  3. Node-RED
  4. Is it possible to connect an Ethernet Gateway to Node-Red and share it?
Scheduled Pinned Locked Moved Node-RED
2 Posts 2 Posters 2.7k Views 2 Watching
  • D
    drock1985
    Is it possible to have Node-Red connect to an ethernet gateway, and then split the connection with multiple clients? I know I could do an MQTT Client/Server, but just curious if Node-red in general could do this. I know it can connect to a Serial Gateway; wasn't sure if Ethernet was supported or not.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • mfalkviddM
      Yes it can be done. There are some cases described in the forum.
      You could start with these
      https://forum.mysensors.org/topic/1965/nodered-injected-between-domoticz-and-mysensors
      https://forum.mysensors.org/topic/3150/use-node-red-to-allow-multiple-connections-to-ethernet-gateway/
      https://forum.mysensors.org/topic/700/node-red-as-controller/
