  2. KiCad
  3. NRF24L01+ smd schematics
Scheduled Pinned Locked Moved KiCad
18 Posts 5 Posters 14.2k Views 4 Watching
  • GertSandersG GertSanders
    @alexsh1
    So you received the boards before I did :-)
    I'm still waiting on them. They are "in the mail" or at least in the hands of my local mail service (any day now...).
    Which type of header/connector did you use to mount in the J1 location ? If the holes are too narrow for the breakable two row male headers, I will adapt this (that is why it is still UNTESTED for me).
    Indeed, one or two single AAA holders are not possible on this board. I found that the double battery holders actually are cheaper, and it allows avoiding two extra holes where the radio now sits.
    Update: I checked the drill size of the part used in v3 to place the header, indeed this is 0,8mm (31 mil) instead of 1,016mm (40 mil).
    In my v4 version I already switched to a wider header, and this one does have 40 mil drill diameter. It's good I did not do a panel with the v3 version.
    alexsh1A
    alexsh1A
    alexsh1
    @GertSanders
    Yes, I have got the boards in 3-4 days. Very quick
    I have used a single row header like this
    http://www.protostack.com/connectors/headers/40-pin-2.54mm-snappable-single-row-header
    • alexsh1A alexsh1
      @GertSanders
      GertSandersG
      GertSandersG
      GertSanders
      @alexsh1
      Ordered from OSHPark ?
      alexsh1A 1 Reply Last reply
        @alexsh1
        alexsh1A
        alexsh1A
        alexsh1
        @GertSanders said:
        @alexsh1
        Yes - these guys are good
        • E
          E
          emc2
          Did anyone successfully used kicad footprint for these guys?
          I received today my first PCB designed for the SMD version, did not work and overheated quite badly. After trying to troubleshoot it, frying a few things on the way, it seems to me that VCC / GND pad are switched between schematics and footprint:
          "Datasheet" from one of many aliexpress / ebay seller (all seems to be the same)
          KiCad PCB view
          I changed it on a local lib to reorder a new PCB and try, but if others can have a look at it, especially @tbowmo to update the official github repo if needed.
          • E emc2
            KiCad PCB view
            alexsh1A
            alexsh1A
            alexsh1
            @emc2 You have to be careful with these. As I discovered myself recently there are ones with PIN1 and PIN2 as VCC and GND and others with PIN1 and PIN8 as VCC and GND.
            This is not well documented!
            E 1 Reply Last reply
            • alexsh1A alexsh1
              E
              E
              emc2
              @alexsh1 Damnit...
              Never encountered a PIN1/PIN8 module yet. Are those with blob? I saw a few modules with black blob, often a big cristal and very cheap but I never ordered them.
              I have a few of this exact module, it has a datasheet on the website and wiring it as described work on a breadboard.
              Did you encounter any PIN1 - GND, PIN2 - VCC so far?
              Problem may be somewhere else, probability that I screwed up my PCB design is high. I will see with the next PCB, with pin switched, if it's working.
              • E emc2
                @alexsh1 Damnit...
                alexsh1A
                alexsh1A
                alexsh1
                @emc2 Yes, all of my nrf24l01+ smd modules have PIN1 - VCC and PIN2 - GND
                No idea why chinese are switching pins
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @emc2
                  Sorry about that, it was made in a jiffy one dark night, and I never got around to verify the footprint myself :(
                  I'll update the footprint later today (or you can make a PR on github and change it your self).
                  • tbowmoT tbowmo
                    @emc2
                    E
                    E
                    emc2
                    @tbowmo
                    Hey no worries, it's still a great ressource and so far I used it without any problem.
                    I'm always confused by github when it came to PR etc but it should work. I just switched the coordinates of pad 1 and 2 it should do the trick.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @emc2
                      I updated the footprint on github (and yes, I also chose the easy route, and swapped pins 1 and 2 on the footprint) :)
