  2. KiCad
  3. NRF24L01+ smd schematics
Scheduled Pinned Locked Moved KiCad
18 Posts 5 Posters 14.0k Views 4 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    @GertSanders you can change the status of your node as "tested". It works just fine - one important thing to remember is to solder the 3.3v solderpad. A couple of observations:
    1. I can no longer fit a single AAA battery holders, but a double one only (AA or AAA)
    2. the holes for J1 are two small and I had to drill them out.
    I have not tested ATSHA204A as I do not have all components yet.
    G 1 Reply Last reply
    • alexsh1A alexsh1
      G Offline
      G Offline
      GertSanders
      @alexsh1
      So you received the boards before I did :-)
      I'm still waiting on them. They are "in the mail" or at least in the hands of my local mail service (any day now...).
      Which type of header/connector did you use to mount in the J1 location ? If the holes are too narrow for the breakable two row male headers, I will adapt this (that is why it is still UNTESTED for me).
      Indeed, one or two single AAA holders are not possible on this board. I found that the double battery holders actually are cheaper, and it allows avoiding two extra holes where the radio now sits.
      Update: I checked the drill size of the part used in v3 to place the header, indeed this is 0,8mm (31 mil) instead of 1,016mm (40 mil).
      In my v4 version I already switched to a wider header, and this one does have 40 mil drill diameter. It's good I did not do a panel with the v3 version.
      alexsh1A 1 Reply Last reply
      • G GertSanders
        @alexsh1
        alexsh1A Offline
        alexsh1A Offline
        alexsh1
        @GertSanders
        Yes, I have got the boards in 3-4 days. Very quick
        I have used a single row header like this
        http://www.protostack.com/connectors/headers/40-pin-2.54mm-snappable-single-row-header
        • alexsh1A alexsh1
          @GertSanders
          G Offline
          G Offline
          GertSanders
          @alexsh1
          Ordered from OSHPark ?
          • G GertSanders
            @alexsh1
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @GertSanders said:
            @alexsh1
            Yes - these guys are good
            • E Offline
              E Offline
              emc2
              Did anyone successfully used kicad footprint for these guys?
              I received today my first PCB designed for the SMD version, did not work and overheated quite badly. After trying to troubleshoot it, frying a few things on the way, it seems to me that VCC / GND pad are switched between schematics and footprint:
              "Datasheet" from one of many aliexpress / ebay seller (all seems to be the same)
              KiCad PCB view
              I changed it on a local lib to reorder a new PCB and try, but if others can have a look at it, especially @tbowmo to update the official github repo if needed.
              • E emc2
                KiCad PCB view
                alexsh1A Offline
                alexsh1A Offline
                alexsh1
                @emc2 You have to be careful with these. As I discovered myself recently there are ones with PIN1 and PIN2 as VCC and GND and others with PIN1 and PIN8 as VCC and GND.
                This is not well documented!
                E 1 Reply Last reply
                • alexsh1A alexsh1
                  E Offline
                  E Offline
                  emc2
                  @alexsh1 Damnit...
                  Never encountered a PIN1/PIN8 module yet. Are those with blob? I saw a few modules with black blob, often a big cristal and very cheap but I never ordered them.
                  I have a few of this exact module, it has a datasheet on the website and wiring it as described work on a breadboard.
                  Did you encounter any PIN1 - GND, PIN2 - VCC so far?
                  Problem may be somewhere else, probability that I screwed up my PCB design is high. I will see with the next PCB, with pin switched, if it's working.
                  • E emc2
                    @alexsh1 Damnit...
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    @emc2 Yes, all of my nrf24l01+ smd modules have PIN1 - VCC and PIN2 - GND
                    No idea why chinese are switching pins
                    • T Offline
                      T Offline
                      tbowmo
                      @emc2
                      Sorry about that, it was made in a jiffy one dark night, and I never got around to verify the footprint myself :(
                      I'll update the footprint later today (or you can make a PR on github and change it your self).
                      • T tbowmo
                        @emc2
                        E Offline
                        E Offline
                        emc2
                        @tbowmo
                        Hey no worries, it's still a great ressource and so far I used it without any problem.
                        I'm always confused by github when it came to PR etc but it should work. I just switched the coordinates of pad 1 and 2 it should do the trick.
                        • T Offline
                          T Offline
                          tbowmo
                          @emc2
                          I updated the footprint on github (and yes, I also chose the easy route, and swapped pins 1 and 2 on the footprint) :)
