  3. Combining Multiple sensors - Reed switch not working
5 Posts 3 Posters 2.8k Views 4 Watching
  • rhuehnR Offline
    rhuehnR Offline
    rhuehn
    wrote on last edited by rhuehn
    Hello:
    I have a multi sensor with a DHT, PIR, NRF, and Reed switch. The PIR is connected to PIN 3, and the Reed switch is connected to PIN 2. The reed switch is setup exactly as the mysensors example here, ( https://www.mysensors.org/build/binary ) and works perfectly fine when only using that sketch. When trying to combine a few sketches, I'm getting everything else to work except for the Reed switch, and can't figure out where I've gone wrong. Is anyone able to possibly shed some light? My code is below, and really appreciate the help thank you.
      #define MY_GW_ID 50
    // Enable debug prints
    //Constants
    #define SKETCH_NAME           "3 in 1 Sensor"
    #define SKETCH_VERSION        "1.0"
    #define CHILD_ID_TEMP 1                  // Child id for Temperature
    #define CHILD_ID_HUM 0                   // Child id for Humidity
    #define CHILD_ID_MOT 2                   // Child id for Motion
    #define HUMIDITY_SENSOR_DIGITAL_PIN 7    // Where is my DHT22 data pin connected to
    #define DIGITAL_INPUT_SENSOR 3           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define CHILD_ID_SW 3                    // Child id for Reed Switch
    #define BUTTON_PIN  2                    // Arduino Digital I/O pin for button/reed switch
    int node_id=50;                          // What is my node id
    Bounce debouncer = Bounce();
    int oldValue=-1;
    DHT dht;
    //Store last values
    float lastTemp = 0 ;
    float lastHum = 0 ;
    boolean lastTripped = false ;
    boolean metric = true;
    boolean gwsend = true;              // to determine if data has to be sent
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
    MyMessage msgsw(CHILD_ID_SW,V_TRIPPED);
      gw.begin(NULL,node_id,false);
      gw.sendSketchInfo("3 in 1 Sensor", "1.0",true);
     //  - NEW Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
     //  - NEW Setup the button END
      gw.present(CHILD_ID_HUM, S_HUM,"Garage Humidity");
      gw.present(CHILD_ID_TEMP, S_TEMP,"Garage Temperature");
      gw.present(CHILD_ID_SW, S_DOOR,"Garage Door");
      // Read Reed switch value
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msgsw.set(value==HIGH ? 1 : 0));
         oldValue = value;
      // Read Temp - Humidity Value
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      // Read digital motion PIR value
      Serial.println(tripped);
      gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    • L Offline
      L Offline
      LastSamurai
      Afaik the debouncer doesn't work with sleep(). Try without or just do something like a
      gw.wait(5);
      before reading the value. At least I had the same problem and fixed it like that.
      • rhuehnR Offline
        rhuehnR Offline
        rhuehn
        Thanks very much @LastSamurai removing the sleep function seemed to work, but the PIR reports like crazy!
        send: 50-50-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,st=ok:0
        I don't really need sleep, but will be adding a relay to this sketch. Any other suggestions that might not trigger the PIR all the time? Thanks very much again!
        • F Offline
          F Offline
          fets
          @rhuehn now that you have a "wait", your loop is not blocked. Then after the "wait" elapses the loop start again and you send a new PIR state (which is certainly the same than the previous loop).
          So you have to memorize the last state and check if the pir state changed in the loop. You send the msg only f state is different.
          I hope my explanation is clear :)
          • rhuehnR Offline
            rhuehnR Offline
            rhuehn
            thanks @fets have I specified the wait time at the wrong location? In the sketch below, everything works, BUT the PIR triggers 0 over and over and over again.....
             #define MY_GW_ID 50
            //Constants
            #define CHILD_ID_TEMP 11                  // Child id for Temperature
            #define CHILD_ID_HUM 10                   // Child id for Humidity
            #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            int oldValue=-1;
            DHT dht;
            //Store last values
            float lastHum = 0 ;
              gw.wait(5);
              debouncer.update();
                 oldValue = value;
                if (!metric) {
                  lastHum = humidity;
