  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 451.8k Views 35 Watching
  • rollercontainerR rollercontainer
    Hm, in the loop, mq135_ro will be read and used. As written in line 78, the MQ135_DEFAULTRO can be overwritten by the messured mq135_ro. Ok, but where is the 10kOhm voltage divider in this calculation? Included in the measurement of mq135_ro?
    https://github.com/empierre/arduino/blob/master/AirQuality-MQ135.ino#L78
    alexsh1A
    alexsh1A
    alexsh1
    @rollercontainer you are correct - mq135_ro is overwritten in the loop and I do not see a point in float mq135_ro = 10000.0; unless the mq135_ro function is deactivated during calibration. However, #define MQ135_DEFAULTRO 68550 this is the parameter you should change during the calibration process. Try to calibrate with the function mq135_ro and deactivating it though I am sure the result will be the same.
    • tantt2810T
      tantt2810T
      tantt2810
      Hi all,
      I have my library for reading sensor. It is open source and its name is OpenSensor. I think that it's useful for every body.
      Besides, I have my a monitoring system in real time using Arduino, MQ2, MQ135, MG811, GP2Y10 sensors and shield wifi ESP8266. It use OpenSensor library to read value from sensor and push it to database of WebServer by ESP826.
      This is link: https://github.com/tantt2810
      Hoping it helpful for all,
      Good job,
      alexsh1A 1 Reply Last reply
      • tantt2810T tantt2810
        Hi all,
        Good job,
        alexsh1A
        alexsh1A
        alexsh1
        #221
        @tantt2810 Thanks
        #define RSRO_CLEAN_AIR_FACTOR        3.7                                    //The value of Rs/Ro in clean air. According chart in datasheet.
        #define RL_VALUE                     20                                     //The value of the load resistance on the board, in kilo ohms.
        #define GET_RO_SAMPLE_TIMES          10                                     //The times of calibrating
        #define GET_RS_SAMPLE_TIMES          10
        Can you please elaborate on how to calibrate the sensor?
        Also how do you connect it if it comes on the board like this?
        http://i.ebayimg.com/00/s/NjAwWDYwMA==/z/vMIAAOxycD9TTOVW/$_1.JPG
        epierreE 1 Reply Last reply
        • alexsh1A alexsh1
          @tantt2810 Thanks
          epierreE
          epierreE
          epierre
          easy here, the AOUT is the one you will put on an analog one.
          the DOUT (Digital OUT) is just an alarm linked to a level you could change on the board)
          z-wave - Vera -> Domoticz
          • epierreE epierre
            alexsh1A
            alexsh1A
            alexsh1
            So DOUT is not used. Just AOUT?
            • alexsh1A alexsh1
              epierreE
              epierreE
              epierre
              yes !
              • alexsh1A
                alexsh1A
                alexsh1
                #225
                @epierre For the air quality purpose which sensor would you recommend TSG-2600 or TS2602? They are slightly different, but both detect aiir contaminants (based on ppm of H2 and EtOH).
                So far, I got MH-Z14A and the Dust sensor working with OLED screen and Domoticz and I just want to add 1-2 sensors to finish the project.
                • epierreE
                  epierreE
                  epierre
                  @alexsh1 well any I would think for they are similar technology
                  • epierreE epierre
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @epierre What about MICS-4514 or MICS-5524?
                    I am thinking ordering this board:
                    https://sgx.cdistore.com/ProductDetail/MICSVZ86F-SGX-Sensortech-Limited-formerly-e2v/556306/#.V2Bw7jVUmec
                    • Tore André RosanderT
                      Tore André Rosander
                      wrote on last edited by Tore André Rosander
                      #228
                      How do i get the Airquality sensor to show in domoticz? I use the AirQuality example from the library and MQ2.
                      I can see that it works in the serial, and it shows as a node under the mysensors hardware, but nothing in log or the device list when i expose it for gas.
                      0_1466081228162_upload-0f9ebe47-10d5-446c-a3bd-24c1649c94c1
                      • Tore André RosanderT Tore André Rosander
                        epierreE
                        epierreE
                        epierre
                        huh you're on which version of mysensors ? have you tried the console (in arduino programmer) to see if there are some readings or a good wiring ?
                          Tore André Rosander
                          #230
                          @epierre Hi! The dev branch (v 2) and the raspberry pi gateway (nrf24 directly connected to RPi GPIO). This is what i get in the serial console when i test with gas from a lighter:
                          Starting sensor (RNNNA-, 2.0.0-beta)
                          Radio init successful.
                          find parent
                          send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                          find parent
                          read: 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          parent=0, d=1
                          req id
                          req id
                          read: 0-0-255 s=255,c=3,t=4,pt=0,l=2,sg=0:5
                          send: 5-5-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                          send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                          send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
                          id=5
                          Init complete, id=5, parent=0, distance=1
                          LPG:0ppm    CO:0ppm    SMOKE:0ppm
                          LPG:8ppm    CO:47ppm    SMOKE:18ppm
                          send: 5-5-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:95
                          send: 5-5-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:0```
                          • epierreE
                            epierreE
                            epierre
                            t=37
                            I don't know, would it be possible to have someone knowing the difference of the gateway with domoticz for 2.0 ? here it seems correct to me, some value are well seend from the sensor, so it is between the gateway and domoticz for me.
                            • tuimansoT
                              tuimansoT
                              tuimanso
                              @epierre I am attempting to apply this code to work with the MQ-8. I am trying to get rid of all of the radio and gw stuff that is in the code. Do you have anything that just calibrates the sensor and reads out the value without of all these other libraries?
                              • tuimansoT
                                tuimansoT
                                tuimanso
                                @epierre Also, what is the purpose of #define MQ135_MAXRSRO 2.428 //for CO2
                                #define MQ135_MINRSRO? I don't see them being referenced after they're defined?
                                • tuimansoT tuimanso
                                  epierreE
                                  epierreE
                                  epierre
                                  Datasheet defines min and max values they should guarantee, this is an application of it.
                                  if(validinterval<MQ135_MAXRSRO && validinterval>MQ135_MINRSRO) {
                                  • tuimansoT
                                    tuimansoT
                                    tuimanso
                                    Your previous message
                                    I have a question about the MQ-8 sensor module . The potentiometer that is soldered onto the board, is it to control the sensitivity of the LED light or for the sensor itself? According to the datasheet for the sensor, the RL (load resistance) for the sensor should be at minimum 10k Ohm, yet I only see an SMD 102 resistor on the board, which is a 1K Ohm resistor. I have used a multimeter to connect the 5V pin and the AOUT pin, and I get precisely a measurement of about 1K Ohm... Does that mean that I should connect a load resistor to this?
                                    This value seems very important since it is referenced in the code, the RL is part of the calculations, yet it is already pre-written 10K ohms...
                                    Please Clarify
                                    ysinhY 1 Reply Last reply
                                    • AtmosChemeA
                                      AtmosChemeA
                                      AtmosCheme
                                      Hello everyone,
                                      I have a few of these sensors, but lately I have been concentrating on a MQ131 ozone sensor module from SainSmart. I am building an array utilizing MQ gas sensors and an Arduino that can be attached to a drone to measure vertical concnentration profiles of ground level ozone.
                                      I am using an ozone generator and a 2B Technologies Ozone Monitor for the calibration of the sensor.
                                      I have done the 24 hour burn in period on my sensors.
                                      I have warmed them up to get steady values on my serial monitor.
                                      The problem that I am having is that I am creating nearly 20,000 ppb O3 and the analog output is only around 25 to 30 units. It works out to around 922 ppb per unit.
                                      Example before ozone is added the sensor reading is steady at 41. After raising the concentration of O3 to 18,727.5 ppb the reading drops to around 17-18.
                                      Recently I have added a 22,000 ohm resistor in series with the analog output so that my readings start out at 971. But I am still only dropping around 20 units to 951 when ozone levels rise to nearly 20,000 ppb.
                                      My question is how do I use a larger range of the units. There are 1023 possible values and I would like to see my reading drop from 971 to maybe the 200 area so that I am using more of the range. I would like each unit to be worth about 0.5 ppb. Ambient outdoor concentrations very rarely go higher than maybe 150 ppb so with the setup I have that would not even register on the serial output.
                                      Thank you in advance for any help.
                                      • AtmosChemeA AtmosCheme
                                        Hello everyone,
                                        epierreE
                                        epierreE
                                        epierre
                                        @AtmosCheme the datasheet gives the MQ131from 1 to 1000 ppb, so you reach the limit obviously
                                        http://eph.ccs.miami.edu/precise/GasSensorSpecs/Ozone.pdf
                                        AtmosChemeA 1 Reply Last reply
                                        • epierreE epierre
                                          AtmosChemeA
                                          AtmosChemeA
                                          AtmosCheme
                                          @epierre
                                          Thank you for the reply epierre.
                                          I was going off of the SainSmart website that says the range for their module is 10 ppb to 200 ppm. That would cover 10 ppb to 200,000 ppb.
                                          http://www.sainsmart.com/sensors/eco/sainsmart-mq131-gas-sensor-ozone-module-for-arduino-uno-mega2560-r3-raspberry-pi.html
                                          The values keep dropping down as more and more ozone is added, I'm not thinking it is a problem with range as much as a problem with resolution. I have gone as high as around 50,000 ppb and continue to get response from the sensor.
                                          Ive thought of using mapping functions in my code as well as resolution functions. But I just wasn't sure if there was a component I could add to the circuit to improve resolution.
                                          In my latest sketch I have used a calibration code that analog reads the sensor for 6 minutes, and then remaps the min and max values observed during that time. I though this would get a broader range of values. The problem is that the longer the sensor is on it becomes stable so the min and max values become the same and there is nothing to map. So the longer it runs the smaller the range of values in the serial monitor.
