexsh1A 2 Replies Last reply
    • AnticimexA Anticimex
      @Anticimex just a noob question: do you have an idea of the performance penalty of (software) signing? Any benchmark figures?
      AnticimexA 1 Reply Last reply
      • YveauxY Yveaux
        AnticimexA
        AnticimexA
        Anticimex
        @Yveaux no, sorry have not got around to compare them. But software signing is actually quicker due to the single write bit banging for the atsha204a. One way to see the difference is measuring the delay for an ACK to come back from a node that require signed messages. I have no figures, but a node with software signing responds slightly faster.
          @Anticimex But is it significantly slower than without any signing?
          • YveauxY Yveaux
            AnticimexA
            AnticimexA
            Anticimex
            @Yveaux yes. But I know that significant improvements can be made in the nonce whitening. It incrementally calculates a hash which is which is far less efficient than calculate the hash of a buffer. So there are room for improvements. I just wish there were more time, and now my arduinos are packed down so I wont be able to test. But volunteers are welcome, I can still code :)
              alexsh1A
              alexsh1A
              alexsh1
              Do you think a message size has anything to do with st=fail?
              • alexsh1A alexsh1
                AnticimexA
                AnticimexA
                Anticimex
                @alexsh1 yes, like I have said here and in other topics, signing often gets the blame for transmission problems because with signing the maximum message buffer is used, and larger messages are more difficult to transmit than short ones. So if you have a poor connection, odds are that a larger message will fail more often than a short one.
                alexsh1A 1 Reply Last reply
                  alexsh1A
                  alexsh1A
                  alexsh1
                  I do not think its signing, but I think it is implementation of signing and sending.
                  I do not get st=fail after the initial 9 messages not even once. Something is just very-very odd.
                  • ximinezX
                    ximinezX
                    ximinez
                    I'm seeing the same failed signings when the device powers up, but it doesn't fail after those.
                    • ximinezX ximinez
                      alexsh1A
                      alexsh1A
                      alexsh1
                      Did you manage to get it sorted?
                      • ximinezX
                        ximinezX
                        ximinez
                        I just ignore the first fails. It works after that, and has done so for close to a month.
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          #482
                          Well, if you think the signing implementation cause initial radio transmissions to fail I am afraid I will need your help in explaining how. Because I fail to see any connection between signing and radio behaviour. st=fail is a transmission problem, and signing implementation require flawless transmissions. I also suspect you both use nrf24 and I also suspect you will not see this if you use rfm69 although I use nrf24 myself for testing and I have not seen what you report. But I am sure you really experience this strange behaviour. But I maintain that it is due to some startup problems of the radio. I am afraid I cannot find anything I can change in the signing codebase to have an influence on st=ok or st=fail. But I am all ears to suggestions of course if you see something suspicious.
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @Anticimex Interesting observation - another node with the same rf24l01+ radio from the sensebender with the same GW and signing works without st=fail. This is now clear that this is not a rf24l01+ hardware issue.
                            • alexsh1A alexsh1
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @alexsh1 Indeed. And also that it is not a signing issue since I take it you use the same FW?
                              I still think it is a HW issue. You have a new node, right? So the radio has a new power source?
                                alexsh1A
                                alexsh1A
                                alexsh1
                                Yes, I tried to compare apples with apples:
                                1. it is the same distance / FW
                                2. the code is different to the expend that the sensebender has got Si7021/ATSHA204a and the other sensor did not. I may try to upload a simplified code to the sensebender just to test it to make it a more equal comparison.
                                3. the power source is the same - 5V 500mA via AMS1117 + cap
                                • alexsh1A alexsh1
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @alexsh1 You could also try soft signing on the sensebender and see if that makes a difference. Perhaps the atsha device interferes with the radio (this depends on routing and such things). I have no sensebender myself and I have not noticed the behavior you describe with nrf24 and atsha204a.
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @Anticimex I tried the sensebender with soft singing - still the same st=fail
                                    AnticimexA YveauxY 2 Replies Last reply
                                    • alexsh1A alexsh1
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @alexsh1 Ok. I guess that is "good news for me" as it rules out signing related hardware as well. I guess so far, the only conclusion is that rf performance is to some extent degraded on the sensebender.
                                      • alexsh1A alexsh1
                                        @alexsh1 just a hunch: do both nodes have identical CPU's & clock frequency?
                                        • YveauxY Yveaux
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Yveaux Correct - I have used Pro Mini 3.3V 8Mhz which corresponds to the sensebender
                                          ximinezX 1 Reply Last reply
