  3. Yet Another RGB driver (activeRGB)
69 Posts 4 Posters 22.6k Views 6 Watching
  • S Samuel235
    @activemind, a normal through hole resistor is measuring around 10mm for me here. It may depend on the resistors you can get your hands on though, but i would say 10mm is what you're after. You could play it super safe and go 15 or 20 but it will take up much more room on your board. I would say the same for caps too. However, i don't use through-hole caps unless breadboarding.
    If this is your first board then through hole is the best thing for you :+1:
    activemind
    Done! I will go with 10mm through hole resistors. Do I want to vertical mount them to save some space though I am targetting 5x5cm PCB so I dont know if I will be in a space crunch!
    I can handle/solder surface mount but as you said, this is my first PCB and I want to play it safe and go with through hole components.
    Onto caps now...I am not sure I even know what all these types mean, will have to google them :-)
    All I am looking for is normal through hole electrolytic caps like the one I see on Easy PCB
    -AM
    S 1 Reply Last reply
    • A activemind
      -AM
      Samuel235
      @activemind Awesome, not sure if you will need to stand them up, that is for you to play around with the layout.
      Those caps are just electrolytic radial cans.
      MySensors 2.1.1
      • A
        activemind
        @Samuel235 - I just want to say thanks for taking the time to walkthrough a noob with his first PCB. Appreciate it!
        For the resistor, just keeping them horizontal for now.
        For the caps, I see Tanta1C_Size type and Discret type in my KiCad apart from SMD types.. Not sure what they mean
        Let me google around to see what footprint people choose in KiCad.
        -AM
        • A
          activemind
          OK, done with the footprint for all the components. A big thanks to all the people who uploaded footprints to github. I was able to use a couple of them.
          Now, onto PCB layout!
          Whats the grid size I should select? Also track size and via sizes too? I have no idea what they need to be or whats a good safe number.
          How do I define what my board size will be so that I can start arranging componets because after pulling in the netlist they are all on top of each other :-)
          My target PCB manufacturer is Itead or dirtyPCB with 5x5 sizing.
          -AM
            Samuel235
            I work on a 0.1mm grid to make the PCB, and sometimes a 0.01mm grid. Whatever you feel comfortable and happy with. There is no standard grid size for the pcb itself, unlike the schematic of 0.1". Track sizes and vias are normally 8-10mil trace and 0.3-0.6mm drill via diameter for dc <5v. I would make an outline dimension of 50mm x 50mm and make it smaller if you can once you have placed all components on there. Please be aware that each board house has different requirements for drill holes and minimum spacing/trace widths.
            This is the guidelines for ITEAD - http://support.iteadstudio.com/support/solutions/articles/1000156313-normal-condition-of-pcb-capabilities
            MySensors 2.1.1
            A 1 Reply Last reply
            • S Samuel235
              activemind
              Thanks again @Samuel235 .
              I made an attempt at untangling the rats nest and it kinda looks okay but..I think I have incorrect footprints for resistors and caps. They seem too big compared to arduino pro mini & NRF.
              These are decoupling caps, so all other boards should have them. I need to look around at other board files to see if I can find the correct footprints because my gut feel is what I have is wrong!
              -AM
              PS: trying to figure out how I can post what I currently have besides taking a screenshot!
              • A
                activemind
                wrote on last edited by activemind
                Here is what it currently looks like which I am sure is wrong!!
                Suggestions?
                -AM
                  Samuel235
                  We could do with someone getting involved that has KiCad experience because i just have zero. I'm assuming that all those header pins and the different sized resistors are wrong too.
                  I'm not too sure why the arduino is actually shown on the board with separate serial header either. You only need 2 rows of female headers for your arduino to soxket in to.
                  I can only assume the libraries used here are incorrect on certain things.
                  MySensors 2.1.1
                  • S Samuel235
                    activemind
                    I'm not too sure why the arduino is actually shown on the board with seperate serial header either. You only need 2 rows of female headers for your arduino to soxket in to.
                    The arduino footprint in from github. So I would assume that is correct!
                    I found the issue with resistor footprint. I had chosen 20mm for 3 and 10mm for the remaining ones. I think I want 10mm for all of them. Though R1,R2 & R4 need to higher wattage but I will deal with that detail after I have sorted out the size issue.
                    I also realized that I need to add connectors for 12V input power and 4 LED output signals!
                    Duh! :-)
                    -AM
                    • A activemind
                      Duh! :-)
                      -AM
                      Samuel235
                      @activemind, learning is the name of the game 😉
                      MySensors 2.1.1
                      • S Samuel235
                        activemind
                        Very true! Once again, thanks much for active feedback! :-)
                        -AM
                        • A
                          activemind
                          Looking better after I fixed the cap and resistor footprints...
                          Do I need to be concerned about arduino footprints if I got them from mysensors github?
                          Need to add labels now and size the PCB?
                          -AM
                            Samuel235
                            Looking much neater and correct now. I wouldn't say you need to be doubting the footprints on github, but i still don't like the look of how KiCAD is showing this on the board. If that was in Eagle it would be showing that i need to solder each component of the arduino onto my board, not pushing a arduino into a socket. However, KiCAD may be completely different to the way it displays things though. Like i said before, we need someone with some KiCAD experience around here, i can't remember who uses it here :(
                            MySensors 2.1.1
                            • A
                              activemind
                              Played around with the placement a little more and I think I am happy with it now as this layout gives me space for silkscreen label and mounting holes.
                              I also got rid of the 2 pin jumper as it didnt really serve any purpose. Now LM317 always outputs 5V which is stepped down to 3.3V by LE33. Depending upon 3 jumper position you can use 3v3 or 5v pro mini. MySX header has both 5v and 3v3 so you can power the sensors off of that.
                              Trying to fix the github arduino pro model because I dont think its correct. There are 4 extra pins which are not there in the sparkfun model. Also, my 3D drawing does not have a different color compared to PCB. Need to fix those.
                              Anyways, here is the updated layout.
                              Once I cleanup all of the above and incorporate feedback (if any), I can start looking at routing the board :-) (which I have never done earlier).
                              -AM
                              • A activemind
                                -AM
                                Samuel235
                                @activemind Looks a little better. Check the spacing between the MySX header and the side of where the arduino will sit, allow enough room for yourself there.
                                MySensors 2.1.1
                                • A
                                  activemind
                                  @Samuel235 Looks fine to my noob eyes :-)
                                  Here is a view from a different angle (I also fixed my 3D model paths)
                                  -AM
                                    Samuel235
                                    Now this looks more like what i would expect. Nice work dude, time to route it now ;)
                                    MySensors 2.1.1
                                    • A
                                      activemind
                                      @Samuel235 Thanks. Wouldnt have been possible to come this far without your help and feedback.
                                      Going to try routing soon, I am thinking 10mil for normal trace and 80mil for 12v/5v/3v3/GND.
                                      Does that sound right?
                                      -AM
                                      • A activemind
                                        -AM
                                        activemind
                                        -AM
                                        80mil looks too fat :-)
                                        How about 60mil?
                                        -AM
                                        • A activemind
                                          -AM
                                          How about 60mil?
                                          -AM
                                          activemind
                                          Is it okay to route most of the power signal on the back and keep GND and everything else on the front?
                                          General routing recommendations? (doing it for the first time :-)
                                          -AM
