  3. Error SerialGateway.ino:41:27: fatal error: MySigningNone.h: No such file or directory
3 Posts 2 Posters 1.0k Views 2 Watching
  • jeffersJ Offline
    jeffersJ Offline
    jeffers
    wrote on last edited by jeffers
    Hi Everyone, I'm getting the error above when I run Serial Gateway. I'm running windows 8.1 and using Arduino v1.7.9. downloaded the recent version of Arduino-master.
    I installed the Arduino-master using Sketch->Import Library->Add Library. I have uninstalled it, re-down loaded it, rebooted the computer, you name it, no luck.
    Weird thing is, I had it working on this same computer about 6-9 months ago. I can't remember if I was running Windows 7 at the time.
    Does Arduino-master run on Windows 8.1 Pro? What am I doing wrong?
    Thanks Jeff
    3 days later after posting this and still can't figure out why the error when the file is right where it's supposed to be. Very annoying.
    alexsh1A 1 Reply Last reply
    • jeffersJ jeffers
      Thanks Jeff
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      @jeffers I am using Arduino 1.6.7 - try using different version.
      Please delete and re-install MySensors in libraries folder
      • jeffersJ Offline
        jeffersJ Offline
        jeffers
        I finally figured it out. I had to put it in the the library where the arduino.exe is. In the programs (x86) folder.
        I could of swore that it worked in the arduino library that is in my documents folder.
        Now that I switched to Windows 10, I'm going to see if it"ll will work in the documents folder where all my other sketches are.
        Hope this helps someone else.
        Jeff
        11.8k
        113.2k
