  3. Signing: no active verification session?
36 Posts 3 Posters 6.6k Views 2 Watching
  • T tomkxy
    @Anticimex Thanks for your reply. Highly appreciated!
    My use case is that the controller sends upon reception of a time request a time response and pending state changes. There is no wait in between. If I understood you correctly this could be reason.
    I will change the controller to have a wait in between both messages. I will report results back.
    AnticimexA
    AnticimexA
    Anticimex
    @tomkxy No worries, and now I will ask for some help in return :)
    I have no hw currently you see so I have no means for verifying atsha or soft signing.
    But I have made a PR with various improvements:
    https://github.com/mysensors/Arduino/pull/454
    If you would be so kind to test it I would be grateful. Even more so if you tried soft signing as well.
    It should permit simultaneous signing sessions at both ends now, and performance for atsha signing should have been improved.
    • T
      tomkxy
      @Anticimex How can I merge the commits of your pull requests into my clone of the development branch?
      If I install the code at my gateway and node. Are "older nodes" (mid march state of dev branch" supposed to work?
      Do you have any particular tests in mind?
      • T
        tomkxy
        @Anticimex Inserting a wait in between consecutive sends at the controller seem to fix it.
        I merged your pull request into my local copy. Are there specific cases you want me to test?
        AnticimexA 1 Reply Last reply
        • T tomkxy
          AnticimexA
          AnticimexA
          Anticimex
          @tomkxy thanks. Well, try removing your delay for starters. Might not be needed anymore. Apart from that, just that it still manages to sign and verify messages.
          • T
            tomkxy
            @Anticimex Will do it tomorrow and let you know.
            • T
              tomkxy
              Ok, I concluded my tests.
              The setup I used was as follows:
              • One node running the sketch as listed above. The sketch just send a time request to the controller. The controller send a time response back and depending on the controller state an additional message carrying the new state.
              • A MQTTClientGateway using ATSHA204 signing
              • Gateway and node were either on current deveopment branch (clone from yesterday) or on pull request branch
              Summary:
              • ATSHA204 signing work
              • Signing in pull request code and current development branch seems not to be compatible
              • Signing through repeater worked (repeater on old dev branch version)
              • Possible issue with soft signing and ATSHA204 signing (will re-run test)
              • Signing Code in pull request made by wait statements between sends in controller code obsolete
              I need to split the Test Details over several posts due to size restrictions,
              Test Details:
              TEST 1
              • Node is using ATSHA204 signing
              • Controller has time delays between time response send and state message
              • Only node upgraded - gateway on current development branch
              RESULT:
              • Message from node did not went through gateway (I would reason that probably signing not compatible between pull request and development branch ?)
              Log file from node (Note: that no message "Time value received and updated" occurs)
              ——— LOG file
              Starting sensor (RNNNAA, 2.0.0-beta)
              Radio init successful.
              Signing required
              Skipping security for command 3 type 15
              send: 32-32-24-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
              Waiting for GW to send signing preferences...
              read: 0-24-32 s=255,c=3,t=15,pt=0,l=2,sg=0:
              Mark node 0 as one that require signed messages
              Mark node 0 as one that do not require whitelisting
              Skipping security for command 3 type 16
              send: 32-32-24-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok:
              Nonce requested from 0. Waiting...
              Skipping security for command 3 type 17
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:5C6D5380AA71742E8676754178E292A5EF45D9AF4AC1DFBDAF
              Nonce received from 0. Proceeding with signing...
              Signing backend: ATSHA204
              Message to process: 2000560011FF322E302E302D62657461
              Current nonce: 5C6D5380AA71742E8676754178E292A5EF45D9AF4AC1DFBDAFAAAAAAAAAAAAAA
              HMAC: 88E620D12206F54747A0913982E7B536D2FA54B23365E938944D79A7785FA653
              Signature in message: 01E620D12206F54747A0913982E7B5
              Message signed
              Message to send has been signed
              send: 32-32-24-0 s=255,c=0,t=17,pt=0,l=10,sg=1,st=ok:2.0.0-beta
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:E9823769510CC4E9DB319047430608FC46E072E1C85DC1729C
              Message to process: 20000E2306FF18
              Current nonce: E9823769510CC4E9DB319047430608FC46E072E1C85DC1729CAAAAAAAAAAAAAA
              HMAC: 3AFE900842CA69B839436A9417E03B7A1B9F56C86947503DA8211384BD380BA8
              Signature in message: 01FE900842CA69B839436A9417E03B7A1B9F56C86947503D
              Message signed
              send: 32-32-24-0 s=255,c=3,t=6,pt=1,l=1,sg=1,st=ok:24
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:62A476471D816BD32D881C6F0F93EECC6F3D10C30FE36C4034
              Message to process: 20008E030BFF53656E736562656E646572204D6963726F
              Current nonce: 62A476471D816BD32D881C6F0F93EECC6F3D10C30FE36C4034AAAAAAAAAAAAAA
              HMAC: DD2922863F989B9FA66A9DCC91C6C68693976C111246A758F2A9D3B35DE4C6C8
              Signature in message: 012922863F989B9F
              Message signed
              send: 32-32-24-0 s=255,c=3,t=11,pt=0,l=17,sg=1,st=ok:Sensebender Micro
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:E5EB28E56178B7A9EA9C6CF6ED4942C7CFCBE36CE8F770E9CD
              Message to process: 20001E030CFF312E35
              Current nonce: E5EB28E56178B7A9EA9C6CF6ED4942C7CFCBE36CE8F770E9CDAAAAAAAAAAAAAA
              HMAC: EE80E376A9134A53E582798BE1B82D0626B749A0B3AB40B146ECBD046A704FE7
              Signature in message: 0180E376A9134A53E582798BE1B82D0626B749A0B3AB
              Message signed
              send: 32-32-24-0 s=255,c=3,t=12,pt=0,l=3,sg=1,st=ok:1.5
              send: 32-32-24-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=ok:
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:086BCF8D9E1FCE7E31DBC460DBBDA3F192423DEB1D7AED29B4
              Message to process: 200006001F00
              Current nonce: 086BCF8D9E1FCE7E31DBC460DBBDA3F192423DEB1D7AED29B4AAAAAAAAAAAAAA
              HMAC: B304BBD4ED2EFC5EEE8345711D1FA7D4ED7DDCB433B93902B35E408732F52CE6
              Signature in message: 0104BBD4ED2EFC5EEE8345711D1FA7D4ED7DDCB433B93902B3
              Message signed
              send: 32-32-24-0 s=0,c=0,t=31,pt=0,l=0,sg=1,st=ok:
              Init complete, id=32, parent=24, distance=2
              ------------- Start request time ------------
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:05804055A92D47DDECE52E060847E918F2D259E02E53B239DF
              Message to process: 2000060301FF
              Current nonce: 05804055A92D47DDECE52E060847E918F2D259E02E53B239DFAAAAAAAAAAAAAA
              HMAC: 860F685BD22C9A93712755D7536E6B1192BA7B5F3BA19B36DA4B18EE80A83912
              Signature in message: 010F685BD22C9A93712755D7536E6B1192BA7B5F3BA19B36DA
              Message signed
              send: 32-32-24-0 s=255,c=3,t=1,pt=0,l=0,sg=1,st=ok:
              ------------- End request time ------------
              Message to send could not be signed!
              sign fail
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:13F748758F5F525808686913EB32CB1301A347DA71BCEC0E24
              Current nonce: 13F748758F5F525808686913EB32CB1301A347DA71BCEC0E24AAAAAAAAAAAAAA
              HMAC: DCE1C3919B3F1438EA00F8736994F5BE4EE8FCE197782A006C313B0053B1F4AC
              Signature in message: 01E1C3919B3F1438EA00F8736994F5BE4EE8FCE197782A006C
              Message signed
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:0E77297DB0F5BB24C127F55A7722A26F2B9F5D82CD3527B2C4
              Current nonce: 0E77297DB0F5BB24C127F55A7722A26F2B9F5D82CD3527B2C4AAAAAAAAAAAAAA
              HMAC: A07FE5FAD14B49598D4D000B1496AFB1B745140C095C7CDB2041B51C3BAF166A
              Signature in message: 017FE5FAD14B49598D4D000B1496AFB1B745140C095C7CDB20
              Message signed
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:CC2B7F584284438EE577F13911AA5BD6B13F11CF19C072C280
              Current nonce: CC2B7F584284438EE577F13911AA5BD6B13F11CF19C072C280AAAAAAAAAAAAAA
              HMAC: 1EE99C23EAF302945390304E8DDF21EFEB1509D482E729E94129DDB14DBEFF72
              Signature in message: 01E99C23EAF302945390304E8DDF21EFEB1509D482E729E941
              Message signed
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:B3B1641F1EFA3E6AC55BCDD8762BBA30684E2E95B5D360534A
              Current nonce: B3B1641F1EFA3E6AC55BCDD8762BBA30684E2E95B5D360534AAAAAAAAAAAAAAA
              HMAC: 2FBF0526DA75A1730B06B42A114A51D0844A7F5D708ED88CD0BF205367D6436E
              Signature in message: 01BF0526DA75A1730B06B42A114A51D0844A7F5D708ED88CD0
              Message signed
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:F2F1E9F252998B73BB5ACDFCB5EABD1CCE80FC922B02AD2708
              Current nonce: F2F1E9F252998B73BB5ACDFCB5EABD1CCE80FC922B02AD2708AAAAAAAAAAAAAA
              HMAC: AF64B1BBCCBA140CC7D888379C5AB5AEEE32A7EF53DCF8E5D381D8BBF10C0EB8
              Signature in message: 0164B1BBCCBA140CC7D888379C5AB5AEEE32A7EF53DCF8E5D3
              Message signed
              read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:70EEB8AB6758247D2BDE15C3E3ECF736A26896507A578451B5
              Current nonce: 70EEB8AB6758247D2BDE15C3E3ECF736A26896507A578451B5AAAAAAAAAAAAAA
              HMAC: 0188F0C5B3E33EA5F367AC3C8A5147000EEAFBC632221B0A2C68A6E912E6502F
              Signature in message: 0188F0C5B3E33EA5F367AC3C8A5147000EEAFBC632221B0A2C
              Message signed
              • T
                tomkxy
                Continuation of test details:
                TEST 2
                • Node and gateway on current development branch
                RESULT:
                • As already confirmed yesterday time responses received back from controller
                Log file from node
                Signing required
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:E6FA71F94B26770A2F95CA73CE0AD5BAF5E20FBE47DCD15009
                Current nonce: E6FA71F94B26770A2F95CA73CE0AD5BAF5E20FBE47DCD15009AAAAAAAAAAAAAA
                HMAC: 35D8295F4A9EFEA36A8B1127EE44374F7778E6960F1F4FCAE5DA2E2ACF66BDF3
                Signature in message: 01D8295F4A9EFEA36A8B1127EE4437
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:5B94347F2300D7469FA9450BABBD441CA0B6A794E9F6EF4A19
                Current nonce: 5B94347F2300D7469FA9450BABBD441CA0B6A794E9F6EF4A19AAAAAAAAAAAAAA
                HMAC: 7C724399F2861D355FC195EEFB19BCA69045B6316065DCA698866C3DB0DD2D30
                Signature in message: 01724399F2861D355FC195EEFB19BCA69045B6316065DCA6
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:EA257A1C0F67F106E0D689CB816EE42309368549BF801263EB
                Current nonce: EA257A1C0F67F106E0D689CB816EE42309368549BF801263EBAAAAAAAAAAAAAA
                HMAC: 1B730087D4F021A92E687301D293893EEF26C59A1DC76783D137A098C0F3BC8A
                Signature in message: 01730087D4F021A9
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:9E3CB2E54C67294BA2FDE0D8581ED4657FAC24C8193898C432
                Current nonce: 9E3CB2E54C67294BA2FDE0D8581ED4657FAC24C8193898C432AAAAAAAAAAAAAA
                HMAC: 4044546C809C92399B8695C6065EEB614E694B8A99ECEB9604D529E3932E515D
                Signature in message: 0144546C809C92399B8695C6065EEB614E694B8A99EC
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:BE44D9741A571A265776618132F4C67D297170489FE1A5DE49
                Current nonce: BE44D9741A571A265776618132F4C67D297170489FE1A5DE49AAAAAAAAAAAAAA
                HMAC: 9146A18E9CFF81636145160052F05583773C17F3CD652323EDED7C8450A3B375
                Signature in message: 0146A18E9CFF81636145160052F05583773C17F3CD652323ED
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:1DE6CEC94F13A3620D3E8A158E57D9383678CD139DA8B886FC
                Current nonce: 1DE6CEC94F13A3620D3E8A158E57D9383678CD139DA8B886FCAAAAAAAAAAAAAA
                HMAC: 377976A6BAC3CD3D095B7E327F83FA8536BC0BF49ADF91F58D7A2FAD6C8B18B7
                Signature in message: 017976A6BAC3CD3D095B7E327F83FA8536BC0BF49ADF91F58D
                Message signed
                read: 0-24-32 s=255,c=3,t=16,pt=0,l=0,sg=0:
                SHA256: F08C3C1E3DA5AB87B604B516A44D243622A4C14EBA8EDF79EF46DFF2A40040A6
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:F08C3C1E3DA5AB87B604B516A44D243622A4C14EBA8EDF79EF
                Signature in message: 01B251AE4BE20816354DE00A0FA2B6
                Message to process: 0020560301FF31343635323833343332
                Current nonce: F08C3C1E3DA5AB87B604B516A44D243622A4C14EBA8EDF79EFAAAAAAAAAAAAAA
                HMAC: C4B251AE4BE20816354DE00A0FA2B6410F3EDCF014E9D7D85776384A1175F56A
                Signature OK
                read: 0-24-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465283432
                Time value received and updated...
                read: 0-24-32 s=0,c=3,t=16,pt=0,l=0,sg=0:
                SHA256: 9FC72D6C543D8F4B63D4D3D000A3FFB94CCC89FB7A446D5177699E115CA56A95
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:9FC72D6C543D8F4B63D4D3D000A3FFB94CCC89FB7A446D5177
                Signature in message: 010A2ACC376944024575A028BC722E7C8602F182B9F82794
                Message to process: 00200E01020030
                Current nonce: 9FC72D6C543D8F4B63D4D3D000A3FFB94CCC89FB7A446D5177AAAAAAAAAAAAAA
                HMAC: 820A2ACC376944024575A028BC722E7C8602F182B9F82794C912D83A19E1CC33
                Signature OK
                read: 0-24-32 s=0,c=1,t=2,pt=0,l=1,sg=0:0
                SHA256: 7D55FD16CF971E9702AA53D575A406123F64FBA233C904C40748B2535A26A548
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:7D55FD16CF971E9702AA53D575A406123F64FBA233C904C407
                Signature in message: 01971DE8FC789C9C773C89261EE7C7E06A646C4479B53844
                Message to process: 00200E01180038
                Current nonce: 7D55FD16CF971E9702AA53D575A406123F64FBA233C904C407AAAAAAAAAAAAAA
                HMAC: FF971DE8FC789C9C773C89261EE7C7E06A646C4479B538444A52BF2C7285EF87
                Signature OK
                read: 0-24-32 s=0,c=1,t=24,pt=0,l=1,sg=0:8
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:A0334E2B3A18F6C64907210670EBEDCC48B089713E321CD8AC
                Current nonce: A0334E2B3A18F6C64907210670EBEDCC48B089713E321CD8ACAAAAAAAAAAAAAA
                HMAC: 9D86902DC3D6F353A34805DB53C4D23E525A2A6563E2D0715B0AF8857C2490B2
                Signature in message: 0186902DC3D6F353A34805DB53C4D23E525A2A6563E2D0715B
                Message signed
                SHA256: FFDDC014EDB87ECF5EC8AB75688B5C2C64B96A01C717491D0C108FF81049EB73
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:FFDDC014EDB87ECF5EC8AB75688B5C2C64B96A01C717491D0C
                Signature in message: 0176C6F293A06DE6ED24828FE89FF7
                Message to process: 0020560301FF31343635323833343635
                Current nonce: FFDDC014EDB87ECF5EC8AB75688B5C2C64B96A01C717491D0CAAAAAAAAAAAAAA
                HMAC: B876C6F293A06DE6ED24828FE89FF728E34B135B52E48615A22C6F76CF3C4A99
                Signature OK
                read: 0-24-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465283465
                SHA256: 8DBF6695277390951AD9DF479264D55207682E6CD178BC06CA31ECB596904B4A
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:8DBF6695277390951AD9DF479264D55207682E6CD178BC06CA
                Signature in message: 01409B6BF1B3B666DAB81D1845A04A98C4D111779492F2E0
                Current nonce: 8DBF6695277390951AD9DF479264D55207682E6CD178BC06CAAAAAAAAAAAAAAA
                HMAC: D3409B6BF1B3B666DAB81D1845A04A98C4D111779492F2E0EE294358EC49179B
                Signature OK
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:3A6C12FD7546268F0D41B0D329AE91D21077965C09045B5A1A
                Current nonce: 3A6C12FD7546268F0D41B0D329AE91D21077965C09045B5A1AAAAAAAAAAAAAAA
                HMAC: 90168F16ECBE84D86D9D029F9FB8B2FEA7B23017BC17DFD794B74FBFE30367AC
                Signature in message: 01168F16ECBE84D86D9D029F9FB8B2FEA7B23017BC17DFD794
                Message signed
                SHA256: 1AF497E7C0AF46E1E9CE4606052BA4D6EB40B9509E2F08ADFDA855C348197072
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:1AF497E7C0AF46E1E9CE4606052BA4D6EB40B9509E2F08ADFD
                Signature in message: 0119794623B47138C025DF9F233ECD
                Message to process: 0020560301FF31343635323833343937
                Current nonce: 1AF497E7C0AF46E1E9CE4606052BA4D6EB40B9509E2F08ADFDAAAAAAAAAAAAAA
                HMAC: 9F19794623B47138C025DF9F233ECDBAF4A9894997361464CFCCA972AE4989A8
                Signature OK
                read: 0-24-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465283497
                SHA256: 58F999A6FC7F4688CC738CD2BC8B959844C8E71A0E9DC4FC0AAE473224D1C0B5
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:58F999A6FC7F4688CC738CD2BC8B959844C8E71A0E9DC4FC0A
                Signature in message: 01CC16B0D5685A602160700EF75089F6073C80F21534F93E
                Current nonce: 58F999A6FC7F4688CC738CD2BC8B959844C8E71A0E9DC4FC0AAAAAAAAAAAAAAA
                HMAC: 69CC16B0D5685A602160700EF75089F6073C80F21534F93E2000948D7E8BC997
                Signature OK
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:E75AE3FF33609B318F5189128FA4244BFA8B1E70359812C2C0
                Current nonce: E75AE3FF33609B318F5189128FA4244BFA8B1E70359812C2C0AAAAAAAAAAAAAA
                HMAC: B6FB768F1A2BB917329A5BE007BAF736AAB801FBD7AAF5E797DA258B335844D2
                Signature in message: 01FB768F1A2BB917329A5BE007BAF736AAB801FBD7AAF5E797
                Message signed
                SHA256: 741733AB092E579BEBBFC59DC028F867F81D96CBC7E5C252D1C92A4F695C64E9
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:741733AB092E579BEBBFC59DC028F867F81D96CBC7E5C252D1
                Signature in message: 0147B776D9FE233CCD972679DF861A
                Message to process: 0020560301FF31343635323833353335
                Current nonce: 741733AB092E579BEBBFC59DC028F867F81D96CBC7E5C252D1AAAAAAAAAAAAAA
                HMAC: 3047B776D9FE233CCD972679DF861A18DBF50268777FAAABC8B57D9AD4E0FDD6
                Signature OK
                read: 0-24-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465283535
                SHA256: D84DC5731286B20B4E7A145AD56E6CC01D4F4BC50D2CF1F15EF2C61031B3ADB4
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:D84DC5731286B20B4E7A145AD56E6CC01D4F4BC50D2CF1F15E
                Signature in message: 0165AC479F9655E4A5AA8BBCEEFBADFD8A5A82098F785DA8
                Current nonce: D84DC5731286B20B4E7A145AD56E6CC01D4F4BC50D2CF1F15EAAAAAAAAAAAAAA
                HMAC: 6265AC479F9655E4A5AA8BBCEEFBADFD8A5A82098F785DA83869EDCF9A3C9AE5
                Signature OK
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:2B043E5A9822F872642044D993996C219D7387ADED3FCBEAAC
                Current nonce: 2B043E5A9822F872642044D993996C219D7387ADED3FCBEAACAAAAAAAAAAAAAA
                HMAC: 232BC7F7C4BDBA0D41559AF67DD47FA212AC12EB8B06401C2C23A7AF0172436D
                Signature in message: 012BC7F7C4BDBA0D41559AF67DD47FA212AC12EB8B06401C2C
                Message signed
                SHA256: BE203E8DCB145A7AEA98A3E7BA43D8D4837A9FD9572D54B220C4DCE37C9CC8B8
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:BE203E8DCB145A7AEA98A3E7BA43D8D4837A9FD9572D54B220
                Signature in message: 010DB59D0F3452D2785F69172BB6D9
                Message to process: 0020560301FF31343635323833353638
                Current nonce: BE203E8DCB145A7AEA98A3E7BA43D8D4837A9FD9572D54B220AAAAAAAAAAAAAA
                HMAC: BC0DB59D0F3452D2785F69172BB6D931F071F8599B4B1685E921800ED64A2ED5
                Signature OK
                read: 0-24-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465283568
                SHA256: 466900BD4216412DF7B918A01726A585D404BF70647DAABA7C43A272142381CE
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:466900BD4216412DF7B918A01726A585D404BF70647DAABA7C
                Signature in message: 011633DF1C1E5CE5BC498D0713D4375337AB1686E6930D72
                Current nonce: 466900BD4216412DF7B918A01726A585D404BF70647DAABA7CAAAAAAAAAAAAAA
                HMAC: 301633DF1C1E5CE5BC498D0713D4375337AB1686E6930D729761FA1833B50550
                Signature OK
                TEST 3
                • Gateway and Node on pull request node
                • By accident repeater is being used by node (repeater on mid march version of development branch)
                RESULT:
                • OK
                Log file form node
                Signing required
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:7FFE40154EF5EDC50456162DDF2DDE74267E32EC275FBD7EAB
                Current nonce: 7FFE40154EF5EDC50456162DDF2DDE74267E32EC275FBD7EABAAAAAAAAAAAAAA
                HMAC: 6A3AA858C7AEFC6C4BE07D05196BE89BE52C70C4799E42B73B8CDF83C0A57B92
                Signature in message: 013AA858C7AEFC6C4BE07D05196BE8
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:19C213A19C060D9AF53333025D95CC0D47E102D7534F6853C2
                Current nonce: 19C213A19C060D9AF53333025D95CC0D47E102D7534F6853C2AAAAAAAAAAAAAA
                HMAC: 3748905CBC38DCEA925EB2919C91D1C62C10766F1FAC36B3278246D5B71F3699
                Signature in message: 0148905CBC38DCEA925EB2919C91D1C62C10766F1FAC36B3
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:C4F140A7704F93F1ADDD92E353B52F64262D51F18C0E31E984
                Current nonce: C4F140A7704F93F1ADDD92E353B52F64262D51F18C0E31E984AAAAAAAAAAAAAA
                HMAC: 438D4A7A4DC4F81D813B776C408D28D330712BDFF9D6918CA5F5D399A39DCC62
                Signature in message: 018D4A7A4DC4F81D
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:6F36BDDE3BFC831A66DD1401932B313456C23E3E43A1043ED2
                Current nonce: 6F36BDDE3BFC831A66DD1401932B313456C23E3E43A1043ED2AAAAAAAAAAAAAA
                HMAC: 539E7375EDC9460D6C1CB93108B7AF3D8681F8DBBA12FF7D4F8EBD789674C526
                Signature in message: 019E7375EDC9460D6C1CB93108B7AF3D8681F8DBBA12
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:FF294B857B47AE22B3A8FDCB6C8900057722A43EAB7C76FEB1
                Current nonce: FF294B857B47AE22B3A8FDCB6C8900057722A43EAB7C76FEB1AAAAAAAAAAAAAA
                HMAC: 1984DB5AA5D62F10664670E558ED2127B3076B8E53594970FCB19090D4114346
                Signature in message: 0184DB5AA5D62F10664670E558ED2127B3076B8E53594970FC
                Message signed
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:346DB0580D3B78948D4642890DEE3BF8B713278F9035F1010E
                Current nonce: 346DB0580D3B78948D4642890DEE3BF8B713278F9035F1010EAAAAAAAAAAAAAA
                HMAC: 7D563A98EB3A82BD356405D848810D80E85B41B13BD5EF160EDC28D0D8410A3B
                Signature in message: 01563A98EB3A82BD356405D848810D80E85B41B13BD5EF160E
                Message signed
                SHA256: F8D84FE5212ADCDAA5DE824AAEC0D1D4EBA27A873C7A27FD6573312A0120144D
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:F8D84FE5212ADCDAA5DE824AAEC0D1D4EBA27A873C7A27FD65
                Signature in message: 01061F649DC8230A23A693B2BD13EF
                Message to process: 0020560301FF31343635323834333532
                Current nonce: F8D84FE5212ADCDAA5DE824AAEC0D1D4EBA27A873C7A27FD65AAAAAAAAAAAAAA
                HMAC: 9B061F649DC8230A23A693B2BD13EF482A0FD3D935AC12CAB83BAEE20AF7AFA6
                Signature OK
                read: 0-24-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465284352
                SHA256: C8D54FA98921070C459C82FA52F15F4588E6B8C7CBFA98E4ABCD41C842152E8E
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:C8D54FA98921070C459C82FA52F15F4588E6B8C7CBFA98E4AB
                Signature in message: 014449082B9AD2C9C678F3CAB3EF978885420D7F5DFC872F
                Current nonce: C8D54FA98921070C459C82FA52F15F4588E6B8C7CBFA98E4ABAAAAAAAAAAAAAA
                HMAC: 0B4449082B9AD2C9C678F3CAB3EF978885420D7F5DFC872F934FD46509728350
                Signature OK
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:ADE703FCA7389B894F9C6967C8556AE9332EC8819CC1403F4B
                Current nonce: ADE703FCA7389B894F9C6967C8556AE9332EC8819CC1403F4BAAAAAAAAAAAAAA
                HMAC: 85FCF9EB6F02220B9C7C541F0E4A39F96E0763ED8EC4B513D608B022A5FD743F
                Signature in message: 01FCF9EB6F02220B9C7C541F0E4A39F96E0763ED8EC4B513D6
                Message signed
                SHA256: 160BFFD15040AAB68A664D1E717A13F713EB4427DF9D5BB85F69BEDCDE371A10
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:160BFFD15040AAB68A664D1E717A13F713EB4427DF9D5BB85F
                Signature in message: 016D402871BF2F0955767FF9BD4D04
                Message to process: 0020560301FF31343635323834333832
                Current nonce: 160BFFD15040AAB68A664D1E717A13F713EB4427DF9D5BB85FAAAAAAAAAAAAAA
                HMAC: B16D402871BF2F0955767FF9BD4D043224B3161ABD93A483898CBE5B034DB929
                Signature OK
                read: 0-24-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465284382
                read: 0-24-32 s=255,c=3,t=17,pt=6,l=25,sg=0:20FE53ECF79ADB4E40AAEFC7822710105C7273500280542C6C
                Current nonce: 20FE53ECF79ADB4E40AAEFC7822710105C7273500280542C6CAAAAAAAAAAAAAA
                HMAC: C206D0F84D4BD17A4F91FEEC96A68FC08809FB764657A78B30BAA156811CAB35
                Signature in message: 0106D0F84D4BD17A4F91FEEC96A68FC08809FB764657A78B30
                Message signed
                SHA256: 26C55258CC012D74F2C67E21D8EEBDD1E360F39E6F15C0C84603D5AE48CF0441
                Transmittng nonce
                send: 32-32-24-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:26C55258CC012D74F2C67E21D8EEBDD1E360F39E6F15C0C846
                Signature in message: 019BDFBD6FB58C08DC10D5CFF9F809
                Message to process: 0020560301FF31343635323834343133
                Current nonce: 26C55258CC012D74F2C67E21D8EEBDD1E360F39E6F15C0C846AAAAAAAAAAAAAA
                HMAC: A99BDFBD6FB58C08DC10D5CFF9F8097420DEE280B27A9CE5ACA2EC0D1120FF98
                Signature OK
                read: 0-24-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465284413
                verify fail
                • T
                  tomkxy
                  TEST 4
                  • Node is using soft signing, GW ATSHA204 signing
                  • Node and gateway on pull request code
                  RESULT:
                  • Failed
                  Note: I just realized that I have in the beginning a couple of transmission errors which is due to he fact that I needed to bring the node and gateway probably to close together in order to get the gateway logs.
                  I will repeat this test!
                  Log file form node
                  Starting sensor (RNNNAS, 2.0.0-beta)
                  Signing required
                  send: 32-32-24-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail:
                  send: 32-32-24-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                  Failed to transmit nonce request!
                  sign fail
                  send: 32-32-24-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:2.0.0-beta
                  sign fail
                  send: 32-32-24-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:24
                  find parent
                  send: 32-32-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                  Skipping security for command 3 type 8
                  read: 0-0-32 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  parent=0, d=1
                  sign fail
                  send: 0-32-0-32 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0
                  send: 32-32-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:9D0A6F87CD7824856F6C5F86135DF9C205A52172154E2ECAA8
                  Signing backend: ATSHA204Soft
                  Current nonce: 9D0A6F87CD7824856F6C5F86135DF9C205A52172154E2ECAA8AAAAAAAAAAAAAA
                  HMAC: 1B03C1339C72E52DE7ADA8312983CE2853E8E4CF7A88C262250900388FFDD1F8
                  Signature in message: 0103C1339C72E52DE7ADA8312983CE2853E8E4CF7A88
                  Message signed
                  send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=3,sg=1,st=ok:1.5
                  send: 32-32-0-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:F6B9819CA822EECEE953357A43742393B952BB5C152C601208
                  Current nonce: F6B9819CA822EECEE953357A43742393B952BB5C152C601208AAAAAAAAAAAAAA
                  HMAC: A74B8E7B71B7F614D6E4DA7E1817459E5F15C26D5A75CA57B1723E9EEC5FC248
                  Signature in message: 014B8E7B71B7F614D6E4DA7E1817459E5F15C26D5A75CA57B1
                  Message signed
                  send: 32-32-0-0 s=0,c=0,t=31,pt=0,l=0,sg=1,st=ok:
                  Init complete, id=32, parent=0, distance=1
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:D84804E29BF6B78CC1F7823E860D19378D399472D3D3A43D6F
                  Current nonce: D84804E29BF6B78CC1F7823E860D19378D399472D3D3A43D6FAAAAAAAAAAAAAA
                  HMAC: CE335FA0706A8C57678547FA4DD9528BDE7AA9401607B3920C79DB515C630B46
                  Signature in message: 01335FA0706A8C57678547FA4DD9528BDE7AA9401607B3920C
                  Message signed
                  send: 32-32-0-0 s=255,c=3,t=1,pt=0,l=0,sg=1,st=ok:
                  Log file from gateway:
                  0;255;3;0;9;Starting gateway (RNNGAA, 2.0.0-beta)
                  0;255;3;0;9;MQTT connected
                  0;255;3;0;9;Skipping security for command 3 type 16
                  0;255;3;0;9;read: 32-32-0 s=255,c=3,t=16,pt=0,l=0,sg=0:
                  0;255;3;0;9;Signing backend: ATSHA204
                  0;255;3;0;9;SHA256: 1F0846076C5AD7D094CA224A960CF66CB67F5E6CB4BD0EEDD2EE290975E1CAAD
                  0;255;3;0;9;Transmittng nonce
                  0;255;3;0;9;Skipping security for command 3 type 17
                  0;255;3;0;9;send: 0-0-32-32 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:1F0846076C5AD7D094CA224A960CF66CB67F5E6CB4BD0EEDD2
                  0;255;3;0;9;Signature in message: 01E921AD315EFBDA944E6F9F1A7FB21BFD2FD798E2C212CB0E
                  0;255;3;0;9;Message to process: 2000060301FF
                  0;255;3;0;9;Current nonce: 1F0846076C5AD7D094CA224A960CF66CB67F5E6CB4BD0EEDD2AAAAAAAAAAAAAA
                  0;255;3;0;9;HMAC: 7C952EBD4EE51B758DA5BFA19E14F01DA5CD375882CE6CAA316F5A5117BA8A54
                  0;255;3;0;9;Signature bad: 01952EBD4EE51B758DA5BFA19E14F01DA5CD375882CE6CAA31
                  0;255;3;0;9;Signature verification failed!
                  0;255;3;0;9;verify fail
                  TEST 5
                  • ATSHA204 signing
                  • Removed delays between send in controller
                  RESULT:
                  • OK
                  Signing required
                  send: 32-32-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                  read: 0-0-32 s=255,c=3,t=15,pt=0,l=2,sg=0:
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:FE59BF15C57BFEE2694AC0808D7E9C1F92739CBD6188E1674E
                  Current nonce: FE59BF15C57BFEE2694AC0808D7E9C1F92739CBD6188E1674EAAAAAAAAAAAAAA
                  HMAC: D627F8CC1ED41A9CC0067FFCA8F2DE919BB51348B20748E8E2406BAF2C96BD76
                  Signature in message: 0127F8CC1ED41A9CC0067FFCA8F2DE
                  Message signed
                  send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=10,sg=1,st=ok:2.0.0-beta
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:A630B1C776C8759946C7F58EA263CA7683B59D828F8161B78F
                  Message to process: 20000E2306FF00
                  Current nonce: A630B1C776C8759946C7F58EA263CA7683B59D828F8161B78FAAAAAAAAAAAAAA
                  HMAC: F4D362400F33CCE581E3A97E40CF7F1AE74ACAB8ED2E97A21E10E4A43B9B619A
                  Signature in message: 01D362400F33CCE581E3A97E40CF7F1AE74ACAB8ED2E97A2
                  Message signed
                  send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,sg=1,st=ok:0
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:CA7A11B0F5EE59A28ADCA0AC74FEFCFD59F430893E548992A9
                  Current nonce: CA7A11B0F5EE59A28ADCA0AC74FEFCFD59F430893E548992A9AAAAAAAAAAAAAA
                  HMAC: 50EBEE0FCE4DDE0CCF63294D4DD6D142D958B9763F206A42219D7B701D184C1D
                  Signature in message: 01EBEE0FCE4DDE0C
                  Message signed
                  send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=17,sg=1,st=ok:Sensebender Micro
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:C505BE34F06A7DF14012B6096C41268BF35B06A0C14D276F70
                  Current nonce: C505BE34F06A7DF14012B6096C41268BF35B06A0C14D276F70AAAAAAAAAAAAAA
                  HMAC: 7DB23045C8B4AE6AE1D49263C36B204781530088F9D6D082B3C11F01C991573A
                  Signature in message: 01B23045C8B4AE6AE1D49263C36B204781530088F9D6
                  Message signed
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:5F3E459CE02B989081990670A0EFC390FB800F5083B961806B
                  Current nonce: 5F3E459CE02B989081990670A0EFC390FB800F5083B961806BAAAAAAAAAAAAAA
                  HMAC: C233B208BCB7B838FD0E2643453510BA9D4B4CA507626C646569B4723508C7E6
                  Signature in message: 0133B208BCB7B838FD0E2643453510BA9D4B4CA507626C6465
                  Message signed
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:5284D3E4DDB1653B612D386C5639215EB2D586CD13F538E44C
                  Current nonce: 5284D3E4DDB1653B612D386C5639215EB2D586CD13F538E44CAAAAAAAAAAAAAA
                  HMAC: 64324E13B3D277F3DAD2F213854702DDC1C56290462A44387C16B9B05C927EB3
                  Signature in message: 01324E13B3D277F3DAD2F213854702DDC1C56290462A44387C
                  Message signed
                  read: 0-0-32 s=255,c=3,t=16,pt=0,l=0,sg=0:
                  SHA256: 051A42C2D547A6501D825592655382F46097B940CB2A9BC7862764640382A6F4
                  Transmittng nonce
                  send: 32-32-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:051A42C2D547A6501D825592655382F46097B940CB2A9BC786
                  Signature in message: 013DA95E35B18396C1610C640882FC
                  Message to process: 0020560301FF31343635323836313037
                  Current nonce: 051A42C2D547A6501D825592655382F46097B940CB2A9BC786AAAAAAAAAAAAAA
                  HMAC: 083DA95E35B18396C1610C640882FC8F7A73BB2F36C4CCB622978F14F8DCF88E
                  Signature OK
                  read: 0-0-32 s=255,c=3,t=1,pt=0,l=10,sg=0:1465286107
                  read: 0-0-32 s=0,c=3,t=16,pt=0,l=0,sg=0:
                  SHA256: 064A0459AAB0F53006E4E0648F9F547E24E39CDEF29299DE10FB759CD49CD6AE
                  Transmittng nonce
                  send: 32-32-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:064A0459AAB0F53006E4E0648F9F547E24E39CDEF29299DE10
                  Signature in message: 01E1A03B9429A6DBFF20E6D19D1E68C07E7CC238E3EC7893
                  Current nonce: 064A0459AAB0F53006E4E0648F9F547E24E39CDEF29299DE10AAAAAAAAAAAAAA
                  HMAC: C1E1A03B9429A6DBFF20E6D19D1E68C07E7CC238E3EC78930184BD18F0823FF6
                  Signature OK
                  read: 0-0-32 s=0,c=1,t=2,pt=0,l=1,sg=0:0
                  SHA256: 0D27D0A1761710382B1527AB510AAFBDF7E965AD4453E1451085252F4C422575
                  Transmittng nonce
                  send: 32-32-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:0D27D0A1761710382B1527AB510AAFBDF7E965AD4453E14510
                  Signature in message: 01BB1C2ABEF5EDB609FC783D2D4068632EA4CFFB49AE2C06
                  Current nonce: 0D27D0A1761710382B1527AB510AAFBDF7E965AD4453E14510AAAAAAAAAAAAAA
                  HMAC: 00BB1C2ABEF5EDB609FC783D2D4068632EA4CFFB49AE2C06F614377BE7576BEC
                  Signature OK
                  read: 0-0-32 s=0,c=1,t=24,pt=0,l=1,sg=0:8
                  TEST 6
                  • Node and gateway on development branch
                  RESULT:
                  • As expected from the tests I did yesterday this test failed
                  Log from node
                  Signing required
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:21F62EF9ADA09F07E5AB18EFA404E54CB1504EE3DA5FF1516E
                  Current nonce: 21F62EF9ADA09F07E5AB18EFA404E54CB1504EE3DA5FF1516EAAAAAAAAAAAAAA
                  HMAC: 1F7E4DF2B93FF4A998032FB88764F4027068F54496697E385F7E1278F3BD7BC8
                  Signature in message: 017E4DF2B93FF4A998032FB88764F4
                  Message signed
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:42C03767A6A847595911A4ABADCE7129FEC4AC76952DDAEAD5
                  Current nonce: 42C03767A6A847595911A4ABADCE7129FEC4AC76952DDAEAD5AAAAAAAAAAAAAA
                  HMAC: 4067930A19F2FF7ECDFB2442F8F9475BA30AF732AA5469A49F18D32ABF89D341
                  Signature in message: 0167930A19F2FF7ECDFB2442F8F9475BA30AF732AA5469A4
                  Message signed
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:BB9F341EBAD0551B8541AF7A7274CBE08EAE92E6914D64CF21
                  Current nonce: BB9F341EBAD0551B8541AF7A7274CBE08EAE92E6914D64CF21AAAAAAAAAAAAAA
                  HMAC: 32623A195B988A45DD84948CD3D037D5F1A2C30570FC0667DEAE2C1A5F6E3870
                  Signature in message: 01623A195B988A45
                  Message signed
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:797BDE0D89EE433BD1105F135F7BC4117889EC9164CC7440B6
                  Current nonce: 797BDE0D89EE433BD1105F135F7BC4117889EC9164CC7440B6AAAAAAAAAAAAAA
                  HMAC: 4014EF97E0847D1320268E43F84DD28DE1B30700DBCC2F3D73E55BE76C86A865
                  Signature in message: 0114EF97E0847D1320268E43F84DD28DE1B30700DBCC
                  Message signed
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:6928BF0F14662D30151049D54DC559D9980BDC58D05E4FCC11
                  Current nonce: 6928BF0F14662D30151049D54DC559D9980BDC58D05E4FCC11AAAAAAAAAAAAAA
                  HMAC: FB7B393036440F4EE838209F596F20A779319E4EA41E775D7B49A118AD405B61
                  Signature in message: 017B393036440F4EE838209F596F20A779319E4EA41E775D7B
                  Message signed
                  read: 0-0-32 s=255,c=3,t=17,pt=6,l=25,sg=0:F1F6E026C9E12A1482F9E0629B219C299702775062CAE96EFC
                  Current nonce: F1F6E026C9E12A1482F9E0629B219C299702775062CAE96EFCAAAAAAAAAAAAAA
                  HMAC: B3F8B969384698B445CC9B94A3F9D632B2BC00282376066306277239A8781164
                  Signature in message: 01F8B969384698B445CC9B94A3F9D632B2BC00282376066306
                  Message signed
                  SHA256: BEA0F900BC32AC08474C32CE30CF7FD09424EE6FD7F56493DE6A79995E23E3F3
                  Transmittng nonce
                  send: 32-32-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:BEA0F900BC32AC08474C32CE30CF7FD09424EE6FD7F56493DE
                  SHA256: 93D42A3EB88FECBA7026EA0CA7B96D4CEEF9CC84238EF7628AC1C6133C3657F5
                  Transmittng nonce
                  send: 32-32-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:93D42A3EB88FECBA7026EA0CA7B96D4CEEF9CC84238EF7628A
                  SHA256: C8C7D4569B16DD09FB5BAFB89FB78FA51E5BF8FEF98ED1F9764E547AE3B8B4BF
                  Transmittng nonce
                  send: 32-32-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:C8C7D4569B16DD09FB5BAFB89FB78FA51E5BF8FEF98ED1F976
                  Signature in message: 0126AF027E257738CFD55BE17BEDEAA3E525ED70ABB279D8
                  Current nonce: C8C7D4569B16DD09FB5BAFB89FB78FA51E5BF8FEF98ED1F976AAAAAAAAAAAAAA
                  HMAC: 3F7E76453D012BADF96D39903092EB63E39B4C6A9DB91307F18E79BB50D58446
                  Signature bad: 017E76453D012BADF96D39903092EB63E39B4C6A9DB91307
                  verify fail
                  No active verification session
                  • T tomkxy
                    TEST 4
                    RESULT:
                    • Failed
                    Log file form node
                    Signing required
                    sign fail
                    sign fail
                    find parent
                    parent=0, d=1
                    sign fail
                    Message signed
                    Message signed
                    Message signed
                    TEST 5
                    • ATSHA204 signing
                    RESULT:
                    • OK
                    Signing required
                    Message signed
                    Message signed
                    Message signed
                    Message signed
                    Message signed
                    Message signed
                    Transmittng nonce
                    Signature OK
                    Transmittng nonce
                    Signature OK
                    Transmittng nonce
                    Signature OK
                    TEST 6
                    RESULT:
                    Log from node
                    Signing required
                    Message signed
                    Message signed
                    Message signed
                    Message signed
                    Message signed
                    Message signed
                    Transmittng nonce
                    Transmittng nonce
                    Transmittng nonce
                    verify fail
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @tomkxy When you use soft signing, have you personalized that node with the same HMAC key? Soft signing on development stores this in EEPROM. It has to match what the other node has in the ATSHA204.
                    • AnticimexA Anticimex
                      tomkxy
                      Yes, while I was writing this occurred to me. That's the reason why I will repeat that test.
                      • T tomkxy
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @tomkxy Ok cool. Thanks a LOT for your testing. From what I can see, you end up with something totally functional (for atsha at least)?
                        No additional delays, signing works (hopefully quicker), and node and gw can exchange signed messages without collisions/dropped messages due to sign fail, etc?
                        • T
                          tomkxy
                          @Anticimex Ok. I repeated the the soft signing tests: Both, gateway and node on soft signing works.
                          Putting node on ATSHA204 signing while gateway is still on soft signing fails.
                          Apart from that issue, the implementation seems to work and improves obviously on the timing issue I had.
                          • T
                            tomkxy
                            So, I repeated the test again, if GW and node are on soft sign it works. If I put either GW or node on soft sign, while the other is using ATSHA204, signing fails
                            To verify my setup I switched to development branch. There I could run the node on soft signing while the GW is using ATSHA204.
                            • T tomkxy
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @tomkxy Hm, ok, so with the updates from PR, soft and atsha signing are not compatible? I need to check into that.
                              Out of curiosity, when you checked from development branch, was the ATSHA node using the code from the PR or was it also from development branch? Just so I know if the issue is in the soft signing implementation or both backends.
                                tomkxy
                                I ran the test with node and gateway on PR code:
                                One test both on soft signing -> ok
                                One test node on soft signing, GW on ATSH204 -> failed
                                Then I repeated with both node and GW on development branch:
                                • node soft sign, GW on ATSHA204 -> OK
                                • T tomkxy
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @tomkxy I think I found the problem. Mistake by me.
                                  Try to change the following two lines (106 & 107) in MySigningAtsha204Soft.cpp:
                                  memset(_signing_current_inbound_nonce, 0x00, NONCE_NUMIN_SIZE_PASSTHROUGH);
                                  memset(_signing_current_outbound_nonce, 0x00, NONCE_NUMIN_SIZE_PASSTHROUGH);
                                  to
                                  memset(_signing_current_inbound_nonce, 0xAA, 32);
                                  memset(_signing_current_outbound_nonce, 0xAA, 32);
                                    to
                                    tomkxy
                                    to
                                    I made the changes. Still not working.
                                    • T tomkxy
                                      to
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @tomkxy Hm. I have rewritten the code to be easier to read. Could you please clean out the changes from my PR (restore to "pristine" development) and then reapply the PR from github?
                                      If possible, also include the verbose logs from both ends so that we can confirm that they agree upon which nonce to use for a message.
                                      • T
                                        tomkxy
                                        I cannot promise that I am able to do that today.
                                        • T tomkxy
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #28
                                          @tomkxy That's ok, No big rush on this. I suspect it is just a matter of the soft and atsha backends are not in agreement on the nonce data. I have not changed the algorithms so I would not expect them to be incompatible.
