  3. Help converting 24VAC to 5VDC
15 Posts 8 Posters 13.3k Views 5 Watching
  • petewillP
    petewillP
    petewill
    Hi Everyone,
    I have had a few projects now where I would like to get power from an existing 24VAC source. So far I have taken the lazy way out and just ran an additional 5VDC source to power my projects. Well, I'd like to change that this time. I have been doing some research and testing and I have successfully converted the AC to DC using a Full Wave Diode Bridge Rectifier. Like this (although I will need some additional capacitors etc after the conversion to DC):
    0_1465862593074_upload-a0a68090-0521-4719-a24b-3fe261354861
    I'd like to know the most efficient way to reduce the rectified to 34 VDC down to 5V. The DC is going to be pretty high and I'm not sure a low dropout regulator is the best choice for this.
    Does anyone have any advice on what I should do? Am I close or am I going about this all wrong?
    Pete
    • dbemowskD
      dbemowskD
      Your best bet here is to probably use what is called a buck converter. Here is an adjustable one from ebay that will accept an input voltage anywhere from 5V to 36V and step it down to anything from 0.8V to 30 V.
      http://www.ebay.com/itm/5W-DC-DC-Buck-Converter-Step-down-5V-36V-to-5-12V-Power-Module-Replace-7805-7812-/281716353294
      Simply connect your input voltage and put a volt meter on the output side and adjust the small variable resistor to get your desired output voltage. This one says that it ships already set to 5V. You will still want to use your bridge rectifier circuit that you have outlined with a few capacitors on it to smooth out the output voltage going into the buck converter
      D 1 Reply Last reply
      • dbemowskD dbemowsk
        drock1985
        @dbemowsk
        Buck Converter is definitely the easiest way to down-step your voltage. Just make sure you put a cap or two before and after the regulator to help with the power cycles on your bridge when converting the AC to DC current.
        I have a rectifier bridge working to convert 16VAC to 5VDC using an LM7805 regulator. It has been working steadily non-stop since October of last year. Would have been much easier just to go with the buck converter but whatever method you use should work fine.
        My Projects
        2 Door Chime Sensor
        Washing Machine Monitor
        • dbemowskD
          dbemowskD
          @drock1985 I don't think that an LM7805 regulator will work for him. He mentions that he is getting 34 volts DC out of his bridge rectifier, and the max input voltage for the 7805 is I believe 24 volts. Besides, for those regulators to convert from the max 24v down to 5v, they will dissipate a lot of heat requiring a fair heat sink. IMHO, I think the buck converter is his only choice in this situation.
            drock1985
            @dbemowsk
            True. Could also down step the voltage twice. LM7812 to LM7805 for example.
            My Projects
            2 Door Chime Sensor
            • J
              J
              Jackpot
              You might try a 5 volt wall wart. I've found that some of them will actually run off of 24 vac as long as you don't need a lot of load. I've done it and it worked for me.
              • dbemowskD
                dbemowskD
                Stepping down the voltage twice I think would be an insane waste of energy. Not that it wouldn't work, but you then have 2 regulators dumping a lot of heat. If you were going to go that route, I would step to 18 volts first with a 7818. I still don't think the 7812 can handle a 34 volt input where the 7818 can.
                As for the wall wart, never tried that, but even if he went with that, the size might be a factor. Besides, I am not sure of the stability. That may also depend on what type of wall wart he used and how low of an input voltage the switching supply will take and still be effective.
                At under $3.00 US, the buck converter is cheap, small, and overall the best solution, IMHO.
                • E
                  E
                  emc2
                  @petewill If you don't need more than 0.5A you may want to give a try to Murata 7805SR-C switching regulator http://www.mouser.com/ProductDetail/Murata-Power-Solutions/7805SR-C/
                  http://www.mouser.com/ds/2/281/dms-78xxsr-47233.pdf
                  No heat, very stable, high quality. I use these guys in their 12V version from 34V to power CPU fan and arduino/radio/sensors (with an additional 3.3V linear regulator from the 12V) in a LED control board https://forum.mysensors.org/topic/3843/mysgrowled and so far so good.
                  • petewillP
                    petewillP
                    petewill
                    Thanks all for the responses! I do have a few buck converters lying around. They look like this:
                    http://www.ebay.com/itm/LM2596S-power-DC-DC-Buck-Converter-Step-Down-Module-5V-3A-LM2596-/182167996468?hash=item2a6a0f0834:g:VxMAAOSw3v5XIvxk
                    The LM2596 looks like it's rated to 45V (although the capacitors say 36V). Maybe I'll give that a shot and see if any smoke comes out. :)
                    Has anyone played with a LM2596 and a couple of capacitors instead of the module like I posted above? Maybe that would be a good option as it seems to have a 5V output?
                    @emc2 That part looks cool although it's a little pricey.
                    • dbemowskD
                      dbemowskD
                      @petewill, It seems like it would be easier to just use the module. The LM2596 probably needs that choke that is there. Also, it may be a bit of calculation to figure out the voltage divider to drop you to the 5v, With the module, you at least have some control so if you wanted to bump it up to say 6v-7v to go to the Raw input on the arduino, you would have that flexibility.
                      petewillP 1 Reply Last reply
                        petewillP
                        petewillP
                        petewill
                        @dbemowsk Thanks. I'll give it a shot.
                        If anyone has any other ideas I'd love to hear them. I'm sure I'll have more projects like this in the future where space is more of an issue.
                        SparkmanS 1 Reply Last reply
                        • petewillP petewill
                          SparkmanS
                          SparkmanS
                          Sparkman
                          @petewill I've used these to convert from 24VAC to 5VDC: http://www.ebay.com/itm/321472165477. They are a bit more expensive, but allow for a large range of AC/DC input to 5VDC. There's also a similar one for 12VDC.
                          Al
                          BulldogLowellB sundberg84S 2 Replies Last reply
                          • SparkmanS Sparkman
                            Al
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            Al
                            :+1:
                              Al
                              sundberg84S
                              sundberg84S
                              Al
                              Im using those as well for my Ip cameras, works great!
                              • petewillP
                                petewillP
                                petewill
                                @Sparkman Cool, thanks for sharing! It's always nice to have options.
