  2. KiCad
  3. NRF24L01+ smd schematics
Scheduled Pinned Locked Moved KiCad
18 Posts 5 Posters 14.2k Views 4 Watching
  • L LastSamurai
    @GertSanders I tried to find the library here but I actually coudln't. Could you perhaps give me a hint where to find it? Thanks!
    GertSandersG
    GertSandersG
    GertSanders
    @LastSamurai
    I have added my EAGLE library below:
    0_1459411902291_NRF24L01plus.lbr
    You can rename it because the forum adds the extra "0_1459411902291_" during upload.
    • L
      L
      LastSamurai
      Thank you for the help!
      • alexsh1A
        alexsh1A
        alexsh1
        @GertSanders you can change the status of your node as "tested". It works just fine - one important thing to remember is to solder the 3.3v solderpad. A couple of observations:
        1. I can no longer fit a single AAA battery holders, but a double one only (AA or AAA)
        2. the holes for J1 are two small and I had to drill them out.
        I have not tested ATSHA204A as I do not have all components yet.
        • alexsh1A alexsh1
          GertSandersG
          GertSandersG
          GertSanders
          @alexsh1
          So you received the boards before I did :-)
          I'm still waiting on them. They are "in the mail" or at least in the hands of my local mail service (any day now...).
          Which type of header/connector did you use to mount in the J1 location ? If the holes are too narrow for the breakable two row male headers, I will adapt this (that is why it is still UNTESTED for me).
          Indeed, one or two single AAA holders are not possible on this board. I found that the double battery holders actually are cheaper, and it allows avoiding two extra holes where the radio now sits.
          Update: I checked the drill size of the part used in v3 to place the header, indeed this is 0,8mm (31 mil) instead of 1,016mm (40 mil).
          In my v4 version I already switched to a wider header, and this one does have 40 mil drill diameter. It's good I did not do a panel with the v3 version.
          alexsh1A 1 Reply Last reply
          • GertSandersG GertSanders
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            @GertSanders
            Yes, I have got the boards in 3-4 days. Very quick
            I have used a single row header like this
            http://www.protostack.com/connectors/headers/40-pin-2.54mm-snappable-single-row-header
            • alexsh1A alexsh1
              @GertSanders
              GertSandersG
              GertSandersG
              GertSanders
              @alexsh1
              Ordered from OSHPark ?
                @alexsh1
                alexsh1A
                alexsh1A
                alexsh1
                @GertSanders said:
                @alexsh1
                Yes - these guys are good
                • E
                  E
                  emc2
                  Did anyone successfully used kicad footprint for these guys?
                  I received today my first PCB designed for the SMD version, did not work and overheated quite badly. After trying to troubleshoot it, frying a few things on the way, it seems to me that VCC / GND pad are switched between schematics and footprint:
                  "Datasheet" from one of many aliexpress / ebay seller (all seems to be the same)
                  KiCad PCB view
                  I changed it on a local lib to reorder a new PCB and try, but if others can have a look at it, especially @tbowmo to update the official github repo if needed.
                  • E emc2
                    KiCad PCB view
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @emc2 You have to be careful with these. As I discovered myself recently there are ones with PIN1 and PIN2 as VCC and GND and others with PIN1 and PIN8 as VCC and GND.
                    This is not well documented!
                    E 1 Reply Last reply
                    • alexsh1A alexsh1
                      E
                      E
                      emc2
                      @alexsh1 Damnit...
                      Never encountered a PIN1/PIN8 module yet. Are those with blob? I saw a few modules with black blob, often a big cristal and very cheap but I never ordered them.
                      I have a few of this exact module, it has a datasheet on the website and wiring it as described work on a breadboard.
                      Did you encounter any PIN1 - GND, PIN2 - VCC so far?
                      Problem may be somewhere else, probability that I screwed up my PCB design is high. I will see with the next PCB, with pin switched, if it's working.
                      • E emc2
                        @alexsh1 Damnit...
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @emc2 Yes, all of my nrf24l01+ smd modules have PIN1 - VCC and PIN2 - GND
                        No idea why chinese are switching pins
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @emc2
                          Sorry about that, it was made in a jiffy one dark night, and I never got around to verify the footprint myself :(
                          I'll update the footprint later today (or you can make a PR on github and change it your self).
                          • tbowmoT tbowmo
                            @emc2
                            E
                            E
                            emc2
                            @tbowmo
                            Hey no worries, it's still a great ressource and so far I used it without any problem.
                            I'm always confused by github when it came to PR etc but it should work. I just switched the coordinates of pad 1 and 2 it should do the trick.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @emc2
                              I updated the footprint on github (and yes, I also chose the easy route, and swapped pins 1 and 2 on the footprint) :)
